AHB7808R-MH-V2
Добавлено: 28 апр 2017, 00:36
На днях преобрел за 10 рублей плату данную, решил поднять для себя. Осмотр показал прошибленный стаб, заменен и во а ля, загрузка пошла. Но завис на заставке зверь, прошивка улетела от перепада напруги видимо, прошивка скачана с ХМ, каким образом ее скормить, uImage из чего слепить?
Вот чего показывает загрузчик
U-Boot 2010.06-svn283 (Nov 05 2015 - 17:38:49)
SPI Nor(cs 0) ID: 0xc2 0x20 0x17
Block:64KB Chip:8MB Name:"MX25L6406E"
SPI Nor total size: 8MB
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
change register for 8710
CONFIG MII
ETH0: PHY(phyaddr=2, rgmii) not link!
higmac init fail!
Press CTRL-C to abort autoboot in 2 seconds8192 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
### /UbootLogo UbootLogoload complete: 21986 bytes loaded to 0x8e800000
jpeg decoding ...
<<addr=0x8e800000, size=0xb85f9, vobuf=0x8f000000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
OpenDev vo:0 intf_type:36 out_sync:16
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 1311, type 1
find_squashfs_file: name boot, start_block 0, offset 1403, type 1
read inode: name boot, sb 0, of 1403, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 1343, type 2
read inode: name zImage.img, sb 0, of 1343, type 2
### FS load complete: 1618160 bytes loaded to 0x82000000
Image Name: linux
Data Size: 1618096 Bytes = 1.5 MiB
Entry Point: 80008000
Booting Linux on physical CPU 0x0
Linux version 3.10.0 (leixinyuan@localhost) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) ) #41 Thu Nov 5 14:50:25 CST 2015
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: bigfish
CPU: All CPU(s) started in SVC mode.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 25400
Kernel command line: mem=100Mconsole=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),2432K(romfs),3520K(usr),1664K(custom),64K(logo),320K(mtd) coherent_pool=2M
Memory: 100MB = 100MB total
Memory: 97236k/97236k available, 5164k reserved, 0K highmem
vmalloc : 0xc6800000 - 0xff000000 ( 904 MB)
lowmem : 0xc0000000 - 0xc6400000 ( 100 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc03b7d54 (3776 kB)
.init : 0xc03b8000 - 0xc03d4924 ( 115 kB)
.data : 0xc03d6000 - 0xc03fdfc0 ( 160 kB)
.bss : 0xc03fdfc0 - 0xc041cb78 ( 123 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:128
GIC CPU mask not found - kernel will fail to boot.
sched_clock: 32 bits at 62MHz, resolution 16ns, wraps every 68719ms
Calibrating delay loop... 2190.54 BogoMIPS (lpj=10952704)
Setting up static identity map for 0xc02c2030 - 0xc02c2088
DMA: preallocated 2048 KiB pool for atomic coherent allocations
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
uart:0: ttyAMA0 at MMIO 0x12080000 (irq = 38) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x12090000 (irq = 39) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x120a0000 (irq = 40) is a PL011 rev2
hi-spi-master hi-spi-master.0: with 2 chip select slaves attached
Switching to clocksource timer0
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
CPU PMU: probing PMU on CPU 0
hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 189
io scheduler noop registered (default)
hiahci: initializing
ahci ahci.0: can't get clock
ahci ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp fbs slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x11010000-0x1101ffff] port 0x100 irq 49
ata2: SATA max UDMA/133 mmio [mem 0x11010000-0x1101ffff] port 0x180 irq 49
Spi id table Version 1.22
Spi(cs0):
Block:64KB Chip:8MB
6 cmdlinepart partitions found on MTD device hi_sfc
0x000000000000-0x000000030000 : "boot"
0x000000030000-0x000000290000 : "romfs"
0x000000290000-0x000000600000 : "usr"
0x000000600000-0x0000007a0000 : "custom"
0x0000007a0000-0x0000007b0000 : "logo"
0x0000007b0000-0x000000800000 : "mtd"
Higmac dma_sg_phy: 0x85400000
libphy: higmac_mdio_bus: probed
ETH0: rgmii, phy_addr=2, mii_name=mdio0
before uhci_hcd and ohci_hcd, not after
hiusb-ehci hiusb-ehci.0: irq 51, io mem 0x10040000
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 50, io mem 0x10030000
и printenv
CONFIG MII
higmac init fail!
Press CTRL-C to abort autoboot in 2 secondshisilicon # <INTERRUPT>
hisilicon # printenv
bootcmd=sf probe 0;sf read 0x84000000 0x7a0000 0x10000;logoload 0x84000000;decjpg;sf read 0x82000000 0x30000 0x300000;squashfsload 82000000;bootm 0x82000000
bootdelay=1
ethaddr=00:0b:3f:00:00:01
ipaddr=192.168.1.10
serverip=192.168.1.12
netmask=255.255.0.0
gatewayip=192.168.1.1
da=mw.b 0x82000000 ff 1000000;tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=mw.b 0x82000000 ff 1000000;tftp 0x82000000 update.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
dd=mw.b 0x82000000 ff 1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
bootargs=mem=100Mconsole=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),2432K(romfs),3520K(usr),1664K(custom),64K(logo),320K(mtd) coherent_pool=2M
appVideoStandard=PAL
appSystemLanguage=Russian
ver=U-Boot 2010.06-svn283 (Nov 05 2015 - 17:38:49)
Environment size: 1372/65532 bytes
hisilicon #
CONFIG MII
higmac init fail!
CFG_BOOT_ADDR:0x0
jpeg decoding ...
decode success!!!!
decode jpeg!
Image Name: linux
Machine: bigfish
NR_IRQS:128
Spi(cs0):
Block:64KB Chip:8MB
и printenv
CONFIG MII
higmac init fail!
bootdelay=1
ipaddr=192.168.1.10
netmask=255.255.0.0
hisilicon #
