После этого уже я пробовал шить ее через tftp всеми доступными прошивками, результат тот же.
Снял лог, во вложении. Ругани там много, после последней строчки камера сама перезагружается.
U-Boot 2010.06-221474 (Sep 09 2016 - 15:09:18)
U-Boot code: 80700000 -> 8070FBE8 BSS: -> 80710610
TI8148-GP rev 3.0
The 2nd stage U-Boot will now be auto-loaded ...
U-Boot 2010.06-221474 (Sep 09 2016 - 15:09:41)
U-Boot code: 80700000 -> 8073E05C BSS: -> 80741F24
ARM clk: 720MHz
DDR clk: 400MHz
DSP clk: 600MHz
IVA clk: 410MHz (HDVICP)
L3/4 clk: 200MHz
ISS clk: 480MHz
DSS clk: 200MHz
DRAM: 1 GiB
NAND: 128 MiB
Net: Detected MACID:a4:14:37:ff:77:88
eth0
Hit Ctrl+u to stop autoboot: 1 0
Trying eth0
link up on port 0, speed 100, full duplex
|RCV UDP pack timeout| not found tftpserver
booting from pri partition...
Copy /nand/uImage to 0x80007fc0... [DONE]
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Linux-2.6.37_DM8127_IPNC_3.00.00
Data Size: 2154804 Bytes = 2.1 MiB
Entry Point: 80008000
get misc tag error,skip it
init started: BusyBox v1.19.3 (2017-05-17 11:22:44 CST)
starting pid 53, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
mtdblock10 is non-existentmount ... OK
diagnose_way = 10, repair_way = 1, interval = 60
cp: can't stat '/devinfo/gamma_table.tar.gz': No such file or directory
cp: 'pppd' and '/home/pppd' are the same file
cp: can't stat 'diald': No such file or directory
cp: can't stat 'chat': No such file or directory
cp: can't stat '/lib/modules/event_notify.ko': No such file or directory
cp: can't stat '/lib/modules/alarm.ko': No such file or directory
tar: can't open 'gamma_table.tar.gz': No such file or directory
8188eu.ko
8192cu.ko
abf_trigger.ko
accl.ko
ak09911.ko
alarm.ko
ap_pwr.ko
base.ko
bd.ko
bldsp.ko
bonding.ko
cmemdrv.ko
compass.ko
cpsw_debug.ko
db171-97.ko
dome_timer.ko
encryption.ko
event_notify.ko
extchip.ko
fpga.ko
gv7700.ko
hdmi.ko
hikcomm.ko
irrc.ko
iscsi_tcp.ko
isp_vd.ko
libiscsi.ko
libiscsi_tcp.ko
looktty.ko
motor.ko
option.ko
rt5370sta.ko
scsi_transport_iscsi.ko
sound.ko
tcs.ko
tgdrv.ko
traffi.ko
uart232.ko
usbserial.ko
usb_wwan.ko
modules.dep
Insmod hikcomm successed!
Insmod cmemdrv successed!
Insmod uart232 successed!
Insmod alarm successed!
Insmod dome_timer successed!
Insmod tcs successed!
modprobe: can't load module accl (/lib/modules/accl.ko): No such device
modprobe: can't load module compass (/lib/modules/compass.ko): No such device
Insmod sound successed!
Press Ctrl-C to stop ...
route: ioctl 0x890c failed: No such process
=====check_config start=====
===main db is ok===
infd read End
Unix bus 0 .
Enter DB_main-------------------
shared memory address is: 0x40343000, sizeof(DEVICECONFIG) = 959832
wait davinci set default...
netprocess Infomation:
version: 5.10.2 [20:30:28-Jul 18 2017]
Path: /Camera/Platform/Trunk/FSP_network_protocol
Last Changed Rev: 299284
Last Changed Date: 2017-07-14 17:00:38 +0800 (Fri, 14 Jul 2017)
[12-28 16:34:38][pid:318][IPC_UNIX][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[12-28 16:34:38][pid:325][IPC_UNIX][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[12-28 16:34:38][pid:325][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[12-28 16:34:38][pid:325][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[12-28 16:34:39][pid:318][IPC_UNIX][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[12-28 16:34:39][pid:325][IPC_UNIX][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[12-28 16:34:39][pid:325][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[12-28 16:34:39][pid:325][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[12-28 16:34:40][pid:318][IPC_UNIX][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[12-28 16:34:40][pid:325][IPC_UNIX][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[12-28 16:34:40][pid:325][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[12-28 16:34:40][pid:325][UNI_IF][ERROR]communicaite_to_davinci failed!!!
App Start ...
[12-28 16:34:41][pid:318][IPC_UNIX][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[12-28 16:34:41][pid:325][IPC_UNIX][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[12-28 16:34:41][pid:325][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[12-28 16:34:41][pid:325][UNI_IF][ERROR]communicaite_to_davinci failed!!!
IEfile uncompressed.
[12-28 16:34:42][pid:318][IPC_UNIX][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[12-28 16:34:42][pid:325][IPC_UNIX][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[12-28 16:34:42][pid:325][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[12-28 16:34:42][pid:325][UNI_IF][ERROR]communicaite_to_davinci failed!!!
starting pid 342, tty '': '-/bin/psh'
BusyBox v1.2.1-273263 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
# [12-28 16:34:43][pid:318][IPC_UNIX][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[12-28 16:34:43][pid:325][IPC_UNIX][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[12-28 16:34:43][pid:325][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[12-28 16:34:43][pid:325][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Bingo errno 2 ,/home/centaurus.lzma /home/centaurus.lzma
Unix bus End
>>>>> user_sysinit()>>>>>
shared memory address is: 0x40660000, sizeof(DEV_CAPABILITY) = 258632
DisplayModel: YES
DeviceModle: DS-2DF7284-AEL
Serial Number: 683206043
Language: English
Tv Standard: PAL
MAC address: a4:14:37:ff:77:88
infrared: YES
AlarmIn number: 7
AlarmOut number:2
bInteligence: NO
SoftVersion: V5.5.0
[12-28 16:34:44][pid:344][OTHER][ERROR]CUSTOM_PATH open error.No such file or directory
[12-28 16:34:44][pid:344][OTHER][ERROR]analysis_custom_devtype error
Probing Hik Cameras on Uart 9600,8,N,1 >>>
hal_getport port init ok
[12-28 16:34:44][pid:318][IPC_UNIX][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[12-28 16:34:44][pid:325][IPC_UNIX][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[12-28 16:34:44][pid:325][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[12-28 16:34:44][pid:325][UNI_IF][ERROR]communicaite_to_davinci failed!!!
hik_probe:[0]hik camera detected,subtype=0x0731
[12-28 16:34:45][pid:318][IPC_UNIX][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[12-28 16:34:45][pid:325][IPC_UNIX][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[12-28 16:34:45][pid:325][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[12-28 16:34:45][pid:325][UNI_IF][ERROR]communicaite_to_davinci failed!!!
HIK ROM VERSION string V3.22.
HIK ROM BUILD string BUILD20141204.
probe:HIK ROM VERSION IS 0x316,compile date is 0xffec04
Camera:HIK DS2ZMD3007BAYER interface:UART_PSEUDO
Camera check complete!
[func_init]sensor_type 0x0, optical_tobe 20
patch_cap_bydev:222a
***********patch_struct_cap-764:8127************
************* patch_seven_inch_2_3 *************
*************** patch_cap_bycamera ***************
*************** patch_camera_cap ***************
*************** patch_cap_3007bayer ***************
*************** patch_camera_common_cap ***************
*************** patch_camera_cap_independ ***************
*************** patch_def_cap_bycamera ***************
*************** patch_camera_def_cap ***************
*************** patch_def_cap_3007bayer ***************
*************** patch_camera_common_def_cap ***************
*************** patch_def_camera_cap_independ ***************
-------Goint to init_database-1640709286
davinci enter init_database
shared memory address is: 0x406b9000, sizeof(DEVICECONFIG) = 959832
davinci init_shared_memory success.
powerLineFrequencyMode = 0
[12-28 16:34:46][pid:344][MOTION][ERROR]motion_clear_pattern mqSend failed
-------pDevCfg->IntelligentCfg.enabled_intelligent_retrieval = 0---------
After set_devcfg_default, database need to init
S: cmd_get_capa_data ,ack 1 --sizeof(ret)= 4
[12-28 16:34:46][pid:324][DATABASE][ERROR][uni_process/DB_uni_process.c 217][get_devcapa_data]communicaite_to_davinci 65574 : service_result 1
going to init database:1
Davinci wait for init dababase
[12-28 16:34:46][pid:324][DATABASE][DEBUG][main/dbutil.c 1726][db_checkandrecovery]db_main check num=0
[12-28 16:34:46][pid:324][DATABASE][DEBUG][main/dbutil.c 1731][db_checkandrecovery]main db is ok
davinci receive cmd_query_davinci_param.
S: cmd_query_davinci_param
[12-28 16:34:46][pid:324][DATABASE][ERROR][main/dbutil.c 8544][init_database]db version = 302848
db_enc_version = 33554432
[12-28 16:34:46][pid:324][DATABASE][DEBUG][main/dbutil.c 6726][db_getdata_byversion]Direct read from the database
S: cmd_check_capa_support ,ack -1
[12-28 16:34:46][pid:324][DATABASE][DEBUG][uni_process/DB_uni_process.c 138][communicaite_to_davinci]communicaite_to_davinci 65566 : service_result 255
S: cmd_check_capa_support ,ack 1
[12-28 16:34:46][pid:324][DATABASE][DEBUG][uni_process/DB_uni_process.c 138][communicaite_to_davinci]communicaite_to_davinci 65566 : service_result 1
[12-28 16:34:46][pid:324][DATABASE][ERROR][main/dbshell.c 12520][db_get_week_list]invalid chan_no(-1) for row_no(30)
[12-28 16:34:46][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[10].get is null
[12-28 16:34:46][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[34].get is null
[12-28 16:34:46][pid:324][DATABASE][ERROR][main/dbshell.c 4372][db_get_local_port]unknown port_type: 5
[12-28 16:34:46][pid:324][DATABASE][ERROR][main/dbshell.c 4617][db_get_local_port_ext]unknown port_type: 5
[12-28 16:34:46][pid:324][STRM_ANLS][ERROR]invalid db_decrypt parameter, src len:0
[12-28 16:34:47][pid:324][STRM_ANLS][ERROR]invalid db_decrypt parameter, src len:0
[12-28 16:34:47][pid:324][DATABASE][DEBUG][main/dbshell.c 20445][db_get_ipdome_ptzparam] ipdome_ptzparam_table is not exist
[12-28 16:34:47][pid:324][DATABASE][DEBUG][main/dbshell.c 17074][db_get_roi_param] roi_param_table is not exist
get 0-0-0-0.000000-0-0-0
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[93].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[94].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[95].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[96].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[97].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[98].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[99].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[100].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[121].get is null
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 592][get_alldata_from_db]tables_fun[122].get is null
[12-28 16:34:47][pid:324][DATABASE][DEBUG][main/dbshell.c 44151][db_get_sdi_local_output_config]select sdi_local_output_enable, local_output_hd from front_other_config where idx=1;
[12-28 16:34:47][pid:324][DATABASE][DEBUG][main/dbshell.c 44291][db_get_sdi_485_enable_config]select * from serial_config_table where serial_type=2;
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbshell.c 43523][db_get_security_config]invalid idx value: 0
decrypted_data--access_key =
decrypted_data--secret_key =
[12-28 16:34:47][pid:324][DATABASE][DEBUG][main/dbshell.c 306][db_get_unknowname_param]gethkpwent success, len:4112
[12-28 16:34:47][pid:324][STRM_ANLS][ERROR]db_decrypt invalid source string length 42, trunc 32
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 585][get_alldata_from_db]device do not support intell monitor
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 575][get_alldata_from_db]device do not support color filter
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 555][get_alldata_from_db]device do not support judicial
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbutil.c 565][get_alldata_from_db]device do not support judicial and prison behavior
[12-28 16:34:47][pid:324][DATABASE][ERROR][main/dbshell.c 67551][db_get_dmesg_record_param_config] ************p_dev_cfg->dmesg_record_param.dmesg_record_logo:0*****************
[12-28 16:34:47][pid:324][DATABASE][DEBUG][main/dbshell.c 67558][db_get_dmesg_record_param_config] ************p_dev_cfg->dmesg_record_param.file_number:0*****************
[12-28 16:34:48][pid:324][STRM_ANLS][ERROR]invalid db_decrypt parameter, src len:0
[12-28 16:34:48][pid:324][DATABASE][DEBUG][main/dbutil.c 1877][add_column]add column net_apn to table lte_4g_param
[12-28 16:34:48][pid:324][DATABASE][DEBUG][main/dbutil.c 1882][add_column]column net_apn already exists in table lte_4g_param
[12-28 16:34:48][pid:324][DATABASE][ERROR][main/dbutil.c 8554][init_database]ipc_db_backup need backup.
[12-28 16:34:48][pid:324][DATABASE][DEBUG][main/DB_main.c 158][main]After init_database...
goint to set_semvalue 1...
This is database process, table_name = 302848,load_type = 0x7001f
channel_no = 0, sensor_no = 0, smd_type = 0, scene_no = 0
EN_GET_OLD_DB_VERSION----
current_db_version = 302848, old_db_version = 302848
current_db_version = (302848-1183), old_db_version = (302848-1183)
database init success, davinci wait sem success
init_database success...
-------end to init_database-1640709288
This is database process, table_name = 0,load_type = 0x7001d
channel_no = 959832, sensor_no = 0, smd_type = 0, scene_no = 0
EN_CHECK_DEVCFG_THE_SAME----
reboot reason is not valid, do nothing
<init_run>5212:capture_mode(17) value. 125967385
<adapt_encoder_param>max_stream_id: [3]
*************** patch_dynamic_cap_bydev ***************
---------------------This is backup_dev_cfg-------------------
database going to sleep----------
######devType=8746
[12-28 16:34:48][pid:344][HW_IF][ERROR]<INIT485>:x=9,maxBaudIdx=15,/dev/uart1
*************baudrate(9600), data(3), stop(0), parity(0), flowcontrol(0)
[12-28 16:34:48][pid:344][RTC][ERROR]rtc = 1640709289 s, sys = 1640709288 s 902999 us, timeUs = -97001 us!
[12-28 16:34:49][pid:344][RTC][ERROR]stime OK, 1640709289 s!
fpgaCapa.beuse is 0, not use fgpa
------------------enter init_isp_frontd_lib-------------
------------------exit init_isp_frontd_lib-------------
[lib][0]cmemFd=17,Invalid argument
[lib][0]AllocShareBuf: idx=0,phyAddr=0xbfc00000,vaddr=0x407a6000,size=0x411000
[lib][0]AllocShareBuf: idx=1,phyAddr=0x55020000,vaddr=0x40c21000,size=0x40000
[lib][0]AllocShareBuf: idx=2,phyAddr=0x40800000,vaddr=0x40ce6000,size=0x40000
[lib][0]AllocShareBuf: idx=3,phyAddr=0x48010000,vaddr=0x40039000,size=0x1000
[lib][0]AllocShareBuf: idx=4,phyAddr=0x89600000,vaddr=0x40d26000,size=0xa00000
[lib][0]AllocShareBuf: idx=5,phyAddr=0x88b00000,vaddr=0x41727000,size=0x500000
[lib][0]AllocShareBuf: idx=6,phyAddr=0x88300000,vaddr=0x41d06000,size=0x500000
[lib][0]AllocShareBuf: idx=7,phyAddr=0xbf400000,vaddr=0x42245000,size=0x800000
[lib][0]AllocShareBuf: idx=8,phyAddr=0x48000000,vaddr=0x42b1c000,size=0x200000
[lib][0]AllocShareBuf: idx=9,phyAddr=0xbf000000,vaddr=0x42d5f000,size=0x400000
[lib][0]AllocShareBuf: idx=10,phyAddr=0xaf000000,vaddr=0x43247000,size=0x3000000
[lib][0]AllocShareBuf: idx=11,phyAddr=0xb2000000,vaddr=0x46276000,size=0x2000000
[lib][0]AllocShareBuf: idx=12,phyAddr=0xb4000000,vaddr=0x48322000,size=0x7000000
[lib][0]AllocShareBuf: idx=13,phyAddr=0x92000000,vaddr=0x4f414000,size=0x13a00000
[lib][0]AllocShareBuf: idx=14,phyAddr=0xad000000,vaddr=0x62e29000,size=0x2000000
[lib][0]AllocShareBuf: idx=15,phyAddr=0xa7000000,vaddr=0x64ea1000,size=0x4000000
[lib][0]AllocShareBuf: idx=16,phyAddr=0xbb000000,vaddr=0x68eda000,size=0x1400000
[lib][0]AllocShareBuf: idx=17,phyAddr=0xa5a00000,vaddr=0x6a3cf000,size=0x1600000
[lib][46118]###################### armShareInfo init #############################
[lib][46118]###################### armShareInfo initdone pa=0xa7000000 va=0x64ea1000 #############################
Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=100, WM Cycles=2000]
[lib][46118]share pDspInitPara=0x407a6000,pAllSharePara=0x40859800
[lib][46118]Netra to host share virt address.......407a6000
@@@@@@@@@@@@@g_pdsp->dspFunctionType [48a]
update_audio_encnde_param
update_voice_talk_param
start_dsp 1
[1;40;33mJul 28 2017 15:17:37 ==>start_dsp(689): start CORE_C674 !!!! ret=0
[m[lib][47408]pDspInitPara->timeStamp = 47408davinci receive cmd_query_davinci_param.
[1;40;33mJul 28 2017 15:17:37 ==>start_dsp(699): start CORE_VID !!!! ret=0
[mdavinci receive cmd_query_davinci_param.
[1;40;33mJul 28 2017 15:17:37 ==>start_dsp(704): start CORE_VPS !!!! ret=0
[m[lib][51598]InitTskDbgAddr: phy=40802180, virt=40ce8180, data=00000005 00000001 00000015 000ce800
[lib][51598]InitTskDbgAddr: phy=55026000, virt=40c27000, data=00000014 00000009 0000002e 00036000
[lib][51598]InitTskDbgAddr: phy=5502de00, virt=40c2ee00, data=00000005 00000001 00000006 00003e00
[lib][51598]dspFunctionType=0x48a
[lib][51600]Arm_InitAudFilter
AllocShareMem base phyAddr=bb000000, endAddr=bc400000
[lib][51600]Arm_cmdRegister : cmdIdx = 709
[lib][51600]Arm_cmdRegister : cmdIdx = 710
[lib][51600]Arm_cmdRegister : cmdIdx = 711
[lib][51600]Arm_cmdRegister : cmdIdx = 712
[lib][51600]Arm_cmdRegister : cmdIdx = 713
[lib][51600]Arm_cmdRegister : cmdIdx = 715
[lib][51600]Arm_InitAudFilter Success!!!
[lib][51600]START init VOLUME
[lib][51600]Arm_cmdRegister : cmdIdx = 120
[lib][51600]START init VOLUME OK!!!
[lib][51600]Arm_cmdRegister : cmdIdx = 732
[lib][51600]start Arm_initVcr+Arm_initVtr+Arm_initVlr !!!!
start_dsp 2
[lib][51602]@@@@@@@@@ getVirtAddr error!!!, phyAddr=0 @@@@@@@@
[lib][51603]@@@@@@@@@ getVirtAddr error!!!, phyAddr=0 @@@@@@@@
[12-28 16:34:54][pid:344][ISP_FRONT][ERROR]do not support LDC correction:0x10a.
@@@@@@@@@@@@@@@fileSize = 800
3dnf filename=/home/isp_conf/3dnf/3dnf_3007_b_0_cfg.bin
@@@@@@@@@@@@@@@fileSize = 329
3dnf filename=/home/isp_conf/3dnf/3dnf_3007_a_0_cfg.bin
cc gama filename=/home/isp_conf/cc/gamma_0.txt
cc gama filename=/home/isp_conf/cc/gamma_1.txt
cc gama filename=/home/isp_conf/cc/gamma_2.txt
cc gama filename=/home/isp_conf/cc/gamma_3.txt
cc gama filename=/home/isp_conf/cc/gamma_4.txt
cc gama filename=/home/isp_conf/cc/gamma_5.txt
cc gama filename=/home/isp_conf/cc/gamma_6.txt
cc gama filename=/home/isp_conf/cc/gamma_7.txt
cc gama filename=/home/isp_conf/cc/gamma_8.txt
cc gama filename=/home/isp_conf/cc/gamma_9.txt
cc gama filename=/home/isp_conf/cc/gamma_10.txt
ee table filename=/home/isp_conf/ee/EE_Table0.txt
ee table filename=/home/isp_conf/ee/EE_Table1.txt
ispconfig filename=/home/isp_conf/sensor/isp_3007_0_cfg.bin
[load_isp_config_table_frontd] ret0.
awbconfig filename=/home/isp_conf/awb/awb_3007_0_cfg.bin
[load_awb_config_table_frontd] ret0.
gbce config filename=/home/isp_conf/gbce/gbce_0.dat
[load_gbce_config_table_frontd] ret0.
[12-28 16:34:54][pid:344][DSP][ERROR]file_name :/home/ASC16 file_len 1349
[12-28 16:34:54][pid:344][DSP][ERROR]file_name :/home/GBK file_len 457196
[12-28 16:34:54][pid:344][DSP][ERROR]file_name :/home/HZK24 file_len 921005
[12-28 16:34:54][pid:344][DSP][ERROR]file_name :/home/ASC24 file_len 3004
[lib][51968]@@@@@@@@@ getVirtAddr error!!!, phyAddr=0 @@@@@@@@
[12-28 16:34:54][pid:344][DSP][ERROR]fontShareInfo is not ready
[12-28 16:34:54][pid:344][DSP][ERROR]file_name :GBK file_len 457196
[12-28 16:34:54][pid:344][DSP][ERROR]copy_data_to_dsp OK.
FIRST_CHAN_NO, DEVCHK_SW_CAPA, SW_ITC_SUP
nothing
[12-28 16:34:54][pid:344][DSP][ERROR]Initial: the permanent code is disable.
hwif_init_dsp over
[VOL_DBG][52038]set sound level!
[VOL_DBG][52038]get codec id 0
[VOL_DBG][52038]CalculateInputGain.Code id 0, input_mode 1, input_volume 0, mic_vol 0 db, dig_vol 0x0, out_volume 80, out_vol 29
[VOL_DBG][52039]codec_id=0, set volume ok!
[12-28 16:34:55][pid:344][DSP][ERROR]HOST_CMD_SET_SOUND_LEVEL 0
[VOL_DBG][52068]set sound level!
[VOL_DBG][52068]get codec id 0
[VOL_DBG][52068]CalculateInputGain.Code id 0, input_mode 1, input_volume 50, mic_vol 0 db, dig_vol 0x9e, out_volume 80, out_vol 29
[VOL_DBG][52069]codec_id=0, set volume ok!
[12-28 16:34:55][pid:344][DSP][ERROR]hwif_dsp_set_audio_volume : [50] status[0]
[12-28 16:34:55][pid:344][DSP][ERROR]audioin_volume : [50]
This is database process, table_name = 0,load_type = 0x70032
[getDisplayBuffer]dataPAddr=b2d8b500, dataVAddr=47001500, net_osd_buffer=0x47001500
[getDisplayBuffer]get osd buf NO.0, virtaul addr:0x4700ba00
Init Menu OSD SUCCESS!
[getDisplayBuffer]get osd buf NO.1, virtaul addr:0x470b1500
Init osd status success!
Init OSD MENU AND DISPLAY OK.
*******************************ret 0, Interrupted system call
[PSWD][0071]:public_base64_len 188 len 140
front_task_dep_func_callback_init OK!
front_task_enable_init OK!
[core_task_send] started!
[func_task_receive] started!
[1;31m get mem since block:0 Total:4 [0m
Init_pool_data:[1;35m0x64ea1000[0m
[12-28 16:34:55][pid:344][OTHER][ERROR]del_gateway ioctl error and errno=3
[12-28 16:34:56][pid:325][UNI_IF][ERROR]
===Davinci Init Finish...
This is database process, table_name = 0,load_type = 0x71026
S: cmd_get_enable_list
[12-28 16:34:56][pid:325][STRM_ANLS][ERROR]invalid db_decrypt parameter, src len:0
isDm365WifiIPCAM=0 is_support_softap = 0
[12-28 16:34:57][pid:344][HW_IF][ERROR]Set HAL_SET_PHYSTATE_DETECT Success!
--------------usrapp:maxEnChanNo = 1 ----------------
[12-28 16:34:57][pid:344][SYSLOG][ERROR]no main log. system log will not work.
[12-28 16:34:57][pid:344][OTHER][ERROR]systerm error, not find thisfunc system_log_module_init
[12-28 16:34:57][pid:344][SYSINIT][ERROR]system_log_module_init failed, ret = -401.
[12-28 16:34:57][pid:344][SD][ERROR]do not support
[12-28 16:34:57][pid:344][SD][ERROR]it's time to set_sd_status_for_alarm !
=====>start wait.
optical 20.
=====>exec ok.
=====>start wait over.
[12-28 16:34:58][pid:344][SENSOR][ERROR]COMMAND 125==CAM_COMMAND_CAMERA_STATE_INQ. not executable.
=====>start wait.
check if need upgrade motor mcu.
[12-28 16:34:58][pid:344][UNI_IF][ERROR]
########motor app only one,no need select !!!########
part_no = 0 ,mcutype = 0,bootParms.Dome.dwDomeVersion = 0,bootParms.Dome.bViolenceProtectType = 0,filename = /dav0/MOTOR_APP =====>exec ok.
plat addr:0xea10.a:8010a10,b:8002000
plat:0x1.
ver not same mcu:160429,motor_app:170623.
or plat not same mcu:1,motor_app:1.
need up motor,bin file name:D_R3_100VB.bin,size:122336,offset:108.
[12-28 16:34:59][pid:344][UNI_IF][ERROR]direct return(ptzCommand:21)(1)(0)
[12-28 16:34:59][pid:344][UNI_IF][ERROR]direct return(ptzCommand:22)(1)(0)
До прошивки камера была в рабочем состоянии, на железо грешить не приходится.
Куда копать?
