Сброс пароля на китайском AHD-регистраторе
dapper
Сообщение dapper » 01 июл 2016, 12:31
Привет!
Принесли AHD-рег с алиэкспресса. Забыли пароль. Телнета нет. Китайские сбрасывалки от старых хайсиликонов не подходят. С консолью тоже беда. Что можно придумать?
U-Boot 2010.06 (Sep 10 2015 - 09:28:27)
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0xc2 0x20 0x18
Block:64KB Chip:16MB Name:"MX25L128XX"
SPI Nor total size: 16MB
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
change register for 8710
CONFIG MII
ETH0: PHY(phyaddr=2, rgmii) not link!
higmac init fail!
Press CTRL-C to abort autoboot in 2 seconds16384 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
### /UbootLogo UbootLogoload complete: 23966 bytes loaded to 0x8e800000
jpeg decoding ...
<<addr=0x8e800000, size=0xb85f9, vobuf=0x8f000000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
OpenDev  vo:0 intf_type:36 out_sync:16
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 2513, type 1
find_squashfs_file: name boot, start_block 0, offset 2625, type 1
read inode: name boot, sb 0, of 2625, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 2545, type 2
read inode: name zImage.img, sb 0, of 2545, type 2
### FS load complete: 3022136 bytes loaded to 0x82000000
   Image Name:   linux
   Data Size:    3022072 Bytes = 2.9 MiB
   Entry Point:  80008000
hisilicon # printenv
bootcmd=sf probe 0;sf read 0x84000000 0xf60000 0x20000;logoload 0x84000000;decjpg;sf read 0x82000000 0x50000 0x500000;squashfsload 82000000;bootm 0x82000000
bootdelay=1
ethaddr=00:0b:3f:00:00:01
ipaddr=192.168.1.10
serverip=192.168.1.12
gatewayip=192.168.1.1
da=mw.b 0x82000000 ff 1000000;tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=mw.b 0x82000000 ff 1000000;tftp 0x82000000 update.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
dd=mw.b 0x82000000 ff 1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
appVideoStandard=PAL
appSystemLanguage=Russian
silent=0
bootargs=mem=80M console=ttyS1,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:320K(boot),3968K(romfs),7104K(usr),1536K(web),2816K(custom),128K(logo),512K(mtd) coherent_pool=2M
ver=U-Boot 2010.06 (Sep 10 2015 - 09:28:27)
Environment size: 1408/65532 bytes
hisilicon #
Re: Сброс пароля на китайском AHD-регистраторе
Сообщение iTuneDVR » 01 июл 2016, 12:39
Вариантов море по сбросу: генерация, включение телнета, сброс области конфигурации как мануально, так и автоматически с флешки при загрузке.
На фото не видно даты на регистраторе.
dapper
Сообщение dapper » 01 июл 2016, 15:16
Пароль с секретного генератора подошел, спасибо!
А что с другими вариантами? Как например можно телнет на нём включить? :)
Сообщение iTuneDVR » 01 июл 2016, 15:18
Пожалуйста!
Если проблема решена, то зачем забирать себе голову ради разовой частной ситуации, которая не повторится? ;)
dapper
Сообщение dapper » 01 июл 2016, 15:31
Да как-то нет уверенности, что не повторится. Есть вероятность, что через некоторое время опять забудут и снова принесут :)
Надо кстати не забыть дамп с него дёрнуть)
Сообщение iTuneDVR » 01 июл 2016, 18:18
dapper писал(а):Да как-то нет уверенности, что не повторится. Есть вероятность, что через некоторое время опять забудут и снова принесут :)
Лучше тренировать память, либо записывать, а раз это заказчики и коммерция, то лучше к поставщику товара....
dapper писал(а):Надо кстати не забыть дамп с него дёрнуть)
Это обязательно!
dapper
Сообщение dapper » 30 дек 2016, 05:00
Вчера принесли такой-же, только под брендом Акьюмен. В этот раз не тупил и разобрался как ему чистый mtd через uboot подкинуть :)
Сообщение iTuneDVR » 30 дек 2016, 14:22
Супер!
karbyrator
Сообщение karbyrator » 09 мар 2017, 20:15
Напишите пожалуйста как именно Вы решили проблему, а то ничего найти не могу. А валяется такой-же.
Сообщение iTuneDVR » 09 мар 2017, 20:18
dapper писал(а):Пароль с секретного генератора подошел, спасибо!
Человек нашел генератор и ....
