Partizan adh-18V не могу стереть
Сообщение hack2003 » 09 окт 2020, 12:23
Есть исправный дамп, не могу залить и стереть
область 80D00000
hilinux # help
? - alias for 'help'
base - print or set address offset
bootp - boot image via network using BOOTP/TFTP protocol
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
jpgd - decode jpeg picture.
erase - erase FLASH memory
ext2load- load binary file from a Ext2 filesystem
ext2ls - list files in a directory (default /)
fsload - load binary file from a filesystem image
help - print online help
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mii - MII utility commands
mm - memory modify (auto-incrementing)
mtest - simple RAM test
mw - memory write (fill)
nand - NAND sub-system
nboot - boot from NAND device
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
protect - enable or disable FLASH write protection
setvobg - set vo backgroud color.
- setvobg [dev color]startgx - open graphics layer.
- startgx [layer addr stride x y w h]
startvo - open interface of vo device.
- startvo [dev type sync]stopgx - close graphics layer.
- stopgx [layer]stopvo - close interface of vo device.
- stopvo [dev]tftp - download or upload image via network using TFTP protocol
usb - USB sub-system
hilinux # erase 0x80D00000 0x00200000
Usage:
hilinux # base
Base Address: 0x00000000
hilinux #
hilinux # flinfo
Bank # 1: CFI conformant FLASH (8 x 8) Size: 16 MB in 128 Sectors
AMD Standard command set, Manufacturer ID: 0x15, Device ID: 0x00
Erase timeout: 4096 ms, write timeout: 1 ms
Buffer write timeout: 3 ms, buffer size: 64 bytes
Sector Start Addresses:
80000000 80020000 80040000 80060000 80080000 RO
800A0000 800C0000 800E0000 80100000 80120000
80140000 80160000 80180000 801A0000 801C0000
801E0000 80200000 80220000 80240000 80260000
80280000 802A0000 802C0000 802E0000 80300000
80320000 80340000 80360000 80380000
Re: Partizan adh-18V не могу стереть
Сообщение iTuneDVR » 09 окт 2020, 13:07
Старый видно совсем регистратор.
protect all off
Как-то так.
Сообщение hack2003 » 09 окт 2020, 13:44
я так понимаю это выключить защиту флешки, а с стирать как , или залить tftp дамп и прошить
Сообщение hack2003 » 09 окт 2020, 17:54
стер но нету старта останавливается
protect off 0x80D00000 +0x2FFFFF
erase 0x80D00000 +0x2FFFFF
protect on all
dvr_vd_tw2862[13]: ############# m_chips=2
box_init[67]: pch=1024x768
box_init[90]: VO0: Type = 2, Sync = 8
box_init[67]: pch=AUTO
box_init[90]: VO2: Type = 0, Sync = 0
hifb info: vo max resolution w:1024 h:768
Thu Jan 1 00:00:35 UTC 1970
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 0)
HISI_WDT-MDC030001 @Hi3511v110_OSDrv_1_0_0_8 2009-03-30 10:45:48<6>HISI_WDT-MDC030001 @Hi3511v110_OSDrv_1_0_0_8 2009-03-30 10:45:48
*** Board tools : ver0.0.1_20060106 ***
0x200f00b4: 0x00000000 --> 0x00000001
HISI_IRDA-MF @Hi3515v100R001_C_0_0_0 2010-03-16 10:47:18
hiir: init ok. ver=May 12 2010, 20:29:57.
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
Сообщение iTuneDVR » 09 окт 2020, 19:39
Обратно все протектить не нужно, потому как там есть и области для записи.
Дай снова в загрузчике fli и конечно же полный файл лога.
Сообщение hack2003 » 12 окт 2020, 18:16
Была проблема в одном из питания, но то что там в конфиге куча херни написанно это да.
все заработало
Сообщение iTuneDVR » 12 окт 2020, 21:08
Супер
