Помогите восстановить NVR small gige v1.1
Добавлено: 25 мар 2017, 23:29
Умерла прошивка. Залил с похожего регистратора, не работает. Помогите подобрать прошивку к этой плате или подскажите как можно исправить.
U-Boot 2010.06 (May 06 2014 - 20:57:31)
NAND: Check nand flash controller v504. found
Special NAND id table Version 1.36
Nand ID: 0xC2 0xF1 0x80 0x1D 0xC2 0xF1 0x80 0x1D
Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4bits/512Byte
128 MiB
Can't find a valid spi flash chip.
(Re)start USB...
USB: scanning bus for devices... 1 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
NAND read: device 0 offset 0x7c00000, size 0x40000
262144 bytes read: OK
mmu_enable
<<imgwidth=1024, imgheight=768, linebytes=2048>>
decode success!!!!
dev 0 set background color!
dev 2 set background color!
dev 0 opened!
dev 2 opened!
graphic layer 0 opened!
graphic layer 2 opened!
NAND read: device 0 offset 0x100000, size 0x300000
3145728 bytes read: OK
Image Name: Linux-3.4.35_hi3535
Data Size: 2845328 Bytes = 2.7 MiB
Entry Point: 80008000
Booting Linux on physical CPU 0
Linux version 3.4.35_hi3535 (root@sqy-desktop) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.32.1+eabi+linuxpthread)) ) #96 SMP Mon Oct 13 11:05:21 CST 2014
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: hi3535
Truncating memory at 0x80000000 to fit in 32-bit physical address space
PERCPU: Embedded 7 pages/cpu @c087c000 s6528 r8192 d13952 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 48768
Kernel command line: mem=192M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=yaffs2 mtdparts=hinand:1M(uboot),3M(kernel),90M(rfs),20M(app),10M(config),4M(logo)
Memory: 192MB = 192MB total
Memory: 187648k/187648k available, 8960k reserved, 0K highmem
vmalloc : 0xcc800000 - 0xff000000 ( 808 MB)
lowmem : 0xc0000000 - 0xcc000000 ( 192 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0677000 (6588 kB)
.init : 0xc0677000 - 0xc06a4980 ( 183 kB)
.data : 0xc06a6000 - 0xc06d6d20 ( 196 kB)
.bss : 0xc06d6d44 - 0xc06f8ac4 ( 136 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:128
sched_clock: 32 bits at 62MHz, resolution 16ns, wraps every 68719ms
Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
Initializing cgroup subsys freezer
CPU0: thread -1, cpu 0, sock)et 0, mpidr 80000000
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x8052cba0 - 0x8052cbd4
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x72430001, Cache size: 262144 B
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3981.31 BogoMIPS).
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
console [ttyAMA0] enabled
Switching to clocksource timer0
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: reno registered
UDP hash table entries: 128 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.18)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 366
encryption fail
no need alpu
no ack
sha204_sn is 1
sha204_sn is 23
sha204_sn is 80
sha204_sn is 88
sha204_sn is 8e
sha204_sn is 7b
sha204_sn is 48
sha204_sn is bc
sha204_sn is ee
sha204_devinfo is 44 i is 0
sha204_devinfo is 56 i is 1
sha204_devinfo is 52 i is 2
sha204_devinfo is 32 i is 3
sha204_devinfo is 33 i is 4
sha204_devinfo is 35 i is 5
sha204_devinfo is 31 i is 6
sha204_devinfo is 35 i is 7
sha204_devinfo is 30 i is 8
sha204_devinfo is 34 i is 9
sha204_devinfo is 1 i is 10
sha204_devinfo is 5d i is 11
sha204_devinfo is 0 i is 12
sha204_devinfo is 0 i is 13
sha204_devinfo is 0 i is 14
sha204_devinfo is 0 i is 15
TempKey is 2e
TempKey is 83
TempKey is 60
TempKey is 85
TempKey is 93
TempKey is 6d
TempKey is 26
TempKey is 2
TempKey is 84
TempKey is bd
TempKey is 4d
TempKey is dc
TempKey is 32
TempKey is 31
TempKey is 2c
TempKey is 1b
TempKey is 62
TempKey is 92
TempKey is 79
TempKey is 3b
TempKey is 68
TempKey is bf
TempKey is 97
TempKey is d0
TempKey is 77
TempKey is d6
TempKey is ba
TempKey is 97
TempKey is f3
TempKey is c3
TempKey is 47
TempKey is e5
encryption ok
io scheduler cfq registered
ahci ahci.0: AHCI 0001.0300 32 slots 3 ports 6 Gbps 0x7 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp fbs slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
scsi2 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x100 irq 63
ata2: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x180 irq 63
ata3: SATA max UDMA/133 mmio [mem 0x12010000-0x1201ffff] port 0x200 irq 63
Spi id table Version 1.22
Found Nand Flash Controller V504.
Nand: Macronix NAND 128MiB 3,3V 8-bit
Nand(Hardware): Block:128KB Page:2KB OOB:64B ECC:4bits/512Byte Chip:128MB*1
6 cmdlinepart partitions found on MTD device hinand
Creating 6 MTD partitions on "hinand":
0x000000000000-0x000000100000 : "uboot"
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000005e00000 : "rfs"
0x000005e00000-0x000007200000 : "app"
0x000007200000-0x000007c00000 : "config"
0x000007c00000-0x000008000000 : "logo"
usbcore: registered new interface driver rt2800usb
hiusb-ehci hiusb-ehci.0: irq 54, io mem 0x10040000
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 53, io mem 0x10030000
hub 2-0:1.0: 2 ports detected
xhci-hcd hiusb3.0: xHCI Host Controller
xhci-hcd hiusb3.0: new USB bus registered, assigned bus number 3
xhci-hcd hiusb3.0: irq 64, io mem 0x12000000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
xhci-hcd hiusb3.0: new USB bus registered, assigned bus number 4
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
usbhid: USB HID core driver
TCP: cubic registered
ata3: SATA link down (SStatus 0 SControl 300)
yaffs: dev is 32505858 name is "mtdblock2" rw
yaffs: passed flags ""
VFS: Mounted root (yaffs2 filesystem) on device 31:2.
Freeing init memory: 180K
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
CPU0: stopping
Backtrace:
[<c000dbc0>] (dump_backtrace+0x0/0x110) from [<c05299b8>] (dump_stack+0x18/0x1c)
r6:c06b24c0 r5:c06a6000 r4:00000001 r3:00000000
[<c05299a0>] (dump_stack+0x0/0x1c) from [<c000eda0>] (handle_IPI+0x1d4/0x1f4)
[<c000ebcc>] (handle_IPI+0x0/0x1f4) from [<c000850c>] (gic_handle_irq+0x64/0x68)
[<c00084a8>] (gic_handle_irq+0x0/0x68) from [<c00090e0>] (__irq_svc+0x40/0x50)
Exception stack(0xc06a7f30 to 0xc06a7f78)
7f20: 00000003 c06b2564 00000000 00000000
7f40: c06a6000 c06d6e48 c052f120 c06b5910 00000000 414fc091 00000000 c06a7f84
7f60: c06a7f88 c06a7f78 c000a788 c000a78c 60000013 ffffffff
r7:c06a7f64 r6:ffffffff r5:60000013 r4:c000a78c
[<c000a758>] (default_idle+0x0/0x38) from [<c000aed4>] (cpu_idle+0xc0/0xf0)
[<c000ae14>] (cpu_idle+0x0/0xf0) from [<c0524bec>] (rest_init+0x78/0x7c)
r7:bfffffff r6:c069d9a4 r5:c06d6d80 r4:c06b2610
[<c0524b74>] (rest_init+0x0/0x7c) from [<c06779b8>] (start_kernel+0x2f4/0x300)
[<c06776c4>] (start_kernel+0x0/0x300) from [<80008044>] (0x80008044)
