Ростелеком ipc-hdw1230sp в Dahua
madfilin
Re: IPC-HDW1230SP помощь в прошивке
Сообщение madfilin » 16 фев 2022, 14:02
SN и MAC  подтерты
файл вложением 1.txt пишет не верное расширение
hi3516cv300 System startup
U-Boot 2010.06 (Jun 01 2020 - 08:20:12)
SPI Nand(cs 0) ID: 0xc8 0x21 Name:"F50L1G41A"
Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:8bit/512
ECC provided by Flash Memory Controller
SPI Nand total size: 128MB
MMC:
EMMC/MMC/SD controller initialization.
Card did not respond to voltage select!
No EMMC/MMC/SD device found !
Set gpio: 60->0
Set gpio: 0->0
Set gpio: 73->1
Set gpio: 27->1
Set gpio: 72->1
No mmc found
NAND read: device 0 offset 0x200000, size 0x500000
 5242880 bytes read: OK
   Image Name:   Linux-3.18.20
   Data Size:    4766539 Bytes = 4.5 MiB
   Entry Point:  80008000
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Linux version 3.18.20 (root@runner-1uqpbhwg-project-22-concurrent-0) (gcc versio        n 4.9.4 20150629 (prerelease) (Hisilicon_v500_20170615) ) #1 Mon Aug 30 08:04:45        UTC 2021
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
Machine model: Hisilicon Hi3516CV300 DEMO Board
Memory policy: Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: mem=64M console=ttyAMA0,115200 rootfstype=ramfs mtdparts=hi        nand:1024K(boot),1024K(tech),5120K(kernel),16384K(app),-(config) hw_type=405 ubi        .mtd=3,2048
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 57244K/65536K available (4124K kernel code, 190K rwdata, 1100K rodata, 1        908K init, 256K bss, 8292K reserved, 0K highmem)
    fixmap  : 0xffc00000 - 0xffe00000   (2048 kB)
    vmalloc : 0xc4800000 - 0xff000000   ( 936 MB)
    lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0522748   (5226 kB)
      .init : 0xc0523000 - 0xc0700000   (1908 kB)
      .data : 0xc0700000 - 0xc072f980   ( 191 kB)
       .bss : 0xc072f980 - 0xc076fbb8   ( 257 kB)
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:16 nr_irqs:16 16
VIC @c4800000: id 0x00641190, vendor 0x41
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Calibrating delay loop... 398.13 BogoMIPS (lpj=1990656)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Setting up static identity map for 0x803f1040 - 0x803f1098
devtmpfs: initialized
VFP support v0.3: not present
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
12100000.uart: ttyAMA0 at MMIO 0x12100000 (irq = 21, base_baud = 0) is a PL011 r        ev2
console [ttyAMA0] enabled
ssp-pl022 12120000.spi: ARM PL022 driver, device ID: 0x00800022
ssp-pl022 12120000.spi: mapped registers from 0x12120000 to c486c000
Switched to clocksource arm,sp804
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
futex hash table entries: 256 (order: -1, 3072 bytes)
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 111
io scheduler cfq registered
pinctrl-single 12040000.pinmux: 66 pins at pa c48c8000 size 264
pinctrl-single 12040800.pinconf: 76 pins at pa c48ca800 size 304
pl061_gpio 12140000.gpio: PL061 GPIO chip @0x12140000 registered
pl061_gpio 12141000.gpio: PL061 GPIO chip @0x12141000 registered
pl061_gpio 12142000.gpio: PL061 GPIO chip @0x12142000 registered
pl061_gpio 12143000.gpio: PL061 GPIO chip @0x12143000 registered
pl061_gpio 12144000.gpio: PL061 GPIO chip @0x12144000 registered
pl061_gpio 12145000.gpio: PL061 GPIO chip @0x12145000 registered
pl061_gpio 12146000.gpio: PL061 GPIO chip @0x12146000 registered
pl061_gpio 12147000.gpio: PL061 GPIO chip @0x12147000 registered
pl061_gpio 12148000.gpio: PL061 GPIO chip @0x12148000 registered
hisi-sfc hisi_spi_nor.0: unrecognized JEDEC id bytes: ff, c8, 21
hisi-sfc hisi_spi_nor.0: spi nor register fail!
hisi-sfc: probe of hisi_spi_nor.0 failed with error -2
SPI Nand ID Table Version 2.2
nand: device found, Manufacturer ID: 0xc8, Chip ID: 0x21
nand: GD/ESMT F50L1G41A
nand: 128MiB, SLC, page size: 2048
Nand(Auto): OOB:64B ECC:8bit/512
nand:  ECC provided by Flash Memory Controller
5 cmdlinepart partitions found on MTD device hinand
Creating 5 MTD partitions on "hinand":
0x000000000000-0x000000100000 : "boot"
0x000000100000-0x000000200000 : "tech"
0x000000200000-0x000000700000 : "kernel"
0x000000700000-0x000001700000 : "app"
0x000001700000-0x000008000000 : "config"
libphy: hisi_femac_mii_bus: probed
hisi-femac 10050000.ethernet: phy_id=0x001cc816, phy_addr=1, phy_mode=rmii
hisi-femac 10050000.ethernet: using random MAC address 1a:f6:5b:39:af:0b
ehci-platform: EHCI generic platform driver
ehci-platform 10120000.ehci: EHCI Host Controller
ehci-platform 10120000.ehci: new USB bus registered, assigned bus number 1
ehci-platform 10120000.ehci: irq 31, io mem 0x10120000
ehci-platform 10120000.ehci: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: 1 port detected
ohci-platform: OHCI generic platform driver
ohci-platform 10110000.ohci: Generic Platform OHCI controller
ohci-platform 10110000.ohci: new USB bus registered, assigned bus number 2
ohci-platform 10110000.ohci: irq 32, io mem 0x10110000
hub 2-0:1.0: 1 port detected
i2c /dev entries driver
hibvt-i2c 12110000.i2c: hibvt-i2c0@100000hz registered
hibvt-i2c 12112000.i2c: hibvt-i2c1@100000hz registered
himci: mmc host probe
TCP: cubic registered
UBI: attaching mtd3 to ubi0
UBI: scanning is finished
UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling        , reserved 16, need 20
UBI: attached mtd3 (name "app", size 16 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 128, bad PEBs: 0, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 140        1014055
UBI: available PEBs: 0, total reserved PEBs: 128, PEBs reserved for bad PEB hand        ling: 16
UBI: background thread "ubi_bgt0d" started, PID 37
Freeing unused kernel memory: 1908K (c0523000 - c0700000)
            _ _ _ _ _ _ _ _ _ _ _ _
            \  _  _   _  _ _ ___
            / /__/ \ |_/
           / __random: S01udev urandom read with 2 bits of entropy available
   /  -  _ ___
  _ _ _ _/ /  /  \_/  \_ ______
___________\___\__________________
[RCS]: /etc/init.d/S01udev
udev[45]: starting version 167
[RCS]: /etc/init.d/S80network
[RCS]: /etc/init.d/S90hibernate
[RCS]: /etc/init.d/S99custom
UBIFS: static UBI volume - read-only mode
UBIFS: mounted UBI device 0, volume 0, name "app", R/O mode
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/20        48 bytes
UBIFS: FS size: 12443648 bytes (11 MiB, 98 LEBs), journal size 2412544 bytes (2        MiB, 19 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID B8B06ACE-5FAC-4DC0-BC57-DDF38        60A69BB, small LPT model
[00:00:04][VC-SYS-Daemon][VCSDaemonInitializer.cpp:54][INFO]: VC-SYS version v1.        2.6-18-g1857204
[00:00:04][VC-SYS-Daemon][GPIOController.cpp:194][INFO]: Initialized peripherial        s for hw_type=405
[00:00:04][VC-SYS-Daemon][LEDController.cpp:141][INFO]: Setting auto leds preset        . ID = 2
[00:00:04][VC-SYS-Daemon][NetworkController.cpp:751][INFO]: Setting (1) as main        interface. Old main interface is (-1)
yaffs: dev is 32505860 name is "mtdblock4" rw
yaffs: passed flags ""
[09:00:04][FWUPDATER][FWUpdater.cpp:183][INFO]: No files to restore from techjso        n
[00:00:05][VC-SYS-Daemon][GPIOController.cpp:266][ERROR]: Invalid key name wps
mount: mounting /dev/mmcblk0p1 on /mnt/mmc01 failed: No such file or directory
Initializing motor modules
mmz_start: 0x84000000, mmz_size: 192M
2735xxxx
*** Board tools : ver0.0.1_20121120 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x1201002c: 0x00000000 --> 0x0604800D
[END]
sh: can't open 'config_sensor.sh': No such file or directory
Module himedia: init ok
The module param setup_allocator is hisi
hi_osal 1.0 init success!
hi3516cv300_base: module license 'Proprietary' taints kernel.
load sys.ko for Hi3516CV300...OK!
load region.ko for Hi3516CV300...OK!
load vgs.ko for Hi3516CV300...OK!
load viu.ko for Hi3516CV300...OK!
ISP Mod init!
load vpss.ko for Hi3516CV300...OK!
load vou.ko for Hi3516CV300...OK!
load rc.ko ...OK!
load venc.ko ...OK!
load chnl.ko for Hi3516CV300...OK!
load vedu.ko ...OK!
load h264e.ko ...OK!
load h265e.ko ...OK!
load jpege.ko ...OK!
load ive.ko for Hi3516CV300...OK!
load hi_piris.ko OK!
load ai.ko OK!
load ao.ko OK!
load aenc.ko OK!
load adec.ko OK!
load acodec.ko for Hi3516CV300...OK!
insert audio
load hi_mipi driver successful!
Load hi_cipher.ko success.
hirtc init ok. ver=Aug 30 2021, 08:05:07.
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nodeamon= 1)
hiwtdg init ok. ver=Aug 30 2021, 08:05:08.
==== Your input Sensor type is ov2735 ====
[00:00:10][VC-SYS-Daemon][ServerMsgDispatcher.cpp:281][INFO]: Read RTC msg recieved
[RTC_READ]
No upgrade log found.
[09:38:33][Agent-Updater][AgentUpdater.cpp:169][INFO]: Staring agent updater, version v1.1.13-b254554
[09:38:33][Agent-Updater][Tools.cpp:350][INFO]: Detected LZMA invokation type: -cd
[09:38:33][Agent-Updater][AgentUpdater.cpp:2343][INFO]: Read config file /tmp/ag-upd.json
[09:38:33][Agent-Updater][AgentUpdater.cpp:2280][INFO]: Added updater url: 'https://camera-updater.camera.rt.ru/agent/:platform/:env/version.json'
[09:38:33][Agent-Updater][AgentUpdater.cpp:2391][INFO]: [QR MODE] Normal.
I0212 09:38:33.845999   159 LogCache.cc:21] Log cache initialized, size = 500000 bytes
I0212 09:38:33.848958   159 Main.cc:53] Starting VC-HAL, version v2.13.3-b254554 (built on Aug 30 2021 at 08:09:59) ...
[09:38:33][Agent-Updater][AgentUpdater.cpp:215][INFO]: Security props = ''
[09:38:33][Agent-Updater][AgentUpdater.cpp:216][INFO]: Security props.once = ''
[09:38:34][Agent-Updater][AgentUpdater.cpp:2207][INFO]: [TRUSTED CA] Reading '/opt/share/vc/cacert.pem'
[09:38:34][Agent-Updater][AgentUpdater.cpp:2218][INFO]: [TRUSTED CA] Loaded 7 root certificates
[09:38:34][Agent-Updater][EvilConfig.cpp:110][INFO]: SetState (0)
W0212 09:38:34.037372   159 Utils.cc:687] System may be unstable! Counter is 2 of 5
[09:38:34][Agent-Updater][AgentGuard.cpp:32][INFO]: AgentGuard init
[09:38:34][Agent-Updater][AgentGuard.cpp:127][INFO]: Check ag-cfg update: /config/vc/ag-cfg.json - exists; bundled md5=,current md5=57bb90a5eecbb110dc7de89ef3e6a540
[09:38:34][Agent-Updater][AgentGuard.cpp:130][WARNING]: Rewriting ag-cfg
[09:38:34][Agent-Updater][EnvController.cpp:105][INFO]: Syncing agent(prod) and system envs(prod)
[09:38:34][Agent-Updater][AgentUpdater.cpp:2170][INFO]: Checking password. Env = prod
WARNING: Logging before InitGoogleLogging() is written to STDERR
I0212 09:38:34.071058   166 InterConn.cc:606] Connecting to 127.0.0.1:10000
I0212 09:38:34.072329   166 InterConn.cc:722] TcpConn error
[09:38:34][Agent-Updater][HalApi.cpp:243][ERROR]: resetRootPassword() error: checkSocket() failed: Connection refused
E0212 09:38:34.099238   159 Utils.cc:118] GET MAC: No running network interfaces found!
E0212 09:38:34.101191   159 Utils.cc:118] GET MAC: No running network interfaces found!
I0212 09:38:34.210961   159 DevInfo.cc:265] Tech json: {
        "sn":   "xxxxxxxxxxxx",
        "wlan-mac":     "xx:xx:xx:xx:xx:xx",
        "hw-type":      "405",
        "eth-mac":      "xx:xx:xx:xx:xx:xx"
madfilin
Сообщение madfilin » 16 фев 2022, 14:04
остатки log файла
I0212 09:38:34.272259   159 PtzCtrl.cc:66] Pan-Tilt-Zoom is not supported
I0212 09:38:34.273875   159 Keyboard.cc:32] No hardware keyboard present
I0212 09:38:34.295946   159 Resolutions.cc:184] Supported channel resolutions:
I0212 09:38:34.296586   159 Resolutions.cc:216]  1) 1920x1080,  30 fps max --> 1920x1080 [m--] WDR: None
I0212 09:38:34.299136   159 Resolutions.cc:216]  2) 1280x 960,  30 fps max --> 1920x1080 [m--] WDR: None
I0212 09:38:34.300313   159 Resolutions.cc:216]  3) 1280x 720,  30 fps max --> 1920x1080 [m--] WDR: None
I0212 09:38:34.300961   159 Resolutions.cc:216]  4)  640x 480,  30 fps max --> 1920x1080 [ms-] WDR: None
I0212 09:38:34.301519   159 Resolutions.cc:216]  5)  640x 360,  30 fps max --> 1920x1080 [ms-] WDR: None
I0212 09:38:34.302057   159 Resolutions.cc:216]  6)  320x 240,  30 fps max --> 1920x1080 [msx] WDR: None
I0212 09:38:34.311607   159 AutoFocus.cc:163] Focus is 'manual' in settings
I0212 09:38:34.321807   159 Resolutions.cc:254] No channels enabled
I0212 09:38:34.322394   159 Resolutions.cc:280] Selected resolution: 1920x1080, 25 fps, offset (0,0)/[0,0], mode "AUTO/normal", WDR 'None'
I0212 09:38:34.324556   159 VideoInputImpl.cc:1228] VB Pool (re)inited: total size is 14747952 bytes in 15 blocks.
Set gpio: 72->1
Set gpio: 73->1
[09:38:34][VC-SYS-Daemon][ServerMsgDispatcher.cpp:249][INFO]: Apply config msg recieved
[09:38:34][VC-SYS-Daemon][VCSNetworkConfig.cpp:55][INFO]: Reading netwoIPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
rk config for ifaceID = 0
[09:38:34][VC-SYS-Daemon][VCSNetworkConfig.cpp:63][INFO]: Iface name = eth0, isEnabled = 1, DHCP = 1
[09:38:34][VC-SYS-Daemon][VCSNetworkConfig.cpp:55][INFO]: Reading network config for ifaceID = 1
[09:38:34][VC-SYS-Daemon][VCSNetworkConfig.cpp:63][INFO]: Iface name = , isEnabled = 1, DHCP = 1
[09:38:34][VC-SYS-Daemon][VCSWifiConfig.cpp:171][INFO]: No WiFi config found. Trying to parse wpa.conf
[09:38:34][VC-SYS-Daemon][WPASuppConfigHandler.cpp:60][ERROR]: Can't read wpa.conf /config/wpa.conf
[09:38:34][VC-SYS-Daemon][VCSWifiConfig.cpp:192][INFO]: Nothing was found in wpa.conf
[09:38:34][VC-SYS-Daemon][VCSNetworkMonitorConfig.cpp:47][INFO]: Reading network monitor config
[09:38:34][VC-SYS-Daemon][VCSConfigManager.cpp:116][INFO]: Applying network config for 0: eth0
[09:38:34][VC-SYS-Daemon][VCSConfigManager.cpp:116][INFO]: Applying network config for 1:
[09:38:34][VC-SYS-Daemon][VCSConfigManager.cpp:157][INFO]: Applying network monitor state: enabled, host: http://camera-updater.camera.rt.ru/check.json, port: 0
[09:38:34][VC-SYS-Daemon][ServerMsgDispatcher.cpp:257][INFO]: Config applied succesfully
[09:38:34][VC-SYS-Daemon][ServerMsgDispatcher.cpp:67][INFO]: Set iface mode msg recieved. IfaceID = 0, enabled = 1
[09:38:34][VC-SYS-Daemon][ServerMsgDispatcher.cpp:33][INFO]: Set network config msg recieved. IfaceID = 0, useDHCP = 1
[09:38:34][VC-SYS-Daemon][ServerMsgDispatcher.cpp:67][INFO]: Set iface mode msg recieved. IfaceID = 1, enabled = 1
[09:38:34][VC-SYS-Daemon][ServerMsgDispatcher.cpp:33][INFO]: Set network config msg recieved. IfaceID = 1, useDHCP = 1
[09:38:34][VC-SYS-Daemon][ServerMsgDispatcher.cpp:267][INFO]: Set network monitor params msg recieved
[09:38:34][VC-SYS-Daemon][ServerMsgDispatcher.cpp:121][INFO]: Set ntp servers msg recieved
[09:38:34][VC-SYS-Daemon][VCSServer.cpp:134][WARNING]: Can't send data to client
I0212 09:38:34.725561   159 Resolutions.cc:254] No channels enabled
I0212 09:38:34.726210   159 Resolutions.cc:280] Selected resolution: 1920x1080, 25 fps, offset (0,0)/[0,0], mode "AUTO/normal", WDR 'None'
Set gpio: 0->1
I0212 09:38:34.970223   159 IspParams.cc:310] /dev/hi_mipi initialized successfully
I0212 09:38:34.970976   159 IspParams.cc:1340] Loading SNS lib "libsns_ov2735.so"
linear mode
hibvt-i2c 12110000.i2c: wait idle abort!, RIS: 0x611
[09:38:35][VC-SYS-Daemon][ServerMsgDispatcher.cpp:267][INFO]: Set network monitor params msg recieved
I0212 09:38:35.224354   159 VideoInputImpl.cc:288] IMAGE SETTINGS: 1920x1080, 25 fps
I0212 09:38:35.253856   159 InterConn.cc:583] Bound to 127.0.0.1:10000
I0212 09:38:35.255651   159 App.cc:1642] Started watchdog with timeout 60 seconds
[09:38:35][VC-SYS-Daemon][ServerMsgDispatcher.cpp:121][INFO]: Set ntp servers msg recieved
I0212 09:38:36.097616   166 InterConn.cc:606] Connecting to 127.0.0.1:10000
I0212 09:38:36.098255   166 InterConn.cc:699] Tcp connected.
I0212 09:38:36.100939   159 InterConn.cc:723] Accepting conn from 127.0.0.1:56256
I0212 09:38:36.103765   159 App.cc:118] New client #1
I0212 09:38:36.112406   159 App.cc:140] Hello from #1. Version is: v1.1.13-b254554
I0212 09:38:36.112987   159 App.cc:142] Sending HELLO ACK...
I0212 09:38:36.119056   159 App.cc:733] #1 initializing ROOT password
I0212 09:38:36.228389   159 App.cc:1334] #1 init ROOT password result: success
[09:38:36][Agent-Updater][AgentGuard.cpp:202][INFO]: Trying to start agent: /var/AgentGreen/AgentGreen /config/vc/ag-cfg.json
[09:38:36][Agent-Updater][AgentUpdater.cpp:2130][INFO]: Checking saved update notification. Filename = /config/vc/update-notification.json
[09:38:36][Agent-Updater][AgentUpdater.cpp:2137][INFO]: No saved update notification
[09:38:36][Agent-Updater][AgentUpdater.cpp:2577][INFO]: [NEXT UPDATE] Initial delay (14)
[09:38:36][Agent-Updater][AgentUpdater.cpp:2615][INFO]: [NEXT UPDATE] Check is in 14 seconds
[09:38:36][Agent-Updater][EvilConfig.cpp:166][INFO]: [SCAN QR] Reason: Network is not okay
[09:38:36][Agent-Updater][EvilConfig.cpp:110][INFO]: SetState (1)
I0212 09:38:36.240411   159 InterConn.cc:723] Accepting conn from 127.0.0.1:56257
I0212 09:38:36.241099   159 App.cc:118] New client #2
I0212 09:38:36.242059   159 InterConn.cc:836] ProtoConn closed
I0212 09:38:36.242574   159 App.cc:128] Client #1 gone...
I0212 09:38:36.239583   166 InterConn.cc:606] Connecting to 127.0.0.1:10000
I0212 09:38:36.259290   166 InterConn.cc:699] Tcp connected.
I0212 09:38:36.260496   159 App.cc:140] Hello from #2. Version is: v1.1.13-b254554
I0212 09:38:36.261072   159 App.cc:142] Sending HELLO ACK...
I0212 09:38:36.264866   159 App.cc:162] #2 subscribing for QR. Well, OK.
I0212 09:38:36.384919   159 InterConn.cc:723] Accepting conn from 127.0.0.1:56258
I0212 09:38:36.385641   159 App.cc:118] New client #3
I0212 09:38:36.387215   159 InterConn.cc:836] ProtoConn closed
I0212 09:38:36.387792   159 App.cc:128] Client #3 gone...
I0212 09:38:36.397938   194 App.cc:21] Starting...
I0212 09:38:36.465273   194 StateCache.cc:229] state cache loaded from /config/vc/agent-state-cache.json
I0212 09:38:36.500244   194 NetUtils.cc:1290] local: 0.0.0.0 => 127.0.0.1
I0212 09:38:36.501694   194 NetUtils.cc:1104] NEW ADDR: lo idx: 1 mac: 00:00:00:00:00:00 mtu: 65536 ip: 127.0.0.1 mask: 255.0.0.0 IF_OPER_UNKNOWN  IFF_UP IFF_LOOPBACK IFF_RUNNING IFF_LOWER_UP
I0212 09:38:36.528286   194 Agent.cc:132] AgentGreen v2.17.2-b254554. Hardware encryption enabled
I0212 09:38:36.579180   194 HostControl.cc:98] add host id: 0, type: VcHal, host: 127.0.0.1
I0212 09:38:36.631873   159 InterConn.cc:723] Accepting conn from 127.0.0.1:56259
I0212 09:38:36.632658   159 App.cc:118] New client #3
I0212 09:38:36.633486   194 InterConn.cc:660] Connecting to 127.0.0.1:10000
I0212 09:38:36.681516   194 RequestQueue.cc:52] enqueued agent_green::GetChannelIdRequest (queue size = 1)
I0212 09:38:36.711405   194 RequestQueue.cc:52] enqueued agent_green::GetChannelIdRequest (queue size = 2)
I0212 09:38:36.717013   194 RequestQueue.cc:52] enqueued agent_green::GetChannelIdRequest (queue size = 3)
I0212 09:38:36.760648   194 RequestQueue.cc:73] executing agent_green::GetChannelIdRequest
I0212 09:38:36.765738   194 RequestQueue.cc:85] completed agent_green::GetChannelIdRequest (queue size = 2)
I0212 09:38:36.767709   194 RequestQueue.cc:73] executing agent_green::GetChannelIdRequest
I0212 09:38:36.768462   194 RequestQueue.cc:85] completed agent_green::GetChannelIdRequest (queue size = 1)
I0212 09:38:36.769002   194 RequestQueue.cc:73] executing agent_green::GetChannelIdRequest
I0212 09:38:36.778863   194 RequestQueue.cc:85] completed agent_green::GetChannelIdRequest (queue size = 0)
I0212 09:38:36.781189   194 InterConn.cc:769] Tcp connected.
I0212 09:38:36.781745   194 ProtoHal.cc:286] connected
I0212 09:38:36.787284   159 App.cc:140] Hello from #3. Version is: v2.17.2-b254554
I0212 09:38:36.787863   159 App.cc:142] Sending HELLO ACK...
I0212 09:38:36.818626   159 App.cc:306] #3 getting device info
I0212 09:38:36.820652   159 App.cc:1092] #3 get device info result: success
I0212 09:38:36.823531   159 App.cc:299] #3 subscribed for alert notifications
I0212 09:38:36.827556   194 DeviceControlImpl.cc:168] {"agent_platform":"vc-hal","agent_version":"v2.17.2-b254554","boot_version":"","build_platform":"hi3516cv300","encoder_version":"","firmware_version":"v2.13.2-b254554 210830","hardware_version":"","mac":"XX:XX:XX:XX:XX:XX","model":"IPC-HDW1230SP","serial":"XXXXXXXXXXXXX","soft_meta_version":"9.4.0830","vendor":"dahua"}
I0212 09:38:36.836503   159 App.cc:463] #3 getting device caps
I0212 09:38:36.837896   159 App.cc:1199] #3 get device caps result: success
I0212 09:38:36.843068   159 App.cc:316] #3 getting video caps
I0212 09:38:36.844841   159 App.cc:1099] #3 get video caps result: success
I0212 09:38:36.929831   194 RequestQueue.cc:52] enqueued agent_green::SetDeviceNameRequest (queue size = 1)
I0212 09:38:36.942764   194 StorageDeviceKeeper.cc:312] new cleanup params: mode: AUTO, threshold: 95
I0212 09:38:36.947996   197 StorageDeviceKeeper.cc:828] memory card '/dev/mmcblk0' not found
I0212 09:38:36.956032   194 RequestQueue.cc:52] enqueued agent_green::SetTimeSettingsRequest (queue size = 2)
I0212 09:38:36.959491   194 RequestQueue.cc:52] enqueued agent_green::GetEncodingCapabilitiesRequest (queue size = 3)
I0212 09:38:36.960377   194 RequestQueue.cc:52] enqueued agent_green::GetEncodingCapabilitiesRequest (queue size = 4)
I0212 09:38:36.960937   194 RequestQueue.cc:52] enqueued agent_green::GetEncodingCapabilitiesRequest (queue size = 5)
I0212 09:38:36.964820   194 RequestQueue.cc:52] enqueued agent_green::SetPIRDetectorParamsRequest (queue size = 6)
I0212 09:38:36.978571   194 RequestQueue.cc:52] enqueued agent_green::SetMotionDetectorParamsRequest (queue size = 7)
I0212 09:38:36.981575   194 RequestQueue.cc:52] enqueued agent_green::SetIntrusionDetectorParamsRequest (queue size = 8)
I0212 09:38:36.983296   194 RequestQueue.cc:52] enqueued agent_green::SetTamperDetectorParamsRequest (queue size = 9)
I0212 09:38:36.985947   194 RequestQueue.cc:52] enqueued agent_green::SetLineCrossingDetectorParamsRquest (queue size = 10)
I0212 09:38:36.987032   194 RequestQueue.cc:52] enqueued agent_green::SetSoundDetectorParamsRequest (queue size = 11)
I0212 09:38:36.988018   194 RequestQueue.cc:52] enqueued agent_green::SetSpeechDetectorParamsRequest (queue size = 12)
W0212 09:38:37.003882   194 StorageDeviceKeeper.cc:712] UNKNOWN => NOT_FOUND
I0212 09:38:37.022606   194 RequestQueue.cc:73] executing agent_green::SetDeviceNameRequest
I0212 09:38:37.025451   159 App.cc:353] #3 setting camera name: XXXXXXXXXXXX
I0212 09:38:37.026191   159 App.cc:1129] #3 set camera name result: success
I0212 09:38:37.028383   194 RequestQueue.cc:85] completed agent_green::SetDeviceNameRequest (queue size = 11)
I0212 09:38:37.029899   194 RequestQueue.cc:73] executing agent_green::SetTimeSettingsRequest
I0212 09:38:37.033497   159 App.cc:403] #3 setting time settings without time
[09:38:37][VC-SYS-Daemon][ServerMsgDispatcher.cpp:96][INFO]: Set timezone msg recieved. Timezone = -540
I0212 18:38:37.042066   159 App.cc:1157] #3 set time settings result: success
I0212 18:38:37.047484   159 App.cc:423] #3 setting NTP settings
[18:38:37][VC-SYS-Daemon][ServerMsgDispatcher.cpp:121][INFO]: Set ntp servers msg recieved
I0212 18:38:37.059942   159 App.cc:1171] #3 set NTP settings result: success
I0212 18:38:37.062783   194 RequestQueue.cc:85] completed agent_green::SetTimeSettingsRequest (queue size = 10)
I0212 18:38:37.065017   194 RequestQueue.cc:73] executing agent_green::GetEncodingCapabilitiesRequest
I0212 18:38:37.068284   159 App.cc:316] #3 getting video caps
I0212 18:38:37.069088   159 App.cc:1099] #3 get video caps result: success
I0212 18:38:37.086405   159 App.cc:326] #3 getting audio caps
I0212 18:38:37.087900   159 App.cc:1106] #3 get audio caps result: success
E0212 18:38:37.103080   194 SettingsPusher.cc:191] invalid audio schema: {"bitrate":0,"channels":0,"codec":"","samplerate":0}
I0212 18:38:37.105983   194 RequestQueue.cc:52] enqueued agent_green::SetEncodingSchemaRequest (queue size = 11)
I0212 18:38:37.107234   194 RequestQueue.cc:52] enqueued agent_green::SetOverlaySchemaRequest (queue size = 12)
I0212 18:38:37.108840   194 RequestQueue.cc:52] enqueued agent_green::SetAudioInputSettingsRequest (queue size = 13)
I0212 18:38:37.109755   194 RequestQueue.cc:52] enqueued agent_green::SetAudioOutputSettingsRequest (queue size = 14)
I0212 18:38:37.110719   194 RequestQueue.cc:52] enqueued agent_green::SetUpstreamParams (queue size = 15)
I0212 18:38:37.111563   194 RequestQueue.cc:52] enqueued agent_green::SetMicrophoneScheduleRequest (queue size = 16)
I0212 18:38:37.112500   194 RequestQueue.cc:52] enqueued agent_green::SetTransmissionScheduleRequest (queue size = 17)
I0212 18:38:37.113245   194 RequestQueue.cc:52] enqueued agent_green::SetTransmissionSchedulePresetRequest (queue size = 18)
I0212 18:38:37.114089   194 RequestQueue.cc:52] enqueued agent_green::SetRecordingScheduleRequest (queue size = 19)
I0212 18:38:37.114802   194 RequestQueue.cc:52] enqueued agent_green::SetRecordingSchedulePresetRequest (queue size = 20)
I0212 18:38:37.115600   194 RequestQueue.cc:52] enqueued agent_green::SetChannelIdRequest (queue size = 21)
I0212 18:38:37.118742   194 RequestQueue.cc:85] completed agent_green::GetEncodingCapabilitiesRequest (queue size = 20)
I0212 18:38:37.119349   194 RequestQueue.cc:73] executing agent_green::GetEncodingCapabilitiesRequest
I0212 18:38:37.139823   159 App.cc:316] #3 getting video caps
I0212 18:38:37.140640   159 App.cc:1099] #3 get video caps result: success
I0212 18:38:37.145525   159 App.cc:326] #3 getting audio caps
I0212 18:38:37.146157   159 App.cc:1106] #3 get audio caps result: success
I0212 18:38:37.148742   194 RequestQueue.cc:52] enqueued agent_green::SetEncodingSchemaRequest (queue size = 21)
I0212 18:38:37.150214   194 RequestQueue.cc:52] enqueued agent_green::SetOverlaySchemaRequest (queue size = 22)
I0212 18:38:37.151064   194 RequestQueue.cc:52] enqueued agent_green::SetAudioInputSettingsRequest (queue size = 23)
I0212 18:38:37.151788   194 RequestQueue.cc:52] enqueued agent_green::SetAudioOutputSettingsRequest (queue size = 24)
I0212 18:38:37.152621   194 RequestQueue.cc:52] enqueued agent_green::SetUpstreamParams (queue size = 25)
I0212 18:38:37.153427   194 RequestQueue.cc:52] enqueued agent_green::SetMicrophoneScheduleRequest (queue size = 26)
I0212 18:38:37.154217   194 RequestQueue.cc:52] enqueued agent_green::SetTransmissionScheduleRequest (queue size = 27)
I0212 18:38:37.154928   194 RequestQueue.cc:52] enqueued agent_green::SetTransmissionSchedulePresetRequest (queue size = 28)
I0212 18:38:37.155723   194 RequestQueue.cc:52] enqueued agent_green::SetRecordingScheduleRequest (queue size = 29)
I0212 18:38:37.156407   194 RequestQueue.cc:52] enqueued agent_green::SetRecordingSchedulePresetRequest (queue size = 30)
I0212 18:38:37.157148   194 RequestQueue.cc:52] enqueued agent_green::SetChannelIdRequest (queue size = 31)
I0212 18:38:37.157852   194 RequestQueue.cc:85] completed agent_green::GetEncodingCapabilitiesRequest (queue size = 30)
I0212 18:38:37.158394   194 RequestQueue.cc:73] executing agent_green::GetEncodingCapabilitiesRequest
I0212 18:38:37.160125   159 App.cc:316] #3 getting video caps
I0212 18:38:37.160928   159 App.cc:1099] #3 get video caps result: success
I0212 18:38:37.510942   159 App.cc:326] #3 getting audio caps
I0212 18:38:37.511551   159 App.cc:1106] #3 get audio caps result: success
I0212 18:38:37.513805   194 RequestQueue.cc:52] enqueued agent_green::SetEncodingSchemaRequest (queue size = 31)
I0212 18:38:37.514901   194 RequestQueue.cc:52] enqueued agent_green::SetOverlaySchemaRequest (queue size = 32)
I0212 18:38:37.515697   194 RequestQueue.cc:52] enqueued agent_green::SetAudioInputSettingsRequest (queue size = 33)
I0212 18:38:37.516420   194 RequestQueue.cc:52] enqueued agent_green::SetAudioOutputSettingsRequest (queue size = 34)
I0212 18:38:37.517266   194 RequestQueue.cc:52] enqueued agent_green::SetUpstreamParams (queue size = 35)
I0212 18:38:37.518081   194 RequestQueue.cc:52] enqueued agent_green::SetMicrophoneScheduleRequest (queue size = 36)
I0212 18:38:37.518934   194 RequestQueue.cc:52] enqueued agent_green::SetTransmissionScheduleRequest (queue size = 37)
I0212 18:38:37.520016   194 RequestQueue.cc:52] enqueued agent_green::SetTransmissionSchedulePresetRequest (queue size = 38)
I0212 18:38:37.520895   194 RequestQueue.cc:52] enqueued agent_green::SetRecordingScheduleRequest (queue size = 39)
I0212 18:38:37.521605   194 RequestQueue.cc:52] enqueued agent_green::SetRecordingSchedulePresetRequest (queue size = 40)
I0212 18:38:37.522343   194 RequestQueue.cc:52] enqueued agent_green::SetChannelIdRequest (queue size = 41)
I0212 18:38:37.522987   194 RequestQueue.cc:85] completed agent_green::GetEncodingCapabilitiesRequest (queue size = 40)
I0212 18:38:37.523524   194 RequestQueue.cc:73] executing agent_green::SetPIRDetectorParamsRequest
I0212 18:38:37.526796   159 App.cc:289] #3 setting alert settings type 0
I0212 18:38:37.537081   159 App.cc:1048] #3 alert settings result (type 0): success
I0212 18:38:37.539458   194 RequestQueue.cc:85] completed agent_green::SetPIRDetectorParamsRequest (queue size = 39)
I0212 18:38:37.541038   194 RequestQueue.cc:73] executing agent_green::SetMotionDetectorParamsRequest
I0212 18:38:37.550253   159 App.cc:289] #3 setting alert settings type 1
I0212 18:38:37.552543   159 App.cc:1048] #3 alert settings result (type 1): success
I0212 18:38:37.554603   194 RequestQueue.cc:85] completed agent_green::SetMotionDetectorParamsRequest (queue size = 38)
I0212 18:38:37.555389   194 RequestQueue.cc:73] executing agent_green::SetIntrusionDetectorParamsRequest
I0212 18:38:37.557071   159 App.cc:289] #3 setting alert settings type 3
I0212 18:38:37.559331   159 App.cc:1048] #3 alert settings result (type 3): success
I0212 18:38:37.561615   194 RequestQueue.cc:85] completed agent_green::SetIntrusionDetectorParamsRequest (queue size = 37)
I0212 18:38:37.563144   194 RequestQueue.cc:73] executing agent_green::SetTamperDetectorParamsRequest
I0212 18:38:37.564649   159 App.cc:289] #3 setting alert settings type 2
I0212 18:38:37.566751   159 App.cc:1048] #3 alert settings result (type 2): success
I0212 18:38:37.568887   194 RequestQueue.cc:85] completed agent_green::SetTamperDetectorParamsRequest (queue size = 36)
I0212 18:38:37.569780   194 RequestQueue.cc:73] executing agent_green::SetLineCrossingDetectorParamsRquest
I0212 18:38:37.577826   159 App.cc:289] #3 setting alert settings type 4
I0212 18:38:37.580266   159 App.cc:1048] #3 alert settings result (type 4): success
I0212 18:38:37.581674   194 RequestQueue.cc:85] completed agent_green::SetLineCrossingDetectorParamsRquest (queue size = 35)
I0212 18:38:37.582454   194 RequestQueue.cc:73] executing agent_green::SetSoundDetectorParamsRequest
I0212 18:38:37.590078   159 App.cc:289] #3 setting alert settings type 5
I0212 18:38:37.593122   159 App.cc:1048] #3 alert settings result (type 5): success
I0212 18:38:37.594508   194 RequestQueue.cc:85] completed agent_green::SetSoundDetectorParamsRequest (queue size = 34)
I0212 18:38:37.595264   194 RequestQueue.cc:73] executing agent_green::SetSpeechDetectorParamsRequest
I0212 18:38:37.599948   159 App.cc:289] #3 setting alert settings type 9
I0212 18:38:37.602025   159 App.cc:1048] #3 alert settings result (type 9): success
I0212 18:38:37.604940   194 RequestQueue.cc:85] completed agent_green::SetSpeechDetectorParamsRequest (queue size = 33)
I0212 18:38:37.606343   194 RequestQueue.cc:73] executing agent_green::SetEncodingSchemaRequest
I0212 18:38:37.609383   159 App.cc:215] #3 setting video settings for chan 101
I0212 18:38:37.611003   159 VideoInput.cc:90] Video settings for chan 101 haven't changed: ignoring
I0212 18:38:37.616677   159 App.cc:961] #3 set video settings result: success
I0212 18:38:37.618981   194 RequestQueue.cc:85] completed agent_green::SetEncodingSchemaRequest (queue size = 32)
I0212 18:38:37.621659   194 RequestQueue.cc:73] executing agent_green::SetOverlaySchemaRequest
I0212 18:38:37.625336   159 App.cc:269] #3 setting overlay settings for chan 101
I0212 18:38:37.640430   159 App.cc:1031] #3 set overlay settings result: success
I0212 18:38:37.641772   194 RequestQueue.cc:85] completed agent_green::SetOverlaySchemaRequest (queue size = 31)
I0212 18:38:37.644546   194 RequestQueue.cc:73] executing agent_green::SetAudioInputSettingsRequest
I0212 18:38:37.647495   159 App.cc:179] #3 requesting audio settings for chan 101
I0212 18:38:37.649535   159 App.cc:192] #3 setting audio settings for chan 101
I0212 18:38:37.656585   159 AudioInput.cc:66] Audio settings for chan 101 haven't changed: ignoring
I0212 18:38:37.657189   159 App.cc:954] #3 set audio settings result: success
I0212 18:38:37.658473   194 RequestQueue.cc:85] completed agent_green::SetAudioInputSettingsRequest (queue size = 30)
I0212 18:38:37.659209   194 RequestQueue.cc:73] executing agent_green::SetAudioOutputSettingsRequest
I0212 18:38:37.993746   159 App.cc:235] #3 setting audio output settings
I0212 18:38:37.994351   159 AudioOutput.cc:61] Audio output settings haven't changed: ignoring
I0212 18:38:37.994871   159 App.cc:968] #3 set audio output settings result: success
I0212 18:38:37.996170   194 RequestQueue.cc:85] completed agent_green::SetAudioOutputSettingsRequest (queue size = 29)
I0212 18:38:37.996901   194 RequestQueue.cc:73] executing agent_green::SetUpstreamParams
I0212 18:38:38.002388   194 BasicUpstream.cc:64] new upstream params: {"iframe_only":false,"inlet_token":"eyJhbGciOiJIUzI1NiIsImtpZCI6ImRlZmF1bHQiLCJ0eXAiOiJKV1QifQ.eyJjaGFubmVsIjoiNzc4ZTdjZTktY2FhZi00YWVmLThlNDYtMDY5ZDA1MDY1MTc2IiwiZXhwIjoxNjQ0NjU1NTU2fQ.ZjFu4RywgS3YDCkUbxqMbEdFAzLIw3iUWY7NbHyBquU","min_iframe_interval":0,"pub_keys":[],"receivers":[{"host":"inlet.camera.rt.ru","port":19009}]}
I0212 18:38:38.005714   194 RequestQueue.cc:85] completed agent_green::SetUpstreamParams (queue size = 28)
I0212 18:38:38.006456   194 RequestQueue.cc:73] executing agent_green::SetMicrophoneScheduleRequest
I0212 18:38:38.007663   194 RequestQueue.cc:85] completed agent_green::SetMicrophoneScheduleRequest (queue size = 27)
I0212 18:38:38.008380   194 RequestQueue.cc:73] executing agent_green::SetTransmissionScheduleRequest
I0212 18:38:38.008935   194 RequestQueue.cc:85] completed agent_green::SetTransmissionScheduleRequest (queue size = 26)
I0212 18:38:38.009588   194 RequestQueue.cc:73] executing agent_green::SetTransmissionSchedulePresetRequest
I0212 18:38:38.011049   194 RequestQueue.cc:85] completed agent_green::SetTransmissionSchedulePresetRequest (queue size = 25)
I0212 18:38:38.011744   194 RequestQueue.cc:73] executing agent_green::SetRecordingScheduleRequest
I0212 18:38:38.016063   194 RequestQueue.cc:85] completed agent_green::SetRecordingScheduleRequest (queue size = 24)
I0212 18:38:38.016794   194 RequestQueue.cc:73] executing agent_green::SetRecordingSchedulePresetRequest
I0212 18:38:38.017346   194 RequestQueue.cc:85] completed agent_green::SetRecordingSchedulePresetRequest (queue size = 23)
I0212 18:38:38.018827   194 RequestQueue.cc:73] executing agent_green::SetChannelIdRequest
I0212 18:38:38.019419   194 SpifPacketizer.cc:96] channel id for stream "main" set to "778e7ce9-caaf-4aef-8e46-069d05065176"
I0212 18:38:38.030221   194 SpifPacketizer.cc:125] stream info changed: {"channel":"778e7ce9-caaf-4aef-8e46-069d05065176"}
I0212 18:38:38.031836   194 ProtoInput.cc:667] subscribing for video channel 101
I0212 18:38:38.032490   194 ProtoInput.cc:684] subscribing for audio channel 101
I0212 18:38:38.033082   194 RequestQueue.cc:85] completed agent_green::SetChannelIdRequest (queue size = 22)
I0212 18:38:38.035409   194 RequestQueue.cc:73] executing agent_green::SetEncodingSchemaRequest
I0212 18:38:38.036729   159 App.cc:252] #3 subscribed for video chan 101
I0212 18:38:38.037420   159 App.cc:245] #3 subscribed for audio chan 101
E0212 18:38:38.037981   159 AudioInput.cc:314] No audio input present (microphone or line-in)
E0212 18:38:38.038486   159 App.cc:1515] No audio input present (microphone or line-in)
I0212 18:38:38.039222   159 App.cc:179] #3 requesting audio settings for chan 101
E0212 18:38:38.041872   194 ProtoInput.cc:753] subscription for audio channel 101 failed: No audio input present (microphone or line-in)
I0212 18:38:38.043241   159 App.cc:192] #3 setting audio settings for chan 101
I0212 18:38:38.043857   159 AudioInput.cc:66] Audio settings for chan 101 haven't changed: ignoring
I0212 18:38:38.044368   159 App.cc:954] #3 set audio settings result: success
I0212 18:38:38.046500   159 App.cc:215] #3 setting video settings for chan 102
I0212 18:38:38.047080   159 VideoInput.cc:90] Video settings for chan 102 haven't changed: ignoring
I0212 18:38:38.047590   159 App.cc:961] #3 set video settings result: success
I0212 18:38:38.048791   194 RequestQueue.cc:85] completed agent_green::SetEncodingSchemaRequest (queue size = 21)
I0212 18:38:38.049548   194 RequestQueue.cc:73] executing agent_green::SetOverlaySchemaRequest
I0212 18:38:38.051689   159 App.cc:269] #3 setting overlay settings for chan 102
I0212 18:38:38.063539   159 App.cc:1031] #3 set overlay settings result: success
I0212 18:38:38.064920   194 RequestQueue.cc:85] completed agent_green::SetOverlaySchemaRequest (queue size = 20)
I0212 18:38:38.065632   194 RequestQueue.cc:73] executing agent_green::SetAudioInputSettingsRequest
I0212 18:38:38.067059   159 App.cc:179] #3 requesting audio settings for chan 101
I0212 18:38:38.069232   159 App.cc:192] #3 setting audio settings for chan 101
I0212 18:38:38.069979   159 AudioInput.cc:66] Audio settings for chan 101 haven't changed: ignoring
I0212 18:38:38.403235   159 App.cc:954] #3 set audio settings result: success
I0212 18:38:38.406409   194 RequestQueue.cc:85] completed agent_green::SetAudioInputSettingsRequest (queue size = 19)
I0212 18:38:38.407137   194 RequestQueue.cc:73] executing agent_green::SetAudioOutputSettingsRequest
I0212 18:38:38.410894   159 App.cc:235] #3 setting audio output settings
I0212 18:38:38.411469   159 AudioOutput.cc:61] Audio output settings haven't changed: ignoring
I0212 18:38:38.411974   159 App.cc:968] #3 set audio output settings result: success
I0212 18:38:38.416868   194 RequestQueue.cc:85] completed agent_green::SetAudioOutputSettingsRequest (queue size = 18)
I0212 18:38:38.417613   194 RequestQueue.cc:73] executing agent_green::SetUpstreamParams
I0212 18:38:38.418550   194 BasicUpstream.cc:64] new upstream params: {"iframe_only":false,"inlet_token":"","min_iframe_interval":0,"pub_keys":[],"receivers":[]}
W0212 18:38:38.429884   194 BasicUpstream.cc:67] upstream params has no valid address
I0212 18:38:38.430472   194 RequestQueue.cc:85] completed agent_green::SetUpstreamParams (queue size = 17)
I0212 18:38:38.431123   194 RequestQueue.cc:73] executing agent_green::SetMicrophoneScheduleRequest
I0212 18:38:38.431668   194 RequestQueue.cc:85] completed agent_green::SetMicrophoneScheduleRequest (queue size = 16)
I0212 18:38:38.432291   194 RequestQueue.cc:73] executing agent_green::SetTransmissionScheduleRequest
I0212 18:38:38.432832   194 RequestQueue.cc:85] completed agent_green::SetTransmissionScheduleRequest (queue size = 15)
I0212 18:38:38.433435   194 RequestQueue.cc:73] executing agent_green::SetTransmissionSchedulePresetRequest
I0212 18:38:38.433977   194 RequestQueue.cc:85] completed agent_green::SetTransmissionSchedulePresetRequest (queue size = 14)
I0212 18:38:38.434603   194 RequestQueue.cc:73] executing agent_green::SetRecordingScheduleRequest
I0212 18:38:38.435139   194 RequestQueue.cc:85] completed agent_green::SetRecordingScheduleRequest (queue size = 13)
I0212 18:38:38.435775   194 RequestQueue.cc:73] executing agent_green::SetRecordingSchedulePresetRequest
I0212 18:38:38.436314   194 RequestQueue.cc:85] completed agent_green::SetRecordingSchedulePresetRequest (queue size = 12)
I0212 18:38:38.436939   194 RequestQueue.cc:73] executing agent_green::SetChannelIdRequest
I0212 18:38:38.437467   194 RequestQueue.cc:85] completed agent_green::SetChannelIdRequest (queue size = 11)
I0212 18:38:38.438100   194 RequestQueue.cc:73] executing agent_green::SetEncodingSchemaRequest
I0212 18:38:38.439411   159 App.cc:179] #3 requesting audio settings for chan 101
I0212 18:38:38.441727   159 App.cc:192] #3 setting audio settings for chan 101
I0212 18:38:38.442332   159 AudioInput.cc:66] Audio settings for chan 101 haven't changed: ignoring
I0212 18:38:38.442847   159 App.cc:954] #3 set audio settings result: success
I0212 18:38:38.444983   159 App.cc:215] #3 setting video settings for chan 103
I0212 18:38:38.445576   159 VideoInput.cc:90] Video settings for chan 103 haven't changed: ignoring
I0212 18:38:38.446092   159 App.cc:961] #3 set video settings result: success
I0212 18:38:38.447306   194 RequestQueue.cc:85] completed agent_green::SetEncodingSchemaRequest (queue size = 10)
I0212 18:38:38.448055   194 RequestQueue.cc:73] executing agent_green::SetOverlaySchemaRequest
I0212 18:38:38.449888   159 App.cc:269] #3 setting overlay settings for chan 103
I0212 18:38:38.457362   159 App.cc:1031] #3 set overlay settings result: success
I0212 18:38:38.458734   194 RequestQueue.cc:85] completed agent_green::SetOverlaySchemaRequest (queue size = 9)
I0212 18:38:38.459455   194 RequestQueue.cc:73] executing agent_green::SetAudioInputSettingsRequest
I0212 18:38:38.461019   159 App.cc:179] #3 requesting audio settings for chan 101
I0212 18:38:38.463179   159 App.cc:192] #3 setting audio settings for chan 101
I0212 18:38:38.463780   159 AudioInput.cc:66] Audio settings for chan 101 haven't changed: ignoring
I0212 18:38:38.464296   159 App.cc:954] #3 set audio settings result: success
I0212 18:38:38.465559   194 RequestQueue.cc:85] completed agent_green::SetAudioInputSettingsRequest (queue size = 8)
I0212 18:38:38.466316   194 RequestQueue.cc:73] executing agent_green::SetAudioOutputSettingsRequest
I0212 18:38:38.467732   159 App.cc:235] #3 setting audio output settings
I0212 18:38:38.468333   159 AudioOutput.cc:61] Audio output settings haven't changed: ignoring
I0212 18:38:38.468824   159 App.cc:968] #3 set audio output settings result: success
I0212 18:38:38.470180   194 RequestQueue.cc:85] completed agent_green::SetAudioOutputSettingsRequest (queue size = 7)
I0212 18:38:38.803864   194 RequestQueue.cc:73] executing agent_green::SetUpstreamParams
I0212 18:38:38.804950   194 BasicUpstream.cc:64] new upstream params: {"iframe_only":false,"inlet_token":"","min_iframe_interval":0,"pub_keys":[],"receivers":[]}
W0212 18:38:38.805747   194 BasicUpstream.cc:67] upstream params has no valid address
I0212 18:38:38.806205   194 RequestQueue.cc:85] completed agent_green::SetUpstreamParams (queue size = 6)
I0212 18:38:38.806818   194 RequestQueue.cc:73] executing agent_green::SetMicrophoneScheduleRequest
I0212 18:38:38.807353   194 RequestQueue.cc:85] completed agent_green::SetMicrophoneScheduleRequest (queue size = 5)
I0212 18:38:38.807965   194 RequestQueue.cc:73] executing agent_green::SetTransmissionScheduleRequest
I0212 18:38:38.808485   194 RequestQueue.cc:85] completed agent_green::SetTransmissionScheduleRequest (queue size = 4)
I0212 18:38:38.809090   194 RequestQueue.cc:73] executing agent_green::SetTransmissionSchedulePresetRequest
I0212 18:38:38.549985   159 VideoInput.cc:168] VIDEO INPUT CLOSED (will reopen)
I0212 18:38:38.809582   194 RequestQueue.cc:85] completed agent_green::SetTransmissionSchedulePresetRequest (queue size = 3)
I0212 18:38:38.810988   194 RequestQueue.cc:73] executing agent_green::SetRecordingScheduleRequest
I0212 18:38:38.811625   194 RequestQueue.cc:85] completed agent_green::SetRecordingScheduleRequest (queue size = 2)
I0212 18:38:38.812278   194 RequestQueue.cc:73] executing agent_green::SetRecordingSchedulePresetRequest
I0212 18:38:38.812798   194 RequestQueue.cc:85] completed agent_green::SetRecordingSchedulePresetRequest (queue size = 1)
I0212 18:38:38.817060   194 RequestQueue.cc:73] executing agent_green::SetChannelIdRequest
I0212 18:38:38.841979   194 Agent.cc:1407] device status changed: {"is_online":false,"is_standalone":false,"remote_address":"violet.videocomfort.ru:4443","status_change_time":1644658718.841820}
I0212 18:38:38.845542   194 RequestQueue.cc:52] enqueued agent_green::GetChannelIdRequest (queue size = 2)
E0212 18:38:38.866187   194 Discovery.cc:128] setsockopt(IP_ADD_MEMBERSHIP): No such device [19]
I0212 18:38:38.880015   194 RequestQueue.cc:85] completed agent_green::SetChannelIdRequest (queue size = 1)
I0212 18:38:38.880772   194 RequestQueue.cc:73] executing agent_green::GetChannelIdRequest
I0212 18:38:38.882328   194 VioletConn.cc:86] connecting to violet violet.videocomfort.ru:4443
I0212 18:38:38.883224   194 RequestQueue.cc:85] completed agent_green::GetChannelIdRequest (queue size = 0)
E0212 18:38:38.885550   194 VioletConn.cc:322] DNS error: Name or service not known
I0212 18:38:38.886250   194 VioletConn.cc:357] next reconnect in 5 seconds
I0212 18:38:38.887606   194 RequestQueue.cc:52] enqueued agent_green::ToggleDetectorRequest (queue size = 1)
I0212 18:38:38.888203   194 RequestQueue.cc:52] enqueued agent_green::ToggleDetectorRequest (queue size = 2)
I0212 18:38:38.888718   194 RequestQueue.cc:52] enqueued agent_green::ToggleDetectorRequest (queue size = 3)
I0212 18:38:38.889238   194 RequestQueue.cc:52] enqueued agent_green::ToggleDetectorRequest (queue size = 4)
I0212 18:38:38.890024   194 RequestQueue.cc:52] enqueued agent_green::ToggleDetectorRequest (queue size = 5)
I0212 18:38:38.890638   194 RequestQueue.cc:52] enqueued agent_green::ToggleDetectorRequest (queue size = 6)
I0212 18:38:38.891168   194 RequestQueue.cc:52] enqueued agent_green::ToggleDetectorRequest (queue size = 7)
I0212 18:38:38.909893   194 RequestQueue.cc:73] executing agent_green::ToggleDetectorRequest
I0212 18:38:39.170717   159 Resolutions.cc:260] Requested source: 1280x720, 25 fps, WDR 'None'
I0212 18:38:39.171389   159 Resolutions.cc:280] Selected resolution: 1920x1080, 25 fps, offset (0,0)/[0,0], mode "AUTO/normal", WDR 'None'
I0212 18:38:39.172024   159 VideoInputImpl.cc:1228] VB Pool (re)inited: total size is 14010672 bytes in 13 blocks.
I0212 18:38:39.360457   159 IspParams.cc:310] /dev/hi_mipi initialized successfully
I0212 18:38:39.361161   159hibvt-i2c 12110000.i2c: wait idle abort!, RIS: 0x611
linear mode
I0212 18:38:39.545333   159 VideoInputImpl.cc:2065] VIDEO SETTINGS (101): H264 (Main) 1280x720, 1024 kBits/s, GOP size = 125, 25.000 fps, VBR(100)
I0212 18:38:39.605171   159 App.cc:289] #3 setting alert settings type 9
I0212 18:38:39.607369   159 App.cc:1048] #3 alert settings result (type 9): success
I0212 18:38:39.608722   194 ProtoInput.cc:750] subscription for video channel 101 succeeded
I0212 18:38:39.620723   194 DetectorRequest.cc:1589] detector of type "SPEECH" turned OFF
I0212 18:38:39.621251   194 RequestQueue.cc:85] completed agent_green::ToggleDetectorRequest (queue size = 6)
I0212 18:38:39.622871   194 RequestQueue.cc:73] executing agent_green::ToggleDetectorRequest
I0212 18:38:39.640612   159 App.cc:289] #3 setting alert settings type 5
I0212 18:38:39.642848   159 App.cc:1048] #3 alert settings result (type 5): success
I0212 18:38:39.645804   194 ProtoInput.cc:290] onVideoConfig: 101 00000001674d001f963540a00b77fe00020002dc04040500000300010000030032840000000168ee3c80
I0212 18:38:39.654386   194 StreamWatcher.cc:66] video is GOOD!
I0212 18:38:39.656512   194 SpifPacketizer.cc:379] H264 1280x720 1024bps 014d001fffe1001e674d001f963540a00b77fe00020002dc040405000003000100000300328401000468ee3c80
I0212 18:38:39.680248   198 MinuteRecorder.cc:557] STREAM has been received (channel="778e7ce9-caaf-4aef-8e46-069d05065176")
I0212 18:38:39.683491   194 DetectorRequest.cc:1589] detector of type "SOUND" turned OFF
I0212 18:38:39.684114   194 RequestQueue.cc:85] completed agent_green::ToggleDetectorRequest (queue size = 5)
I0212 18:38:39.685174   194 RequestQueue.cc:73] executing agent_green::ToggleDetectorRequest
I0212 18:38:39.687387   159 App.cc:289] #3 setting alert settings type 4
I0212 18:38:39.691545   159 App.cc:1048] #3 alert settings result (type 4): success
I0212 18:38:39.692970   198 MinuteRecorder.cc:586] VIDEO-ES has been received (channel="778e7ce9-caaf-4aef-8e46-069d05065176")
I0212 18:38:39.695436   194 DetectorRequest.cc:1589] detector of type "LINE_CROSSING" turned OFF
I0212 18:38:39.695966   194 RequestQueue.cc:85] completed agent_green::ToggleDetectorRequest (queue size = 4)
I0212 18:38:39.696940   194 RequestQueue.cc:73] executing agent_green::ToggleDetectorRequest
I0212 18:38:39.699128   159 App.cc:289] #3 setting alert settings type 2
I0212 18:38:39.701619   159 App.cc:1048] #3 alert settings result (type 2): success
I0212 18:38:39.703460   194 DetectorRequest.cc:1589] detector of type "TAMPER" turned ON
I0212 18:38:39.703977   194 RequestQueue.cc:85] completed agent_green::ToggleDetectorRequest (queue size = 3)
I0212 18:38:39.704962   194 RequestQueue.cc:73] executing agent_green::ToggleDetectorRequest
I0212 18:38:39.706982   159 App.cc:289] #3 setting alert settings type 3
I0212 18:38:39.709133   159 App.cc:1048] #3 alert settings result (type 3): success
I0212 18:38:39.712862   194 DetectorRequest.cc:1589] detector of type "INTRUSION" turned OFF
I0212 18:38:39.721287   194 RequestQueue.cc:85] completed agent_green::ToggleDetectorRequest (queue size = 2)
I0212 18:38:39.722438   194 RequestQueue.cc:73] executing agent_green::ToggleDetectorRequest
I0212 18:38:39.724588   159 App.cc:289] #3 setting alert settings type 1
I0212 18:38:39.730316   159 App.cc:1048] #3 alert settings result (type 1): success
I0212 18:38:39.731819   194 DetectorRequest.cc:1589] detector of type "MOTION" turned ON
I0212 18:38:39.732340   194 RequestQueue.cc:85] completed agent_green::ToggleDetectorRequest (queue size = 1)
I0212 18:38:39.733343   194 RequestQueue.cc:73] executing agent_green::ToggleDetectorRequest
I0212 18:38:39.740759   159 App.cc:289] #3 setting alert settings type 0
I0212 18:38:39.743968   159 App.cc:1048] #3 alert settings result (type 0): success
I0212 18:38:39.745275   194 DetectorRequest.cc:1589] detector of type "PIR" turned OFF
I0212 18:38:39.745805   194 RequestQueue.cc:85] completed agent_green::ToggleDetectorRequest (queue size = 0)
I0212 18:38:43.562376   159 NightMode.cc:119] NIGHT MODE IS ENABLED
I0212 18:38:44.610458   194 VioletConn.cc:86] connecting to violet violet.videocomfort.ru:4443
E0212 18:38:44.626052   194 VioletConn.cc:322] DNS error: Name or service not known
I0212 18:38:44.627570   194 VioletConn.cc:357] next reconnect in 3 seconds
I0212 18:38:44.773635   159 HalServer.cc:1923] VC-HAL-SETTINGS.JSON saved (camera-name, alert, overlay)
[18:38:46][Agent-Updater][HalApi.cpp:207][ERROR]: scanQrCode() error: Timeout
I0212 18:38:46.262230   159 InterConn.cc:836] ProtoConn closed
I0212 18:38:46.262809   159 App.cc:128] Client #2 gone...
[18:38:46][Agent-Updater][AgentUpdater.cpp:1836][INFO]: Checking network url=http://camera-updater.camera.rt.ru/check.json
[18:38:46][Agent-Updater][AgentUpdater.cpp:1840][ERROR]: Http client error: DNS failed (-6), http code 0
[18:38:46][Agent-Updater][EvilConfig.cpp:110][INFO]: SetState (2)
[18:38:46][Agent-Updater][EvilConfig.cpp:166][INFO]: [SCAN QR] Reason: Network is not okay
[18:38:46][Agent-Updater][EvilConfig.cpp:110][INFO]: SetState (1)
I0212 18:38:46.783577   166 InterConn.cc:606] Connecting to 127.0.0.1:10000
I0212 18:38:46.784174   166 InterConn.cc:699] Tcp connected.
I0212 18:38:46.787009   159 InterConn.cc:723] Accepting conn from 127.0.0.1:56260
I0212 18:38:46.787715   159 App.cc:118] New client #4
I0212 18:38:46.788583   159 App.cc:140] Hello from #4. Version is: v1.1.13-b254554
I0212 18:38:46.789094   159 App.cc:142] Sending HELLO ACK...
I0212 18:38:46.791313   159 App.cc:162] #4 subscribing for QR. Well, OK.
I0212 18:38:48.614430   194 VioletConn.cc:86] connecting to violet violet.videocomfort.ru:4443
E0212 18:38:48.616649   194 VioletConn.cc:322] DNS error: Name or service not known
I0212 18:38:48.617403   194 VioletConn.cc:357] next reconnect in 7 seconds
I0212 18:38:53.570060   159 VideoInput.cc:1043] 101: 13.94/13.96 sec (+0%), 348/349 frm (+0%), unit 3606/3600 (+0%|100%), 842/1024 kbps (82%)
(none) login: I0212 18:38:56.429955   194 VioletConn.cc:86] connecting to violet violet.videocomfort.ru:4443
E0212 18:38:56.432837   194 VioletConn.cc:322] DNS error: Name or service not known
I0212 18:38:56.433569   194 VioletConn.cc:357] next reconnect in 9 seconds
[18:38:56][Agent-Updater][HalApi.cpp:207][ERROR]: scanQrCode() error: Timeout
I0212 18:38:56.814138   159 InterConn.cc:836] ProtoConn closed
I0212 18:38:56.814715   159 App.cc:128] Client #4 gone...
[18:38:57][Agent-Updater][AgentUpdater.cpp:332][INFO]: Checking updates
[18:38:57][Agent-Updater][AgentGuard.cpp:239][INFO]: Read agent version file version.json
I0212 18:38:57.332868   166 InterConn.cc:606] Connecting to 127.0.0.1:10000
I0212 18:38:57.333418   166 InterConn.cc:699] Tcp connected.
I0212 18:38:57.334488   159 InterConn.cc:723] Accepting conn from 127.0.0.1:56261
I0212 18:38:57.335171   159 App.cc:118] New client #4
I0212 18:38:57.335981   159 App.cc:140] Hello from #4. Version is: v1.1.13-b254554
I0212 18:38:57.336500   159 App.cc:142] Sending HELLO ACK...
I0212 18:38:57.338515   159 App.cc:306] #4 getting device info
I0212 18:38:57.344612   159 App.cc:1092] #4 get device info result: success
[18:38:57][Agent-Updater][AgentUpdater.cpp:418][INFO]: [CamInfo] MAC = XX:XX:XX:XX:XX:XX
[18:38:57][Agent-Updater][AgentGuard.cpp:286][INFO]: Read agent config file
I0212 18:38:57.351121   159 InterConn.cc:836] ProtoConn closed
I0212 18:38:57.351707   159 App.cc:128] Client #4 gone...
[18:38:57][Agent-Updater][AgentUpdater.cpp:2155][INFO]: [UTC timestamp] Current UTC offset is 0 seconds
[18:38:57][Agent-Updater][AgentUpdater.cpp:1886][INFO]: soft-meta-version "9.4" (old) == "9.4" (new), or empty, NOT posting update
[18:38:57][Agent-Updater][AgentUpdater.cpp:1916][INFO]: CU: Agent [<none>], Updater [<none>], Firmware [<none>], Meta [<none>]
[18:38:57][Agent-Updater][AgentUpdater.cpp:2308][INFO]: Checking updates https://camera-updater.camera.rt.ru/agent/hi3516cv300-dahua-nand/prod/version.json?ag_version=v2.17.2_hi3516cv300_b2b_b2c_v1.0.49-b254554&fw_branch=v2-13-2&fw_date=210830&fw_env=prod&fw_version=v2.13.2-b254554&mac_address=XX%3AXX%3AXX%3AXX%3AXX%3AXX&model=dahua%20IPC-HDW1230SP&sn=XXXXXXXXXXX&up_version=v1.1.13-b254554
Error: mbedtls_net_connect returned 0
[18:38:57][Agent-Updater][AgentUpdater.cpp:2318][ERROR]: Http client error: DNS failed (-6), http code 0
[18:38:57][Agent-Updater][AgentUpdater.cpp:2586][INFO]: [NEXT UPDATE] failed=1, agent_ok=1, counter=0, max_count=3, network_fail=1, native=0
[18:38:57][Agent-Updater][AgentUpdater.cpp:2590][INFO]: [NEXT UPDATE] Network problem -> small interval (10)
[18:38:57][Agent-Updater][AgentUpdater.cpp:2615][INFO]: [NEXT UPDATE] Check is in 10 seconds
[18:38:57][Agent-Updater][AgentUpdater.cpp:1836][INFO]: Checking network url=http://camera-updater.camera.rt.ru/check.json
[18:38:57][Agent-Updater][AgentUpdater.cpp:1840][ERROR]: Http client error: DNS failed (-6), http code 0
[18:38:57][Agent-Updater][EvilConfig.cpp:166][INFO]: [SCAN QR] Reason: Network is not okay
[18:38:57][Agent-Updater][EvilConfig.cpp:110][INFO]: SetState (1)
I0212 18:38:57.455188   159 InterConn.cc:723] Accepting conn from 127.0.0.1:56263
I0212 18:38:57.455866   159 App.cc:118] New client #4
I0212 18:38:57.456858   166 InterConn.cc:606] Connecting to 127.0.0.1:10000
I0212 18:38:57.457460   166 InterConn.cc:699] Tcp connected.
I0212 18:38:57.458573   159 App.cc:140] Hello from #4. Version is: v1.1.13-b254554
I0212 18:38:57.459141   159 App.cc:142] Sending HELLO ACK...
I0212 18:38:57.466184   159 App.cc:162] #4 subscribing for QR. Well, OK.
I0212 18:39:06.329799   194 VioletConn.cc:86] connecting to violet violet.videocomfort.ru:4443
E0212 18:39:06.340931   194 VioletConn.cc:322] DNS error: Name or service not known
I0212 18:39:06.341706   194 VioletConn.cc:357] next reconnect in 5 seconds
I0212 18:39:07.010682   197 StorageDeviceKeeper.cc:828] memory card '/dev/mmcblk0' not found
[18:39:07][Agent-Updater][HalApi.cpp:207][ERROR]: scanQrCode() error: Timeout
I0212 18:39:07.481626   159 InterConn.cc:836] ProtoConn closed
I0212 18:39:07.482234   159 App.cc:128] Client #4 gone...
[18:39:08][Agent-Updater][AgentUpdater.cpp:332][INFO]: Checking updates
[18:39:08][Agent-Updater][AgentGuard.cpp:239][INFO]: Read agent version file version.json
I0212 18:39:08.011961   159 InterConn.cc:723] Accepting conn from 127.0.0.1:56264
I0212 18:39:08.012688   159 App.cc:118] New client #4
I0212 18:39:08.013496   166 InterConn.cc:606] Connecting to 127.0.0.1:10000
I0212 18:39:08.014127   166 InterConn.cc:699] Tcp connected.
I0212 18:39:08.015293   159 App.cc:140] Hello from #4. Version is: v1.1.13-b254554
I0212 18:39:08.015883   159 App.cc:142] Sending HELLO ACK...
I0212 18:39:08.020758   159 App.cc:306] #4 getting device info
I0212 18:39:08.021549   159 App.cc:1092] #4 get device info result: success
[18:39:08][Agent-Updater][AgentUpdater.cpp:418][INFO]: [CamInfo] MAC = 08:ed:ed:f8:39:ef
[18:39:08][Agent-Updater][AgentGuard.cpp:286][INFO]: Read agent config file
I0212 18:39:08.030337   159 InterConn.cc:836] ProtoConn closed
I0212 18:39:08.030918   159 App.cc:128] Client #4 gone...
[18:39:08][Agent-Updater][AgentUpdater.cpp:2155][INFO]: [UTC timestamp] Current UTC offset is 0 seconds
[18:39:08][Agent-Updater][AgentUpdater.cpp:1886][INFO]: soft-meta-version "9.4" (old) == "9.4" (new), or empty, NOT posting update
[18:39:08][Agent-Updater][AgentUpdater.cpp:1916][INFO]: CU: Agent [<none>], Updater [<none>], Firmware [<none>], Meta [<none>]
[18:39:08][Agent-Updater][AgentUpdater.cpp:2308][INFO]: Checking updates https://camera-updater.camera.rt.ru/agent/hi3516cv300-dahua-nand/prod/version.json?ag_version=v2.17.2_hi3516cv300_b2b_b2c_v1.0.49-b254554&fw_branch=v2-13-2&fw_date=210830&fw_env=prod&fw_version=v2.13.2-b254554&mac_address=XX%3AXX%3AXX%3AXX%3AXX%3AXX&model=dahua%20IPC-HDW1230SP&sn=XXXXXXXXXXXX&up_version=v1.1.13-b254554
Сообщение iTuneDVR » 16 фев 2022, 17:07
Да, это то, что делалось.
madfilin
Сообщение madfilin » 16 фев 2022, 17:36
пока только просмотрено через консоль
еще ничего не напортачил своими (корявыми ручками) решил спросить может кто уже делал
зачем лисапед изобретать
Сообщение iTuneDVR » 16 фев 2022, 22:34
madfilin писал(а):пока только просмотрено через консоль
Тут в том то и дело, что у каждого ласапед свой и как крутить педали на нем, если таковые будут нужно решить самому, изучив материал, а иначе ты продвинешься дальше?
По бумажке сделать и то не просто, а решить самому, сложнее, но интереснее.
Это твой опыт и сам он не наберется, сидя сложа руки ;)
madfilin
Сообщение madfilin » 27 фев 2022, 20:01
не могли бы вы поделится прошивкой или образом на HDW-1230SP
файл через команду tftp (образа) имя файла загружается в память
как сохранить его дальше так и не понял
MMC:
hi3516cv300-vc #
hi3516cv300-vc # tftp update.img
Hisilicon ETH net controler
MAC: xx-xx-xx-xx-xx-xx
eth0 : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M
eth0 : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M
TFTP from server 192.168.1.250; our IP address is 192.168.1.204
Download Filename 'update.img'.
Download to address: 0x80008000
Downloading: #################################################
done
Bytes transferred = 13398568 (cc7228 hex)
hi3516cv300-vc # printenv
bootargs=mem=64M console=ttyAMA0,115200 rootfstype=ramfs mtdparts=hinand:1024K(boot),1024K(tech),5120K(kernel),16384K(app),-(config)
hw_type=405 ubi.mtd=3,2048
bootcmd=hi_gpio $(hi_gpios); fwupdate mmc 0:1 firmware.bin --enable-legacy-fw --with-props; nand read 0x82000000 0x200000 0x500000;
bootm 0x82000000; setenv bootargs $(bootargs) bkp=1; nand read 0x82000000 0x700000 0x500000; bootm 0x82000000
bootdelay=1
hi_gpios=60! 0! 73 27 72
ethaddr=xx:xx:xx:xx:xx:xx
ID=xxxxxxxxxxxx
HWID=IPC-HDW1230sp:01:02:06:4f:25:00:01:00:00:00:00:2d0:00:00:00:00:00:01:00:00:100
devalias=IPC-HDW1230SP
ver=U-Boot 2010.06 (Jun 01 2020 - 08:20:12)
filesize=CC7228
fileaddr=80008000
netmask=255.255.255.0
ipaddr=192.168.1.204
serverip=192.168.1.250
Environment size: 816/131068 bytes
Сообщение iTuneDVR » 28 фев 2022, 13:38
Загрузчик у камер Ростелеком свой и понимает по умолчанию свои шаблоны обновления, но поддерживает общие моменты загрузки данных в память и запись их на флешь.
update.img это специально подготовленный формат обновления для Dahua, который может быть обработан только загрузчиком от Dahua.
Абы что, конечно грузить и записывать не нужно, но если снят образ для возврата к экспериментам, то конечно нужно пробовать ,чтобы получить свой опыт.
madfilin
Сообщение madfilin » 28 фев 2022, 14:57
это понятно вопрос где взять дамп для IPC-HDW1230SP
и надо понять какой HWID у этой камеры
Я готов его залить через программатор
посмотрел CH341APro через NeoProgrammer_2.2.0.10 поддерживает F50L1G41LB думаю F50L1G41A тоже возьмет
для возврата есть еще такие же камеры
за дамп готов заданатить в разумных приделах
Сообщение iTuneDVR » 28 фев 2022, 17:34
madfilin писал(а):за дамп готов заданатить в разумных приделах
Я бы тоже был бы рад не углубляться в тему, не исследовать ничего, а задонатить за готовое решение в разумных пределах, но к сожалению, все пришлось решать самому.
madfilin
Сообщение madfilin » 28 фев 2022, 23:20
Спасибо за вежливый отказ так держать (товарищъ)
Вернуться в «IPC Ростелеком»
