Falcon Eye FE-NR-5936 PRO - циклическая перезагрузка
dapper
Re: Falcon Eye FE-NR-5936 PRO - циклическая перезагрузка
Сообщение dapper » 01 мар 2017, 08:53
Исходный лог загрузки:
U-Boot 2010.06 (Aug 07 2014 - 22:08:42)
NAND:  Check nand flash controller v504. found
Special NAND id table Version 1.36
Nand ID: 0xAD 0xF1 0x80 0x1D 0xAD 0xF1 0x80 0x1D
Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4bits/512Byte
128 MiB
Can't find a valid spi flash chip.
(Re)start USB...
USB:   scanning bus for devices... 1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
NAND read: device 0 offset 0x7c00000, size 0x40000
 262144 bytes read: OK
mmu_enable
<<imgwidth=1024, imgheight=768, linebytes=2048>>
decode success!!!!
dev 0 set background color!
dev 2 set background color!
dev 0 opened!
dev 2 opened!
graphic layer 0 opened!
graphic layer 2 opened!
NAND read: device 0 offset 0x100000, size 0x300000
 3145728 bytes read: OK
   Image Name:   Linux-3.4.35_hi3535
   Data Size:    2450240 Bytes = 2.3 MiB
   Entry Point:  80008000
Booting Linux on physical CPU 0
Linux version 3.4.35_hi3535 (root@sqy-desktop) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #8 SMP Fri May 22 10:33:01 CST 2015
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
Machine: hi3535
Truncating memory at 0x80000000 to fit in 32-bit physical address space
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c0879000 s5888 r8192 d14592 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 79248
Kernel command line: mem=312M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=yaffs2  mtdparts=hinand:1M(uboot),3M(kernel),90M(rfs),20M(app),10M(config),4M(logo)
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 312MB = 312MB total
Memory: 310344k/310344k available, 9144k reserved, 0K highmem
    vmalloc : 0xd4000000 - 0xff000000   ( 688 MB)
    lowmem  : 0xc0000000 - 0xd3800000   ( 312 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc058d000   (5652 kB)
      .init : 0xc058d000 - 0xc05b9700   ( 178 kB)
      .data : 0xc05ba000 - 0xc05eaa80   ( 195 kB)
       .bss : 0xc05eaaa4 - 0xc060435c   ( 103 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:128
sched_clock: 32 bits at 62MHz, resolution 16ns, wraps every 68719ms
Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
Initializing cgroup subsys freezer
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x804574c0 - 0x804574f4
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x72430001, Cache size: 262144 B
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3981.31 BogoMIPS).
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 42) is a PL011 rev2
No PCIe controller 1!
controller0, config base:0x20800000, mem size:0x800000
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io  0x37800000-0x3fffffff]
pci_bus 0000:00: root bus resource [mem 0x30000000-0x377fffff]
PCI: bus0: Fast back to back transfers disabled
pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
PCI: bus1: Fast back to back transfers disabled
pci 0000:00:00.0: BAR 0: assigned [mem 0x30000000-0x307fffff pref]
pci 0000:00:00.0: BAR 9: assigned [mem 0x30800000-0x30ffffff pref]
pci 0000:00:00.0: BAR 8: assigned [mem 0x31000000-0x311fffff]
pci 0000:00:00.0: BAR 1: assigned [mem 0x31200000-0x3120ffff]
pci 0000:01:00.0: BAR 0: assigned [mem 0x30800000-0x30ffffff pref]
pci 0000:01:00.0: BAR 2: assigned [mem 0x31000000-0x310fffff]
pci 0000:01:00.0: BAR 1: assigned [mem 0x31100000-0x3110ffff]
pci 0000:01:00.0: BAR 3: assigned [mem 0x31110000-0x3111ffff]
pci 0000:01:00.0: BAR 4: assigned [mem 0x31120000-0x3112ffff]
pci 0000:00:00.0: PCI bridge to [bus 01-01]
pci 0000:00:00.0:   bridge window [mem 0x31000000-0x311fffff]
pci 0000:00:00.0:   bridge window [mem 0x30800000-0x30ffffff pref]
vgaarb: loaded
Switching to clocksource timer0
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NTFS driver 2.1.30 [Flags: R/W DEBUG].
msgmni has been set to 606
encryption fail
no ack
sha204_sn is 1
sha204_sn is 23
sha204_sn is 5f
sha204_sn is 9
sha204_sn is f6
sha204_sn is b0
sha204_sn is f3
sha204_sn is df
sha204_sn is ee
sha204_devinfo  is 44 i is 0
sha204_devinfo  is 56 i is 1
sha204_devinfo  is 52 i is 2
sha204_devinfo  is 32 i is 3
sha204_devinfo  is 33 i is 4
sha204_devinfo  is 35 i is 5
sha204_devinfo  is 31 i is 6
sha204_devinfo  is 35 i is 7
sha204_devinfo  is 30 i is 8
sha204_devinfo  is 34 i is 9
sha204_devinfo  is 1 i is 10
sha204_devinfo  is 5b i is 11
sha204_devinfo  is 0 i is 12
sha204_devinfo  is 0 i is 13
sha204_devinfo  is 0 i is 14
sha204_devinfo  is 0 i is 15
TempKey  is 94
TempKey  is e5
TempKey  is a
TempKey  is e
TempKey  is 1c
TempKey  is 22
TempKey  is 2f
TempKey  is 19
TempKey  is f3
TempKey  is 52
TempKey  is ee
TempKey  is a3
TempKey  is 81
TempKey  is 4
TempKey  is 5f
TempKey  is 5b
TempKey  is b4
TempKey  is d0
TempKey  is 60
TempKey  is f0
TempKey  is 4d
TempKey  is 96
TempKey  is a1
TempKey  is 62
TempKey  is f
TempKey  is 6f
TempKey  is 69
TempKey  is ce
TempKey  is c
TempKey  is b0
TempKey  is 86
TempKey  is cc
encryption ok
brd: module loaded
ahci ahci.0: AHCI 0001.0300 32 slots 3 ports 6 Gbps 0x7 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp fbs slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x100 irq 63
ata2: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x180 irq 63
Spi id table Version 1.22
Found Nand Flash Controller V504.
Nand: Hynix NAND 128MiB 3,3V 8-bit
Nand(Hardware): Block:128KB Page:2KB OOB:64B ECC:4bits/512Byte Chip:128MB*1
6 cmdlinepart partitions found on MTD device hinand
Creating 6 MTD partitions on "hinand":
0x000000000000-0x000000100000 : "uboot"
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000005e00000 : "rfs"
0x000005e00000-0x000007200000 : "app"
ata1: SATA link down (SStatus 0 SControl 300)
0x000007200000-0x000007c00000 : "config"
0x000007c00000-0x000008000000 : "logo"
usbcore: registered new interface driver rt2800usb
hiusb-ehci hiusb-ehci.0: irq 54, io mem 0x10040000
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 53, io mem 0x10030000
hub 2-0:1.0: 2 ports detected
xhci-hcd hiusb3.0: xHCI Host Controller
xhci-hcd hiusb3.0: new USB bus registered, assigned bus number 3
xhci-hcd hiusb3.0: irq 64, io mem 0x12000000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
xhci-hcd hiusb3.0: new USB bus registered, assigned bus number 4
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
usbhid: USB HID core driver
TCP: cubic registered
ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata2.15: Port Multiplier 1.2, 0x197b:0x3219 r0, 9 ports, feat 0x5/0xf
ata2.00: hard resetting link
ata2.00: SATA link down (SStatus 0 SControl 320)
ata2.01: hard resetting link
ata2.01: SATA link down (SStatus 0 SControl 320)
ata2.02: hard resetting link
ata2.02: SATA link down (SStatus 0 SControl 320)
ata2.03: hard resetting link
ata2.03: SATA link down (SStatus 0 SControl 320)
ata2.04: hard resetting link
ata2.04: SATA link down (SStatus 0 SControl 320)
ata2.05: hard resetting link
ata2.05: SATA link down (SStatus 0 SControl 320)
ata2.06: hard resetting link
ata2.06: SATA link down (SStatus 0 SControl 320)
ata2.07: hard resetting link
ata2.07: SATA link down (SStatus 0 SControl 320)
ata2.08: hard resetting link
ata2.08: SATA link down (SStatus 0 SControl 320)
ata2: EH complete
yaffs: dev is 32505858 name is "mtdblock2" rw
yaffs: passed flags ""
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 805 [#1] SMP ARM
Modules linked in:
CPU: 0    Not tainted  (3.4.35_hi3535 #8)
PC is at yaffs_unlink_worker+0x124/0x1bc
LR is at 0x2
pc : [<c01ab874>]    lr : [<00000002>]    psr: 80000013
sp : d302bb38  ip : d30a4ca8  fp : d302bc64
r10: 00000100  r9 : d3019c00  r8 : d3019d48
r7 : d30a4c18  r6 : d30a4c4c  r5 : d30a4c38  r4 : 00000000
r3 : 00000000  r2 : 00000000  r1 : d3019e0c  r0 : d30a4c4c
Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 8000404a  DAC: 00000015
PC: 0xc01ab7f4:
b7f4  0a000018 e24bd020 e89da9f0 e3540000 0a00000b e3520003 0a000038 e595c008
b814  e3a0e000 e1a00005 e1a0300e e3052284 e34c2054 e59c1da4 e58de000 ebfffaa6
b834  eaffffef e242e001 e35e0004 979ff10e ea000015 c01ab8e8 c01ab8dc c01ab868
b854  c01ab8a0 c01ab8d0 e1a00004 ebfffae8 eaffffe3 e5953074 e285c070 e5952070
b874  e5832000 e5823004 e5951064 e585c074 e3510003 e585c070 1a00000f e595e068
b894  e2850068 e150000e 0a00000b e3a00000 eaffffd3 e5951018 e2853014 e5952014
b8b4  e1a00005 e5812000 e5821004 e5853014 e5853018 ebffface eaffffc9 e1a00005
b8d4  ebfffacb eaffffc6 e1a00005 ebfffb24 eaffffc3 e1a00005 ebffff2d eaffffc0
SP: 0xd302bab8:
bab8  d336cc38 00000000 d302baec d302bad0 c01aa4c4 c01a7054 c01ab874 80000013
bad8  ffffffff d302bb24 d302bc64 d302baf0 c0009078 c0008410 d30a4c4c d3019e0c
baf8  00000000 00000000 00000000 d30a4c38 d30a4c4c d30a4c18 d3019d48 d3019c00
bb18  00000100 d302bc64 d30a4ca8 d302bb38 00000002 c01ab874 80000013 ffffffff
bb38  00000000 00000000 00000000 d30a4a18 d302bc84 d302bb58 c01ab8d8 c01aa414
bb58  00000000 00000000 00000000 00000000 00000000 00000000 00000000 d3019000
bb78  d302bc2c d302bb88 c01a90bc c01b1010 d302bbec d302bbf4 00000000 00000000
bb98  d302bbbc d302bba8 c01b3210 c01b3010 d302bbcc d302bbb8 c01b3210 c01b3010
IP: 0xd30a4c28:
4c28  00000000 00000000 00000000 00000000 000000f0 00000012 d3019000 d330b394
4c48  d31f264c d30a4c4c d30a4c4c d30a4bb0 d30a4c18 d30a4c18 00007a00 00000000
4c68  00000101 00000004 00002626 00000000 00000000 00000000 00000000 00000000
4c88  00000000 00000108 00000108 00000000 00000000 00000003 d30a4ca0 d30a4ca0
4ca8  00000000 00000000 00000000 00000000 00000000 00000000 000000b0 00000005
4cc8  d3019000 d330b30c d331ea8c d30a4cd4 d30a4cd4 d330b388 d30a53c8 d30a48a0
4ce8  00007a02 00000000 00000102 00000000 00000005 00000000 00000000 00000000
4d08  00000368 00000264 00010100 000a0000 00400002 00000000 00000000 00000003
FP: 0xd302bbe4:
bbe4  c01b31a8 d330b410 0000067c 00000001 00000028 00000000 00000000 d302bc44
bc04  d330b0e0 d330b0e0 d330b410 d3019000 00000001 d330b278 d330b410 d3019000
bc24  d336cc38 d30a4ca0 c05d0e9c d30a4ca0 d3019d48 d302bc64 d302bc48 c01ab96c
bc44  d30a4c38 d30a4c18 c05d0e9c d30a4c18 d3019d48 d302bc84 d302bc68 c01ab96c
bc64  c01ab75c d30a4bb0 d30a4d68 c05d0e9c d330b368 d302bca4 d302bc88 c01ab994
bc84  c01ab918 d3019000 c05d0e9c d31f1b18 d3019d48 d302bcdc d302bca8 c01ac4e0
bca4  c01ab918 000006ad 00000000 f0000010 d313dc00 d3019000 c05d0e98 d32fa600
bcc4  00000000 00000002 d32fa600 d302bd6c d302bce0 c01a4f90 c01abc64 c05cda08
R0: 0xd30a4bcc:
4bcc  d330b300 d30a4d68 d30a4708 00000000 00000000 00000000 00000000 00000000
4bec  00000000 00000000 00000000 00000000 00000000 0000000b 00000108 00000108
4c0c  00000000 00000000 00000003 d30a4c58 d30a4c58 d330b370 d3019e0c 00000000
4c2c  00000000 00000000 00000000 000000f0 00000012 d3019000 d330b394 d31f264c
4c4c  d30a4c4c d30a4c4c d30a4bb0 d30a4c18 d30a4c18 00007a00 00000000 00000101
4c6c  00000004 00002626 00000000 00000000 00000000 00000000 00000000 00000000
4c8c  00000108 00000108 00000000 00000000 00000003 d30a4ca0 d30a4ca0 00000000
4cac  00000000 00000000 00000000 00000000 00000000 000000b0 00000005 d3019000
R1: 0xd3019d8c:
9d8c  d330b388 d330b300 ffffffff 00000000 d30aa200 00000000 d330b498 d330b410
9dac  00000000 00000018 00000419 00000000 d3036000 00000000 d3036800 00000000
9dcc  d3037000 00000000 d3037800 00000000 d32f0000 00000000 d32f0800 00000000
9dec  00000002 00000000 00000000 00000000 00001205 00000000 00000000 00000000
9e0c  d30a4c20 d330b370 0000003f d313e000 000002e7 00006ccb 0000004e 00000000
9e2c  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000051
9e4c  00000000 00000000 00000000 00000000 00000000 000026a4 000026a4 00000000
9e6c  00000000 00006328 00000484 00000000 00000000 00000000 00000000 00000000
R5: 0xd30a4bb8:
4bb8  d3019000 d30a4d54 d30a4914 d30a4bc4 d30a4bc4 d330b300 d30a4d68 d30a4708
4bd8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
4bf8  00000000 00000000 0000000b 00000108 00000108 00000000 00000000 00000003
4c18  d30a4c58 d30a4c58 d330b370 d3019e0c 00000000 00000000 00000000 00000000
4c38  000000f0 00000012 d3019000 d330b394 d31f264c d30a4c4c d30a4c4c d30a4bb0
4c58  d30a4c18 d30a4c18 00007a00 00000000 00000101 00000004 00002626 00000000
4c78  00000000 00000000 00000000 00000000 00000000 00000108 00000108 00000000
4c98  00000000 00000003 d30a4ca0 d30a4ca0 00000000 00000000 00000000 00000000
R6: 0xd30a4bcc:
R7: 0xd30a4b98:
4b98  d30a4b98 d30a4b98 00000000 00000000 00000000 00000000 00000070 00000000
R8: 0xd3019cc8:
9cc8  d31f132c 00000006 d335c5e4 d31f13b4 00000004 d335c66c d31f143c 00000006
9ce8  d335c6f4 d31f14c4 00000005 d335c77c d31f154c 00000005 d335c804 d31f165c
9d08  00000004 d335c88c d31f16e4 00000004 d335c914 d31f176c 00000006 d335c99c
9d28  d31f17f4 00000004 d335ca24 d331e7e4 00000003 d335caac d31f198c 00000004
9d48  d335cb34 d31f1b24 00000005 00000000 000077d0 d32fc400 00000000 00000001
9d68  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
9d88  d313e400 d330b388 d330b300 ffffffff 00000000 d30aa200 00000000 d330b498
9da8  d330b410 00000000 00000018 00000419 00000000 d3036000 00000000 d3036800
R9: 0xd3019b80:
9b80  d336acac d30af394 00000005 d336ad34 d331c804 00000005 d336adbc d30af4a4
9ba0  00000005 d336ae44 d31f121c 00000007 d336aecc d331cbbc 00000004 d336af54
9bc0  d31f02b4 00000005 d336afdc d31f033c 00000004 d3354f74 d331cffc 00000005
9be0  d336b064 d331d194 00000004 d336b0ec d31f066c 00000004 d336b174 d31f077c
9c00  00000003 d336b1fc d31f088c 00000005 d336b284 d3336ecc 00000003 d336b30c
9c20  d31f0a24 00000004 d336b394 d31f0aac 00000006 d336b41c d31f0b34 00000005
9c40  d336b4a4 d31f0bbc 00000005 d335c00c d334855c 00000003 d335c094 d31f0ccc
9c60  00000006 d335c11c d31f0ddc 00000006 d335c1a4 d331d98c 00000003 d335c22c
Process swapper/0 (pid: 1, stack limit = 0xd302a270)
Stack: (0xd302bb38 to 0xd302c000)
bb20:                                                       00000000 00000000
bb40: 00000000 d30a4a18 d302bc84 d302bb58 c01ab8d8 c01aa414 00000000 00000000
bb60: 00000000 00000000 00000000 00000000 00000000 d3019000 d302bc2c d302bb88
bb80: c01a90bc c01b1010 d302bbec d302bbf4 00000000 00000000 d302bbbc d302bba8
bba0: c01b3210 c01b3010 d302bbcc d302bbb8 c01b3210 c01b3010 d3019000 00000285
bbc0: d302bc54 d302bbd0 c01a81f8 c01b31a8 d3019000 0000067c 00000001 00000029
bbe0: c01a81f8 c01b31a8 d330b410 0000067c 00000001 00000028 00000000 00000000
bc00: d302bc44 d330b0e0 d330b0e0 d330b410 d3019000 00000001 d330b278 d330b410
bc20: d3019000 d336cc38 d30a4ca0 c05d0e9c d30a4ca0 d3019d48 d302bc64 d302bc48
bc40: c01ab96c d30a4c38 d30a4c18 c05d0e9c d30a4c18 d3019d48 d302bc84 d302bc68
bc60: c01ab96c c01ab75c d30a4bb0 d30a4d68 c05d0e9c d330b368 d302bca4 d302bc88
bc80: c01ab994 c01ab918 d3019000 c05d0e9c d31f1b18 d3019d48 d302bcdc d302bca8
bca0: c01ac4e0 c01ab918 000006ad 00000000 f0000010 d313dc00 d3019000 c05d0e98
bcc0: d32fa600 00000000 00000002 d32fa600 d302bd6c d302bce0 c01a4f90 c01abc64
bce0: c05cda08 00000020 c048abb0 00000000 00000000 00000000 00000000 00000000
bd00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 6264746d
bd20: 6b636f6c c01f0032 d302bd7c d302bd44 d302bd6c d302bd48 c01e2a54 c01fc3a0
bd40: c053d464 d2c12400 00000083 d2c12470 00008000 d313dc00 00000000 00000000
bd60: d302bd7c d302bd70 c01a5298 c01a4ac8 d302bdc4 d302bd80 c00bb19c c01a5280
bd80: 6264746d 6b636f6c d3020032 00000006 00000005 d32fd4c0 c05f91f8 d309ca80
bda0: d309ca80 c05d0f04 c05d0f04 00008000 00000000 d302be80 d302bddc d302bdc8
bdc0: c01a1db4 c00bb024 c01a5274 d302bdd8 d302be0c d302bde0 c00b96f8 c01a1da0
bde0: 00000006 c05d0f04 c05d0f04 d309ca80 c05d0f04 d32fd4c0 00000000 00000000
be00: d302be34 d302be10 c00d7050 c00b96e8 00000000 c05d0f04 d32fd480 00000000
be20: d32fd4c0 00008000 d302be5c d302be38 c00d712c c00d7004 00000000 00000020
be40: 00000000 d32fd4c0 d32fd480 00008000 d302beb4 d302be60 c00d731c c00d70fc
be60: 00000000 00000000 00008000 00001000 d302be9c d302be80 c00969bc c00968c4
be80: d3006190 d2c19700 00000000 d301f000 c05240c4 00000000 00008000 c05240c4
bea0: c05b7c48 00000098 d302beec d302beb8 c00d7980 c00d71d0 00000000 00000002
bec0: d2c26408 00000000 d32fd4c0 d32fd480 d301c000 c05b229c d301c000 00008000
bee0: d302bf14 d302bef0 c058dbfc c00d7900 00000000 c05eaac0 00008000 d301c000
bf00: c05b229c d301c000 d302bf6c d302bf18 c058de7c c058dbdc 00000001 00006000
bf20: d302bf5c d302bf30 c00c5184 c00c1f38 d3006190 d2c19900 00000002 c05b22ad
bf40: c05eaac0 00000002 c05b22ad c05eaac0 c058d26c c05b1a74 c05b7c48 00000098
bf60: d302bf94 d302bf70 c058e0b8 c058dd80 c05b22a8 c05eaac0 c05eab20 c05b22ad
bf80: c05eaac0 c058d26c d302bfb4 d302bf98 c058e258 c058dfc4 d302bfb4 d302bfa8
bfa0: c05b1a74 00000008 d302bff4 d302bfb8 c058d4b8 c058e0cc 00000007 00000007
bfc0: c058d26c c058d2f4 c002176c 00000000 c058d2f4 c002176c 00000013 00000000
bfe0: 00000000 00000000 00000000 d302bff8 c002176c c058d300 ffffffff ffffffff
Backtrace:
[<c01ab750>] (yaffs_unlink_worker+0x0/0x1bc) from [<c01ab96c>] (yaffs_del_dir_contents+0x60/0xa4)
 r8:d3019d48 r7:d30a4c18 r6:c05d0e9c r5:d30a4c18 r4:d30a4c38
[<c01ab90c>] (yaffs_del_dir_contents+0x0/0xa4) from [<c01ab994>] (yaffs_del_dir_contents+0x88/0xa4)
 r7:d330b368 r6:c05d0e9c r5:d30a4d68 r4:d30a4bb0
[<c01ab90c>] (yaffs_del_dir_contents+0x0/0xa4) from [<c01ac4e0>] (yaffs_guts_initialise+0x888/0xa6c)
 r7:d3019d48 r6:d31f1b18 r5:c05d0e9c r4:d3019000
[<c01abc58>] (yaffs_guts_initialise+0x0/0xa6c) from [<c01a4f90>] (yaffs_internal_read_super+0x4d4/0x7b8)
[<c01a4abc>] (yaffs_internal_read_super+0x0/0x7b8) from [<c01a5298>] (yaffs2_internal_read_super_mtd+0x24/0x34)
[<c01a5274>] (yaffs2_internal_read_super_mtd+0x0/0x34) from [<c00bb19c>] (mount_bdev+0x184/0x1b0)
[<c00bb018>] (mount_bdev+0x0/0x1b0) from [<c01a1db4>] (yaffs2_mount+0x20/0x28)
[<c01a1d94>] (yaffs2_mount+0x0/0x28) from [<c00b96f8>] (mount_fs+0x1c/0xd8)
[<c00b96dc>] (mount_fs+0x0/0xd8) from [<c00d7050>] (vfs_kern_mount+0x58/0xb8)
 r9:00000000 r8:00000000 r6:d32fd4c0 r5:c05d0f04 r4:d309ca80
[<c00d6ff8>] (vfs_kern_mount+0x0/0xb8) from [<c00d712c>] (do_kern_mount+0x3c/0xd4)
 r8:00008000 r7:d32fd4c0 r6:00000000 r5:d32fd480 r4:c05d0f04
r3:00000000
[<c00d70f0>] (do_kern_mount+0x0/0xd4) from [<c00d731c>] (do_mount+0x158/0x730)
 r8:00008000 r7:d32fd480 r6:d32fd4c0 r5:00000000 r4:00000020
r3:00000000
[<c00d71c4>] (do_mount+0x0/0x730) from [<c00d7980>] (sys_mount+0x8c/0xcc)
[<c00d78f4>] (sys_mount+0x0/0xcc) from [<c058dbfc>] (do_mount_root+0x2c/0xb8)
 r7:00008000 r6:d301c000 r5:c05b229c r4:d301c000
[<c058dbd0>] (do_mount_root+0x0/0xb8) from [<c058de7c>] (mount_block_root+0x108/0x244)
[<c058dd74>] (mount_block_root+0x0/0x244) from [<c058e0b8>] (mount_root+0x100/0x108)
[<c058dfb8>] (mount_root+0x0/0x108) from [<c058e258>] (prepare_namespace+0x198/0x1d4)
 r7:c058d26c r6:c05eaac0 r5:c05b22ad r4:c05eab20
[<c058e0c0>] (prepare_namespace+0x0/0x1d4) from [<c058d4b8>] (kernel_init+0x1c4/0x1d8)
 r5:00000008 r4:c05b1a74
[<c058d2f4>] (kernel_init+0x0/0x1d8) from [<c002176c>] (do_exit+0x0/0x804)
Code: eaffffe3 e5953074 e285c070 e5952070 (e5832000)
---[ end trace 0b9a04cb6458aa8a ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
CPU1: stopping
Backtrace:
[<c000dbc0>] (dump_backtrace+0x0/0x110) from [<c04542d8>] (dump_stack+0x18/0x1c)
 r6:c05c64c0 r5:d3052000 r4:00000000 r3:00000000
[<c04542c0>] (dump_stack+0x0/0x1c) from [<c000f4b0>] (handle_IPI+0x1d4/0x1f4)
[<c000f2dc>] (handle_IPI+0x0/0x1f4) from [<c000850c>] (gic_handle_irq+0x64/0x68)
[<c00084a8>] (gic_handle_irq+0x0/0x68) from [<c00090e0>] (__irq_svc+0x40/0x50)
Exception stack(0xd3053f68 to 0xd3053fb0)
3f60:                   00000001 c05c6564 00000000 00000000 d3052000 c05eab88
3f80: c045a120 c05c99e8 8000406a 414fc091 00000000 d3053fbc d3053fc0 d3053fb0
3fa0: c000a788 c000a78c 60000013 ffffffff
 r7:d3053f9c r6:ffffffff r5:60000013 r4:c000a78c
[<c000a758>] (default_idle+0x0/0x38) from [<c000aed4>] (cpu_idle+0xc0/0xf0)
[<c000ae14>] (cpu_idle+0x0/0xf0) from [<c0451a98>] (secondary_start_kernel+0x10c/0x110)
 r7:c05eadd8 r6:10c03c7d r5:00000001 r4:c05cde5c
[<c045198c>] (secondary_start_kernel+0x0/0x110) from [<804515d4>] (0x804515d4)
 r5:00000015 r4:9304006a
Лог обновления с флешки:
128 MiB
(Re)start USB...
USB:   scanning bus for devices... 2 USB Device(s) found
       scanning bus for storage devices... usb_stor_get_info->1406,blksz:512
1 Storage Device(s) found
g_antsupdate_index is 0
121752 bytes read
121629 bytes read
119268 bytes read
121582 bytes read
119630 bytes read
reading auto_u-boot.bin.3535
279664 bytes read
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
NAND erase: device 0 offset 0x0, size 0x100000
Erasing at 0xe0000 -- 100% complete.
NAND write: device 0 offset 0x0, size 0x80000
pure data length is 524288, len_incl_bad is 524288
 524288 bytes written: OK
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
reading auto_linux.img.3535
2845392 bytes read
NAND erase: device 0 offset 0x100000, size 0x300000
Erasing at 0x3e0000 -- 100% complete.
NAND write: device 0 offset 0x100000, size 0x300000
pure data length is 3145728, len_incl_bad is 3145728
 3145728 bytes written: OK
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
reading auto_rfs.yaffs.3535
65774016 bytes read
NAND erase: device 0 offset 0x400000, size 0x5a00000
Skipping bad block at  0x00500000
Skipping bad block at  0x00520000
Skipping bad block at  0x00c00000
Skipping bad block at  0x00c20000
Erasing at 0x5de0000 -- 100% complete.
NAND write: device 0 offset 0x400000, size 0x3eba1c0
pure data length is 63780864, len_incl_bad is 64356352
Skip bad block 0x00500000
Skip bad block 0x00520000
Skip bad block 0x00c00000
Skip bad block 0x00c20000
 65774016 bytes written: OK
reading auto_logo.jpeg.3535
4194304 bytes read
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
NAND erase: device 0 offset 0x7c00000, size 0x40000
Erasing at 0x7c20000 -- 100% complete.
NAND write: device 0 offset 0x7c00000, size 0x40000
pure data length is 262144, len_incl_bad is 262144
 262144 bytes written: OK
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
Лог загрузки после обновления:
U-Boot 2010.06 (May 06 2014 - 20:57:31)
128 MiB
*** Warning - bad CRC or NAND, using default environment
(Re)start USB...
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
   Data Size:    2845328 Bytes = 2.7 MiB
Linux version 3.4.35_hi3535 (root@sqy-desktop) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #96 SMP Mon Oct 13 11:05:21 CST 2014
Machine: hi3535
PERCPU: Embedded 7 pages/cpu @c087c000 s6528 r8192 d13952 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 48768
Kernel command line: mem=192M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=yaffs2  mtdparts=hinand:1M(uboot),3M(kernel),90M(rfs),20M(app),10M(config),4M(logo)
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 192MB = 192MB total
Memory: 187648k/187648k available, 8960k reserved, 0K highmem
    vmalloc : 0xcc800000 - 0xff000000   ( 808 MB)
    lowmem  : 0xc0000000 - 0xcc000000   ( 192 MB)
      .text : 0xc0008000 - 0xc0677000   (6588 kB)
      .init : 0xc0677000 - 0xc06a4980   ( 183 kB)
      .data : 0xc06a6000 - 0xc06d6d20   ( 196 kB)
       .bss : 0xc06d6d44 - 0xc06f8ac4   ( 136 kB)
NR_IRQS:128
Setting up static identity map for 0x8052cba0 - 0x8052cbd4
Brought up 2 CPUs
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 128 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.18)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 366
encryption fail
no need alpu
no ack
sha204_sn is 1
sha204_sn is 23
sha204_sn is 5f
sha204_sn is 9
sha204_sn is f6
sha204_sn is b0
sha204_sn is f3
sha204_sn is df
sha204_sn is ee
TempKey  is 16
TempKey  is b1
TempKey  is ba
TempKey  is 43
TempKey  is ce
TempKey  is 35
TempKey  is 78
TempKey  is 45
TempKey  is 66
TempKey  is 2b
TempKey  is e
TempKey  is bf
TempKey  is a1
TempKey  is b7
TempKey  is 65
TempKey  is a5
TempKey  is 4f
TempKey  is dc
TempKey  is fc
TempKey  is 3f
TempKey  is 88
TempKey  is aa
TempKey  is fd
TempKey  is 67
TempKey  is 7c
TempKey  is 76
TempKey  is 85
TempKey  is a7
TempKey  is bc
TempKey  is f1
TempKey  is 41
TempKey  is 20
encryption ok
brd: module loaded
loop: module loaded
scsi2 : ahci_platform
ata3: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x200 irq 63
usb 2-2: new low-speed USB device number 2 using hiusb-ohci
input: USB OPTICAL MOUSE  as /devices/platform/hiusb-ohci.0/usb2/2-2/2-2:1.0/input/input0
generic-usb 0003:0101:0007.0001: input: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-hiusb-ohci-2/input0
ata2: EH complete
ata3: SATA link down (SStatus 0 SControl 300)
VFS: Mounted root (yaffs2 filesystem) on device 31:2.
Freeing init memory: 180K
            _ _ _ _ _ _ _ _ _ _ _ _
            \  _  _   _  _ _ ___
            / /__/ \ |_/
           / __   /  -  _ ___
  _ _ _ _/ /  /  \_/  \_ ______
___________\___\__________________
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
udevd (632): /proc/632/oom_adj is deprecated, please use /proc/632/oom_score_adj instead.
[RCS]: /etc/init.d/S02toe
stmmac: Unknown symbol sysctl_tcp_retries2 (err 0)
insmod: can't insert '/hitoe/stmmac.ko': unknown symbol in module, or unknown parameter
[RCS]: /etc/init.d/S03ants
hi3535_base: module license 'Proprietary' taints kernel.
load sys.ko for Hi3535...OK!
Load tde.ko ...OK!
load vgs.ko for Hi3535...OK!
load venc.ko for Hi3535...OK!
load chnl.ko for Hi3535...OK!
load h264e.ko for Hi3535...OK!
load rc.ko for Hi3535...OK!
load jpege.ko for Hi3535...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load vda.ko ....OK!
load region.ko ....OK!
load vdec.ko ....OK
load vhd firmware.ko OK
load hdmi.ko ....OK!
Load hi_jpegdec.ko success.     (SDK_VERSION:[SDK_VERSION] Build Time:[Feb  6 2015, 19:57:25])
insmod: can't insert 'extdrv/rt5370sta.ko': No such file or directory
usbcore: registered new interface driver option
USB Serial support registered for GSM modem (1-port)
acodec inited!
rm: can't remove '/usr/etc/config.tar.gz': No such file or directory
mkdir: can't create directory '/usr/etc/ppp': File exists
mkdir: can't create directory '/usr/etc/ppp/peers': File exists
ifconfig: SIOCSIFADDR: No such device
/etc/init.d/S03ants: line 30: can't create /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established: nonexistent directory
mv: can't rename '/root/sysinit': No such file or directory
/etc/init.d/S03ants: line 35: /etc/startusb: not found
[RCS]: /etc/init.d/S80network
Auto login as root ...
Jan  3 23:42:25 login[979]: root login on 'ttyS000'
Welcome to HiLinux.
None of nfsroot found in cmdline.
# begin dvr//////////////////////////////////////////////////////////////
argc 2, argv ./ants_dvr
g_iDevType 15b
 open /usr/etc/mycfg.xml
 open /root/res_xml/Keyboard.xml
 open /tmp/qtembedded-0//fonts//fontdb.tmp
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/gulim_17_50.qpf2
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/microsoft_sans_serif_12_75.qpf2
 open /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts/yh_17_50.qpf2
DBG[embedded/qscreenlinuxfb_qws.cpp connect--350]       QLinuxFbScreen::connect :0
DBG[embedded/qscreenlinuxfb_qws.cpp connect--379]
 open /dev/fb0
DBG[embedded/qscreenlinuxfb_qws.cpp connect--397]       open device /dev/fb0 success
DBG[embedded/qscreenlinuxfb_qws.cpp connect--425]
 open /root/DeviceDisplay.xml
DBG[embedded/qscreenlinuxfb_qws.cpp connect--469]       vinfo.xres 1024 768
DBG[embedded/qscreenlinuxfb_qws.cpp connect--481]       d_ptr->fd 8 vinfo xres 1024, xres_virtual1024
DBG[embedded/qscreenlinuxfb_qws.cpp connect--513]       screen vinfo
 bits_per_pixel 32
 r g b 8 8 8
 d = 32
 finfo.line_length 2560
DBG[embedded/qscreenlinuxfb_qws.cpp connect--554]       dw is 1024,dh is 768 lstep 4096
DBG[embedded/qscreenlinuxfb_qws.cpp connect--600]
  mmap fb0 : d_ptr->fd 8,  data -1247961088, mapsize 8294400
 open /dev/tty0
newMouseHandler mouseProto auto, mouseDev/dev/mouse0
erro[embedded/qmousedriverfactory_qws.cpp create--111]
erro[embedded/qmousedriverfactory_qws.cpp create--114]
erro[embedded/qmousedriverfactory_qws.cpp create--117]
 open /dev/psaux
 open /dev/input/mice
QWSTtyKeyboardHandler /dev/ttyS2
kbdType RS485
kbdType RS485PelcoD
 open /dev/hi_gpio
 open /dev/ttyS1
termdata.c_iflag 5
termdata.c_oflag 0
termdata.c_cflag b0
termdata.c_lflag 0
termdata.c_ispeed 3450e854
termdata.c_ospeed 3450e854
termdata.c_line 0
termdata.c_cc 0 0
kbdType gpioMini
 open /dev/hi_gpio
 open /root/res/language_English.qm
 open /root/res/LanguageInfo.xml
 open /root/res/default.qss
font=efont
font-size=16
from config -> font=efont
from config -> font-size=16
QLayout: Attempting to add QLayout "" to informationFrame "IMShowMain", which already has a layout
 open ./pinyin/english.xml
 open /root/res/cursor.png
 open /root/res/pre_enlarge.png
 open /root/res/label_Mouse.png
 open /root/res/enlarge.png
 open /root/res/shrink.png
 open /root/res/up_Mouse.png
 open /root/res/down_Mouse.png
 open /root/res/left_Mouse.png
 open /root/res/right_Mouse.png
 open /root/res/up_left_Mouse.png
 open /root/res/up_right_Mouse.png
 open /root/res/down_left_Mouse.png
 open /root/res/down_right_Mouse.png
QImage::pixel: coordinate (10,6) out of range
QImage::pixel: coordinate (10,7) out of range
QImage::pixel: coordinate (10,8) out of range
QImage::pixel: coordinate (10,9) out of range
QImage::pixel: coordinate (10,10) out of range
QImage::pixel: coordinate (10,11) out of range
QImage::pixel: coordinate (10,12) out of range
QImage::pixel: coordinate (10,13) out of range
QImage::pixel: coordinate (10,14) out of range
QLayout: Attempting to add QLayout "" to CQRCode "", which already has a layout
QLayout: Attempting to add QLayout "" to DlgDragChannel "", which already has a layout
 open /root/res/pre_recordState.png
QLayout: Attempting to add QLayout "" to SysRecover "", which already has a layout
 open /root/res/play_left.png
 open /root/res/play_play.png
 open /root/res/play_noVideo.png
 open /root/res/play_stop.png
 open /root/res/play_sound.png
 open /root/res/play_fast.png
 open /root/res/play_slow.png
 open /root/res/play_capture.png
 open /root/res/play_backup.png
 open /root/res/play_frame.png
 open /root/res/play_fullscreen.png
QWidget::setLayout: Attempting to set QLayout "horizontalLayout_2" on DlgScreenInfo "DlgScreenInfo_UI", when the QLayout already has a parent
 open /root/res/ptz_back.png
 open /root/res/ptz_up.png
 open /root/res/ptz_up_Hover.png
 open /root/res/ptz_up_press.png
 open /root/res/ptz_down.png
 open /root/res/ptz_down_Hover.png
 open /root/res/ptz_down_press.png
 open /root/res/ptz_left.png
 open /root/res/ptz_left_Hover.png
 open /root/res/ptz_left_press.png
 open /root/res/ptz_right.png
 open /root/res/ptz_right_Hover.png
 open /root/res/ptz_right_press.png
 open /root/res/ptz_left_top.png
 open /root/res/ptz_left_top_Hover.png
 open /root/res/ptz_left_top_press.png
 open /root/res/ptz_right_top.png
 open /root/res/ptz_right_top_Hover.png
 open /root/res/ptz_right_top_press.png
 open /root/res/ptz_left_down.png
 open /root/res/ptz_left_down_Hover.png
 open /root/res/ptz_left_down_press.png
 open /root/res/ptz_right_down.png
 open /root/res/ptz_right_down_Hover.png
 open /root/res/ptz_right_down_press.png
 open /root/res/ptz_auto.png
 open /root/res/ptz_auto_hover.png
 open /root/res/ptz_auto_press.png
 open /root/res/ptz_minus.png
 open /root/res/ptz_plus.png
QLayout: Attempting to add QLayout "" to DlgAutoIP "", which already has a layout
 open /root/res/pre_AudioOpen.png
 open /root/res/pre_AudioClose.png
 open /root/res/pre_DiskNormal.png
 open /root/res/pre_DiskNormal.png.bmp
 open /root/res/pre_DiskNormal.png.jpeg
 open /root/res/pre_DiskNormal.png.jpg
 open /root/res/pre_DiskNormal.png.pbm
 open /root/res/pre_DiskNormal.png.pgm
 open /root/res/pre_DiskNormal.png.png
 open /root/res/pre_DiskNormal.png.ppm
 open /root/res/pre_DiskNormal.png.xbm
 open /root/res/pre_DiskNormal.png.xpm
 open /root/res/pre_DiskFull.png
 open /root/res/pre_DiskFull.png.bmp
 open /root/res/pre_DiskFull.png.jpeg
 open /root/res/pre_DiskFull.png.jpg
 open /root/res/pre_DiskFull.png.pbm
 open /root/res/pre_DiskFull.png.pgm
 open /root/res/pre_DiskFull.png.png
 open /root/res/pre_DiskFull.png.ppm
 open /root/res/pre_DiskFull.png.xbm
 open /root/res/pre_DiskFull.png.xpm
 open /root/res/pre_DiskNull.png
 open /root/res/pre_DiskNull.png.bmp
 open /root/res/pre_DiskNull.png.jpeg
 open /root/res/pre_DiskNull.png.jpg
 open /root/res/pre_DiskNull.png.pbm
 open /root/res/pre_DiskNull.png.pgm
 open /root/res/pre_DiskNull.png.png
 open /root/res/pre_DiskNull.png.ppm
 open /root/res/pre_DiskNull.png.xbm
 open /root/res/pre_DiskNull.png.xpm
QPixmap::scaled: Pixmap is a null pixmap
 open /root/res/pre_alarm1.png
 open /root/res/pre_alarm2.png
 open /root/res/pre_Disk.png
 open /root/res/pre_Disk.png.bmp
 open /root/res/pre_Disk.png.jpeg
 open /root/res/pre_Disk.png.jpg
 open /root/res/pre_Disk.png.pbm
 open /root/res/pre_Disk.png.pgm
 open /root/res/pre_Disk.png.png
 open /root/res/pre_Disk.png.ppm
 open /root/res/pre_Disk.png.xbm
 open /root/res/pre_Disk.png.xpm
[Mid] start init
system:/root/nvr_daemon &
system:killall -9 ntpd;ntpd -l
killall: ntpd: no process killed
[Mid] load custom cfg
[MID]load RTSP
[WEBSDK][../../src/AntsWebSDK.c:ants_HostMgr_Lib_GetFxns:651:time:14:25:28]Start================================[WebServer] SUCCESS
load host proto /root/host_libs/libwebserver.so
load host proto /root/host_libs/libhost_platform_umeye.so
[DANA-I][ants_HostMgr_Lib_GetFxns:3614]Get Fxns Name[Dana] ID[17]
load host proto /root/host_libs/libdana.so
load host proto /root/host_libs/libcloud.so
umount: tmpfs busy - remounted read-only
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL toRestarting system.
Также после обновления перестают работать сетевые интерфейсы в U-boot. Поэтому пришлось вернуть родной загрузчик на место, чтобы слить дамп. Дамп флешки после обновления сейчас также отправлю.
Сообщение iTuneDVR » 01 мар 2017, 12:17
Родимый!
Логи ведь не для меня производители делают, а для всех ;)
У тебя и для тебя там всё чёрным по белому в среднем логе написано!
Внимательно читаем и не испытываем иллюзий!
Как я неоднократно пишу и прошу, чтобы при оформлении вопроса изначально выкладывалось максимум информации всех процессов, а иначе это затягивание времени. Всё это время проблема перед носом, а ты водишь за нос оставляя в неведении ;)
dapper
Сообщение dapper » 02 мар 2017, 04:00
Ну так пара бэдов на флешке не проблема! Проблема найти рабочую прошивку!
Сообщение iTuneDVR » 02 мар 2017, 11:38
dapper писал(а):Ну так пара бэдов на флешке не проблема! Проблема найти рабочую прошивку!
Проблема недопонимании сути происходящего ! ;)
dapper
Сообщение dapper » 07 мар 2017, 09:08
Не совсем понял про испытывание иллюзий и недопонимание сути, ну да ладно.
Облазил почти весь китайский интернет и наконец-то нашел прошивку на двухпроцессорный Hi3535 на сайте http://www.dongjiadigital.com/.
Залил и всё заработало. Всем спасибо :)
Сообщение iTuneDVR » 07 мар 2017, 09:56
dapper писал(а):Не совсем понял про испытывание иллюзий и недопонимание сути, ну да ладно.
Так бывает.
Про этот файл 20160707_015b_double_3535_9HDD_64ch.update идёт речь?
Тебе изначально дали, как ты думаешь рабочую прошивку и продавец сказал как ей пользоваться и не работает.
В среднем логе, в единственном месте вместе ругнулось на несколько bad'ов, как ты выразился и какое совпадение, что это как раз раздел romfs и по логу загрузки спотыкается на загрузке в определенном месте.
При этом при заливки других разделов такого не наблюдается нигде!!!
С одной стороны, что там bad'ы ничего и страшного, ведь они выявлены - с другой стороны нет никаких гарантий.
Может новая прошивка (основное модули загрузки) легли чуть в другое место и оно просто обошлось стороной, а может и нет ...
На что еще можно подумать в данной ситуации столкнувшись в первый раз с таким и видя только такую информацию??? ;)
Если не сложно, то нормальный лог загрузки выложи, раз ты его демонстрируешь на скриншоте!
Получается продавец не смог или не захотел выдать, то, что нужно для техподдержки!
Рад что всё получилось.
dapper
Сообщение dapper » 07 мар 2017, 11:54
Файл с рабочей прошивкой этот, да.
Продавец сам даже не пробовал использовать то, что ему дали китайцы, я позже нашел эти же файлы на сайте китайской компании и там они указаны как recovery к совсем другим моделям регистраторов :)
По поводу бэдов - проверял несколько раз. Если я заливаю образ с tftp и пишу его с помощью команды nand write, то запись ведётся прямо в бэды и всё плохо. То же самое с nand read - читает всё, включая бэды. А если автозагрузкой с флешки, то бэды пропускаются и всё отлично.
Рабочий лог загрузки:
128 MiB
(Re)start USB...
mmu_enable
decode success!!!!
dev 0 opened!
dev 2 opened!
Machine: hi3535
NR_IRQS:128
Brought up 2 CPUs
vgaarb: loaded
encryption fail
no ack
sha204_sn is 1
sha204_sn is 23
sha204_sn is 5f
sha204_sn is 9
sha204_sn is f6
sha204_sn is b0
sha204_sn is f3
sha204_sn is df
sha204_sn is ee
TempKey  is a4
TempKey  is e
TempKey  is 63
TempKey  is 12
TempKey  is be
TempKey  is 1f
TempKey  is 25
TempKey  is 4c
TempKey  is d9
TempKey  is 40
TempKey  is a6
TempKey  is eb
TempKey  is 8a
TempKey  is 12
TempKey  is bd
TempKey  is dd
TempKey  is fc
TempKey  is bc
TempKey  is 36
TempKey  is d3
TempKey  is f5
TempKey  is 4
TempKey  is fe
TempKey  is 48
TempKey  is fd
TempKey  is 84
TempKey  is f5
TempKey  is c0
TempKey  is 2d
TempKey  is a3
TempKey  is d6
TempKey  is ab
encryption ok
brd: module loaded
ata2: EH complete
Freeing init memory: 176K
            \  _  _   _  _ _ ___
            / /__/ \ |_/
           / __   /  -  _ ___
udevd (585): /proc/585/oom_adj is deprecated, please use /proc/585/oom_score_adj instead.
STMMAC driver:
        platform registration...
        done!
Set system config register 0x200300ec with value 0x003f003f
        done!
        DWMAC1000 - user ID: 0x10, Synopsys ID: 0x36
        Enhanced descriptor structure
MACADDR in get is 0:0:0:0:0:0
        no valid MAC address for MAC 0;please, use ifconfig or nwhwconfig!
stmmac_associate_phy: phy 0 mode=6
        eth0 - (dev. name: stmmaceth - id: 0, IRQ #59
        IO base addr: 0xfe0a0000)
STMMAC MII Bus: probed
eth0: PHY ID 001cc915 at 0 IRQ 0 (1:00)
eth0: PHY ID 001cc915 at 2 IRQ -6 (1:02) active
stmmac_reset: RESET COMPLETE!
*  TNK driver built on Jan 20 2015 at 15:36:53
*  TNK driver mode is TOE
stmmac: Rx Checksum Offload Engine supported
Load tde.ko ...OK!
load vou.ko ....OK!
load vda.ko ....OK!
load vdec.ko ....OK
acodec inited!
PCIe HI35XX_DEV :Apr 21 2015, 14:50:26
PCI device[0] probed!
PCI: enabling device 0000:01:00.0 (0140 -> 0142)
PCIe DMA Trans :Apr 21 2015, 14:50:29
MCC_PROTOCOL :Apr 21 2015, 14:50:27
MCC_USR :Apr 21 2015, 14:50:28
PCIe BOOT SLAVE :Apr 21 2015, 14:50:25
mkdir: can't createth0: generated random MAC address fa:ab:8a:b2:ee:70
e directory '/usMACADDR in set is fa:ab:8a:b2:ee:70
mount: mounting usbfs on /proc/bus/usb/ failed: No such file or directory
hi35xx pcie boot application
we get device 1[353519e5].
init_registers called!
# start DDR training!!
DDRT code to cpy [0x1e00 bytes]
count = 8388608, dest = 0x82000000
count = 1224768, dest = 0x82800000
start device[1][].
Starting device[0x353519e5][0x1]
 All devices start up success!
Jan 10 03:05:43 login[979]: root login on 'ttyS000'
Welcome to HiLinux.
g_iDevType 15b
 open /dev/fb0
 bits_per_pixel 32
 r g b 8 8 8
 d = 32
  mmap fb0 : d_ptr->fd 8,  data -1247518720, mapsize 8294400
 open /dev/tty0
 open /dev/psaux
kbdType RS485
kbdType RS485PelcoD
 open /dev/hi_gpio
 open /dev/ttyS1
termdata.c_iflag 5
termdata.c_oflag 0
termdata.c_cflag b0
termdata.c_lflag 0
termdata.c_ispeed 43d726da
termdata.c_ospeed 43d726da
termdata.c_line 0
termdata.c_cc 0 0
kbdType gpioMini
 open /dev/hi_gpio
 open /root/res/language_Russian.qm
font=efont
font-size=16
[Mid] start init
[MID]load RTSP
[pci_vdd_open, 50]: Try to open a non-exist dev[0x5].
[hi_mcc_userdev_release, 113]: handle is not open.
## check device 0x1
dev[1] shared memory[0xbf800000]
[host_check_slv, 413]: shm base 0xbf800000
    First half:
     data_base: 0xd6000080, data_end: 0xd605ff40
          section start: 0xd6000080, section end: 0xd6020000
          section start: 0xd6020100, section end: 0xd605ff40
    Second half:
     data_base: 0xd6060080, data_end: 0xd60bff40
          section start: 0xd6060080, section end: 0xd6080000
          section start: 0xd6080100, section end: 0xd60bff40
AEC_Init error framelen(320)
[Func]:MPI_AI_AecInit [Line]:375 [Info]:aec open fail.
MidLibInfo.nNvrCurrExMode = 2
[NVR/DVR] [dvr/enc] = 0 nvr = 36 dec = 36
pAntsDVRInfo->byChanNum = 0 byDecodeChans = 36
!!pAntsDVRInfo->byChanNum = 0 byDecodeChans = 36 LocalChannelnum= 12
ANTS_Sys_GetDmaAddr ok 0xafe23000 0xa7214000 33554432
[enable] all
[disable] RTSP
load ipc proto /root/ipc_libs/libonvif.so
load ipc proto /root/ipc_libs/libi9.so
load ipc proto /root/ipc_libs/libi12.so
load ipc proto /root/ipc_libs/libi8h.so
load ipc proto /root/ipc_libs/libi8.so
load ipc proto /root/ipc_libs/libi8s.so
.........................stacksize = 8388608  -16384
dwNVRChnum = 36
[0/1] bSlaveReady= 0
[MasterSlaveThreadAll.7825] new i = 0
[1 ->1 bSlaveReady= 1
[0/1] bSlaveReady= 1
byDecodeChans = 4 dwRealDecodeChnNum = 36 bDeviceInfo_AuxRecord = 1 dwDecodChnNum = 36 ReplayChnNum=4
******MidLibInfo.dwTotalChnNum  = 36,[1,15b,2]  36
[SaveHDCfg.7320]
[ANTS_DVR_LogicLayer_Init.5962.zero]Support = 0
system:rm -fr /tmp/sata
[SaveHDCfg.7320]
sd_serialport.cpp:213 No such file or directory
serial232 not op[GPIO] GPIOGET_WATCHDOG Enable chardata = 1!!!
en[MID] net server load...
killall wpa_supplicant
[MasterSlaveThreadAll.7825] new i = 1
killall: wpa_supplicant: no process killed
[MasterSlaveThreadAll.7825] new i = 2
[StopWPASupplicant:2722] killall wpa_supplicant result[0]
[ANTS_SERVER_Initialize:9857] rm -rf  /usr/etc/udhcpc_* result[0]
[MasterSlaveThreadAll.7825] new i = 3
[ANTS_SERVER_Initialize:9867] mkdir -p /var/run/wpa_supplicant result[0]
[ANTS_SERVER_Initialize:9877] chmod -R 777 /usr/etc/ppp result[0]
chmod: /usr/etc/var: No such file or directory
[ANTS_SERVER_Initialize:9887] chmod -R 777 /usr/etc/var result[0]
[ANTS_SERVER_Initialize:9897] chmod 777 /etc/resolv.conf result[0]
chmod: /etc/ppp/resolv.conf: No such file or directory
[ANTS_SERVER_Initialize:9907] chmod 777 /etc/ppp/resolv.conf result[0]
[I8-Server] [src/AntsServerSDK.cpp:9447:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_peanuthull.so
[I8-Server] [src/AntsServerSDK.cpp:9447:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_noip.so
[I8-Server] [src/AntsServerSDK.cpp:9447:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_dnsdynamic.so
[I8-Server] [src/AntsServerSDK.cpp:9447:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_dyndns.so
[I8-Server] [src/AntsServerSDK.cpp:9447:GSVRLoadDDNSLib] Load ddns proto /root/ddns_libs/libddns_3322.so
[src/AntsServerSDK.cpp:00009617:GSVRInitDVR] GetDeviceType Result[33643300] DeviceType[NVR-15B-36CH]
[src/AntsServerSDK.cpp:4362:set_mac_addr] offset->8 sn->015b0123dff3b0f6095f
[src/AntsServerSDK.cpp:4371:set_mac_addr] MacAddrUnit ->f3 MacAddr->0xf3
[src/AntsServerSDK.cpp:4371:set_mac_addr] MacAddrUnit ->b0 MacAddr->0xb0
[src/AntsServerSDK.cpp:4371:set_mac_addr] MacAddrUnit ->f6 MacAddr->0xf6
[src/AntsServerSDK.cpp:4371:set_mac_addr] MacAddrUnit ->09 MacAddr->0x09
[src/AntsServerSDK.cpp:4371:set_mac_addr] MacAddrUnit ->5f MacAddr->0x5f
[src/AntsServerSDK.cpp:4380:set_mac_addr] mac[0] addr->0x00:0xf3:0xb0:0xf6:0x09:0x5f
[src/AntsServerSDK.cpp:4458:set_mac_addr] offset->8 sn->015b0123dff3b0f6095f
[src/AntsServerSDK.cpp:4467:set_mac_addr] MacAddrUnit ->f3 MacAddr->0xf3
[src/AntsServerSDK.cpp:4467:set_mac_addr] MacAddrUnit ->b0 MacAddr->0xb0
[src/AntsServerSDK.cpp:4467:set_mac_addr] MacAddrUnit ->f6 MacAddr->0xf6
[src/AntsServerSDK.cpp:4467:set_mac_addr] MacAddrUnit ->09 MacAddr->0x09
[src/AntsServerSDK.cpp:4467:set_mac_addr] MacAddrUnit ->5f MacAddr->0x5f
[src/AntsServerSDK.cpp:4476:set_mac_addr] mac[1] addr->0x02:0xf3:0xb0:0xf6:0x09:0x5f
[I8-Server] [src/AntsServerSDK.cpp:4495:set_mac_addr] ifconfig eth0 down
[set_mac_addr:4501] ifconfig eth0 down result[0]
[I8-Server] [src/AntsServerSDK.cpp:4569:set_mac_addr] ifconfig eth0 hw ether 0:f3:b0:f6:9:5f
MACADDR in set is 0:f3:b0:f6:9:5f
[set_mac_addr:4575] ifconfig eth0 hw ether 0:f3:b0:f6:9:5f result[0]
[I8-Server] [src/AntsServerSDK.cpp:4650:set_mac_addr] ifconfig eth0 192.168.1.188 netmask 255.255.255.0
[set_mac_addr:4657] ifconfig eth0 192.168.1.188 netmask 255.255.255.0 result[0]
[I8-Server] [src/AntsServerSDK.cpp:4766:set_mac_addr] route add default gw 192.168.1.1 eth0
[set_mac_addr:4806] route add default gw 192.168.1.1 eth0 result[0]
[set_loopback_addr:4863] ifconfig lo 127.0.0.1 netmask 255.0.0.0
[set_loopback_addr:4873] ifconfig lo 127.0.0.1 netmask 255.0.0.0 result[0]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[1] [DynDns]->[members.dyndns.org:80]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[2] [PeanutHull]->[ddns.oray.org:80]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[3] [No-IP]->[dynupdate.no-ip.com:80]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[4] [3322]->[members.3322.org:80]
[I8-Server] [src/AntsParameter.cpp:195:InitializeDDNSAbility] ddns[7] [DnsDynamic]->[www.dnsdynamic.org:80]
usb 3-1: new low-speed USB device number 2 using xhci-hcd
usb 3-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
input: USB OPTICAL MOUSE  as /devices/platform/hiusb3.0/usb3/3-1/3-1:1.0/input/input0
generic-usb 0003:0101:0007.0001: input: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-hiusb3.0-1/input0
[I8-Server] [943:CheckExternalIP] call cur wanip[]
ERROR: PPP link is not active on ppp0
route: SIOCDELRT: No such device
[MID] ARP server load...
[MID] ARP server load...ok
[MID] nvr ipcs load...
[MID] nvr ipcs load...ok
[MID] nvr host load...
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:84:time:14:25:27]g_struWebSiteSDKInfo.g_ChanNum===============================[36]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:85:time:14:25:27]g_struWebSiteSDKInfo.g_byIPChanNum===========================[36]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:86:time:14:25:27]g_struWebSiteSDKInfo.g_DVRType===============================[2]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:87:time:14:25:27]g_struWebSiteSDKInfo.g_AlarmOutPortNum=======================[4]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:88:time:14:25:27]g_struWebSiteSDKInfo.g_AlarmInPortNum========================[4]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:89:time:14:25:27]g_struWebSiteSDKInfo.g_byStartChan===========================[0]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:90:time:14:25:27]g_struWebSiteSDKInfo.sSerialNumberm==========================[015b0123dff3b0f6095f]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:99:time:14:25:27]g_struWebSiteSDKInfo.wDVRPort================================[5050]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:100:time:14:25:27]g_struWebSiteSDKInfo.wHttpPort===============================[80]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:101:time:14:25:27]g_struWebSiteSDKInfo.wHttpsPort==============================[4433]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:102:time:14:25:27]g_struWebSiteSDKInfo.wRTMPPort===============================[1935]
[WEBSDK][../../src/AntsWebCommon.c:Initia_DeviceInfo:109:time:14:25:27]g_struWebSiteSDKInfo.wRTSPPort===============================[554]
[WEBSDK][../../src/AntsWebSDK.c:ANTS_WEB_Start:434:time:14:25:28]Server Start
[11:06:02.210842] [1000][ants_dvr] COMPANYNAME is
[11:06:02.212315] [1000][ants_dvr] local port = 38800
[11:06:02.212785] [1000][ants_dvr] glnk_init:434: PushURL = meidian.push2u.com
[11:06:02.213228] [1000][ants_dvr] glnk_init end!
[11:06:02.213553] [1143][TSI_start] TSI_SetStatus:333: statue  [0] -> [1]   2204
[11:06:02.213627] [1143][TSI_start] TSI_SetStatus:333: statue  [1] -> [3]   2242
[WEBS][../../src/AntsWebSDK.c:0132:initWebs]WebPath[/root/web/www]
[WEBS][../../src/webs.c:0399:websOpenListen]Create websListenSocket[0x9c215950]
[WEBS][../../src/webs.c:0455:websOpenListen]Create AcceptThread[0x962124c0] DeleteThread[0x961124c0]
[WEBSDK][../../src/AntsWebSDK.c:initWebs:378:time:14:25:28]Call End
[WEBSDK][../../src/AntsWebSDK.c:AntsHostMgrLibStart:618:time:14:25:28]AntsHostMgrLibStart================================[1] SUCCESS
[MID] nvr host load.ok..
dwRuleNum1 = 0!!!!!!!!!!
system:echo 1 >/proc/sys/net/ipv4/ip_forward
system:iptables -t nat -F
modprobe: chdir(/lib/modules): No such file or directory
iptables v1.4.21: can't initialize iptables table `nat': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
dwRuleNum2 = 0!!!!!!!!!!
[MID] nvr rtsp/onvif/rtmp server load...
[MID] nvr rtsp/onvif/rtmp server load...ok
Ants_RTMPServer_Start !!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1935
[INFO.Ants_RTMPServer_Start.66]Ants_RTMPServer_Start  start!
[INFO.Ants_RTMPServer_Start.87]create i 1 start!
[RTMP] [server/server.cpp:00003087:Start] Start ok!
[RTMP] [server/server.cpp:00003131:StartListenThread] Create Listen Thread OK
[INFO.Ants_RTMPServer_Start.91]create i 1 end!
[INFO.Ants_RTMPServer_Start.102]hRtmpHandle = 1!
[INFO.Ants_RTMPServer_Start.106]Ants_RTMPServer_Start  end!
[INFO.Ants_RTMPServer_SetStreamCallBackV2.291]Ants_RTMPServer_SetStreamCallBack  start!
[INFO.Ants_RTMPServer_SetStreamCallBackV2.315]Ants_RTMPServer_SetStreamCallBack  end!
[INFO.Ants_RTMPServer_SetStreamCallBack.145]Ants_RTMPServer_SetStreamCallBack  start!
[INFO.Ants_RTMPServer_SetStreamCallBack.165]Ants_RTMPServer_SetStreamCallBack  end!
Ants_RTMPServer_Start !!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1935  ok
[RTMP][static void* CRtmpServer::ListenThread(void*):3378]pid=1161 enter
[INFO.ListenProc.3420]ListenProc  start!
ANTS_ONVIF_SERVER_Init !!!!!!!!!!!!!!!!!!!!!!!!!!!!! 8000  [95c77b38]
[ONVIFS-E][src/ants_onvif_server_api.c.ants_onvif_init.2599]init begin(Type = 0)
[Mid] start init
[ONVIFS-E][src/ants_onvif_server_api.c.ants_onvif_init.2657]NormalPort[8000] RtspPort[554] HttpPort[80]
[ONVIFS-E][src/ants_onvif_server_funs.c._Ants_onvif_Init_GetDeviceInfo.213]Get FactoryInfo Error
 open /usr/etc/myExceptionState.xml
erro[preview/preview.cpp SysAudio--4963]        no right stopAudio
GUI -->   [0/0] dwAbilityType= 2305 bsupp = 1
GUI -->   [1/1] dwAbilityType= 2306 bsupp = 1
GUI -->   [2/2] dwAbilityType= 2307 bsupp = 1
GUI -->   [3/3] dwAbilityType= 2308 bsupp = 1
GUI -->   [4/4] dwAbilityType= 2309 bsupp = 1
GUI -->   [5/5] dwAbilityType= 2310 bsupp = 1
GUI -->   [6/6] dwAbilityType= 2311 bsupp = 1
GUI -->   [7/7] dwAbilityType= 2312 bsupp = 1
[IPCMgrThreadAll.8087] new i = 0
[IPCMgrThreadAll.8087] new i = 1
[IPCMgrThreadAll.8087] new i = 2
[IPCMgrThreadAll.8087] new i = 3
[IPCMgrThreadAll.8087] new i = 4
[IPCMgrThreadAll.8087] new i = 5
 QLinuxFbScreen::disconnect
 munmap 8294400
DBG[embedded/qscreenlinuxfb_qws.cpp connect--350]       QLinuxFbScreen::connect /dev/fb0
 open /dev/fb0
DBG[embedded/qscreenlinuxfb_qws.cpp connect--469]       vinfo.xres 1280 1024
DBG[embedded/qscreenlinuxfb_qws.cpp connect--481]       d_ptr->fd 8 vinfo xres 1280, xres_virtual1280
 bits_per_pixel 32
 r g b 8 8 8
 d = 32
DBG[embedded/qscreenlinuxfb_qws.cpp connect--554]       dw is 1280,dh is 1024 lstep 5120
vm.drop_caches = 3
 open /root/res/prv_voice.png
 open /root/res/pre_capture.png
 open /root/res/pre_start.png
 open /root/res/pre_screen.png
 open /root/res/pre_ptz.png
 open /root/res/pre_config.png
 open /root/res/pre_playback.png
 open /root/res/pre_backup.png
 open /root/res/pre_alarm.png
 open /root/res/pre_file.png
 open /root/res/pre_record.png
I/O warning : failed to load external entity "/usr/etc/onvif_cfg.xml"
[ONVIFS-E][src/ants_onvif_server_api.c.ants_onvif_init.2701]init end
ANTS_ONVIF_SERVER_Init !!!!!!!!!!!!!!!!!!!!!!!!!!!!! 8000  [95c77b38] ok
Ants_RTSPServer_Start !!!!!!!!!!!!!!!!!!!!!!!!!!!!! 554
 open /root/res/pre_link_addipc.png
[0] Net out
[I8S] build Mar  3 2016 16:28:47
local mac[0] [0 f3 b0 f6 9 5f]
[0] Net out
[I8-Server] [959:CheckExternalIP] call failed(wanip[])
[0] Net out
[0] Net out
PHY: 1:02 - Link is Up - 1000/Full
delete 1 nDelIdx = 0
delete 2  nStart = 0
delete 2  nStart = 0
delete 2  nStart = 2
[11:06:22.814609] [1143][TSI_start] TSI_SetStatus:333: statue  [3] -> [2]   2262
dapper
Сообщение dapper » 07 мар 2017, 12:01
Да, что меня еще сбило с толку и отняло кучу времени - на плате китаец маркером написал возле флешки "N6001-64EH". Как я понял, когда-то на этой двухпроцессорной базе действительно выпускалась эта модель, но всё, что сейчас есть на рынке под этой маркой - базируется на одном Hi3536. Прошивки от них естественно не подошли :)
Сообщение iTuneDVR » 07 мар 2017, 12:11
Прошивки отличаются, даже размером и не слабо!!!
Однако, процесс восстановления аналогичный и рабочий, файлы с флешки для восстановления беруться, а значит аналогичные правильные есть и для твоего аппарата, просто другие.
