Dahua DH-DVR3116 плата DVR-3100 10-4322
Сообщение hack2003 » 13 апр 2018, 16:39
пришел аппарат включаться загружается , появляется Dahua потом 16 камер 2 секунды и черный экран включил отладку
не нашел не чего плохо что это может быть ????
U-Boot 2008.10-svn104 (May 30 2011 - 10:10:00)condense
DRAM: 128 MB
Flash: 8 MB
DVR> #
Unknown command '' - try 'help'
DVR> # help
? - alias for 'help'
erase - erase FLASH memory
flwrite - write data into FLASH memory
fsload - load binary file from a filesystem image
help - print online help
hwid - set hardware id and save to flash
lip - set local ip address but not save to flash
loadslaveos - load slave uboot and kernel!
mac - set mac address and save to flash
netrep - report net up progress
netup - update the system via net, without console
protect - enable or disable FLASH write protection
run - run commands in an environment variable
sip - set server ip address but not save to flash
slavestart - start slave arm!
tftp - download or upload image via network using TFTP protocol
wdg_start - start hi watchdog
wdg_stop - stop watchdog
DVR> # fli
Unknown command 'fli' - try 'help'
DVR> #
DVR> # ▒
DRAM: 128 MB
Flash: 8 MB
Unknown command 'showlogo' - try 'help'
PHY not link!
### CRAMFS loading 'boot/uImage' to 0xe3000000
### CRAMFS load complete: 1476776 bytes loaded to 0xe3000000
## Booting kernel from Legacy Image at e3000000 ...
Image Name: Linux-2.6.24-rt1-hi3520v100
Data Size: 1476712 Bytes = 1.4 MB
Load Address: e2800000
Entry Point: e2800000
Uncompressing Linux............................................................................................. done, booting the kernel.
Linux version 2.6.24-rt1-hi3520v100 (lv_ke@driver) (gcc version 3.4.3 (release) (CodeSourcery ARM Q3cvs 2004)) #65 Thu May 5 15:36:32 CST 2011
CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387f
Machine: hi3520v100
CPU0: D VIPT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 24384
Kernel command line: mem=96M console=ttyAMA0,115200 root=1f01 rootfstype=cramfs mtdparts=physmap-flash.0:256K(boot),2176k(rootfs),3712k(user),1M(web),128K(custom),256K(logo),640K(config) user_debug=0x1f pcimod=host pciclksel=1 mac=90:02:a9:82:4c:58 mdio_intf=mii dh_keyboard=0 mac=90:02:a9:82:4c:58
PID hash table entries: 512 (order: 9, 2048 bytes)
Memory: 96MB = 96MB total
Memory: 94244KB available (2684K code, 243K data, 88K init)
HI_VERSION=LINUX_2_6_24-M01C04FB01F @Hi3520v100R001_C_0_2_0 2010-06-29 22:31:34
net_namespace: 64 bytes
Hisilicon clock system V0.01
PCI: device 0000:00:00.0 has unknown header type 25, ignoring.
PCI: device 0000:00:01.0 has unknown header type 25, ignoring.
PCI: device 0000:00:02.0 has unknown header type 25, ignoring.
PCI: device 0000:00:03.0 has unknown header type 25, ignoring.
PCI: device 0000:00:05.0 has unknown header type 12, ignoring.
PCI: device 0000:00:06.0 has unknown header type 12, ignoring.
PCI: device 0000:00:07.0 has unknown header type 12, ignoring.
PCI: device 0000:00:08.0 has unknown header type 12, ignoring.
PCI: device 0000:00:09.0 has unknown header type 12, ignoring.
PCI: device 0000:00:0a.0 has unknown header type 12, ignoring.
PCI: device 0000:00:0b.0 has unknown header type 12, ignoring.
PCI: device 0000:00:0c.0 has unknown header type 12, ignoring.
PCI: device 0000:00:0d.0 has unknown header type 12, ignoring.
PCI: device 0000:00:0e.0 has unknown header type 12, ignoring.
PCI: device 0000:00:0f.0 has unknown header type 12, ignoring.
PCI: device 0000:00:10.0 has unknown header type 12, ignoring.
PCI: device 0000:00:11.0 has unknown header type 12, ignoring.
PCI: device 0000:00:12.0 has unknown header type 12, ignoring.
PCI: device 0000:00:13.0 has unknown header type 12, ignoring.
PCI: device 0000:00:14.0 has unknown header type 12, ignoring.
PCI: device 0000:00:15.0 has unknown header type 12, ignoring.
PCI: device 0000:00:16.0 has unknown header type 12, ignoring.
PCI: device 0000:00:17.0 has unknown header type 12, ignoring.
PCI: device 0000:00:18.0 has unknown header type 12, ignoring.
PCI: device 0000:00:19.0 has unknown header type 12, ignoring.
PCI: device 0000:00:1a.0 has unknown header type 12, ignoring.
PCI: device 0000:00:1b.0 has unknown header type 12, ignoring.
PCI: device 0000:00:1c.0 has unknown header type 12, ignoring.
PCI: device 0000:00:1d.0 has unknown header type 12, ignoring.
PCI: device 0000:00:1e.0 has unknown header type 12, ignoring.
PCI: device 0000:00:1f.0 has unknown header type 12, ignoring.
PCI: bus0: Fast back to back transfers enabled
Time: hisi_timer1 clocksource has been installed.
yaffs May 3 2011 09:09:56 Installing.
uart:0: ttyAMA0 at MMIO 0x20090000 (irq = 12) is a AMBA/PL011
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x200a0000 (irq = 12) is a AMBA/PL011
uart:2: ttyAMA2 at MMIO 0x200b0000 (irq = 13) is a AMBA/PL011
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
PCI: enabling device 0000:00:04.0 (0140 -> 0143)
0x403f: latency timer and cache line value !
*************** bar5: b0020000
!!!!!!!! mmio_base phy: e8872000 ctl: 8a !
sata_sil 0000:00:04.0: Applying R_ERR on DMA activate FIS errata fix
scsi0 : sata_sil
scsi1 : sata_sil
ata1: SATA max UDMA/100 mmio m512@0xb0020000 tf 0xb0020080 irq 29
ata2: SATA max UDMA/100 mmio m512@0xb0020000 tf 0xb00200c0 irq 29
ata1: SATA link down (SStatus 0 SControl 310)
ata2: SATA link down (SStatus 0 SControl 310)
physmap platform flash device: 04000000 at 80000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
7 cmdlinepart partitions found on MTD device physmap-flash.0
Creating 7 MTD partitions on "physmap-flash.0":
0x00000000-0x00040000 : "boot"
0x00040000-0x00260000 : "rootfs"
0x00260000-0x00600000 : "user"
0x00600000-0x00700000 : "web"
0x00700000-0x00720000 : "custom"
0x00720000-0x00760000 : "logo"
0x00760000-0x00800000 : "config"
h2v100-ehci h2v100-ehci.0: h2v100-ehci
h2v100-ehci h2v100-ehci.0: new USB bus registered, assigned bus number 1
h2v100-ehci h2v100-ehci.0: irq 23, io mem 0x100b0000
h2v100-ehci h2v100-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: 2 ports detected
h2v100-ohci h2v100-ohci.0: h2v100-ohci
h2v100-ohci h2v100-ohci.0: new USB bus registered, assigned bus number 2
h2v100-ohci h2v100-ohci.0: irq 22, io mem 0x100a0000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: 2 ports detected
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 88K
init started: BusyBox v1.1.2 (2011.03.31-08:43+0000) multi-call binary
Starting pid 738, console /dev/console: '/etc/init.d/rcS'
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S98
jffs2_scan_inode_node(): CRC failed on node at 0x00072a2c: Read 0xffffffff, calculated 0x2f4cc96e
UNRAR 3.93 freeware Copyright (c) 1993-2010 Alexander Roshal
Extracting from /usr/lib/lib.rar
Creating /var/lib OK
Extracting /var/lib/hi3520_md.ko OK
Extracting /var/lib/hi3520_venc.ko OK
Extracting /var/lib/hidmac.ko OK
Extracting /var/lib/hi3520_base.ko OK
Extracting /var/lib/hi3520_viu.ko OK
Extracting /var/lib/hi3520_group.ko OK
Extracting /var/lib/h2gether.ko OK
Extracting /var/lib/gpio.ko OK
Extracting /var/lib/hi3520_dsu.ko OK
Extracting /var/lib/hifb.ko OK
Extracting /var/lib/mmz.ko OK
Extracting /var/lib/mcc_usrdev.ko OK
Extracting /var/lib/consoles.ko OK
Extracting /var/lib/hi3520_ao.ko OK
Extracting /var/lib/hi3520_vd.ko OK
Extracting /var/lib/tde.ko OK
Extracting /var/lib/hi3520_sys.ko OK
Extracting /var/lib/hi3520_jpege.ko OK
Extracting /var/lib/hi3520_sio.ko OK
Extracting /var/lib/wdt.ko OK
Extracting /var/lib/hi3520_ai.ko OK
Extracting /var/lib/gpioi2c.ko OK
Extracting /var/lib/hi3520_h264d.ko OK
Extracting /var/lib/hi3520_adec.ko OK
Extracting /var/lib/hi3520_aenc.ko OK
Extracting /var/lib/hi3520_vou.ko OK
Extracting /var/lib/hi3520_chnl.ko OK
Extracting /var/lib/hi3520_h264e.ko OK
Extracting /var/lib/hi3520_vdec.ko OK
Extracting /var/lib/IR.ko OK
Extracting /var/lib/hi3520_vpp.ko OK
All OK
H2GMAC module init start!
H2GMAC MDIO Bus: probed
phy name is 0:00
H2GMAC module init done!
[RCS]: /etc/init.d/S99
*** Board tools : ver0.0.1_20060106 ***
0x20130C00: 0x00000000 --> 0x00000000
0x20130D00: 0x00000000 --> 0x00000000
0x20130E00: 0x00000000 --> 0x00000000
gpio-i2c Dec 14 2010, 16:10:32
insmod: cannot open module `adv_7441.ko': No such file or directory
hifb: module license 'Proprietary' taints kernel.
hifb info: HIFB_MAIN_VERSION[v1.0.0.2] Build Time[Jan 17 2011, 11:05:08]
hifb info: video:vram0_size=2621440,vram2_size=835584,vram3_size=835584
hifb info: succeed in registering the fb0: ovl0 frame buffer device
hifb info: succeed in registering the fb1: ovl2 frame buffer device
hifb info: succeed in registering the fb2: ovl3 frame buffer device
TDE_MAIN_VERSION[v2.0.0.0] Build Time[Jan 17 2011, 11:05:02]
TDE_ADP_VERSION[hi3520adp v2.0.0.0] Build Time[Jan 17 2011, 11:05:02]
tde run on master arm
tde run for video service
tde map reg:basePhyAddr:20140000 baseVirAddr:c6874000 size:3000
Chip Version: Hi35200100
load vd.ko ....OK!
load vou.ko ....OK!
load vdec.ko ....OK
load vpp.ko ....OK!
load md.ko....OK!
load h264d.ko OK
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=180 sec (nowayout= 0, nodeamon= 1)
WDT @Hi3515
infrared Apr 19 2011, 10:01:30 load succesful!
0x20110104: 0x00009876 --> 0x00009654
0x20110100: 0x00000888 --> 0x00000886
0x2011010c: 0x00000001 --> 0x00000002
0x20110110: 0x00000002 --> 0x00010C86
0x20110114: 0x00000003 --> 0x00010C87
0x20110118: 0x00000005 --> 0x00000006
0x2011011c: 0x00000006 --> 0x00000007
0x20110128: 0x00000007 --> 0x00010020
0x2011012c: 0x00000007 --> 0x000103A1
0x20110130: 0x00000007 --> 0x00010605
0x20110134: 0x00000007 --> 0x00010605
0x20110138: 0x00000007 --> 0x00000004
0x2011013c: 0x00000007 --> 0x00000004
0x20050078: 0x00000000 --> 0x00008002
0x20120100: 0x00000444 --> 0x00000444
0x20120104: 0x00009876 --> 0x00009654
0x2012010c: 0x00000001 --> 0x00010640
0x20120110: 0x00000002 --> 0x00000003
0x20120114: 0x00000003 --> 0x00000004
0x20120118: 0x00000005 --> 0x00000001
0x2012011c: 0x00000006 --> 0x00000002
0x20120128: 0x00000007 --> 0x00000005
0x2012012c: 0x00000007netinit uses obsolete (PF_INET,SOCK_PACKET)
--> 0x00000005
0x20120130: 0x00000007 --> 0x00000005
0x20120134: 0x00000007 --> 0x00000005
0x20120138: 0x00000007 --> 0x00000005
0x2012013c: 0x00000007 --> 0x00000005
netint [ethname] [Ipaddress] [Netmask] [Gateway]
Example for set ip :
netinit 192.168.1.34
Example for set netmask :
LIBDVR : Version : V6V5V4:000
LIBDVR : dvr3116 no cpld product init
Ip = 192.168.1.108, Netmask = 255.255.255.0, Gateway = 192.168.1.1
mac : 90-2-a9-82-4c-58
Utils : Current Network Seting===>
Ip = 192.168.1.108
++++Start pppd,Version 1.42 2009-08-05+++
Extracting from /usr/bin/Challenge.rar
Extracting /var/Challenge 1%main 202 UPNP.PRO::CtrlPointStar 11%CtrlPointRefresh 462 UPNP.PRO::CtrlPointSearch 25%main 208 UPNP.PRO::success CtrlPointStart OK
All OK
Utils : check file /mnt/mtd/Log/Log
Data CRC f4a265a9 != calculated CRC d3088d4f for node at 00074228
Utils : check file /mnt/mtd/Log/LogSet
Utils : Auto start program
Version:1.1.0
Build date:Jan 5 2011 19:58:55
Desc:Release1.1.0
Version:1.1.0
Build date:Nov 24 2010 16:21:41
Desc:thread Release
Version:1.1.0
Build date:Oct 8 2010 13:35:16
Desc:buffer Relese
Version:1.2.0
Build date:Apr 18 2011 19:52:15
Desc:GUI ctrls Relese
Version:1.2.0
Build date:Mar 4 2011 08:55:57
Desc:build
Version:1.1.0
Build date:Apr 11 2011 10:04:16
Desc:user release
15:32:13|trace main(2, /var/Challenge buf)
LIBDVR : 2018-4-13, today is weekday 5 time:15:32:14
LIBDVR : DvrShowInformation
LIBDVR : DvrGetHwidInformation(PRODUCT_TYPE) = 0
| SYSTEM INFORMATION
| N52 libdvr version: 1.06.0 - Jun 10 2011 11:32:04
| DVR ID: 0x0006a48967800090
| product type: DVR
| video channel: 16
| audio channel: 4
| alarm in: 0
| alarm out: 0
| frontboard type: 1U
| video chip: TW2868
| DSP chip: HI3520
| analog audio mode: tw28XX control
| audio surpport: Yes
| matrix surpport: No
| loop surpport: No
| video tour surpport: Yes
| real time: No
| disk interface: SATA
| LCD surpport: No
| CDRW surpport: Yes
| hardware version: 1
| audio interface: alt
| disk num: 1
| net card: 0
| dsp num: 1
| playback num: 16
15:32:14|trace CVersion::CVersion()>>>>>>>>>
15:32:14|trace Challenge Version Info:2.606.0000.1 BuildDate 2011-07-12 08:57:44
15:32:14|trace CChallenger::CChallenger()>>>>>>>>>
15:32:14|debug tracepoint: ../../Challenger.cpp, 212.
* Lua Engine Version: Lua 5.0.2
* Supported Language: Russian,English
* SupportedVideoStand: PAL
CDevFrontboard::CDevFrontboard()>>>>
15:32:14|trace CThreadManager::CThreadManager()>>>>>>>>>
15:32:14|trace
WatchDogTime::WatchDogTime()>>>>>>>>>
15:32:14|trace WatchDogTime::OnkeepAlive!!!
######iCount=1
>>>>>>>>>>>>>has audio 1 , MatrixBoard has 0 loop
--------g_CapsEx.ForATM = 0----------
15:32:14|trace CLocales::loadFont()>>>>>>>>>
CPacketManager::CPacketManager()>>>>>>>>>
Packet usage : 0K / 20480K, 0%
----------------------[04-13 15:32:14]
15:32:14|trace CTimerManager::CTimerManager()>>>>>>>>>
15:32:14|trace CDeviceManager::CDeviceManager(hifb info: vo max resolution w:1024 h:768
15:3hifb info: The layer is show(1) now!
2:14|trace CDeviceManager::Start()>>>>>>>>>
==>CPacketManager: hifb info: vo max resolution w:720 h:576
allocate buffer:hifb info: The layer is show(1) now!
0x00F02B5C size:16384
######iCount=2
++++++libvos.a Video2GetOutChannels() 5135 DSP:3520,ProductType:DVR3116
* Libvos.a Ver: 1.0, Compiled At May 6 2011 08:51:27
* DSPType:1, ProductType=:16,Maxchannel:160, Vstd:0
++++++libvos.a GetDefaultCSC() 2104 ===============Vo:0 CsC===================
++++++libvos.a GetDefaultCSC() 2111 Get LUMA, Vo:0 Val:50
++++++libvos.a GetDefaultCSC() 2124 Get CONTR, Vo:0 Val:54
++++++libvos.a GetDefaultCSC() 2137 Get HUE, Vo:0 Val:49
++++++libvos.a GetDefaultCSC() 2150 Get SATU, Vo:0 Val:55
++++++libvos.a GetDefaultCSC() 2104 ===============Vo:2 CsC===================
++++++libvos.a GetDefaultCSC() 2111 Get LUMA, Vo:2 Val:50
++++++libvos.a GetDefaultCSC() 2124 Get CONTR, Vo:2 Val:55
++++++libvos.a GetDefaultCSC() 2137 Get HUE, Vo:2 Val:50
++++++libvos.a GetDefaultCSC() 2150 Get SATU, Vo:2 Val:49
++++++libvos.a SetCSC() 2181 Get LUMA, Vo:0 Val:58
++++++libvos.a SetCSC() 2201 Get CONTR, Vo:0 Val:48
++++++libvos.a SetCSC() 2220 Get HUE, Vo:0 Val:58
++++++libvos.a SetCSC() 2240 Get SATU, Vo:0 Val:55
++++++libvos.a SetCSC() 2181 Get LUMA, Vo:2 Val:48
++++++libvos.a SetCSC() 2201 Get CONTR, Vo:2 Val:50
++++++libvos.a SetCSC() 2220 Get HUE, Vo:2 Val:53
++++++libvos.a SetCSC() 2240 Get SATU, Vo:2 Val:52
HIVosTask in :VideoCtrlTaskFunc() 3085 pid 1051
+++++AudioCreate:audio_talk_mux = 1++++
libcap.a : CaptureGetChannels 1439 info : chip_type = 1 total_chip = 1, total_chl = 16, per_chip = 16, audio_talk_mux = 1(chn 0
), platform_mark = 0xa0++++
libplay.a DSPType:HI3520, MaxPlayChannels:16,Real_time:0,InnerProductType:0xa0
+++++mafei: audio_chl = 4++++++
* Libplay.a Ver: V0.00.0 for 16 chs
* Compile at May 3 2011 13:53:55
libplay.a+++ debug: LibPlayInit() 420 DSPType:1,MaxPlayChannel:16
HIDecTask in :PlayCmdThread() 279 pid 1052
HIStreamTask in :PlayStreamThread() 540 pid 1053
*stvid ch:0 User:41b6d008,Kernel:41b6d008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:1 User:41bae008,Kernel:41bae008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:2 User:41bef008,Kernel:41bef008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:3 User:41c30008,Kernel:41c30008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:4 User:41c71008,Kernel:41c71008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:5 User:41cb2008,Kernel:41cb2008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:6 User:41cf3008,Kernel:41cf3008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:7 User:41d34008,Kernel:41d34008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:8 User:41d75008,Kernel:41d75008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:9 User:41db6008,Kernel:41db6008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:10 User:41df7008,Kernel:41df7008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:11 User:41e38008,Kernel:41e38008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:12 User:41e79008,Kernel:41e79008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:13 User:41eba008,Kernel:41eba008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:14 User:41efb008,Kernel:41efb008,Read_p:0,Write_p:0,PESSize:40000*
*stvid ch:15 User:41f3c008,Kernel:41f3c008,Read_p:0,Write_p:0,PESSize:40000*
* libhicap.a version: v2.00.0 svn: 1721 Compile at: 11:58:23 Jul 6 2011
* max channel: 32
define HI35XX_JPEG_ALLCHN
define HI35XX_JPEG_D1
define HI35XX_AI_LPCM
libcap.a : CaptureCreate 1050 info : in
libcap.a : PCICreate 902 info : local chip
hidemo : cmd_h2d_host_connected 1973 info : ***********************************************************************************
hidemo : cmd_h2d_host_connected 1974 info : **********g_SYS_CHN = 16 g_SYS_ACHN = 4 g_SYS_CHIP = 0 g_TOTAL_CHN = 16**********
hidemo : cmd_h2d_host_connected 1976 info : ***g_SYS_DSPTYPE = 1(HI3520) g_D1_RealTime = 0 g_PROC_TYPE = 0 Audio is alt : TRUE***
hidemo : cmd_h2d_host_connected 1977 info : *************************************************************************
hislave : HiSlaveThreadCreate 53 info : nPriority = 0, name : AVencGetStream
hislave : AVencGetStream 8082 info : pid 1054
hislave : HiSlaveThreadCreate 209 info : policy = 0, nPriority = 50, name : AVencGetStream
hislave : HiSlaveThreadCreate 53 info : nPriority = 0, name : MdGetStream
hislave : MdGetStream 730 info : pid 1055
hislave : HiSlaveThreadCreate 209 info : policy = 0, nPriority = 50, name : MdGetStream
hislave : HiSlaveThreadCreate 53 info : nPriority = 0, name : showDatatimeOSD_thread
hidemo : showDatatimeOSD_thread 1138 info : pid 1057
hislave : HiSlaveThreadCreate 209 info : policy = 0, nPriority = 50, name : showDatatimeOSD_thread
libcap.a : CaptureCreate 1070 info : out
15:32:14|trace PreRecLen = 5120
15:32:14|trace Packet Num [2048]
+++++AudioInCreate:audio_talk_mux = 1++++
15:32:16|trace CGeneral::CGeneral()>>>>>>>>>
15:32:16|trace DvrGetHwidInformation(CPLD_REAL_TIME) = 0
CGeneral setLanguage:6
15:32:17|trace CGeneral::Start()>>>>>>>>>
libcap.a : CaptureSetExtendFunc 5217 info : ++libstcap++CaptureSetExtendFunc: Video DHAV stream!
libcap.a : CaptureSetExtendFunc 5232 info : ++libstcap++CaptureSetExtendFunc: Audio G711a stream!
&&&&##set Audio format sucess!Chn[0]--Audio[0]
&&&&##set Audio format sucess!Chn[1]--Audio[0]
&&&&##set Audio format sucess!Chn[2]--Audio[0]
&&&&##set Audio format sucess!Chn[3]--Audio[0]
&&&&##set Audio format sucess!Chn[4]--Audio[0]
&&&&##set Audio format sucess!Chn[5]--Audio[0]
&&&&##set Audio format sucess!Chn[6]--Audio[0]
&&&&##set Audio format sucess!Chn[7]--Audio[0]
&&&&##set Audio format sucess!Chn[8]--Audio[0]
&&&&##set Audio format sucess!Chn[9]--Audio[0]
&&&&##set Audio format sucess!Chn[10]--Audio[0]
&&&&##set Audio format sucess!Chn[11]--Audio[0]
&&&&##set Audio format sucess!Chn[12]--Audio[0]
&&&&##set Audio format sucess!Chn[13]--Audio[0]
&&&&##set Audio format sucess!Chn[14]--Audio[0]
&&&&##set Audio format sucess!Chn[15]--Audio[0]
++++++libvos.a Split2SetVstd() 4672 Index=0,dwStandard:0
| [Tw2867 && Cx25838 ] V1.00.0 for 16 chs, compile time May 27 2011 14:47:38 |
GpioWrite(1,5,0) ret = 0
GpioWrite(1,5,1) ret = 0
-->Libfvideo ad_init(TW2868) N_CHIPS = 2 <----!
tw2868_init_reg dsp_type = 1 page = 0
-->Libfvideo tw2868_init_reg<----!
tw2868_init_reg dsp_type = 1 page = 1
-->Libfvideo VideoSetVstd<----!
++++++libvos.a Graphics2SetVstd() 4528 dwStandard 0
Graphics2GetSurface() layer:0 :Addr:0x41401000 pitch:2048 format:0 15:32:24|trace ==========================
15:32:24|trace m_index = 0
15:32:24|trace mem = 0x41401000 0x00000000 0x00000000
15:32:24|trace pitch = 2048
15:32:24|trace width = 1024
15:32:24|trace height = 768
15:32:24|trace foramt = 0
++++++libvos.a Graphics2SetColorKey() 4566 stColorKey_p->u32Key =0
++++++libvos.a Graphics2SetAlpha() 4591 alpha:200 delta:0
hislave : HiSlaveThreadCreate 53 info : nPriority = 0, name : JPEGCapStream
hislave : JPEGCapStream 8663 info : chn 0 pid 1059
hislave : HiSlaveThreadCreate 209 info : policy = 0, nPriority = 50, name : JPEGCapStream
hislave : JPEGCapStream 8663 info : chn 1 pid 1060
hislave : JPEGCapStream 8663 info : chn 2 pid 1061
hislave : JPEGCapStream 8663 info : chn 3 pid 1062
hislave : JPEGCapStream 8663 info : chn 4 pid 1063
hislave : JPEGCapStream 8663 info : chn 5 pid 1064
hislave : JPEGCapStream 8663 info : chn 6 pid 1065
hislave : JPEGCapStream 8663 info : chn 7 pid 1066
hislave : JPEGCapStream 8663 info : chn 8 pid 1067
hislave : JPEGCapStream 8663 info : chn 9 pid 1068
hislave : JPEGCapStream 8663 info : chn 10 pid 1069
hislave : JPEGCapStream 8663 info : chn 11 pid 1070
hislave : JPEGCapStream 8663 info : chn 12 pid 1071
hislave : JPEGCapStream 8663 info : chn 13 pid 1072
15:32:24|trace WatchDogTime::OnkeepAlive!!!
######iCount=3
hislave : JPEGCapStream 8663 info : chn 14 pid 1073
hislave : JPEGCapStream 8663 info : chn 15 pid 1074
15:32:24|trace CGUI::Start()>>>>>>>>>
++++++libvos.a GraphicsSetResolution() 3557 resolution 7
++++++libvos.a Graphics2SetAlpha() 4591 alpha:255 delta:0
15:32:24|trace liblog:CLogImp::CLogImp()>>>>>>>>>
liblog:///////////////////////////
liblog:Init the log(....)!
liblog:/mnt/mtd/Log/Log
liblog:1024
liblog:0
liblog:0
liblog:-1
/mnt/mtd/Logliblog:init over
CPlay::Start()>>>>>>>>>
15:32:24|trace CDisplay::CDisplay()>>>>>>>>>
15:32:24|trace CDisplay::Start()>>>>>>>>>
++++++libvos.a error SetViewPortsPositions() 3027 Unsupport split format 0 assume SPLIT1!!!
15:32:24|debug tracepoint: ../../Devices/DevVideo.cpp, 181.
++++++libvos.a Video2Switch() 5090 index=0, dwType=0
++++++libvos.a Split2Combine() 4685 index=0,dwMode=5,dwindex=0
15:32:24|trace >>>>CAudioManager Start!!
15:32:24|trace >>>>Enter CPageDesktop::CPageDesktop...
can't find[Hebrew] from language array.
15:32:24|trace in pagemain >>>>>>>>>
15:32:24|trace CPagePlayNew::CreatePreviewItem----mask:131071
15:32:24|trace creat first page OK the rest will be ok >>>>>>>>>
15:32:25|debug tracepoint: ../../GUI/Pages/PageConfigEvent.cpp, 576.
15:32:25|trace i =3 blank
15:32:25|trace i =4 blank
++CPageImageColor::CPageImageColo:m_ShowWhiteLevel=5412096
15:32:25|trace CAlarm::CAlarm()>>>>>>>>>
15:32:25|trace GUI Objects:
15:32:25|trace BitmapButtons 0 x 308
15:32:25|trace Buttons 260 x 412
15:32:25|trace CheckBoxs 406 x 320
15:32:25|trace ComboBoxs 219 x 360
15:32:25|trace DateTimeCtrls 14 x 408
15:32:25|trace Edits 49 x 384
15:32:25|trace GridCtrls 3 x 524
15:32:25|trace GroupBoxs 19 x 288
15:32:25|trace IPAddressCtrls 15 x 312
15:32:25|trace ListBoxs 19 x 408
15:32:25|trace Menus 17 x 1964
15:32:25|trace NumberBoxs 346 x 368
15:32:25|trace NumberPads 0 x 312
15:32:25|trace Pages 83 x 548
15:32:25|trace ProgressCtrls 5 x 316
15:32:25|trace ScrollBars 0 x 336
15:32:25|trace SliderCtrls 15 x 420
15:32:25|trace Statics 838 x 336
15:32:25|trace TimingCtrls 32 x 364
15:32:25|trace Radios 123 x 364
15:32:25|trace Calendars 3 x 512
15:32:25|trace TimeTable 3 x 1528
15:32:25|trace TimeGrid 0 x 412
15:32:25|trace (null) 4 x 0
15:32:25|trace (null) 0 x 0
15:32:25|trace 2473 Items have been created, Total size = 918072
15:32:25|trace CPtz::CPtz()>>>>>>>>>
15:32:25|trace CPtz::Init()>>>>>>>>>
The following PTZ protocols have been loaded:
AD1641M,ADMATRIX,BANKNOTE,DH-CC440,DH-MATRIX,DH-SD1,DH-SD2,EPTZ,General,HAIYU,HY,LILIN,Mercer,Mercer-1,PANASONIC,PE5051K,PELCO-9750,PELCOASCII,PELCOD,PELCOD-DON,PELCOD-S,PELCOD-S1,PELCOD-T,PELCOD1,PELCOD1-T,PELCOP,PELCOP-A,PELCOP-HK,PELCOP1,PELCOP1-A,PELCOP5,PHILIPS,PIH-717,PelcoP-SD,QT-2XXD,RM110A,SAE,SAMSUNG,SANLI,SANTACHI,SHARP,SIERA-D,SIERA-P,SONY,WV-CS850I,WV-CS850II,WV-CS950,YAAN
15:32:25|trace PTZTour Module Start---------->>>>>>>>>>
iWhiteLevel 00
iWhiteLevel 80
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
iWhiteLevel 00
*********m_internal->m_chipCaps[Data CRC f4a265a9 != calculated CRC d3088d4f for node at 00074228
i].chipsId:0
*********mUnable to handle kernel NULL pointer dereference at virtual address 00000000
_internal->m_chipCaps[i]pgd = c3a9c000
.chipsId:1504054[00000000] *pgd=e5a990310
, *pte=00000000, *ppte=00000000
Internal error: Oops: 817 [#1]
Modules linked in: IR wdt consoles(P) gpio hi3520_adec(P) hi3520_aenc(P) hi3520_ao(P) hi3520_ai(P) hi3520_sio(P) hi3520_jpege(P) hi3520_h264d(P) hi3520_h264e(P) hi3520_md(P) hi3520_vpp(P) hi3520_group(P) hi3520_venc(P) hi3520_vdec(P) hi3520_chnl(P) hi3520_viu(P) hi3520_vou(P) hi3520_vd(P) hi3520_dsu(P) hi3520_sys(P) hi3520_base(P) tde(P) hifb(P) gpioi2c mcc_usrdev hidmac mmz h2gether
CPU: 0 Tainted: P (2.6.24-rt1-hi3520v100 #65)
PC is at jffs2_write_end+0x64/0x2a0
LR is at generic_file_buffered_write+0x18c/0x680
pc : [<c00c9f0c>] lr : [<c005eb10>] psr: 68000013
sp : c4451cc4 ip : 00000000 fp : c4451d14
r10: c58cd1c4 r9 : 00000000 r8 : 000020b0
r7 : 00000000 r6 : c5e72000 r5 : 000000b0 r4 : c58cd198
r3 : 000000c0 r2 : c5e72200 r1 : 000000b0 r0 : c03832c0
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 00c5387f Table: e5a9c008 DAC: 00000015
Process Challenge (pid: 1044, stack limit = 0xc4450258)
Stack: (0xc4451cc4 to 0xc4452000)
1cc0: 00000003 c02d8264 c4451d04 00000001 00000000 000000c0 000000b0
1ce0: 00000000 00000010 00000000 c0229d70 00000010 000020b0 00000000 00000010
1d00: 000000b0 c4450000 c4451dac c4451d18 c005eb10 c00c9eb4 00000010 00000010
1d20: c03832c0 c4451d90 00000f50 c58ccb80 c4451f04 c4451d88 c58cd1c4 00000001
1d40: 00000001 c5e72200 00000000 00000000 c0229d70 c58cd25c c58cd1c4 c0229d70
1d60: c58cd25c c5e8e960 c4451e9c c4451d90 c03832c0 c4451e94 00000001 00000000
1d80: 00000010 000020b0 00000000 00000000 00000000 c5e8e960 c4451de8 c4450000
1da0: c4451e48 c4451db4 c005f6a8 c005e994 000020b0 00000000 c4451ee4 00000010
1dc0: 00000000 c0092218 c5806bfc c5c0d1a0 00000000 c58cd25c c4451ee4 c4451e94
1de0: c4451e9c 00000010 000020b0 00000000 00000010 00000001 c4451f68 c4451f44
1e00: c007ab40 c009145c 00000002 00000003 00000000 c5e8e960 c4451f04 c5c262c0
1e20: c4451e9c 000020b0 00000000 c4451ee4 c58cd1c4 c4451e94 c58cd230 c4451e88
1e40: c4451e4c c005f8b0 c005f2e0 00000000 c58cd1c4 c58cd25c c5e8e960 00000001
1e60: c4451e9c c4451ee4 c5e8e960 c4451e94 c4451f78 00000000 00000000 c4451f4c
1e80: c4451e90 c007b858 c005f844 000020b0 00000000 01815950 00000010 00000000
1ea0: c02e8f80 00000000 00000001 ffffffff c5e8e960 00000000 00000000 00000000
1ec0: 00000000 c5d99740 00000000 00000000 c02e8fa4 c5d99740 c00491fc c4451edc
1ee0: c4451edc 000020b0 00000000 c003a694 c01373dc 00000000 c02e8fec 00000001
1f00: 00000010 c4451f10 c003a210 c003a094 c02c74f0 c02f46dc 00000000 c4451f58
1f20: c4451f2c 00000010 c5e8e960 01815950 c4451f78 c007b790 c4450000 00529500
1f40: c4451f74 c4451f50 c007b954 c007b79c fffffff2 c5e8e980 c5e8e960 c4451f78
1f60: 000020b0 00000000 c4451fa4 c4451f78 c007bab4 c007b8b0 000020b0 00000000
1f80: 00000001 00000010 000000c5 01815950 00000004 c001f004 00000000 c4451fa8
1fa0: c001ee60 c007ba74 00000010 000000c5 000000c5 01815950 00000010 00000000
1fc0: 00000010 000000c5 01815950 00000010 ffffffff 00000000 00529500 bec13970
1fe0: be800000 bec13828 0045392c 004a881c 68000010 000000c5 00000000 00000000
Backtrace:
[<c00c9ea8>] (jffs2_write_end+0x0/0x2a0) from [<c005eb10>] (generic_file_buffered_write+0x18c/0x680)
[<c005e988>] (generic_file_buffered_write+0x4/0x680) from [<c005f6a8>] (__generic_file_aio_write_nolock+0x3d4/0x560)
[<c005f2d4>] (__generic_file_aio_write_nolock+0x0/0x560) from [<c005f8b0>] (generic_file_aio_write+0x7c/0xfc)
[<c005f838>] (generic_file_aio_write+0x4/0xfc) from [<c007b858>] (do_sync_write+0xc8/0x114)
[<c007b790>] (do_sync_write+0x0/0x114) from [<c007b954>] (vfs_write+0xb0/0x148)
[<c007b8a4>] (vfs_write+0x0/0x148) from [<c007bab4>] (sys_write+0x4c/0x7c)
r8:00000000 r7:000020b0 r6:c4451f78 r5:c5e8e960 r4:c5e8e980
[<c007ba68>] (sys_write+0x0/0x7c) from [<c001ee60>] (ret_fast_syscall+0x0/0x2c)
r8:c001f004 r7:00000004 r6:01815950 r5:000000c5 r4:00000010
Code: e5926150 e50b4034 e24a402c e50b303c (058cc000)
---[ end trace 2d280d465d146dc1 ]---
LIBDVR : challenge exit
HiDog: Unexpected close, not stopping watchdog!
close
MMB LEAK(pid=1044): 0xE0E56000, 135168 bytes, ''
mmz_userdev_release: mmb<0xE0E56000> mapped to userspace 0x42769000 will be force unmaped!
MMB LEAK(pid=1044): 0xE0EBF000, 135168 bytes, ''
mmz_userdev_release: mmb<0xE0EBF000> mapped to userspace 0x427e4000 will be force unmaped!
MMB LEAK(pid=1044): 0xE0F28000, 135168 bytes, ''
mmz_userdev_release: mmb<0xE0F28000> mapped to userspace 0x4285f000 will be force unmaped!
MMB LEAK(pid=1044): 0xE0F91000, 135168 bytes, ''
mmz_userdev_release: mmb<0xE0F91000> mapped to userspace 0x428da000 will be force unmaped!
Re: Dahua DH-DVR3116 плата DVR-3100 10-4322
Сообщение iTuneDVR » 13 апр 2018, 17:38
Зачистить конфиг софтово через appauto=0 по инструкции и снова лог в студию.
Если не поможет, то из загрузчика, ту же область.
Возможно, что во флеше дырки.
Сообщение hack2003 » 14 апр 2018, 11:56
зашел cd /mnt/mtd/Config
стер конфиги
rm*
сделал
ii
поставил setenv appauto 1
перегрузился и вообще не чего
темный экран и лог
DRAM: 128 MB
Flash: 8 MB
PHY not link!
Machine: hi3520v100
scsi0 : sata_sil
scsi1 : sata_sil
usb 2-1: new low speed USB device using h2v100-ohci and address 2
usb 2-1: configuration #1 chosen from 1 choice
input: Logitech Optical USB Mouse as /class/input/input0
input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-hisilicon-1
Starting pid 745, console /dev/console: '/etc/init.d/rcS'
All OK
phy name is 0:00
load vd.ko ....OK!
load vou.ko ....OK!
load vdec.ko ....OK
load vpp.ko ....OK!
load md.ko....OK!
load h264d.ko OK
WDT @Hi3515
0x2012012c: 0xnetinit uses obsolete (PF_INET,SOCK_PACKET)
Ip = 192.168.1.108
Extracting /var/Challenge 1%main 202 UPNP.PRO::CtrlPointStart 11%CtrlPointRefresh 462 UPNP.PRO::CtrlPointSearch 25%main 208 UPNP.PRO::success CtrlPointStart OK
All OK
Version:1.1.0
Desc:Release1.1.0
Version:1.1.0
Desc:thread Release
Version:1.1.0
Desc:buffer Relese
Version:1.2.0
Version:1.2.0
Desc:build
Version:1.1.0
Desc:user release
10:53:48|trace main(2, /var/Challenge buf)
LIBDVR : 2018-4-14, today is weekday 6 time:10:53:49
| SYSTEM INFORMATION
| product type: DVR
| video channel: 16
| audio channel: 4
| alarm in: 0
| alarm out: 0
| frontboard type: 1U
| video chip: TW2868
| DSP chip: HI3520
| audio surpport: Yes
| matrix surpport: No
| loop surpport: No
| real time: No
| LCD surpport: No
| CDRW surpport: Yes
| hardware version: 1
| disk num: 1
| net card: 0
| dsp num: 1
| playback num: 16
10:53:49|trace CVersion::CVersion()>>>>>>>>>
10:53:49|trace Challenge Version Info:2.606.0000.1 BuildDate 2011-07-12 08:57:44
10:53:49|trace CChallenger::CChallenger()>>>>>>>>>
10:53:49|debug tracepoint: ../../Challenger.cpp, 212.
10:53:49|trace CThreadManager::CThreadManager()>>>>>>>>>
10:53:49|trace
10:53:49|trace WatchDogTime::OnkeepAlive!!!
######iCount=1
10:53:49|trace CLocales::loadFont()>>>>>>>>>
----------------------[04-14 10:53:49]
10:53:49|trace CTimerManager::CTimerManager()>>>>>>>>>
10:53:49|trace CDeviceManager:hifb info: vo max resolution w:1280 h:1024
:CDeviceManager(hifb info: The layer is show(1) now!
10:53:49|trace CDeviceManager::Start()>>>>>>>>>
==>CPacketMhifb info: vo max resolution w:720 h:576
anager: allocatehifb info: The layer is show(1) now!
buffer:0x00F36594 size:16384
######iCount=2
HIVosTask in :VideoCtrlTaskFunc() 3085 pid 1058
HIDecTask in :PlayCmdThread() 279 pid 1059
HIStreamTask in :PlayStreamThread() 540 pid 1060
* max channel: 32
hislave : AVencGetStream 8082 info : pid 1061
hislave : MdGetStream 730 info : pid 1062
hidemo : showDatatimeOSD_thread 1138 info : pid 1064
10:53:49|trace PreRecLen = 5120
10:53:49|trace Packet Num [2048]
10:53:50|trace readConfig file1 failed
10:53:50|trace CConfigManager::initialize() first config file parsing failed.
10:53:50|trace readConfig file2 failed
10:53:50|trace CConfigManager::initialize() second config file parsing failed too.
10:53:50|trace CConfigManager::setupConfig, recall config : 'Location'
10:53:50|trace CGeneral::CGeneral()>>>>>>>>>
10:53:50|trace DvrGetHwidInformation(CPLD_REAL_TIME) = 0
10:53:50|trace CConfigManager::setupConfig, recall config : 'General'
10:53:50|trace CConfigManager::setupConfig, recall config : 'GUISet'
10:53:50|trace CConfigManager::setupConfig, recall config : 'VideoColor'
10:53:50|trace CConfigManager::setupConfig, recall config : 'RECWorksheet'
10:53:50|trace CConfigManager::setupConfig, recall config : 'ALMWorksheet'
10:53:50|trace CConfigManager::setupConfig, recall config : 'MTDWorksheet'
10:53:50|trace CConfigManager::setupConfig, recall config : 'RecordMode'
10:53:50|trace CConfigManager::setupConfig, recall config : 'Record'
10:53:50|trace CConfigManager::setupConfig, recall config : 'PTZ'
10:53:50|trace CConfigManager::setupConfig, recall config : 'PTZAlarm'
10:53:50|trace CConfigManager::setupConfig, recall config : 'Alarm'
10:53:50|trace CConfigManager::setupConfig, recall config : 'NetAlarm'
10:53:50|trace CConfigManager::setupConfig, recall config : 'Motion'
10:53:50|trace CConfigManager::setupConfig, recall config : 'PTZTour'
10:53:50|trace CConfigManager::setupConfig, recall config : 'Loss'
10:53:50|trace CConfigManager::setupConfig, recall config : 'Blind'
10:53:50|trace CConfigManager::setupConfig, recall config : 'Comm'
10:53:50|trace CConfigManager::setupConfig, recall config : 'Play'
10:53:50|trace CConfigManager::setupConfig, recall config : 'MonitorTour'
10:53:50|trace CConfigManager::setupConfig, recall config : 'TVAdjust'
10:53:50|trace CConfigManager::setupConfig, recall config : 'ChannelTitle'
10:53:50|trace CConfigManager::setupConfig, recall config : 'VideoOSD'
10:53:50|trace CConfigManager::setupConfig, recall config : 'StorageNotExist'
10:53:50|trace CConfigManager::setupConfig, recall config : 'StorageFailure'
10:53:50|trace CConfigManager::setupConfig, recall config : 'StorageLowSpace'
10:53:50|trace CConfigManager::setupConfig, recall config : 'NetAbort'
10:53:50|trace CConfigManager::setupConfig, recall config : 'NetArp'
10:53:50|trace CConfigManager::setupConfig, recall config : 'Encode'
10:53:51|trace CConfigManager::setupConfig, recall config : 'DHCP'
10:53:51|trace CConfigManager::setupConfig, recall config : 'VideoWidget'
10:53:51|trace CConfigManager::setupConfig, recall config : 'AutoMaintain'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetCommon'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetFTPServer'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetFTPApplication'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetIPFilter'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetMultiCast'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetPPPOE'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetDDNS'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetAlarmServer'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetNTP'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetEmail'
10:53:51|trace CConfigManager::setupConfig, recall config : 'NetDns'
10:53:51|trace CConfigManager::setupConfig, recall config : 'RegServer'
10:53:51|trace CConfigManager::setupConfig, recall config : 'RECState'
10:53:51|trace CConfigManager::setupConfig, recall config : 'WaterMark'
10:53:51|trace CConfigManager::setupConfig, recall config : 'AudioInFormat'
10:53:51|trace CGeneral::Start()>>>>>>>>>
Graphics2GetSurface() layer:0 :Addr:0x41401000 pitch:2560 format:0 10:53:57|trace ==========================
10:53:57|trace m_index = 0
10:53:57|trace mem = 0x41401000 0x00000000 0x00000000
10:53:57|trace pitch = 2560
10:53:57|trace width = 1280
10:53:57|trace height = 1024
10:53:57|trace foramt = 0
hislave : JPEGCapStream 8663 info : chn 0 pid 1066
hislave : JPEGCapStream 8663 info : chn 1 pid 1067
hislave : JPEGCapStream 8663 info : chn 2 pid 1068
hislave : JPEGCapStream 8663 info : chn 3 pid 1069
hislave : JPEGCapStream 8663 info : chn 4 pid 1070
hislave : JPEGCapStream 8663 info : chn 5 pid 1071
hislave : JPEGCapStream 8663 info : chn 6 pid 1072
hislave : JPEGCapStream 8663 info : chn 7 pid 1073
hislave : JPEGCapStream 8663 info : chn 8 pid 1074
hislave : JPEGCapStream 8663 info : chn 9 pid 1075
hislave : JPEGCapStream 8663 info : chn 10 pid 1076
hislave : JPEGCapStream 8663 info : chn 11 pid 1077
hislave : JPEGCapStream 8663 info : chn 12 pid 1078
hislave : JPEGCapStream 8663 info : chn 13 pid 1079
hislave : JPEGCapStream 8663 info : chn 14 pid 1080
hislave : JPEGCapStream 8663 info : chn 15 pid 1081
hislave : HiSlaveThreadCreate 209 info : policy = 0, nPriority = 50, name : JPEGCapStreaData CRC f4a265a9 != calculated CRC d3088d4f for node at 00074228
m
10:53:57|tracUnable to handle kernel NULL pointer dereference at virtual address 00000000
e CGUI::Start()>pgd = c3aa8000
Graphi[00000000] *pgd=e5aa5031cs2GetSurface() , *pte=00000000layer:0 :Addr:0x, *ppte=0000000041401000 pitch:2
560 format:0 10:Internal error: Oops: 817 [#1]
sp : c5059cc4 ip : 00000000 fp : c5059d14
r10: c58ce1c4 r9 : 00000000 r8 : 000020b0
r7 : 00000000 r6 : c5e7f200 r5 : 000000b0 r4 : c58ce198
r3 : 000000c0 r2 : c5e7f400 r1 : 000000b0 r0 : c0374460
Control: 00c5387f Table: e5aa8008 DAC: 00000015
Process Challenge (pid: 1051, stack limit = 0xc5058258)
Stack: (0xc5059cc4 to 0xc505a000)
9cc0: 00000002 c02d8264 c5059d04 00000001 00000000 000000c0 000000b0
9ce0: 00000000 00000010 00000000 c0229d70 00000010 000020b0 00000000 00000010
9d00: 000000b0 c5058000 c5059dac c5059d18 c005eb10 c00c9eb4 00000010 00000010
9d20: c0374460 c5059d90 00000f50 c0030928 c02d8234 c5059d58 c58ce1c4 00000001
9d40: 00000001 c5e7f400 00000000 00000000 c0229d70 c58ce25c c58ce1c4 c0229d70
9d60: c58ce25c c1c6d340 c5059e9c c5059d90 c0374460 c5059e94 00000001 00000000
9d80: 00000010 000020b0 00000000 00000000 00000000 c1c6d340 c5059de8 c5058000
9da0: c5059e48 c5059db4 c005f6a8 c005e994 000020b0 00000000 c5059ee4 00000010
9dc0: 00000000 c0031b88 c0031ae8 00000000 00000000 c58ce25c c5059ee4 c5059e94
9de0: c5059e9c 00000010 000020b0 00000000 00000010 00000001 c004dfc8 c00287b8
9e00: 00000e7c c5059e3c 5ad1ddc6 01a0b42a 000023cd bf108878 00000000 bf0f6a10
9e20: c5059e9c 000020b0 00000000 c5059ee4 c58ce1c4 c5059e94 c58ce230 c5059e88
9e40: c5059e4c c005f8b0 c005f2e0 c02d8264 c5059e88 c58ce25c c1c6d340 00000001
9e60: c5059e9c c5059ee4 c1c6d340 c5059e94 c5059f78 00000000 00000000 c5059f4c
9e80: c5059e90 c007b858 c005f844 000020b0 00000000 010bd750 00000010 c5059f20
9ea0: c02e91a0 00000000 00000001 ffffffff c1c6d340 00000000 00000000 00000000
9ec0: 00000000 c5c71980 00000000 00000000 c5059efc c5c71980 c00491fc c5059edc
9ee0: c5059edc 000020b0 00000000 00000000 c5059f0c c5059f00 c007c6b0 c007782c
9f00: 00000010 c5059f10 c0101f78 c0101a9c c5d99a38 c02d8264 00000000 c5059f58
9f20: c5059f2c 00000010 c1c6d340 010bd750 c5059f78 c007b790 c5058000 00529500
9f40: c5059f74 c5059f50 c007b954 c007b79c fffffff2 c1c6d360 c1c6d340 c5059f78
9f60: 000020b0 00000000 c5059fa4 c5059f78 c007bab4 c007b8b0 000020b0 00000000
9f80: 00000001 00000010 000000b3 010bd750 00000004 c001f004 00000000 c5059fa8
9fa0: c001ee60 c007ba74 00000010 000000b3 000000b3 010bd750 00000010 00000000
9fc0: 00000010 000000b3 010bd750 00000010 ffffffff 00000000 00529500 be9918b8
9fe0: be400000 be991770 0045392c 004a881c 68000010 000000b3 00000702 000001f8
Backtrace:
r8:00000000 r7:000020b0 r6:c5059f78 r5:c1c6d340 r4:c1c6d360
r8:c001f004 r7:00000004 r6:010bd750 r5:000000b3 r4:00000010
53:57|trace ====================---[ end trace 8176864c9f1392d4 ]---
++++++libvos.a GraphicsSetResolution() 3557 resolution 4
10:53:58|trace liblog:CLogImp::CLogImp()>>>>>>>>>
liblog:1024
liblog:0
liblog:0
liblog:-1
10:53:58|trace CDisplay::CDisplay()>>>>>>>>>
10:53:58|trace CDisplay::Start()>>>>>>>>>
10:53:58|debug tracepoint: ../../Devices/DevVideo.cpp, 181.
10:53:58|trace >>>>CAudioManager Start!!
10:53:58|trace Can not open file:/mnt/mtd/Config/group
10:53:58|trace LoadAll :: Load cfg failed
hislave : JPEGCapStream 8766 error : 1 chan :44 C240c 0xa0068010
hislave : JPEGCapSHiDog: Unexpected close, not stopping watchdog!
tream 8766 errorclose
: 1 chan :44 C2MMB LEAK(pid=1051): 0xE0E56000, 135168 bytes, ''
40c 0xa0068010
hislave : JPEGCaMMB LEAK(pid=1051): 0xE0EBF000, 135168 bytes, ''
pStream 8766 errmmz_userdev_release: mmb<0xE0EBF000> mapped to userspace 0x427e4000 will be force unmaped!
or : 1 chan :44 MMB LEAK(pid=1051): 0xE0F28000, 135168 bytes, ''
C240c 0xa0068010mmz_userdev_release: mmb<0xE0F28000> mapped to userspace 0x4285f000 will be force unmaped!
hislave : JPEGMMB LEAK(pid=1051): 0xE0F91000, 135168 bytes, ''
CapStream 8766 emmz_userdev_release: mmb<0xE0F91000> mapped to userspace 0x428da000 will be force unmaped!
hislave : J
Сообщение hack2003 » 14 апр 2018, 13:35
сделал дамп , пока не нашел прошивку, есть???
микросхему не сколько раз перепрошил , ошибок нету
Сообщение iTuneDVR » 14 апр 2018, 17:59
Дамп получил.
Рекомендация по удалению конфига
rm /mnt/* -rf
Стереть и снова запустить и лог в студию.
Модель в hardware.lua указана DVR3116-ENG
Прошивка вот
General_DVR3116_Eng_P_V2.606.0000.1.R.20110712.bin
(6.61 МБ) 515 скачиваний
Сообщение hack2003 » 16 апр 2018, 12:47
спасибо запустился работает , не получилось затереть папку web, работает прекрасно! а что же произошло?
Сообщение iTuneDVR » 16 апр 2018, 13:52
По rm не получилось?
Сообщение hack2003 » 16 апр 2018, 13:59
часть удалилась, а папка web нет, но самое главное заработало
Сообщение iTuneDVR » 16 апр 2018, 16:46
hack2003 писал(а):часть удалилась, а папка web нет, но самое главное заработало
в том и смысл этого универсального метода, работающего и для регистраторов и для камер.
Указав общий путь, удалится все то, что для записи, а что примонтировано для чтения - не коснется ;)
В камерах бывают Backup, от которых есть некоторые проблемы при сбросе, вот поэтому...
Главное, что внесена ясность и все работает ;)
