Страница 5 из 6
Re: Прошивка для DH-DVR0404HF-AN
Добавлено: 13 окт 2017, 00:09
На видимости надо посмотреть, но очень аккуратно!
Добавлено: 13 окт 2017, 00:48
veter737
U-Boot 2010.06 (Sep 20 2012 - 19:42:06) svn:477
23:45:20.911>
23:45:20.911>
23:45:20.911>
23:45:20.911> TI8148-GP rev 2.1
23:45:20.911>
23:45:20.911>
23:45:20.911>
23:45:20.911> N56_DVR Run at mode: A
23:45:20.911>
23:45:20.911>
23:45:20.911>
23:45:21.599> SF: Detected MX25L12805D with page size 256, total 16777216 bytes
23:45:21.599>
23:45:22.036> Net: Detected MACID:90:d7:eb:c3:b8:66
23:45:22.036>
23:45:22.036> cpsw
23:45:22.036>
23:45:23.848> Hit any key to stop autoboot: 0
23:45:23.848>
23:45:29.027> Auto negotitation failed
23:45:29.027>
23:45:29.027> Set skew to 1.4ns ...
23:45:29.027>
23:45:29.401> netup time out: 2
23:45:29.401>
23:45:31.086> Timeout
23:45:31.086>
23:45:31.648> SF: Detected MX25L12805D with page size 256, total 16777216 bytes
23:45:31.648>
23:45:32.521> SPI probe: 16384 KiB MX25L12805D at 0:0 is now current device
23:45:32.521>
23:45:33.395> ### CRAMFS loading '/boot/uImage' to 0x80007fc0
23:45:33.395>
23:45:36.283> ### CRAMFS load complete: 2430160 bytes loaded to 0x80007fc0
23:45:36.283>
23:45:36.283> ## Booting kernel from Legacy Image at 80007fc0 ...
23:45:36.283>
23:45:36.283> Image Name: Linux-2.6.37
23:45:36.283>
23:45:36.283> Image Type: ARM Linux Kernel Image (uncompressed)
23:45:36.283>
23:45:36.283> Data Size: 2430096 Bytes = 2.3 MiB
23:45:36.283>
23:45:36.283> Load Address: 80008000
23:45:36.283>
23:45:36.283> Entry Point: 80008000
23:45:36.283>
23:45:38.202> Verifying Checksum ... OK
23:45:38.202>
23:45:38.202> Loading Kernel Image ... OK
23:45:38.202>
23:45:38.202> OK
23:45:38.202>
23:45:38.202>
23:45:38.202>
23:45:38.202> Starting kernel ... mem=128M, console=ttyO0,115200n8 rootfstype=cramfs root=/dev/mtdblock1 earlyprintk netmode=RGMII watchdog=1 notifyk.vpssm3_sva=0xBFD00000 dh_keyboard=1 load_modules=1 m3_print=1 watchdog=1
23:45:38.202>
23:45:38.202>
23:45:38.202>
23:45:38.202> Uncompressing Linux... done, booting the kernel.
23:45:38.202>
то что теперь выдает терминал
3:45:38.202> Starting kernel ... mem=128M, console=ttyO0,115200n8 rootfstype=cramfs root=/dev/mtdblock1 earlyprintk netmode=RGMII watchdog=1 notifyk.vpssm3_sva=0xBFD00000 dh_keyboard=1 load_modules=1 m3_print=1 watchdog=1-----вот это не понятно????
Добавлено: 13 окт 2017, 01:51
Остановить загрузку.
и увидишь движ
Добавлено: 13 окт 2017, 23:04
veter737
Как остановить загрузку((((клавиша * не помогает(Putty///ncom///terminal Restart the DVR,press “***” key of your PC keyboard quickly
уже все подрят жму-----никак
Добавлено: 13 окт 2017, 23:16
Должна работать, если все подключено правильно.
Если большая обычнач клавиатура, но на цифровой части справа, если ноут то shift+8
Есть и другой вариант: зайти телнетом и там установить переменную и перезагрузится. Может и прокатить.
Клавишу удавить и держать.
Пробуй разные терминалы!
Добавлено: 14 окт 2017, 19:18
veter737
Хоть руки отрубай...ни как ((((и контакты менял..и клавиатуру....и терминалы...как заколдованый...
TFTP Server должен быть подключен чтоб остановить загрузку в NCom????
По телнету тож никак! начинает входить и выбрасывает на рабочий стол
Добавлено: 14 окт 2017, 20:23
Чудеса какие-то!
Выстави регистратор наружу в DMZ, адрес в почту и посмотрим.
Если специально не закрывал телнет, то все должно быть доступно!
Добавлено: 14 окт 2017, 22:27
veter737
Пересел за ноут --все заработало...ЧУДЕСА
iTuneDVR Спасибо за Вашу помощь )))Оба регистратора ожили!!!! Я вот только не помню были ли они на русском,может и нет))
Единственно что осталось у них теперь серийники и маки одинаковы....где то видел как поправить...может подскажете:-)))
Опыт уже маленький есть)))) прошил General_DVRxx04LF-A_Eng_P_V2.608.0000.6.R.20170312 похоже последняя! Полет нормальный(Русского нет)
Добавлено: 15 окт 2017, 00:02
veter737 писал(а):Пересел за ноут --все заработало...ЧУДЕСА
Пожалуйста!
veter737 писал(а):Оба регистратора ожили!!!! Я вот только не помню были ли они на русском,может и нет))
Русификаторы доступны на старые прошивки!
veter737 писал(а): Единственно что осталось у них теперь серийники и маки одинаковы....где то видел как поправить...может подскажете:-)))
Это так же в загрузчике устанавливается
Выполнить
и подправить значения через
veter737 писал(а):Опыт уже маленький есть)))) прошил General_DVRxx04LF-A_Eng_P_V2.608.0000.6.R.20170312 похоже последняя! Полет нормальный(Русского нет)
Прошивки не подписаны, поэтому можно пробовать старые русификаторы, под конкретные модели!
Добавлено: 15 окт 2017, 14:05
veter737
Уваж. iTuneDVR мак востановил(благо на одном наклейка сохранилась с маком и серийным) теперь хоть в одной сети работать смогут СПАСИБО (я знаю что оно не булькает) может в лику напишите куда отправить)))))
Читал тему о русификации такого же регистратора...
viewtopic.php?t=744&start=30 но ни че ни понял
update_General_Rus_P_General_WebRus_General_N5_V2.606.0.R.101112 как например попробовать прошить отдельно этот бин???
как выдрать из дампа отдельно u-boot и отдельно его залить?
Рус или инглиш--не суть важно----это для собственного развития)))не зра ж паяльную станцию и программатор покупал))
Если ли конечно у Вас есть время)))
