Checking DDR......OK
UBL Version: 1.43t(DM368 12/25/2012)
Oscillator: 24MHZ
ARM Rate: 270 MHZ
DDR Rate: 216 MHZ
start watchdog
BootMode: SPI
Starting SPI Memory Copy...
DONE
U-Boot 1.3.6 (jerry) (Jan 8 2013 - 14:50:52)
DRAM: 128 MB
SF: Got idcode 01 20 18
SF: Detected S25FL128P with page size 256, total 16 MB
Ethernet PHY: GENERIC
total gio 2
gio[22]=1
gio[25]=1
Loading...
Filename 'upgrade_info_7db780a713a4.txt'.
Load address: 0x80100000
Loading:
Retry count exceeded.
Failed to get info.txt
==>use default images
## Booting kernel from Legacy Image at 80800000 ...
Image Name: Linux-2.6.18_pro500-davinci_evm-
Data Size: 1926860 Bytes = 1.8 MB
Entry Point: 80008000
Uncompressing Linux............................................................................................................................... done, booting the kernel.
Подскажи что дальше хочу сделать полный дамп всей прошивки консоль больше не реагирует?
