Восcтановление RVI IPC-43s
Re: Восcтановление RVI IPC-43s
Сообщение Kvintek » 19 окт 2017, 16:39
Не нашлось дампа?
Сообщение iTuneDVR » 19 окт 2017, 23:11
По сути он не нужен!
Почти все что нужно есть в прошивке с сайта RVI
http://rvi-cctv.ru/download/download.ph ... z&ID=36946
Group_IPC-HX1X2X-Themis_RusEng_P_V1.002.GP02.1.T.20160913.bin
Помодульно!
Если конечно шильдик на камере не врет!
Сообщение Kvintek » 26 окт 2017, 11:42
Вот что имеем.
Terminal log file
Date: 26.10.2017 - 10:37:15
U-Boot 2010.06-svn3112 (Mar 18 2016 - 16:13:13)
I2C:   ready
DRAM:  110 MiB
gBootLogPtr:00b80008.
spinor flash ID is 0xc81840c8
partition file version 2
rootfstype squashfs root /dev/mtdblock5
TEXT_BASE:01000000
Net:   Detected MACID:40:f4:13:40:63:d7
PHY:0x001cc816,addr:0x00
phy RTL8201 init
Using ambarella mac device
Download to address: 0x5000000
Downloading: *
Try again use backup_serverip
*** ERROR: `serverip' not set
Failed to get info.txt
Fail to get info file!
Init error!
Download to address: 0x2000000
Downloading: *
state:ff,err_count:04
SPI probe: 16384 KiB GD25Q128C at 0:0 is now current device
## Booting kernel from Legacy Image at 02000000 ...
   Image Name:   Linux-3.10.50
   Created:      2016-03-16  12:07:04 UTC
   Data Size:    1506584 Bytes = 1.4 MiB
   Load Address: 00208000
   Entry Point:  00208000
   Loading Kernel Image ...OK
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Linux version 3.10.50 (jenkins@Centos-104) (gcc version 4.9.1 20140625 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2014.06) ) #29 PREEMPT Wed Mar 16 20:06:47 CST 2016
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
Machine: Ambarella S2L (Flattened Device Tree), model: Ambarella S2LM Kiwi Board
 - 200000 ,  6e00000
init gLogRamRes: start=0x6f7e000;size=0x80000
Ambarella:      AHB = 0xe0000000[0xe0000000],0x01000000 0
Ambarella:      APB = 0xe8000000[0xe8000000],0x01000000 0
Ambarella:      PPM = 0x00000000[0xdfe00000],0x00200000 9
Ambarella:      AXI = 0xf0000000[0xf0000000],0x00030000 0
Ambarella:    DRAMC = 0xdffe0000[0xef000000],0x00020000 0
Ambarella:   DBGBUS = 0xec000000[0xec000000],0x00200000 0
Ambarella:   IAVMEM = 0x07000000[          ],0x09000000
CPU: All CPU(s) started in SVC mode.
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 27940
Kernel command line: console=ttyS0,115200 mem=110M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc
Memory: 110MB = 110MB total
Memory: 106924k/106924k available, 5716k reserved, 0K highmem
    vmalloc : 0x87000000 - 0xff000000   (1920 MB)
    lowmem  : 0x80000000 - 0x86e00000   ( 110 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x8038c1d4   (3601 kB)
      .init : 0x8038d000 - 0x803a77e4   ( 106 kB)
      .data : 0x803a8000 - 0x803dd3a0   ( 213 kB)
       .bss : 0x803dd3a0 - 0x804032a0   ( 152 kB)
NR_IRQS:240
sched_clock: 32 bits at 72MHz, resolution 13ns, wraps every 59652ms
console [ttyS0] enabled
Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
Setting up static identity map for 0x802b2788 - 0x802b27d4
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
ambarella-gpio gpio.0: Ambarella GPIO driver registered
ambarella-dma e0005000.dma: Ambarella DMA Engine
Switching to clocksource ambarella-cs-timer
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 208
io scheduler deadline registered
io scheduler cfq registered (default)
e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
core_bus_freq 288000000;get_ssi3_freq_hz 288000000 divider:6 tmp:0xfff81800
flash id not supported
mtd .name = (null), .size = 0x1000000 (16MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
Creating 14 MTD partitions on "(null)":
0x000000000000-0x000000040000 : "MinBoot"
0x0000000c0000-0x0000000e0000 : "hwid"
0x0000000e0000-0x0000000f0000 : "partition"
0x0000000f0000-0x000000270000 : "Kernel"
0x000000270000-0x0000003c0000 : "romfs"
0x0000003c0000-0x0000005d0000 : "web"
0x0000005d0000-0x000000e00000 : "user"
0x000000e00000-0x000000e30000 : "updateflag"
0x000000e30000-0x000000ea0000 : "config"
0x000000ea0000-0x000000eb0000 : "product"
0x000000eb0000-0x000000ed0000 : "custom"
0x000000ed0000-0x000000fb0000 : "backupker"
0x000000fb0000-0x000001000000 : "backupfs"
SPI NOR Controller probed
ambarella-ehci e0018000.ehci: EHCI Host Controller
ambarella-ehci e0018000.ehci: new USB bus registered, assigned bus number 1
ambarella-ehci e0018000.ehci: irq 39, io mem 0xe0018000
ambarella-ehci e0018000.ehci: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.50 ehci_hcd
usb usb1: SerialNumber: AmbUSB
hub 1-0:1.0: 2 ports detected
TCP: bic registered
sit: IPv6 over IPv4 tunneling driver
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
ThumbEE CPU extension supported.
console [netcon0] enabled
netconsole: network logging started
VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
devtmpfs: mounted
Freeing unused kernel memory: 104K (8038d000 - 803a7000)
dh_keyboard:0
libphy: Ambarella MII Bus: probed
ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x001cc816!
ambarella-eth e000e000.ethernet: MAC Address[40:f4:13:40:63:d7].
n Aug 11 2015 at 10:32:30. product=IPC-HF2320R
cp: can't stat '/var/tmp/product/IPC-HF2320R/*': No such file or directory
Default manual len in manual
manual
IPC-HDW1320S
cap_dsp =
d on Aug 11 2015 at 10:32:30.
9 compile time: Sep  6 2016 19:28:00
21:01:02|CFG_prvInit_HFW4320B
0
nputBnd done!
LG Build on May  6 2016 at 14:56:47.
01:03|[AEW]  Get the TypeID is OK! the type ID = 4!
EW] the aew cfg subVer is: 29274.000
330 Initial OK!
nalog can not support mode 0!
3Vout error: vout1-1 docmd[3301] return with -515!
3Vout error: CVBS-0 docmd[42000] return with -515!
1:01:03|[ENC_DRV]    1920x1080P   30   RGB   12bits   16:9   AUTO   rev[0]
1:04|[AmbaVideo] entry AR0330_setFormat device_mode=0x3
296P   20   RGB   12bits   16:9   AUTO   rev[0]
RV] Stream0 max size 2304x1296, max M 1, long ref enablement 0.
76, input 2304x1296.
ewType=0
wType = 0
_filter2_mode:0 stage1-3_enb:1 1 0
>>> gain:168 -273 -219 -152 -213 0 0
>>> shift:9 0 0 0
>>> bias_off:0 0 0 8 8 123 132
no translater for filter 10
init 3A done
loop start now
nsType = 0
nit pa_explore->defFps = 20.000000, mwAeParam.current_vin_fps = 25600000
no translater fordsp_put_cmd(348): ===== DSP CMD Q is full. Wait for next INT!
 filter 10
Warning. Incorrect AlgoMode 0
uence:50000
AEW] restart aew time normal =1150 ms
6Total system load 11664,  maximum 305340 in mode [0].
6S2L chip ID [1], DSP memory bandwidth [372 MB/s], limit [1287 MB/s].
ck
oure buffer 5 max size 0x0.
9|[AEW] get amba vin_mode=30, vin_fps=25600000
main:size 2304x1296, raw:2304x1296, resolution:12
->res.isp_pipeline=2====
over|655): Invalid cover parameter, don't reset cover
di] pLensType = 0
e[../src/alg_isp.c],Line[223] lensType=0
ing for streamId 0x8
6Total system load 11664,  maximum 305340 in mode [4].
6S2L chip ID [1], DSP memory bandwidth [664 MB/s], limit [1287 MB/s].
00
0 Done
1:10|[libencode] Current wdr mode is the same with set mode
sensitivityLevel is 0, c2bEvThr =60.000000, c2bHareThr =85.000000
 = 50, sat = 50, hue = 50, crt = 50
ramType=3
01:12|[AEW] sensitivityLevel is 0, c2bEvThr =60.000000, c2bHareThr =85.000000
|21:01:13|[StreamApp][StreamApp.cpp:18]|INFO [StreamAppComponent] initStreamAppServerComponent
|21:01:13|[StreamApp][QuickMulticast.cpp:17]|INFO [StreamAppComponent] initStreamAppQuickMulticastComponent
|21:01:13|[StreamApp][TsMulticastService.cpp:7]|INFO [StreamAppComponent] initStreamAppTsMulticastServiceComponent
|21:01:13|[StreamApp][TalkbackSvr.cpp:18]|INFO [StreamAppComponent] initStreamAppHttpTalkbackSvrComponent
|21:01:13|[StreamSvr][TransformatBase.cpp:9]|INFO [StreamAppComponent] initStreamSvrParseCreaterComponent
|21:01:13|[StreamApp][DHEncryptLiveStreamSource.cpp:17]|INFO [StreamAppComponent] initStreamAppDHEncryptComponent
ethNum = 1
initOnvifMetaStreamC
ager] debug tid:220 setTelnet interface ok!!!!!!!!,110,Src/Helper/TelnetHelper.cpp
.cpp:141 system has no supportLanguages.
-2014.06.so,0000018f 00100075
[76d15000-76d16000] libc-2.19-2014.06.so,0000018f 00100077
[76d19000-76d7d000] libm-2.19-2014.06.so,0000018f 00000075
[76d84000-76d85000] libm-2.19-2014.06.so,0000018f 00100075
[76d85000-76d86000] libm-2.19-2014.06.so,0000018f 00100077
[76d86000-76e21000] libstdc++.so.6.0.20,0000018f 00000075
[76e28000-76e2c000] libstdc++.so.6.0.20,0000018f 00100075
[76e2c000-76e2e000] libstdc++.so.6.0.20,0000018f 00100077
[76e34000-76e35000] libutils.so,0000018f 00000075
[76e3c000-76e3d000] libutils.so,0000018f 00100077
[76e3d000-76e4f000] libz.so.1.2.8,0000018f 00000075
[76e57000-76e58000] libz.so.1.2.8,0000018f 00100077
[76e58000-76e5d000] librt-2.19-2014.06.so,0000018f 00000075
[76e64000-76e65000] librt-2.19-2014.06.so,0000018f 00100075
[76e65000-76e66000] librt-2.19-2014.06.so,0000018f 0 Recalc !!!
pdc] WARN  : Watch dog will timeout after 2660 ms!
I2C:   ready
DRAM:  110 MiB
TEXT_BASE:01000000
phy RTL8201 init
Downloading: *
Init error!
Downloading: *
state:ff,err_count:05
   Created:      2015-10-22   5:17:43 UTC
   Data Size:    891864 Bytes = 871 KiB
init started: BusyBox v1.18.4 (2015-04-13 15:29:18 CST)
mount: mounting none on /proc/bus/usb failed: No such file or directory
mount: mounting tmpfs on /var failed: Invalid argument
mount: mounting /dev/mtdblock3 on /mnt/custom failed: Invalid argument
mount: mounting /dev/mtdblock4 on /mnt/pd failed: Invalid argument
mount: mounting /dev/mtdblock8 on /mnt/afix/autoFix failed: Invalid argument
mount: mounting /dev/mtdblock9 on /mnt/afix/autoFixBackup failed: Invalid argument
BusyBox v1.18.4 (2015-04-13 15:29:18 CST) built-in shell (ash)
Revision: 9308
/bin/sh: can't access tty; job control turned off
~ # UPGRADED_MSG: Do memlock
Date: 26.10.2017 - 10:39:55
End log file
Сообщение Kvintek » 26 окт 2017, 13:22
все, победил я этого товарищи ))
Сообщение iTuneDVR » 26 окт 2017, 13:41
Сообщение Kvintek » 26 окт 2018, 14:57
И снова здравствуйте ) попалась мне опять 43S
Terminal log file
Date: 26.10.2018 - 13:54:49
U-Boot 2010.06-svn2656 (Oct 22 2015 - 11:37:53)
I2C:   ready
DRAM:  110 MiB
spinor flash ID is 0xc81840c8can't find corresponding entry
fail to resolve
fail to resolve
partition file version 1
TEXT_BASE:01000000
Net:   Detected MACID:40:f4:13:40:62:d0
phy RTL8201 init
state:ff,err_count:03
Downloading: *
Init error!
Downloading: *
SPI probe: 16384 KiB W25Q128FV at 0:0 is now current device
   Created:      2015-10-22   3:56:55 UTC
   Data Size:    1490584 Bytes = 1.4 MiB
fail to resolve
fail to resolve
fail to resolve
Date: 26.10.2018 - 13:55:39
End log file
Сообщение iTuneDVR » 26 окт 2018, 14:58
лог включен?
Сообщение Kvintek » 26 окт 2018, 14:59
Беда похожая, загрузку не остановить, но блин прошел год и я забыл в чем была тогда беда. Да и место работы сменил а там остались все накопленное богатство
Сообщение Kvintek » 26 окт 2018, 15:10
а вот заметил что иногда и вот такое проскакиет
Сообщение iTuneDVR » 27 окт 2018, 02:44
Загрузку все-таки надо остановить и включить логи, да и printenv не помешает выполнить ;)
Вернуться в «IPC RVi»
