Partizan adh-18V не могу стереть
Добавлено: 09 окт 2020, 12:23
Есть исправный дамп, не могу залить и стереть
область 80D00000
hilinux # help
? - alias for 'help'
base - print or set address offset
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
jpgd - decode jpeg picture.
erase - erase FLASH memory
ext2ls - list files in a directory (default /)
fsload - load binary file from a filesystem image
go - start application at address 'addr'
help - print online help
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mii - MII utility commands
mm - memory modify (auto-incrementing)
mtest - simple RAM test
mw - memory write (fill)
nand - NAND sub-system
nboot - boot from NAND device
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
protect - enable or disable FLASH write protection
reset - Perform RESET of the CPU
setenv - set environment variables
setvobg - set vo backgroud color.
- setvobg [dev color]startgx - open graphics layer.
- startgx [layer addr stride x y w h]
startvo - open interface of vo device.
- startvo [dev type sync]stopgx - close graphics layer.
- stopgx [layer]stopvo - close interface of vo device.
- stopvo [dev]tftp - download or upload image via network using TFTP protocol
usb - USB sub-system
usbboot - boot from USB device
hilinux # erase 0x80D00000 0x00200000
Usage:
hilinux # base
Base Address: 0x00000000
hilinux #
hilinux # flinfo
Bank # 1: CFI conformant FLASH (8 x 8) Size: 16 MB in 128 Sectors
AMD Standard command set, Manufacturer ID: 0x15, Device ID: 0x00
Erase timeout: 4096 ms, write timeout: 1 ms
Buffer write timeout: 3 ms, buffer size: 64 bytes
Sector Start Addresses:
80000000 80020000 80040000 80060000 80080000 RO
800A0000 800C0000 800E0000 80100000 80120000
80140000 80160000 80180000 801A0000 801C0000
801E0000 80200000 80220000 80240000 80260000
80280000 802A0000 802C0000 802E0000 80300000
80320000 80340000 80360000 80380000
область 80D00000
hilinux # help
cp - memory copy
md - memory display
Usage:
hilinux # base
hilinux #
hilinux # flinfo
