3104P NVR Bricked
Re: 3104P NVR Bricked
Сообщение iTuneDVR » 23 фев 2016, 01:43
chamek писал(а):ok i will try no power need or do i need to plug it on electric?
Gd without power.
+5(3.3) with power.
Do you know how?
Make proto of your power tester?
Power tester to the ring mode. MB power off. Black probe to the ground contact at the MB, red probe to the 1st dot. If ring then it Gd, if not then shift red probe to the nest dot.....
Power tester to the to the D.C. mode =20V. MB power on. Black probe to the ground contact at the MB, red probe to the 1st dot. Watch for indications? and etc.
chamek
Сообщение chamek » 23 фев 2016, 02:03
Сообщение iTuneDVR » 23 фев 2016, 02:14
Good!
chamek
Сообщение chamek » 23 фев 2016, 02:14
I HAVE TRIED AT BOTH OPTIONS NO ONE IS BEEPING ITS ON THE o MODE.
BUT WHEN I TOUCH LITTLE UP ABOVE ONE CIRCLE ITS BEEPING.
ONLY ONE IS DOING THIS.
Сообщение iTuneDVR » 23 фев 2016, 02:22
chamek писал(а):I HAVE TRIED AT BOTH OPTIONS NO ONE IS BEEPING ITS ON THE o MODE.
Make sure that your ground contact at your MB is normal!
chamek
Сообщение chamek » 23 фев 2016, 02:24
how do you mean?
Сообщение iTuneDVR » 23 фев 2016, 02:31
I mean present and good!
Do you know how operate power tester?
chamek
Сообщение chamek » 23 фев 2016, 02:32
no i dont know. Is it better to use a chat site maybe better for convesation? skype maybe?
Сообщение iTuneDVR » 23 фев 2016, 02:39
chamek писал(а):no i dont know. Is it better to use a chat site maybe better for convesation? skype maybe?
It will be more harder than you think. ;)
I ask one man in Gemany. If he not busy possible he can solve your problem.
Wait.
chamek
Сообщение chamek » 23 фев 2016, 02:41
Wait.
Thanks allot :D
