3104P NVR Bricked
chamek
3104P NVR Bricked
Сообщение chamek » 04 янв 2016, 22:48
Hello all,
iTuneDVR advised me to place an topic here about the issue i am having.
I have bought an NVR3104 from dahua but i installed the wrong update on my nvr. I have used the 4 serie instead of 3 serie.
Problem now is the NRV is getting on the lights on the nvr are blicking but thats all.
No boot, No startup -- NOTHING.
Now i have read on some fora that you can reset the firmware with special cable. Is this possible and can anyone explane me in steps how to fix this.
Thanks in advance.
Greetings,
Chamekos
Re: 3104P NVR Bricked
Сообщение iTuneDVR » 05 янв 2016, 00:55
Hi!
Get TTL2RS232 adapter, open you NVR and fint 4pin
and read this
viewtopic.php?t=441
Сообщение iTuneDVR » 05 янв 2016, 01:09
iTuneDVR писал(а):Hi!
and read this
viewtopic.php?t=441
Need logs and etc.
chamek
Сообщение chamek » 05 янв 2016, 07:01
and read this
viewtopic.php?t=441
Need logs and etc.
Pls give me an hrk to order this cable
Сообщение iTuneDVR » 05 янв 2016, 17:08
chamek писал(а):Pls give me an hrk to order this cable
http://www.aliexpress.com/af/ttl-rs232. ... =y&catId=0
chamek
Сообщение chamek » 05 янв 2016, 22:41
When should i connect the 4 pins to?
Сообщение iTuneDVR » 05 янв 2016, 23:43
Bad photo!
Find 4 dot (holes). Test +5V(3.3) Rx,Tx,Gd
chamek
Сообщение chamek » 02 фев 2016, 17:36
It was quite a task to make a good picture but here it is. I received today dat cable also so i am ready to go.
https://drive.google.com/file/d/0B6hZTk ... sp=sharing
Сообщение iTuneDVR » 02 фев 2016, 21:27
chamek писал(а):It was quite a task to make a good picture but here it is. I received today dat cable also so i am ready to go.
It's somethimg other
Make good qualuty photo whole mb
