Oltec hdvr-88avh слет настройки не сбрасывается в завод,
Сообщение hack2003 » 07 ноя 2019, 18:29
Oltec hdvr-88avh слет настройки 2-3 дня все настройки слитают
сбрасывает иногда на китайский интерфейс
лог
U-Boot 2008.10-svn12 (Oct 18 2010 - 16:35:48)
DRAM:  256 MB
Flash: 16 MB
MAC:   00-0C-9F-A0-D8-4F
Press CTRL-C to abort autoboot in u-boot # <INTERRUPT>
u-boot # printenv
bootargs=mem=54M console=ttyAMA0,115200 root=1f01 rootfstype=cramfs mtdparts=physmap-flash.0:640K(boot),3M(romfs),6784K(usr),1536K(web),3200K(custom),128K(logo),1M(mtd) busclk=220000000
bootcmd=lload;xmtest;fload;bootm 0xC1000000
slave_bootcmd=bootm e0300000 e0a00000
bootdelay=1
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.0.0
da=protect off all;tftp 0xC1000000 u-boot.bin.img;flwrite
du=tftp 0xC1000000 user-x.cramfs.img;flwrite
dr=tftp 0xC1000000 romfs-x.cramfs.img;flwrite
dw=tftp 0xC1000000 web-x.cramfs.img;flwrite
dl=tftp 0xC1000000 logo-x.cramfs.img;flwrite
dc=tftp 0xC1000000 custom-x.cramfs.img;flwrite
up=tftp 0xC1000000 update.img;flwrite
tk=fload;tftp 0xC1000000 zImage.img; bootm 0xC1000000
dd=tftp 0xC1000000 mtd-x.jffs2.img;flwrite
ds=tftp 0xC1000000 slvfs-x.cramfs.img;flwrite
ethaddr=00:0c:9f:a0:d8:4f
xmerr=fffffe6f
ver=U-Boot 2008.10-svn12 (Oct 18 2010 - 16:35:48)
Environment size: 982/131068 bytes
u-boot #
u-boot # flinfo
Bank # 1: CFI conformant FLASH (8 x 8)  Size: 16 MB in 128 Sectors
  AMD Standard command set, Manufacturer ID: 0x15, Device ID: 0x00
  Erase timeout: 4096 ms, write timeout: 1 ms
  Buffer write timeout: 3 ms, buffer size: 64 bytes
  Sector Start Addresses:
  80000000        80020000        80040000        80060000        80080000   RO
  800A0000        800C0000        800E0000        80100000        80120000
  80140000        80160000        80180000        801A0000        801C0000
  801E0000        80200000        80220000        80240000        80260000
  80280000        802A0000        802C0000        802E0000        80300000
  80320000        80340000        80360000        80380000        803A0000
  803C0000        803E0000        80400000        80420000        80440000
  80460000        80480000        804A0000        804C0000        804E0000
  80500000        80520000        80540000        80560000        80580000
  805A0000        805C0000        805E0000        80600000        80620000
  80640000        80660000        80680000        806A0000        806C0000
  806E0000        80700000        80720000        80740000        80760000
  80780000        807A0000        807C0000        807E0000        80800000
  80820000        80840000        80860000        80880000        808A0000
  808C0000        808E0000        80900000        80920000        80940000
  80960000        80980000        809A0000        809C0000        809E0000
  80A00000        80A20000        80A40000        80A60000        80A80000
  80AA0000        80AC0000        80AE0000        80B00000        80B20000
  80B40000        80B60000        80B80000        80BA0000        80BC0000
  80BE0000        80C00000        80C20000        80C40000        80C60000
  80C80000        80CA0000        80CC0000        80CE0000        80D00000
  80D20000        80D40000        80D60000        80D80000        80DA0000
  80DC0000        80DE0000        80E00000        80E20000        80E40000
  80E60000        80E80000        80EA0000        80EC0000        80EE0000
  80F00000        80F20000        80F40000        80F60000        80F80000
  80FA0000        80FC0000        80FE0000
u-boot #
tftp 0x80000000 test.bin 0x001000000
загрузка и тишина в консоле не чего не набирается
[code]u-boot # boot
can't find corresponding entry
NVP1114B detect error:ff
NVP1114A detect error:ff
. done
Un-Protected 1 sectors
Erasing Flash...
. done
Erased 1 sectors
Writing to Flash... done
. done
Protected 1 sectors
### boot load complete: 1402204 bytes loaded to 0xc1000000
### SAVE TO c0c00000 !
## Booting kernel from Legacy Image at c1000000 ...
Image Name: linux
Data Size: 1402140 Bytes = 1.3 MB
Load Address: c0c00000
Entry Point: c0c00000
Uncompressing Linux.......................................................................................... done, booting the kernel.
/code]
Re: Oltec hdvr-88avh слет настройки не сбрасывается в завод,
Сообщение iTuneDVR » 07 ноя 2019, 21:19
Вообщем рег хакнут, внутри живность, mtd блок конфига с JFFS2 немного побит, но место есть.
Возможно регом рулят удаленно.
Рутовую фс еще не смотрел, не предмет ссылок на процессы, но выводы уже можно делать
Сообщение iTuneDVR » 07 ноя 2019, 21:27
Вообщем нужно остановить загрузку и зачистить mtd блок.
Ограничить доступ извне к регистратору и контролировать внутри.
Возможно пересобрать блок и отключить телнет, чтобы не беЗпокоил никто, ведь у данной серии 09 вроде бы нет облака.
Сообщение hack2003 » 07 ноя 2019, 21:46
А свежей прошивки нету? Я не могу понять принципа нумерации, серии. Это надо стереть последний мегабайт?
Сообщение iTuneDVR » 07 ноя 2019, 21:51
hack2003 писал(а):А свежей прошивки нету? Я не могу понять принципа нумерации, серии.
Это модель DVR5008L
Прямо суперсвежее с новым функционалом искать не стоит и надеяться, но если и найдется там минимум.
Самое главное очистить содержимое mtd области, закрыть доступ и лучше сделать на текущую пересборку и обновить с закрытым телнетом, чтобы было спокойнее.
hack2003 писал(а):Это надо стереть последний мегабайт?
Да
Сообщение hack2003 » 07 ноя 2019, 22:58
erase 0xF00000 +0x‭FFFFF‬ так ?
Сообщение hack2003 » 08 ноя 2019, 09:34
сделал erase 0x80F00000 +0x100000
как выключить telent
Сообщение hack2003 » 08 ноя 2019, 10:05
затер сбросился в китайский интерфейс , слил дамп MTD стал чище
как это сделать?
дамп прилагаю
Сообщение iTuneDVR » 08 ноя 2019, 12:09
Если сбросился в чинай, то это хорошо.
Погляжу дамп, постараюсь сегодня вечером сделать прошивку для обновления с регистратора или веба.
Пересоберу rootfs и удалив запуск телнета в скриптах.
Сообщение hack2003 » 08 ноя 2019, 13:03
может есть статья , я и сам смогу
