Jassun JSR-P0803 нет старта
Re: Jassun JSR-P0803 нет старта
Сообщение fobos » 10 май 2017, 22:26
методом проб и ошибок нашелся бут, с которым все завелось, правда при первом запуске был хворост, но вслепую удалось переключиться на русский язык. теперь вывод help&printenv выглядит следующим образом:
hisilicon # help
?       - alias for 'help'
base    - print or set address offset
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
bootp   - boot image via network using BOOTP/TFTP protocol
cmp     - memory compare
cp      - memory copy
decjpg  - jpgd   - decode jpeg picture.
ext2load- load binary file from a Ext2 filesystem
ext2ls  - list files in a directory (default /)
fatls   - list files in a directory (default /)
fload   - fload  - load binary file from a filesystem image for system boot
flwrite - SPI flash sub-system
getinfo - print hardware information
help    - print command description/usage
lip     - lip      - set local ip address but not save to flash
lload   - lload  - load logo file
logoload- logoload  - load binary file from a filesystem image for system boot
loop    - infinite loop on address range
mac     - mac      - set mac address and save to flash
md      - memory display
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mtest   - simple RAM read/write test
mw      - memory write (fill)
nm      - memory modify (constant address)
sf      - SPI flash sub-system
sip     - sip      - set server ip address but not save to flash
squashfsload- fsload  - load binary file from a filesystem image
tftp    - tftp   - download or upload image via network using TFTP protocol
usb     - USB sub-system
hisilicon #
hisilicon # printenv
bootcmd=sf probe 0;sf read 84000000 e80000 40000;logoload 84000000;decjpg;fload;bootm 0x82000000
bootdelay=1
restore=1
da=mw.b 0x82000000 ff 1000000;tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=mw.b 0x82000000 ff 1000000;tftp 0x82000000 update.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
dd=mw.b 0x82000000 ff 1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
ipaddr=192.168.1.10
serverip=192.168.1.1
gatewayip=192.168.0.1
ethaddr=00:0b:3f:00:00:01
bootargs=mem=105M console=ttyAMA0,115200 root=1f01 rootfstype=cramfs mtdparts=hi_sfc:512K(boot),4M(romfs),5632K(usr),1536K(web),3M(custom),256K(logo),1280K(mtd)
appSystemLanguage=Russian
appVideoStandard=PAL
ver=U-Boot 2010.06-svn200 (Dec 05 2014 - 13:19:22)
Environment size: 1302/262140 bytes
hisilicon #
Сообщение iTuneDVR » 10 май 2017, 23:00
Ну там не особо и в слепую, потому как там всё до боли знакомо! ;)
В итоге всё нормально?
Сообщение fobos » 10 май 2017, 23:05
Да, все ок!
Сообщение iTuneDVR » 10 май 2017, 23:19
fobos писал(а):Да, все ок!
Ну, вот, я рад!
Вернуться в «Видеорегистраторы Jassun»
