Восстановление IPC-HFW1100SP
killeo
Сообщение killeo » 11 мар 2016, 13:04
Прошу помощи.
IPC-HFW1100SP
Перезагружается.
rs232->tftp->(прошивка HFW11XX(с польского FTP))-> OK -> reboot
перезагружается на том-же месте
rs232->tftp->(прошивка HFW11XX по отдельности 12 файлов .img (найдена у братьев итальянцев))
run up
run da
run ... т.д., как написано в printenv
-> OK -> reboot
тоже самое.
U-Boot 2010.06-svn2134 (May 26 2014 -16:15:03)
DRAM: 256MiB
Check spi flash controller v 350... Found
Spi(cs1):Block:64KB Chip:16MB Name:"MX25L128XX"
boot from spi
partition file version 2
rootfstype squashfs root /dev/mtdblock7
TEXT_BASE:81000000
        Hisilicon ETH net controler
MAC:   90-02-A9-44-C6-C4
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending thro1
Download to address: 0x84000000
Downloading: *
Fail to get info file!
Init error!
miiphy_register: non unique device name '0:1'
UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M
Downloading: *
   Image Name:   Linux-3.0.8
   Data Size:    1337924 Bytes = 1.3 MiB
   Entry Point:  80008000
   Loading Kernel Image ...OK
cmdLine mem=85M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
Linux version 3.0.8 (huang_zhendi@localhost.localdomain) (gcc version 4.4.1 (Hi4
Machine: hi3518
ethaddr0=90:2:a9:44:c6:c4
ethaddr1=0:0:0:0:0:0
wifiAddr=0:0:0:0:0:0
lip0=192.168.1.108
lip1=0.0.0.0
id=TZC4CU029W00086
U-Boot 0x40000 0x80000 0x0
hwid 0x40000 0xc0000 0x0
custom 0x20000 0x140000 0x0
product 0x20000 0x160000 0x0
Kernel 0x160000 0x180000 0x0
web 0x220000 0x2e0000 0x0
romfs 0x1a0000 0x500000 0x0
user 0x840000 0x6a0000 0x0
syslog 0x60000 0xee0000 0x0
config 0x60000 0xf40000 0x0
backup 0x60000 0xfa0000 0x0
num parts is 12.
Ignoring unrecognised tag 0x54410011
AXI bus clock 220000000.
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 21590
Kernel command line: mem=85M console=ttyS0,115200 root=/dev/mtdblock7 rootfstyp
dh_keyboard:0
Memory: 85MB = 85MB total
Memory: 82548k/82548k available, 4492k reserved, 0K highmem
    vmalloc : 0xc5800000 - 0xfe000000   ( 904 MB)
    lowmem  : 0xc0000000 - 0xc5500000   (  85 MB)
      .init : 0xc0008000 - 0xc0020000   (  96 kB)
      .text : 0xc0020000 - 0xc035d000   (3316 kB)
      .data : 0xc035e000 - 0xc03782e0   ( 105 kB)
       .bss : 0xc0378304 - 0xc038f758   (  94 kB)
NR_IRQS:32 nr_irqs:32 32
devtmpfs: initialized
console [ttyS0] enabled
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 161
Spi id table Version 1.22
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 0x16777216
chip num: 1
0x0000006a0000-0x000000ee0000 : "user"
0x000000ee0000-0x000000f40000 : "syslog"
Fixed MDIO Bus: probed
himii: probed
hub 1-0:1.0: 1 port detected
hub 2-0:1.0: 1 port detected
TCP bic registered
�VFS: Mounted root (squashfs filesystem) readonly on device 31:7.
devtmpfs: mounted
Freeing init memory: 96K
proc_file_read: Apparent buffer overflow!
.'��ѕ����������ѕ��quoted string
keyboard = 0
pa:85500000, va:c5a00000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
[OSA-DRV] OSA Build on Nov 27 2014 at 13:41:35.
[OSA-DRV] SVN NUM: 3047.
[OSA-DRV] Monitor    Task   pid=474   tid=474
[LOG-DRV] LOG Build on Mar  5 2014 at 17:06:42.
[LOG-DRV] SVN NUM: 5356.
[LOG-DRV] ramStart:0x0;ramSize:0x0;select:0
00:00:04|[Binder] Binder.ko Build on Sep  3 2013 at 10:07:04.
00:00:04|[Binder] SVN NUM: 1366.
00:00:04|[Binder] Create binder memory pool(size:524288) OK!
00:00:04|[Binder] Create binder memory pool(size:3145728) OK!
00:00:04|[Binder] NameServer Initial OK !
00:00:04|[Binder] Binder Initial OK !
00:00:04|[OSA-DRV] Char device create OK !
00:00:04|[Binder] SR driver initial OK !
00:00:04|[Binder] NS driver initial OK !
00:00:04|[Binder] Binder driver initial OK !
00:00:04|[SPF] SPF Build on Apr 23 2014 at 20:23:56.
00:00:04|[SPF] SVN NUM: 5976.
00:00:04|[SPF] SIL initial OK !
00:00:04|[SPF] SPF initial ok !
00:00:04|[SPF] SPF Proc Create OK!!!
00:00:04|[SPF] SPF driver initial ok !
00:00:04|[prc] PRC Driver Build on Jun 12 2014 at 16:05:38.
00:00:04|[prc] SVN NUM: 2234.
00:00:04|[prc] Start to init module!
00:00:04|[prc] pinmux init ok
00:00:04|[prc] gpio soc init ok
00:00:04|[prc] spi init ok
00:00:04|[prc] IIC init ok
00:00:04|[prc] PRC_wdtInit OK
00:00:04|[prc] PRC_rtcInit OK!
00:00:04|[prc] i2c businit ok
00:00:04|[prc] DMA init ok
00:00:04|[SPF] Dai 3 register OK !
00:00:04|[prc] IIS init: ok
00:00:04|[SPF] codecType 32 register OK !
00:00:04|[prc] Codec init ok
00:00:04|[prc] Success to init module!
00:00:04|[pdc]
PDC Build on Aug 19 2014 at 17:21:03.
00:00:04|[pdc] SVN NUM: 4564.
00:00:04|[pdc] BASE_LINE: 210
00:00:04|[pdc] OSA_kProcCreate OK
00:00:04|[pdc] PDC_PartionInit ok!!
00:00:04|[pdc] HWID : IPC-HDW1100S:01:02:04:1D:0E:00:01:00:00:00:00:190:00:00:00
00:00:04|[pdc] binderFlag: 0x3, funcap: 0x18538b,0x0,0x0,0x0
00:00:04|[OSA-DRV] recordTsk  Task   pid=515   tid=515
00:00:04|[pdc] SenCfg Match OK,pCfgParams->pCfg: bf2690bc
00:00:04|[pdc] PDC_PRODUCT_OWNER: 0
00:00:04|[pdc] Find Product: IPC-HDW1100S.
00:00:04|[pdc] wifi cut down 0
00:00:04|[pdc] sd cut down 1610612755
00:00:04|[pdc] Config size 1428 !
00:00:04|[pdc] SenCfgSize: 204 Bytes
00:00:04|[pdc] Init spiBus2  Successed!
00:00:04|[prc] WARN  : TheKernel: ssp initial ok!
 I2C0 has benn  created
00:00:04|[pdc] Init I2CBus0  Successed!
00:00:04|[pdc] PDC_MODULE_RESET_STATE
00:00:04|[pdc] Dev has No shutDown Cfg!
00:00:04|[pdc] P***************AT88SC Crypt Version***************
DC_pinInit As UsType: DH General. UserZone ReadOnly: false
ual!
SVN: 2263
00:00:04|[pdc] GBuilt in: Jun 24 2014 16:19:37
et reset pin: 12**************************************************
 OK !
00:00:04|[pdc] ircut types = [0]
00:00:04|[pdc] ircut types = [1]
00:00:04|[pdc] ircut types = [2]
00:00:04|[pdc] Get comPort Cfg ok !0sa
00:00:04|[pdc] PDC_comInit OK!
00:00:04|[pdc] PDC_MODULE_SENSOR
00:00:04|[pdc] Try RtcDev: SocRtc
00:00:04|[pdc] phyaddr = 854ff000, memLen = 1000
00:00:04|[pdc] DDRdata crc incorrect, Load from sramFile
00:00:04|[pdc] A B OK
00:00:04|[pdc] Both of Chief and Backup File CRC check OK!
00:00:04|[pdc] DDRdata crc incorrecterror: write byte error
, Load from sramerror: write_nbytes failed
File
rror: verify_read_password failed, PAC = ffffffff
32m00:00:04|[pdcerror: authenticate failed
00:00:04|[pdc] Choose RtcType: 4 -> SocRtc
00:00:04|[pdc] OSA_kProcAddFile:pdcRtc OK!
Restarting system.
00:00:04|[pdc] DDRdata crc incorrecterror: write byte error, Load from sramerror: write_nbytes failed
Возможно прошивки не подходят?
Re: Восстановление IPC-HFW1100SP
Сообщение iTuneDVR » 11 мар 2016, 18:51
Камера чинайская?
