Re: не грузится RVi-16LB-PRO
Добавлено: 17 июл 2017, 17:35
уже, ставлю на виртуал бокс линукс =)
Сайт-мотиватор ИТ исследований систем видеонаблюдения: DVR, NVR, IPC, NVS, PC+ПО
http://itunedvr.ru/forum/phpBB3/
Terminal log file
Date: 18.07.2017 - 8:41:16
FB_FEED
U-Boot 2010.06-svn1455 (Sep 22 2014 - 19:29:18)
DRAM: 256 MiB
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128BV"
judge ddr init
user init finish.C
Hit any key to stop autoboot: 3 2 1 0
Phy use RGMII!
netup time out: 1000
Timeout
Phy use RGMII!
Download to address: 0x80100000
Downloading: *T T T
Failed to get info.txt
### JFFS2 loading '/boot/uImage' to 0x82000000
squashfs use lzma
squashfs use lzma
### squashfs load complete: 2273056 bytes loaded to 0x82000000
Image Name: Linux-3.0.8
Data Size: 2272992 Bytes = 2.2 MiB
Entry Point: 80008000
Linux version 3.0.8 (he_liangbin@localhost.localdomain) (gcc version 4.4.1 (Hisilicon_v200(gcc4.4-290+glibc-2.11+eabi+nptl)) ) #3 SMP Tue May 20 19:32:54 CST 2014, svn:3264
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Machine: godnet
chip type is hi3531
bus_clk = 310000000
PERCPU: Embedded 7 pages/cpu @c07d3000 s5120 r8192 d15360 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 63500
Kernel command line: mem=250M, console=ttyAMA0,115200 rootfstype=squashfs root=/dev/mtdblock1 dh_keyboard=0 load_modules=1 chiptype=2 sim_video_ch=0 dig_video_ch=0
Memory: 250MB = 250MB total
Memory: 247724k/247724k available, 8276k reserved, 0K highmem
vmalloc : 0xd0000000 - 0xfe000000 ( 736 MB)
lowmem : 0xc0000000 - 0xcfa00000 ( 250 MB)
.init : 0xc0008000 - 0xc0036000 ( 184 kB)
.text : 0xc0036000 - 0xc0543000 (5172 kB)
.data : 0xc0544000 - 0xc056dd40 ( 168 kB)
.bss : 0xc056dd64 - 0xc05d7bdc ( 424 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:128 nr_irqs:128 128
sched_clock: 32 bits at 155MHz, resolution 6ns, wraps every 27709ms
sched_clock: wrong multiply/shift: 432960413>>26 vs calculated 3463683303>>29
sched_clock: fix multiply/shift to avoid scheduler hiccups
Calibrating delay loop... 1849.75 BogoMIPS (lpj=9248768)
Calibrating local timer... 154.96MHz.
Brought up 2 CPUs
SMP: Total of 2 processors activated (3706.06 BogoMIPS).
console [ttyAMA0] enabled
uart:3: ttyAMA3 at MMIO 0x200b0000 (irq = 43) is a PL011 rev2
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
UDP hash table entries: 128 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
L2cache cache controller enabled
*** min_free_kbytes=2015, tmp = 2012, min=2012
*** WMARK_LOW = 2512, WMARK_HIGH=3016
*** min_free_kbytes=2015, tmp = 0, min=0
*** WMARK_LOW = 0, WMARK_HIGH=0
msgmni has been set to 483
alg: No test for stdrng (krng)
io scheduler cfq registered
ahci ahci.0: ********** turning off CAP_NCQ
ahci ahci.0: AHCI 0001.0200 32 slots 2 ports 3 Gbps 0x3 impl platform mode
ahci ahci.0: flags: sntf stag pm led clo only pmp pio slum part ccc sxs boh
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x100 irq 68
ata2: SATA max UDMA/133 mmio [mem 0x10080000-0x1008ffff] port 0x180 irq 68
Spi id table Version 1.22
Hisilicon Spi Flash Controller V300 New Device Driver, Version 1.10
Check Spi Flash Controller V300 New.
Found
Spi(cs1):
Block:64KB
Chip:16MB
partitions[0] = {.name = boot+env, .offset = 0x00000000, .size = 0x00060000 (384KiB) }
partitions[1] = {.name = rootfs, .offset = 0x00060000, .size = 0x00c80000 (12800KiB) }
partitions[2] = {.name = web, .offset = 0xffffffff, .size = 0x00180000 (1536KiB) }
partitions[3] = {.name = custom, .offset = 0xffffffff, .size = 0x00020000 (128KiB) }
partitions[4] = {.name = logo, .offset = 0xffffffff, .size = 0x00040000 (256KiB) }
partitions[5] = {.name = config, .offset = 0xffffffff, .size = 0x00000000 (0KiB) }
0x000000000000-0x000000060000 : "boot+env"
0x000000060000-0x000000ce0000 : "rootfs"
0x000000ce0000-0x000000e60000 : "web"
Fixed MDIO Bus: probed
STMMAC driver:
platform registration...
done!
Set system config register 0x200300ec with value 0x003f003f
done!
DWMAC1000 - user ID: 0x10, Synopsys ID: 0x36
Enhanced descriptor structure
MACADDR in get is 0:0:0:0:0:0
eth0 - (dev. name: stmmaceth - id: 0, IRQ #119
IO base addr: 0xd01c0000)
STMMAC MII Bus: probed
cccaaa :addr =3, priv->phy_addr =3
eth0: PHY ID 00070431 at 3 IRQ -6 (1:03) active
stmmac_reset: RESET COMPLETE!
* TNK driver built on May 20 2014 at 19:32:25
* TNK driver mode is BYPASS
stmmac: Rx Checksum Offload Engine supported
usbmon: debugfs is not available
hiusb-ehci hiusb-ehci.0: irq 63, io mem 0x100b0000
hub 1-0:1.0: 2 ports detected
hiusb-ohci hiusb-ohci.0: irq 64, io mem 0x100a0000
hub 2-0:1.0: 2 ports detected
usbhid: USB HID core driver
TCP cubic registered
Mobile IPv6
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
шata2: SATA link down (SStatus 0 SControl 300)
squashfs use lzma
Freeing init memory: 184K
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S80network
[RCS]: /etc/init.d/S81toe
[RCS]: /etc/init.d/S99dahua
squashfs use lzma
*** min_free_kbytes=5120, tmp = 5120, min=5120
*** WMARK_LOW = 6400, WMARK_HIGH=7680
*** min_free_kbytes=5120, tmp = 0, min=0
Extracting adec.ko
Extracting aenc.ko
Extracting ai.ko
Extracting ao.ko
Extracting avss.ko
Extracting base.ko
Extracting chnl.ko
Extracting driverbox.ko
Extracting dsu.ko
Extracting flashtool.ko
Extracting group.ko
Extracting h264e.ko
Extracting hdmi.ko
Extracting hidmac.ko
Extracting hifb.ko
Extracting ive.ko
Extracting jpeg.ko
Extracting jpege.ko
Extracting mmz.ko
Extracting pciv.ko
Extracting pciv_fmw.ko
Extracting rc.ko
Extracting region.ko
Extracting rt5370sta.ko
Extracting sio.ko
Extracting sys.ko
Extracting tde.ko
Extracting usbserial.ko
Extracting vcmp.ko
Extracting vda.ko
Extracting vdec.ko
Extracting venc.ko
Extracting vfmw.ko
Extracting viu.ko
Extracting vou.ko
Extracting vpss.ko
Extracting watchdog.ko
Everything is Ok
driverbox load begin!
version:V1.0 Jun 16 2014, 17:35:56
cpu type is HI3531
DRIVER:regisetr gpio miscdevice Jun 16 2014, 17:35:57
DVR_DRV-gpio MSG: product type gpio value: 0x12
DVR_DRV-gpio MSG: product=0, sub_product=2, Area:Abroad
DVR_DRV-gpio MSG: DMA clock register value: 2
DVR_DRV-gpio MSG: Reset AD2964 or AD2968
DVR_DRV-gpio MSG: port= 0x20250000, bit=5, value = 0
DVR_DRV-gpio MSG: port= 0x20250000, bit=5, value = 32
DRIVER: regisetr hardware_id miscdevice Jun 16 2014, 17:35:58
DVR_DRV-csb_device MSG: after hwid analyse, DvrHwid=0x83150406ace4070e
DVR_DRV-csb_device ERR: FUNC:configfile_hwid_init() 1512 open hwid config file failed
| SYSTEM INFORMATION
| cpld version: 1.02
| product type: DVR
| CPU chip: HI3531
| DSP chip: NONE
| video chip: TW2964-960
| analog audio mode: STxx control
| audio interface: Self_audio
| frontboard type: Base
| abroad info: Abroad
| rtc vendor: Dallas
| video channel: 16
| audio channel: 4
| digital video: 0
| alarm in: 16
| alarm out: 3
| disk num: 2
| net card: 1
| dsp num: 0
| audio support: YES
| matrix support: YES
| esata support: NO
| frontboard digit: NO
| frontboard shift: YES
| RS232 surpport: YES
| RS485 surpport: YES
| product sub type: Default
| app version: 2.608
| encode type: D1 real-time
DRIVER:regisetr resource miscdevice Jun 16 2014, 17:35:57
DVR_DRV-resource MSG: Get DVR product resource data!
DRIVER: disk resource, sata_num=2, esata_num=0, pm_flag = 0
DVR_DRV-resource MSG: Alarm type: IIC!
DRIVER: regisetr gpio_i2c miscdevice Jun 16 2014, 17:35:57
DVR_DRV-gpioi2c MSG: i2c_info[00]: SCL=12.5 SDA=12.4
DVR_DRV-gpioi2c MSG: i2c_info[01]: SCL=10.5 SDA=10.4
DVR_DRV-gpioi2c MSG: mcu_i2c: SCL=12.2 SDA=12.3
DVR_DRV-gpioi2c MSG: Data=0x11, RTC oscillator is enable
DRIVER: cmos miscdevice Jun 16 2014, 17:35:59
DVR_DRV-cmos MSG: cmos use dev 0xd0 offset 0x8
DRIVER: regisetr rtc miscdevice Jun 16 2014, 17:35:59
DRIVER: alarm miscdevice Jun 16 2014, 17:35:59
DRIVER:regisetr console miscdevice Jun 16 2014, 17:35:59
driverbox load end!
hi3531_base: module license 'Proprietary' taints kernel.
load sys.ko for Hi3531...OK!
Load tde.ko ...OK!
load venc.ko for Hi3531...OK!
load group.ko for Hi3531...OK!
load chnl.ko for Hi3531...OK!
load h264e.ko for Hi3531...OK!
load rc.ko for Hi3531...OK!
load jpege.ko for Hi3531...OK!
load viu.ko for Hi3531...OK!
load vou.ko ....OK!
load vpss.ko ....OK!
load vda.ko ....OK!
load region.ko ....OK!
load vdec.ko ....OK
insmod: can't open '/var/lib/hiuser.ko#20140505': No such file or directory
load vhd firmware.ko OK
load hdmi.ko ....OK!
Load jpeg6b.ko success. (SDK_VERSION:[jpeg6bv1.0] Build Time:[Mar 20 2013, 01:13:37])
DVR_DRV-csb_device MSG: Invalid CLPD Info command 25!
ial support registered for generic
usbcore: registered new interface driver usbserial_generic
rtusb init rt2870 --->
rt3070_2.5.0.3 SVN_VERSION:2710 Complie time Dec 25 2013 16:16:47
usbcore: registered new interface driver rt2870
MACADDR in set is 4c:11:bf:14:dc:28
PHY: 1:03 - Link is Up - 100/Full
Extracting Challenge
Everything is Ok
[LIBDVR] LIBDVR_TOOL: dvrhelper version: 5042(Aug 2 2013 13:59:31)
Date: 18.07.2017 - 8:41:55
End log file
Version: 530(Jun 24 2netinit uses obsolete (PF_INET,SOCK_PACKET)
013 15:24:13)
Example for set ip :
netinit 192.168.1.34
Example for set netmask :
eth0
mac : 4c-11-bf-14-dc-28
ip : 192.168.1.252
netmask : 255.255.255.0
gateway : 192.168.1.1
mtu : 1500
==============>PPPOE2.4.RESOURCE_USB_PROT
5:Complie time Jul 14 2
