Не восстанавливается DH-IPC-KW12WP
Kvintek
Re: Не восстанавливается DH-IPC-KW12WP
Сообщение Kvintek » 31 окт 2017, 10:21
Вот что имеем
Terminal log file
Date: 31.10.2017 - 9:19:51
U-Boot 2010.06-svn2134 (May 26 2014 - 16:15:03)
DRAM:  256 MiB
reset/hold pin now is RESET
boot from spi
partition file version 2
rootfstype squashfs root /dev/mtdblock7
TEXT_BASE:81000000
Hisilicon ETH net controler
MAC:   00-12-34-56-78-9A
Download to address: 0x84000000
Downloading: *
Fail to get info file!
Init error!
miiphy_register: non unique device name '0:1'
Download Filename 'failed.txt'.
Downloading: *
   Image Name:   Linux-3.0.8
   Data Size:    1337924 Bytes = 1.3 MiB
   Entry Point:  80008000
   Loading Kernel Image ...OK
cmdLine mem=80M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
Linux version 3.0.8 (huang_zhendi@localhost.localdomain) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.30.2+eabi+linuxpthread)) ) #6 Sat Mar 1 08:58:54 CST 2014
Machine: hi3518
appauto=1
dh_keyboard=0
ethaddr0=0:12:34:56:78:9a
ethaddr1=0:0:0:0:0:0
wifiAddr=0:12:34:56:78:91
lip0=192.168.1.108
lip1=0.0.0.0
id=000000000000000000
U-Boot 0x40000 0x80000 0x0
hwid 0x40000 0xc0000 0x0
partition 0x40000 0x100000 0x0
custom 0x20000 0x140000 0x0
product 0x20000 0x160000 0x0
Kernel 0x160000 0x180000 0x0
web 0x220000 0x2e0000 0x0
romfs 0x1a0000 0x500000 0x0
user 0x840000 0x6a0000 0x0
syslog 0x60000 0xee0000 0x0
config 0x60000 0xf40000 0x0
backup 0x60000 0xfa0000 0x0
num parts is 12.
Ignoring unrecognised tag 0x54410011
AXI bus clock 220000000.
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 20320
Kernel command line: mem=80M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
dh_keyboard:0
Memory: 80MB = 80MB total
Memory: 77492k/77492k available, 4428k reserved, 0K highmem
    vmalloc : 0xc5800000 - 0xfe000000   ( 904 MB)
    lowmem  : 0xc0000000 - 0xc5000000   (  80 MB)
      .init : 0xc0008000 - 0xc0020000   (  96 kB)
      .text : 0xc0020000 - 0xc035d000   (3316 kB)
      .data : 0xc035e000 - 0xc03782e0   ( 105 kB)
       .bss : 0xc0378304 - 0xc038f758   (  94 kB)
NR_IRQS:32 nr_irqs:32 32
devtmpfs: initialized
uart:0: ttyS0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyS0] enabled
uart:1: ttyS1 at MMIO 0x20090000 (irq = 5) is a PL011 rev2
msgmni has been set to 151
io scheduler cfq registered
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 0x16777216
chip num: 1
Creating 12 MTD partitions on "hi_sfc":
0x000000080000-0x0000000c0000 : "U-Boot"
0x0000000c0000-0x000000100000 : "hwid"
0x000000100000-0x000000140000 : "partition"
0x000000140000-0x000000160000 : "custom"
0x000000160000-0x000000180000 : "product"
0x000000180000-0x0000002e0000 : "Kernel"
0x0000002e0000-0x000000500000 : "web"
0x000000500000-0x0000006a0000 : "romfs"
0x0000006a0000-0x000000ee0000 : "user"
0x000000ee0000-0x000000f40000 : "syslog"
0x000000fa0000-0x000001000000 : "backup"
Fixed MDIO Bus: probed
himii: probed
hub 1-0:1.0: 1 port detected
hub 2-0:1.0: 1 port detected
TCP bic registered
TCP cubic registered
шVFS: Mounted root (squashfs filesystem) readonly on device 31:7.
devtmpfs: mounted
Freeing init memory: 96K
proc_file_read: Apparent buffer overflow!
/var/script: line 9: can't create яїяяяяяяяяяяяяяяяяяЧїяяяяяяяяэяяяяяяяячяяяячяпяюяЇяяяяяяяяяяяяяяяяяяэяяяїяяяяяяяяНяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяЇяяяяяяяяяяяяяяяюяяяяяяяяяяяяяяяяяыяяяяяяяяяяяяяяяяяяяяяяяяяяяяяыяяяяэяяяяяяяяэяяяяяяяЯяяяїяяюяпяяяяяяяяяяяпяяячяяяяяяяяяяяїяяяЮяяяяяяяяяяяяяэяяяэяяяяяяяяяяяяя~яяяяяяяяяяЯяяэяяяяыяяяяяяяяяяяяяяяяяяяЯяяяяяяяяяїяяяяяяяяяяяяяяяяЯяяяяяяяяячяяяяяяяяяяяяяяяяяяяїяэяяяяяяяяяяяяяяяяяяяяяяяяяяячяяяяїяЯяяяяяяЯыяячяяяяяяїяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяюяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяэяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяЫяяяяяяяяяяяяюяЯяяяяяяяяяяяяяяяяяэяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяыяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяЯяыяяяяяяяяяяяэяяяяяяЯчяяэячяяяяюяяпяяяяяяяяяяяяяяяяяяяяяяюяяяяпяяяяяяяяяяяяяяяяяяяяяпЧяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяыяяяяяяяяяяяяэяяяяяпяяюпяыяяячяяяяяяїїяяяяяяяяяяяяяяяяяяяяѕяяяяяяяяяяяяюяяяяяяїчяяяїяяяяяяяяяяяяяяяяяЅяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяюяяяяяячяїяяяэяяяяяяяяяяяяяяяяяяяячяяяяяяяїяяяяяяяяяяяяяЯяяяяяяяяяяяяяяяыяяяяяїяяяяяяяпяяяяяячяяїяяяяяяюяяяяэяяяяяяяяяяяяяяяяяяяячяяяяяяяяяпяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяячяяяяяяяяяяяяяяяяэяяяяяяяяяяяяяяячячяяяыяяяяяяяЯяпяяяяяяяяяяяяяяяяяыыяяяяяяяяяяяяяяяяяяяяЯяяяяяяяяяїяяяяяяяЯяЅяяяяяяяяяяяяяяяяяяя?яяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяячяяяяяяяяяяяяяяяяяяяяяыяяяяяюяяЯяяяяяяяяїячяяяяяяяяяяяяяяяяяяяяяяяячяяяяячяэяяЯяяЯяяяяяяяяяпяяяяяяяюяяяяяяяяяяяяяяяяяыяяяыяяяяяяяяячяяяяяяяяяэяяэяяяяяяяяяюяячяяяЯяяяяяяяяяяьїяэяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяїяяюяяяяюяяуяяяяяяяяяяяяяяяюяяяЯяыяяяяяяяїяяяяяяяяяяяяяяяяяяяяяяяяяэяяпяяэяяячяяяяяяяпяяяяяяяяяяяЯяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяя: File name too long
/var/script: line 9: яяяяяяяяяяяыяюяяяяяяэяяяяяяяячяюяяяяяяяяїяяяяwяяяїяяюяяяпячяяяяяяяюяяяяяяяпяяяяяяяяяяяяяяяяяяяяяяяяяяяЯяяяяяяяяяяяяяяяяяюяцяяяяяяяыяяяяяяяяяЇляяяїяяяяяяяПяяяяпяяяяяяяяяяяяяяячяяяяяяяяяяяяяїяЯяяяяяяяяяяяяяяяяяяяяяяяяыяяяяяяяяяяяяяяпяяяяяяяыяяяяяяяяяяяячяяяцяяяяяяяяяяяячяяяяяяяяяячяЯящяяяяяяяяяяяяяяяыяяюяяпэяяяяяяяяюяяяяяяяяяяяяяяяяЯяяяяяяяяяяыяяячяяяячяыяяяяяяяяяяяяяяяяяяяяяЫяэяяяяяяяяяяяїяяяяяяЯяяяяяяяяяяяяяяяячяяюяяїяЯяяяяяяяяяяяяяяяыяыяяяяяяяяяяяяяяяяячяяяяяяяяяяяяяяяяяяяяяяюяюяяїяяяяяяяяяяяяяяяыяяяюяюяэяяэяяяяяяьяяяюяяяяяяяяяяяЇяяяяыяяяюяяяюяяяяяяяяяяяяяяязяяячяяяяїяяюяяяяяяяяяяяяяяяяяяяяяяяыяяяяяяяяяяяяяуяяяяЯяяЯяяяяяяяяяяяяяяяяяяяыяяяЯяЧїяяяяяяяяяяяяяяяяяяяЯяяюяяяяяяяяяяяяяяяяЅячяяяяяяяпяяяяяїяяяяяяяяяяяяяяяяячяяяяяяяЯяяяяяяяяяяяяяяЮяяяяяяяяяяяяяяяяяяяяяяЯяячячяяяяяяяяяэяюяяяпяяяяяяяяяэязяяяяЯяяяяяяяяяяяяяяяяяяяыяыяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяячяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяпяпяяяяяяяяяяяюяяяяяяяяяяяяяяяяяяяяяяяяяяяяыяяяяяяяяяяяячяяяяяяяяяяяяяяяяяяяяячяяяяяяяяяяяяяяяяяяЯяяяяяяяяяяяяяяяяяыяяяяяяэяяяяяяяяяяoяяяэяяяяяяяяяяЯяяЯяoяяяяїяяяпляяяяяэяяяэяяяячяЯяяяяюЯячяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяїяяяяяяяяэяяяыяяяяяяяяяяячяячячяяяяяяяпяяяяяяяяяяяяяяэяяяяяяяяэяяяяяяяяяяяяяюяяяЯяяяяяыяяяяяяяяэяяяяяяяяяяяяяяяяэяяяяяяяяяяяяяяяяяяяяяпяяяяячяяяяЯяяяяяяяяяяяяяяяяяяяяяяяяяяяяюяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяыяHisilicon Media Memory Zone Manager
яяяяяяячяяяяяяяяяяяэяяяяяяюяяяяяяяяяяяюяяяяяяяяяяяяяюяяяяяяяяяяяяяяя?яюяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяячяяїяяяяяяяяюяэяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяпяяяпяяяяяяяыяяяяяяяяяяяяяяяяяяяяяяяяячяяяяяяяЯяяяяяїяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяїяяяяяяяяяяяяячяяяяяяяяяЯэяяяяяяяяяяяяяяяяяяяwяЭяяяяяяяпяяяяяяяяяяюяяяяяяяяяяяяяпяяяяяяяяЯяяяяяяЯяяяяяяяяяяяяяяяяя?яяяяяяяяяяяяя~яяяэяяяюяяяяпїяяяяяяяїяяяяяяяяяяящяяяяяяяяяhi3518_base: module license 'Proprietary' taints kernel.
яяяяяяяяїяяяяяяяDisabling lock debugging due to kernel taint
яяяяяяюяяяяяяяяячяяяяяяяяяячяяяяяяяяяgяяяэяяяяяяяяяяяяяяя·юяяяяяэяяЯяяяHisilicon UMAP device driver interface: v3.00
яяыяяяяяяяяяяпяяяяяяяяяяяяяяяяяяяяяяяїяяяяяяяпяяяяЮяяЯэяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяїяяяяяяяяяяяяячяяяяяяяяяяяяяяяэяяяяяяяяяяяяяяяЯяїяяяяяяяяяпяяяяяяяяяяїяыяяпяяяэяЯячяяяяяяяпяяяюЯяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяяэяяяяяяяяяяяяяыяяяяяяяяяяяяяяЯяяяяяя·яяяяяяяяяяюяяяяяяяяяяяыяяяяяяяяяяяяяяяяячяпяяяяяяяяяяяяя: File name too long
keyboard = 0
pa:85500000, va:c5a00000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load venc.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
Restarting system.
Сообщение iTuneDVR » 31 окт 2017, 17:34
Модули от какой прошивки сейчас загружены во флеш?
Остановить загрузку, потестировать RAM.
Kvintek
Сообщение Kvintek » 01 ноя 2017, 09:56
General_IPC-HX1100_Eng_P_P2P_V2.420.0000.0.R.20150601
и
General_IPC-KW12W_Eng_P_V2.210.0000.0.T.20140328
и еще кучей подобных но разных версий
http://prntscr.com/h4o0sv
результат один
Сообщение iTuneDVR » 02 ноя 2017, 00:44
Все эти дают один результат при обновлении всех модулей?
Конечно , достаточно было с одной прошивкой поработать и не cмешивать....
В данный момент какая именно установлена?
Текущий дамп софтово сделай.
Тест памяти был?
Kvintek
Сообщение Kvintek » 02 ноя 2017, 10:56
пробовал на всех т.к. разных версий.
Установил General_IPC-HX1100_Eng_P_P2P_V2.420.0000.0.R.20150601
Сообщение iTuneDVR » 02 ноя 2017, 21:04
Поглядим
