DOWNGRADE XVR DAHUA
joe2323
DOWNGRADE XVR DAHUA
Сообщение joe2323 » 16 ноя 2024, 16:04
hello
when i'm downgrading XVR1B16H-I via tftp
it gives me an error
U-Boot 2019.04-svn7837 (May 29 2024 - 20:36:33 +0800), Build: jenkins-GSP_DH3.RD008767_DB11_X7_linux-1039
CPU: Novatek NT @ 1200 MHz
Watchdog enabled
DRAM: 2 GiB
Relocation to 0x3fdd8000, Offset is 0x01dd8000 sp at 3f8b23d0
otp_init[1.00.002]
120MHz
otp_timing_reg= 0xff6050
Read power trim = 0x00000000
remap_data 8
pwm_pinmux = 0x1
pwm_id(0) pwm_pinmux(0x1)
pclk_freq(30000000) div(3)
NAND: drv_nand_reset: spi flash pinmux 0x11
id = 0xe5 0x71 0xe5 0x71
use flash on-die ecc
nvt spinand 4-bit mode @ 24000000 Hz
128 MiB
MMC:
Loading Environment from NAND... OK
misc_init_r: Firmware name: FW98336A.bin FW98336T.bin FW98336A.fdt.bin
misc_init_r: boot time: 3325479(us)
MMC interface configure failed
Open SD fail: No SD device?
misc_init_r: boot time: 3356317(us)
DTS find cpu freq clock 1200MHz
Set CPU clk 1200MHz
misc_init_r: boot time: 3435001(us)
Net: na51090_eth_initialize 1.0.0.2
na51090_eth_initialize: dtb node /eth0@2,f0200000 found
eqos_initialize 0x2f0200000
eth_parse_phy_intf: get IO MEM 0x2f0200000
DTS /eth0@2,f0200000 found
eth_parse_phy_intf: ref-clk-out 0
eth_parse_phy_intf: pinmux detect RGMII 0x501501
phy_rtl8211fd addr 0 cfg ok!
eth0
Warning: eth0 MAC addresses don't match:
Address in SROM is 0a:0b:0c:0d:0e:01
Address in environment is 3c:e3:6b:9b:f1:e8
nvt@na51090: run dr
Using eth0 device
TFTP from server 192.168.1.1; our IP address is 192.168.1.108
Filename 'romfs-x.squashfs.img'.
timeout_count up to 10
Load address: 0x7800000
Loading: *
time = 14083
#############################################T ####################
5.5 MiB/s
Bytes transferred = 46497856 (2c58040 hex)
close frondboard!
nvtviot_wdt_disable
Bad Image info
flwrite error 1!
connect frondboard!
resetting ...
Re: DOWNGRADE XVR DAHUA
Сообщение iTuneDVR » 18 ноя 2024, 20:13
Screenshot from label device, link for officials fimware source that you use.
Possible
joe2323 писал(а):U-Boot 2019.04-svn7837 (May 29 2024 - 20:36:33 +0800), Build: jenkins-GSP_DH3.RD008767_DB11_X7_linux-1039
u-boot too fressm but you try something, something old!
Why need downgrade?
