3104P NVR Bricked
Re: 3104P NVR Bricked
Сообщение iTuneDVR » 03 фев 2016, 12:57
bottom-right 4 dot
Test it may
+5(+3,3) Rx,Tx,Gd
But you ring Gd, then DVR is off & you test votage contact then DVR on.
Other dot is Rx and Tx.
Use normal TTL2RS232 adapter that you connect to you PC COM or USB
If you use USB do not use power dot!!!
chamek
Сообщение chamek » 03 фев 2016, 23:23
think i have orderd the wrong cable. I order a cable like this one:
http://www.aliexpress.com/item/PL2303TA ... e2d464d6a0
So do i need to order another cable or is this one oke? What do i need to do?
BTW. If found the dots you mean i've zoomed in at picture.
https://drive.google.com/file/d/0B6hZTk ... daeGs/view
picture name: IMG_20160202_234503.jpg
Сообщение iTuneDVR » 04 фев 2016, 00:29
Take voltage tester in your hands.
Find contact land him and attached needle and connect to MB.
Find contact + 5V (3.3) and do not use it because your USB option.
The remaining two pins supplied as is, do not go, then reversed.
Configuring the driver on your TTL2RH232 adapter.
In the settings of the COM port put speed - 115200, flow control - none.
Use HyperTerminal program.
chamek
Сообщение chamek » 22 фев 2016, 19:17
Hi i am back
I got me a multimeter as i didnt have one and i have searched for a part with four needles to attach to the motherboard.
https://drive.google.com/open?id=0B6hZT ... WRWd2FBS2s
First i fully unscrewed the motherboard from the case.
I made some new pictures from the back to show to you:
https://drive.google.com/open?id=0B6hZT ... EFPdmhCazQ
Now there are two options to insert the pins in J7 (bottom right) or (J5 Upper left)
At the back J5 has a description as J7 dont.
J5 back:
https://drive.google.com/open?id=0B6hZT ... ks5ZkpsaGs
J7 back:
https://drive.google.com/open?id=0B6hZT ... FJIa1NEZUE
https://drive.google.com/open?id=0B6hZT ... DlMRWlRYlE
Tried to get the voltage with a multi meter put it on a insert a needle and tried to read it out but im just a big noob.
First question:
What do you mean with contact land him? Do you mean the squire?
Second Q:
With the back info is it more clear which one i need upper or lower dots?
And what color needs to be used on what needle? as i have 4 colors white green red black.
Сообщение iTuneDVR » 22 фев 2016, 20:35
Enable access to your link or share to another resource!
Where are you from?
chamek
Сообщение chamek » 22 фев 2016, 21:05
I am from the Netherlands.
Сообщение iTuneDVR » 22 фев 2016, 21:09
chamek писал(а):I am from the Netherlands.
Any service, who can rebold flash? Maybe in Gemany?
chamek
Сообщение chamek » 22 фев 2016, 21:17
I dont know but i would like to try it out my self.
chamek
Сообщение chamek » 22 фев 2016, 21:18
pictures are accessible
Сообщение iTuneDVR » 22 фев 2016, 21:23
chamek писал(а):I dont know but i would like to try it out my self.
ok
chamek писал(а):pictures are accessible
Yes!
