Re: AHB7808R-MH-V2
Добавлено: 28 апр 2017, 23:57
watchdog не срабатывает, висит и намека на ребут не видно.
Сайт-мотиватор ИТ исследований систем видеонаблюдения: DVR, NVR, IPC, NVS, PC+ПО
http://itunedvr.ru/forum/phpBB3/
KiFFiR писал(а):watchdog не срабатывает, висит и намека на ребут не видно.
appauto=1
dh_keyboard=1
U-Boot 2010.06-svn283 (Nov 05 2015 - 17:38:49)
SPI Nor(cs 0) ID: 0xc2 0x20 0x17
Block:64KB Chip:8MB Name:"MX25L6406E"
SPI Nor total size: 8MB
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
change register for 8710
CONFIG MII
ETH0: PHY(phyaddr=2, rgmii) not link!
higmac init fail!
Press CTRL-C to abort autoboot in 2 seconds8192 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
### /UbootLogo UbootLogoload complete: 21986 bytes loaded to 0x8e800000
jpeg decoding ...
<<addr=0x8e800000, size=0xb85f9, vobuf=0x8f000000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
OpenDev vo:0 intf_type:36 out_sync:16
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 1311, type 1
find_squashfs_file: name boot, start_block 0, offset 1403, type 1
read inode: name boot, sb 0, of 1403, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 1343, type 2
read inode: name zImage.img, sb 0, of 1343, type 2
### FS load complete: 1586768 bytes loaded to 0x82000000
Image Name: linux
Data Size: 1586704 Bytes = 1.5 MiB
Entry Point: 80008000
Booting Linux on physical CPU 0x0
Linux version 3.10.0 (wutao@localhost.localdomain) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) ) #4 Wed Dec 28 19:07:06 CST 2016
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: bigfish
CPU: All CPU(s) started in SVC mode.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 25400
Kernel command line: mem=100Mconsole=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),2432K(romfs),3520K(usr),1664K(custom),64K(logo),320K(mtd) coherent_pool=2M
Memory: 100MB = 100MB total
Memory: 97228k/97228k available, 5172k reserved, 0K highmem
vmalloc : 0xc6800000 - 0xff000000 ( 904 MB)
lowmem : 0xc0000000 - 0xc6400000 ( 100 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc03b44a0 (3762 kB)
.init : 0xc03b5000 - 0xc03d243c ( 118 kB)
.data : 0xc03d4000 - 0xc03fde40 ( 168 kB)
.bss : 0xc03fde40 - 0xc041e310 ( 130 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:128
GIC CPU mask not found - kernel will fail to boot.
sched_clock: 32 bits at 62MHz, resolution 16ns, wraps every 68719ms
Calibrating delay loop... 2190.54 BogoMIPS (lpj=10952704)
Setting up static identity map for 0xc02b7f70 - 0xc02b7fc8
DMA: preallocated 2048 KiB pool for atomic coherent allocations
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
uart:0: ttyAMA0 at MMIO 0x12080000 (irq = 38) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x12090000 (irq = 39) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x120a0000 (irq = 40) is a PL011 rev2
hi-spi-master hi-spi-master.0: with 2 chip select slaves attached
Switching to clocksource timer0
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
CPU PMU: probing PMU on CPU 0
hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 189
io scheduler noop registered (default)
hiahci: initializing
ahci ahci.0: can't get clock
ahci ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp fbs slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x11010000-0x1101ffff] port 0x100 irq 49
ata2: SATA max UDMA/133 mmio [mem 0x11010000-0x1101ffff] port 0x180 irq 49
Spi id table Version 1.22
Spi(cs0):
Block:64KB Chip:8MB
6 cmdlinepart partitions found on MTD device hi_sfc
0x000000000000-0x000000030000 : "boot"
0x000000030000-0x000000290000 : "romfs"
0x000000290000-0x000000600000 : "usr"
0x000000600000-0x0000007a0000 : "custom"
0x0000007a0000-0x0000007b0000 : "logo"
0x0000007b0000-0x000000800000 : "mtd"
Higmac dma_sg_phy: 0x85400000
libphy: higmac_mdio_bus: probed
Net PHY: LAN8710
at higmac_demux() phy_intf:1 [1:mii,5:rmii,6:rgmii];MAC_TXCKOUT_MUX_REG value:0x2 [1,rgmii;2,mii;3,rmii;]
ETH0: mii, phy_addr=2, mii_name=mdio0
before uhci_hcd and ohci_hcd, not after
hiusb-ehci hiusb-ehci.0: irq 51, io mem 0x10040000
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 50, io mem 0x10030000
hub 2-0:1.0: 2 ports detected
usbhid: USB HID core driver
TCP: cubic registered
sit: IPv6 over IPv4 tunneling driver
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
Freeing unused kernel memory: 116K (c03b5000 - c03d2000)
init started: BusyBox v1.20.2 (2016-12-07 15:16:29 CST)
mount: mounting none on /proc/bus/usb/ failed: No such file or directory
MEM_START=0x86400000 HVRMEM=100Mconsole=ttyAMA0,115200 MEM_LEN=412M
Module himedia: init ok
hi3521a_base: module license 'Proprietary' taints kernel.
load sys.ko for Hi3521A...OK!
load vdec.ko ....OK
load vhd firmware.ko OK
Load hi_tde.ko success. (SDK_VERSION:[SDK_VERSION] Build Time:[Dec 19 2015, 17:57:57])
load region.ko ....OK!
load vgs.ko for Hi3521A...OK!
load viu.ko ...OK!
load vpss.ko ....OK!
load vou.ko ....OK!
load hdmi.ko ....OK!
load rc.ko for Hi3521A...OK!
load venc.ko for Hi3521A...OK!
load chnl.ko for Hi3521A...OK!
load h264e.ko for Hi3521A...OK!
load vda.ko ....OK!
load ive.ko ... OK!
FVIDEO driver init start ...
fvideo driver init successful!
| HIRTC: SVN:43,Compiled by jinweiwei at Jul 20 2015 14:38:23 |
at24c16:========================================================
at24c16:Driver Version=20150717 DateTime=Aug 24 2015-11:05:22.
at24c16:Driver for HISI3521A Linux 3.10.0 (by jinweiwei).
gpio_i2c_wread_24c16 0x33:ff
gpio_i2c_read_24c16 0x34:ff
insmod: can't insert 'extdrv/at24c.ko': Operation not permitted
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 1)
| HIWDT: SVN:43,Compiled by jinweiwei at Jul 18 2015 13:56:14 |
HISI_IRDA-MF @Hi3521Av100R001
| HIIR: SVN:49,Compiled by jinweiwei at Jul 20 2015 14:43:41 |
hiir: init ok. ver=Jul 20 2015, 14:43:41.
insert audio
[reg] = 0x12150200,[val]= 0x00000080
./loadmod: line 16: ./S81toe: not found
ifconfig: SIOCGIFFLAGS: No such device
ifconfig: SIOCSIFADDR: No such device
env_init: mtd0,start:58000000,size:30000,esize:10000 name:boot"
/etc/init.d/rcS: line 30: dogtest: not found
/etc/init.d/rcS: line 29: routedaemon: not found
env_init 264
Get telnetctrl Fialed, telnetctrl=1
write 9527close to file .
macGuarder: Close telnetd Forever
LIBDVR:Open 9530COM.
CryptoCreate Open Crypto Failed!
LibCrypto : at24c - write reg error
LibCrypto :IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
atmagic[0]=0,atmagic[1]=0 at24
flash read buf[0]=[d2], buf[1]=[d4]
LibCrypto : g_cryptotype mem= 2
LIBDVR : getmac_from_crypto:use gen_mac
line:HOSTIP = 192.168.88.4
line:
line:SUBMASK = 255.255.255.0
line:
line:GATEWAYIP = 192.168.88.1
line:
/etc/init.d/rcS: line 46: /mnt/custom/extapp.sh: not found
PPPD: Start PPPD deamon, Version 1.0.0 Build Time: Aug 28 2015 09:27:16
| PPPD: SVN:11,Compiled by zhaoqiting at Aug 28 2015 09:27:16 |
PPPD: Open /mnt/mtd/Config/ppp/pppoe-enable file failed!
dvrHelper version: Dec 7 2016
env_init 264
Get xmauto Fialed ,xmauto = 1
<<<<<<<<<<<xm_auto=1 ...>>>>>>>>>>>>>>>>>>>
Cannot connect with 127.0.0.1 to send log.
/var/Sofia is starting ...
<<<<<<<<<<at inter_proc(): Create the pthread 9527.>>>>>>>>
at inter_bebug(): This is thread 9527 inter_bebug.>>>>>>>>
Get xmuart Fialed ,xmuart = 1
hidog_ioctl
hidog_ioctl
PPPD: Disable PPPOE!
sf probe 0
