Не восстанавливается DH-IPC-KW12WP
Сообщение Kvintek » 19 окт 2017, 16:39
Собственно проблема в том что с загрузчика начал восстанавливать прошивку, после того как залил камера уходит в ребут
вот ЛОГ
Terminal log file
Date: 18.10.2017 - 15:43:23
U-Boot 2010.06-svn2134 (May 26 2014 - 16:15:03)
DRAM:  256 MiB
reset/hold pin now is RESET
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128B"
boot from spi
can't find corresponding entry
fail to resolve
partition file version 1
TEXT_BASE:81000000
Hisilicon ETH net controler
MAC:   00-12-34-56-78-9A
Download to address: 0x84000000
Downloading: *
Fail to get info file!
Init error!
miiphy_register: non unique device name '0:1'
Downloading: *
   Image Name:   Linux-3.0.8
   Data Size:    1337924 Bytes = 1.3 MiB
   Entry Point:  80008000
   Loading Kernel Image ...OK
fail to resolve
Linux version 3.0.8 (huang_zhendi@localhost.localdomain) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.30.2+eabi+linuxpthread)) ) #6 Sat Mar 1 08:58:54 CST 2014
Machine: hi3518
ethaddr0=0:12:34:56:78:9a
ethaddr1=0:0:0:0:0:0
wifiAddr=0:12:34:56:78:91
lip0=192.168.1.108
lip1=0.0.0.0
id=000000000000000000
U-Boot 0x40000 0x80000 0x0
hwid 0x40000 0xc0000 0x0
custom 0x20000 0x140000 0x0
product 0x20000 0x160000 0x0
Kernel 0x160000 0x180000 0x0
web 0x220000 0x2e0000 0x0
romfs 0x1a0000 0x500000 0x0
user 0x880000 0x6a0000 0x0
syslog 0x20000 0xf20000 0x0
config 0x60000 0xf40000 0x0
backup 0x60000 0xfa0000 0x0
num parts is 12.
Ignoring unrecognised tag 0x54410011
AXI bus clock 220000000.
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 20320
Kernel command line: mem=80M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
dh_keyboard:0
Memory: 80MB = 80MB total
Memory: 77492k/77492k available, 4428k reserved, 0K highmem
    vmalloc : 0xc5800000 - 0xfe000000   ( 904 MB)
    lowmem  : 0xc0000000 - 0xc5000000   (  80 MB)
      .init : 0xc0008000 - 0xc0020000   (  96 kB)
      .text : 0xc0020000 - 0xc035d000   (3316 kB)
      .data : 0xc035e000 - 0xc03782e0   ( 105 kB)
       .bss : 0xc0378304 - 0xc038f758   (  94 kB)
NR_IRQS:32 nr_irqs:32 32
devtmpfs: initialized
console [ttyS0] enabled
msgmni has been set to 151
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 0x16777216
chip num: 1
0x0000006a0000-0x000000f20000 : "user"
0x000000f20000-0x000000f40000 : "syslog"
Fixed MDIO Bus: probed
himii: probed
hub 1-0:1.0: 1 port detected
hub 2-0:1.0: 1 port detected
TCP bic registered
шVFS: Mounted root (squashfs filesystem) readonly on device 31:7.
devtmpfs: mounted
Freeing init memory: 96K
mount: mounting /dev/mtdblock4 on /mnt/pd/ failed: Invalid argument
jffs2: Too few erase blocks (2)
mount: Invalid argument
erase block:0,offset:00000000
erase block:1,offset:00010000
keyboard = 0
pa:85500000, va:c5a00000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load vou.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
load vda.ko ....OK!
[OSA-DRV] OSA Build on Oct 22 2013 at 16:49:51.
[OSA-DRV] SVN NUM: 1086.
[OSA-DRV] Monitor    Task   pid=477   tid=477
[LOG-DRV] LOG Build on Jan 14 2014 at 14:36:20.
[LOG-DRV] SVN NUM: 5180.
[LOG-DRV] ramStart:0x0;ramSize:0x0;select:0
 on Mar 13 2014 at 20:56:44.
[libpdi] SVN NUM: 13636.
[libpdi] ERROR  (PDI_productInit|407): Can't open /dev/pdcHwid
[libpdi] ERROR  (PDI_preInit|93): PDI_productInit execute Error and return OSA_EFAIL
[libpdi] ERROR  (PDI_hwidGet|330): Ioctl execute error
[libpdi] ERROR  (PDI_preInit|98): PDI_hwidGet execute Error and return OSA_EFAIL
[libpdi] ERROR  (Cfg_platInit|153): Unknown Product Type
[libpdi] WARN  : RTC Dev not exists,status = -1
[libpdi]  Flashtype = 3,patSize = 40000,rwSize = 1,ersSize = 10000
[libpdi] WARN  : Device has no crypt chip!
[Systools]: Build on Mar 13 2014 at 20:53:39.
[Systools]:SVN NUM: 13637.
IPV6: only init eth0
"netinit6 help" for help
eth0:
MAC: <00:12:34:56:78:9a>
IPV6: <2008::6>      preFixLen: <112>
product_name =
fvideo_chip = 0
unzip: can't open /mnt/pd/product.zip, /mnt/pd/product.zip.zip, /mnt/pd/product.zip.ZIP
cp: can't stat '/var/tmp/product/ProductTransform': No such file or directory
cp: can't stat '/var/tmp/2Acfg/3D.bin': No such file or directory
cp: can't stat '/var/tmp/2Acfg/reg.bin': No such file or directory
/usr/etc/IPCimod: cd: line 146: can't cd to usr/bin
/usr/etc/IPCimod: line 148: udelay: not found
./usr/etc/app.sh: line 13: can't create /proc/osa_root/pdc/pdcWdt: nonexistent directory
[OSA-APP] OSA Build on Oct 22 2013 at 17:02:35.
[OSA-APP] SVN NUM: 1086.
==============>PPPOE2.4.5:Complie time Oct 29 2013 16:21:37 SvnVersion = 2713<=============
get username * password error!
[libpdi] libpdi.so Build on Mar 13 2014 at 20:56:44.
PHY: himii:01 - Link is Up - 100/Full
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
0|trace CMagicBox::config '/var/tmp/pd/ProductDefinition'
Fail to get env authcode!
th:          0
 language:null
but default config is not set yet!
face!
libNetApp] debug m_oldConfigRoute:null
e success
32m00:00:11|[libpdi] EthName:eth0 route delete ok!
info OnConfigWLan::WLanOpen:: Sucess
= 0x4991eec4
warn  CConfigManager::getConfig 'RTSP', but default config is not set yet!
1|warn  CConfigManager::getConfig 'DVRIP', but default config is not set yet!
ig 'T2UServer', but default config is not set yet!
fig is not set yet!
32;40m00:00:11|info  ############getDefault:DDNS
rchIP/DeviceDiscover.cpp,36
00:00:12|info  ========================================================================
 : "%y-%M-%d\/%c\/dav\/%h\/%h.%m.%s-%h.%m.%s[%E][%O@%S][%R].dav"
      "Channels" : [
            "MaxPictures" : 0,
            "Path" : null
      "FileHoldTime" : 0,
      "Memo" : "For FTP Files",
      "Name" : "FTP",
      "OverWrite" : true,
      "PicturePathRule" : "%y-%M-%d\/%c\/jpg\/%h\/%m\/%s[%E][%O@%S][%R].jpg",
      "RecordPathRule" : "%y-%M-%d\/%c\/dav\/%h\/%h.%m.%s-%h.%m.%s[%E][%O@%S][%R].dav"
rd = 0] failed
Date: 18.10.2017 - 15:46:11
End log file
пробовал другой прошивкой шить, там в ребут не уходит, камера пингуется, но софтом не видится.
Сейчас прошивка General_IPC-HX1100
а на которой пингуется General_IPC-KW12W_
Re: Не восстанавливается DH-IPC-KW12WP
Сообщение iTuneDVR » 19 окт 2017, 21:47
Данные лога говорят, что не все разделы восстановлены корректно.
Какой именно прошивкой восстанавливал?
Сообщение Kvintek » 20 окт 2017, 10:10
General_IPC-HX1100_Eng_P_P2P_V2.420.0000.0.R.20150601
и
General_IPC-KW12W_Eng_P_V2.210.0000.0.T.20140328
Сообщение iTuneDVR » 20 окт 2017, 13:21
Свой консольный лог восстановления тоже.
Сообщение Kvintek » 20 окт 2017, 13:50
Terminal log file
Date: 20.10.2017 - 12:42:59
зк  printenv
bootcmd=kload 0x82000000; bootm 0x82000000
bootdelay=1
ethaddr=00:12:34:56:78:9A
gatewayip=192.168.1.1
wifiaddr=00:12:34:56:78:91
ID=000000000000000000
da=tftp 0x82000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite
dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite
dk=tftp 0x82000000 kernel.img; flwrite
du=tftp 0x82000000 user-x.squashfs.img; flwrite
dw=tftp 0x82000000 web-x.squashfs.img; flwrite
dp=tftp 0x82000000 partition-x.cramfs.img;flwrite
dc=tftp 0x82000000 custom-x.squashfs.img; flwrite
up=tftp 0x82000000 update.img; flwrite
tk=tftp 0x82000000 uImage; bootm
loglevel=4
serverip=192.168.1.77
ipaddr=192.168.1.108
bootargs=mem=80M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
filesize=A040
fileaddr=82000000
ver=U-Boot 2010.06-svn2134 (May 26 2014 - 16:15:03)
Environment size: 930/262140 bytes
> setenv      run dr a
UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M
TFTP from server 192.168.1.77; our IP address is 192.168.1.108
Download Filename 'dhboot.bin.img'.
Downloading: *##################################
Bytes transferred = 172096 (2a040 hex)
## Checking Image at 82000000 ...
   Legacy image found
   Image Name:   boot
   Image Type:   ARM Linux Firmware (uncompressed)
   Data Size:    172032 Bytes = 168 KiB
   Load Address: 00080000
   Entry Point:  000c0000
Programing start at: 0x00080000
write : 0%
write : 0%
write : 33%
write : 66%
write : 100%
Download Filename 'dhboot-min.bin.img'.
Downloading: *
TFTP error: (1)'File not found'
Not retrying...
> run dr
Download Filename 'romfs-x.squashfs.img'.
Downloading: *#################################################################
Bytes transferred = 737344 (b4040 hex)
   Legacy image found
   Image Name:   romfs
   Image Type:   ARM Linux Standalone Program (gzip compressed)
   Data Size:    737280 Bytes = 720 KiB
   Load Address: 00500000
   Entry Point:  006a0000
Programing start at: 0x00500000
write : 0%
write : 0%
write : 8%
write : 16%
write : 25%
write : 33%
write : 41%
write : 50%
write : 58%
write : 66%
write : 75%
write : 83%
write : 91%
write : 100%
> run dk
Download Filename 'kernel.img'.
Bytes transferred = 1338052 (146ac4 hex)
   Legacy image found
   Image Name:   kernel
   Data Size:    1337988 Bytes = 1.3 MiB
   Load Address: 00180000
   Entry Point:  002e0000
Programing start at: 0x00180000
write : 0%
write : 0%
write : 4%
write : 9%
write : 14%
write : 19%
write : 23%
write : 28%
write : 33%
write : 38%
write : 42%
write : 47%
write : 52%
write : 57%
write : 61%
write : 66%
write : 71%
write : 76%
write : 80%
write : 85%
write : 90%
write : 95%
write : 100%
> run du
Download Filename 'user-x.squashfs.img'.
Bytes transferred = 8327232 (7f1040 hex)
   Legacy image found
   Image Name:   user
   Data Size:    8327168 Bytes = 7.9 MiB
   Load Address: 006a0000
   Entry Point:  00ee0000
Programing start at: 0x006a0000
write : 0%
write : 0%
write : 0%
write : 1%
write : 2%
write : 3%
write : 3%
write : 4%
write : 5%
write : 6%
write : 7%
write : 7%
write : 8%
write : 9%
write : 10%
write : 10%
write : 11%
write : 12%
write : 13%
write : 14%
write : 14%
write : 15%
write : 16%
write : 17%
write : 17%
write : 18%
write : 19%
write : 20%
write : 21%
write : 21%
write : 22%
write : 23%
write : 24%
write : 25%
write : 25%
write : 26%
write : 27%
write : 28%
write : 28%
write : 29%
write : 30%
write : 31%
write : 32%
write : 32%
write : 33%
write : 34%
write : 35%
write : 35%
write : 36%
write : 37%
write : 38%
write : 39%
write : 39%
write : 40%
write : 41%
write : 42%
write : 42%
write : 43%
write : 44%
write : 45%
write : 46%
write : 46%
write : 47%
write : 48%
write : 49%
write : 50%
write : 50%
write : 51%
write : 52%
write : 53%
write : 53%
write : 54%
write : 55%
write : 56%
write : 57%
write : 57%
write : 58%
write : 59%
write : 60%
write : 60%
write : 61%
write : 62%
write : 63%
write : 64%
write : 64%
write : 65%
write : 66%
write : 67%
write : 67%
write : 68%
write : 69%
write : 70%
write : 71%
write : 71%
write : 72%
write : 73%
write : 74%
write : 75%
write : 75%
write : 76%
write : 77%
write : 78%
write : 78%
write : 79%
write : 80%
write : 81%
write : 82%
write : 82%
write : 83%
write : 84%
write : 85%
write : 85%
write : 86%
write : 87%
write : 88%
write : 89%
write : 89%
write : 90%
write : 91%
write : 92%
write : 92%
write : 93%
write : 94%
write : 95%
write : 96%
write : 96%
write : 97%
write : 98%
write : 99%
write : 100%
> run dw
Download Filename 'web-x.squashfs.img'.
Bytes transferred = 1499200 (16e040 hex)
   Legacy image found
   Image Name:   web
   Data Size:    1499136 Bytes = 1.4 MiB
   Load Address: 002e0000
   Entry Point:  00500000
Programing start at: 0x002e0000
write : 0%
write : 0%
write : 4%
write : 8%
write : 13%
write : 17%
write : 21%
write : 26%
write : 30%
write : 34%
write : 39%
write : 43%
write : 47%
write : 52%
write : 56%
write : 60%
write : 65%
write : 69%
write : 73%
write : 78%
write : 82%
write : 86%
write : 91%
write : 95%
write : 100%
> run pc  dp
Download Filename 'partition-x.cramfs.img'.
Downloading: *#
Bytes transferred = 4160 (1040 hex)
   Legacy image found
   Image Name:   partition
   Data Size:    4096 Bytes = 4 KiB
   Load Address: 00100000
   Entry Point:  00140000
Programing start at: 0x00100000
write : 0%
write : 0%
write : 100%
> run dc
Download Filename 'custom-x.squashfs.img'.
Bytes transferred = 41024 (a040 hex)
   Legacy image found
   Image Name:   custom
   Data Size:    40960 Bytes = 40 KiB
   Load Address: 00140000
   Entry Point:  00160000
Programing start at: 0x00140000
write : 0%
write : 0%
write : 100%
> run tk
Date: 20.10.2017 - 12:49:36
End log file
Сообщение iTuneDVR » 20 окт 2017, 14:32
Ну, а другие модули разве не надо??? ;)
Сообщение Kvintek » 20 окт 2017, 14:41
и в прошивке 9 файлов
Сообщение iTuneDVR » 20 окт 2017, 14:47
Посмотри внимательно лог и увидишь, что один отсутствует и пропущен!
Сообщение Kvintek » 20 окт 2017, 15:32
tk? так его в прошивке нет
Сообщение iTuneDVR » 20 окт 2017, 15:53
Kvintek писал(а):tk? так его в прошивке нет
Я не про это.
