HDBW4300E проблема с флэшкой??
kalam
Сообщение kalam » 11 июл 2017, 15:35
Перестала работать.. Полез перепрошивать.. прошивка General_IPC-HX5(4)XXX-Adreia_Eng_P_Stream3_V2.420.0009.0.R.20151106.
Через RS232 (файлы dhboot.bin.img, dhboot-min.bin.img, update.img присутствуют) .
Cоответственно run da для обновления uboot. и далее run up
вот вывод:
run up
TFTP from server 192.168.1.207; our IP address is 192.168.1.108
Filename 'update.img'.
Load address: 0xc2000000
Loading: *#################################################################
    32 MB received
Bytes transferred = 41798410 (27dcb0a hex)
Erasing update flag partition.
## Checking Image at c2000040 ...
   Legacy image found
   Image Name:   boot
   Created:      2015-11-06  11:35:05 UTC
   Image Type:   ARM Linux Firmware (uncompressed)
   Data Size:    317440 Bytes = 310 KiB
   Load Address: 00200000
   Entry Point:  00300000
Programing start at: 0x00200000
erase : 0%erase : 12%erase : 25%erase : 37%erase : 50%erase : 62%erase : 75%erase : 87%erase : 100%erase : 100%write :  0%write :  00%write :  33%write :  66%write : 100%
## Checking Image at c204d880 ...
   Legacy image found
   Image Name:   romfs
   Data Size:    7340032 Bytes = 7 MiB
   Load Address: 01200000
   Entry Point:  01a00000
Programing start at: 0x01200000
erase : 0%erase : 1%erase : 3%erase : 4%erase : 6%erase : 7%erase : 9%erase : 10%erase : 12%erase : 14%erase : 15%erase : 17%erase : 18%erase : 20%erase : 21%erase : 23%erase : 25%erase : 26%erase : 28%erase : 29%erase : 31%erase : 32%erase : 34%erase : 35%erase : 37%erase : 39%erase : 40%erase : 42%erase : 43%erase : 45%erase : 46%erase : 48%erase : 50%erase : 51%erase : 53%erase : 54%erase : 56%erase : 57%erase : 59%erase : 60%erase : 62%erase : 64%erase : 65%erase : 67%erase : 68%erase : 70%erase : 71%erase : 73%erase : 75%erase : 76%erase : 78%erase : 79%erase : 81%erase : 82%erase : 84%erase : 85%erase : 87%erase : 89%erase : 90%erase : 92%erase : 93%erase : 95%erase : 96%erase : 98%erase : 100%erase : 100%write :  0%write :  00%write :  01%write :  03%write :  05%write :  07%write :  08%write :  10%write :  12%write :  14%write :  16%write :  17%write :  19%write :  21%write :  23%write :  25%write :  26%write :  28%write :  30%write :  32%write :  33%write :  35%write :  37%write :  39%write :  41%write :  42%write :  44%write :  46%write :  48%write :  50%write :  51%write :  53%write :  55%write :  57%write :  58%write :  60%write :  62%write :  64%write :  66%write :  67%write :  69%write :  71%write :  73%write :  75%write :  76%write :  78%write :  80%write :  82%write :  83%write :  85%write :  87%write :  89%write :  91%write :  92%write :  94%write :  96%write :  98%write : 100%
## Checking Image at c274d8c0 ...
   Legacy image found
   Image Name:   user
   Created:      2015-11-06  11:35:18 UTC
   Image Type:   ARM Linux Standalone Program (uncompressed)
   Data Size:    20447232 Bytes = 19.5 MiB
   Load Address: 02200000
   Entry Point:  03b80000
Programing start at: 0x02200000
erase : 0%erase : 0%erase : 0%erase : 1%erase : 1%erase : 2%erase : 2%erase : 3%erase : 3%erase : 4%erase : 4%erase : 5%erase : 5%erase : 6%erase : 6%erase : 7%erase : 7%erase : 8%erase : 8%erase : 9%erase : 9%erase : 10%erase : 10%erase : 11%erase : 11%erase : 12%erase : 12%erase : 13%erase : 13%erase : 14%erase : 14%erase : 15%erase : 15%erase : 16%erase : 16%erase : 17%erase : 17%erase : 18%erase : 18%erase : 19%erase : 19%erase : 20%erase : 20%erase : 21%erase : 21%erase : 22%erase : 22%erase : 23%erase : 23%erase : 24%erase : 24%erase : 25%erase : 25%erase : 25%erase : 26%erase : 26%erase : 27%erase : 27%erase : 28%erase : 28%erase : 29%erase : 29%erase : 30%erase : 30%erase : 31%erase : 31%erase : 32%erase : 32%erase : 33%erase : 33%erase : 34%erase : 34%erase : 35%erase : 35%erase : 36%erase : 36%erase : 37%erase : 37%erase : 38%erase : 38%erase : 39%erase : 39%erase : 40%erase : 40%erase : 41%erase : 41%erase : 42%erase : 42%erase : 43%erase : 43%erase : 44%erase : 44%erase : 45%erase : 45%erase : 46%erase : 46%erase : 47%erase : 47%erase : 48%erase : 48%erase : 49%erase : 49%erase : 50%erase : 50%erase : 50%erase : 51%erase : 51%erase : 52%erase : 52%erase : 53%erase : 53%erase : 54%erase : 54%erase : 55%erase : 55%erase : 56%erase : 56%erase : 57%erase : 57%erase : 58%erase : 58%erase : 59%erase : 59%erase : 60%erase : 60%erase : 61%erase : 61%erase : 62%erase : 62%erase : 63%erase : 63%erase : 64%erase : 64%erase : 65%erase : 65%erase : 66%erase : 66%erase : 67%erase : 67%erase : 68%erase : 68%erase : 69%erase : 69%erase : 70%erase : 70%erase : 71%erase : 71%erase : 72%erase : 72%erase : 73%erase : 73%erase : 74%erase : 74%erase : 75%erase : 75%erase : 75%erase : 76%erase : 76%erase : 77%erase : 77%erase : 78%erase : 78%erase : 79%erase : 79%erase : 80%erase : 80%erase : 81%erase : 81%erase : 82%erase : 82%erase : 83%erase : 83%erase : 84%erase : 84%erase : 85%erase : 85%erase : 86%erase : 86%erase : 87%erase : 87%erase : 88%erase : 88%erase : 89%erase : 89%erase : 90%erase : 90%erase : 91%erase : 91%erase : 92%erase : 92%erase : 93%erase : 93%erase : 94%erase : 94%erase : 95%erase : 95%erase : 96%erase : 96%erase : 97%erase : 97%erase : 98%erase : 98%erase : 99%erase : 99%erase : 100%erase : 100%write :  0%write :  00%write :  00%write :  01%write :  01%write :  02%write :  03%write :  03%write :  04%write :  05%write :  05%write :  06%write :  07%write :  07%write :  08%write :  08%write :  09%write :  10%write :  10%write :  11%write :  12%write :  12%write :  13%write :  14%write :  14%write :  15%write :  16%write :  16%write :  17%write :  17%write :  18%write :  19%write :  19%write :  20%write :  21%write :  21%write :  22%write :  23%write :  23%write :  24%write :  25%write :  25%write :  26%write :  26%write :  27%write :  28%write :  28%write :  29%write :  30%write :  30%write :  31%write :  32%write :  32%write :  33%write :  33%write :  34%write :  35%write :  35%write :  36%write :  37%write :  37%write :  38%write :  39%write :  39%write :  40%write :  41%write :  41%write :  42%write :  42%write :  43%write :  44%write :  44%write :  45%write :  46%write :  46%write :  47%write :  48%write :  48%write :  49%write :  50%write :  50%write :  51%write :  51%write :  52%write :  53%write :  53%write :  54%write :  55%write :  55%write :  56%write :  57%write :  57%write :  58%write :  58%write :  59%write :  60%write :  60%write :  61%write :  62%write :  62%write :  63%write :  64%write :  64%write :  65%write :  66%write :  66%write :  67%write :  67%write :  68%write :  69%write :  69%write :  70%write :  71%write :  71%write :  72%write :  73%write :  73%write :  74%write :  75%write :  75%write :  76%write :  76%write :  77%write :  78%write :  78%write :  79%write :  80%write :  80%write :  81%write :  82%write :  82%write :  83%write :  83%write :  84%write :  85%write :  85%write :  86%write :  87%write :  87%write :  88%write :  89%write :  89%write :  90%write :  91%write :  91%write :  92%write :  92%write :  93%write :  94%write :  94%write :  95%write :  96%write :  96%write :  97%write :  98%write :  98%write :  99%write : 100%
## Checking Image at c3acd900 ...
   Legacy image found
   Image Name:   web
   Created:      2015-11-06  11:35:06 UTC
   Data Size:    7733248 Bytes = 7.4 MiB
   Load Address: 01a00000
   Entry Point:  02200000
Programing start at: 0x01a00000
erase : 0%erase : 1%erase : 3%erase : 4%erase : 6%erase : 7%erase : 9%erase : 10%erase : 12%erase : 14%erase : 15%erase : 17%erase : 18%erase : 20%erase : 21%erase : 23%erase : 25%erase : 26%erase : 28%erase : 29%erase : 31%erase : 32%erase : 34%erase : 35%erase : 37%erase : 39%erase : 40%erase : 42%erase : 43%erase : 45%erase : 46%erase : 48%erase : 50%erase : 51%erase : 53%erase : 54%erase : 56%erase : 57%erase : 59%erase : 60%erase : 62%erase : 64%erase : 65%erase : 67%erase : 68%erase : 70%erase : 71%erase : 73%erase : 75%erase : 76%erase : 78%erase : 79%erase : 81%erase : 82%erase : 84%erase : 85%erase : 87%erase : 89%erase : 90%erase : 92%erase : 93%erase : 95%erase : 96%erase : 98%erase : 100%erase : 100%write :  0%write :  00%write :  01%write :  03%write :  05%write :  06%write :  08%write :  10%write :  11%write :  13%write :  15%write :  16%write :  18%write :  20%write :  22%write :  23%write :  25%write :  27%write :  28%write :  30%write :  32%write :  33%write :  35%write :  37%write :  38%write :  40%write :  42%write :  44%write :  45%write :  47%write :  49%write :  50%write :  52%write :  54%write :  55%write :  57%write :  59%write :  61%write :  62%write :  64%write :  66%write :  67%write :  69%write :  71%write :  72%write :  74%write :  76%write :  77%write :  79%write :  81%write :  83%write :  84%write :  86%write :  88%write :  89%write :  91%write :  93%write :  94%write :  96%write :  98%write : 100%
## Checking Image at c422d940 ...
   Legacy image found
   Image Name:   pd
   Created:      2015-11-06  11:35:20 UTC
   Data Size:    1703936 Bytes = 1.6 MiB
   Load Address: 00940000
   Entry Point:  00c80000
Programing start at: 0x00940000
erase : 0%erase : 3%erase : 7%erase : 11%erase : 15%erase : 19%erase : 23%erase : 26%erase : 30%erase : 34%erase : 38%erase : 42%erase : 46%erase : 50%erase : 53%erase : 57%erase : 61%erase : 65%erase : 69%erase : 73%erase : 76%erase : 80%erase : 84%erase : 88%erase : 92%erase : 96%erase : 100%erase : 100%write :  0%write :  00%write :  07%write :  15%write :  23%write :  30%write :  38%write :  46%write :  53%write :  61%write :  69%write :  76%write :  84%write :  92%write : 100%
## Checking Image at c43cd980 ...
   Legacy image found
   Image Name:   custom
   Created:      2015-11-06  11:35:26 UTC
   Load Address: 00600000
   Entry Point:  00940000
Programing start at: 0x00600000
## Checking Image at c456d9c0 ...
   Legacy image found
   Image Name:   partition
   Data Size:    4096 Bytes = 4 KiB
   Load Address: 00500000
   Entry Point:  00600000
Programing start at: 0x00500000
erase : 0%erase : 12%erase : 25%erase : 37%erase : 50%erase : 62%erase : 75%erase : 87%erase : 100%erase : 100%write :  0%write :  00%write : 100%
## Checking Image at c456ea00 ...
   Legacy image found
   Image Name:   kernel
   Data Size:    2546948 Bytes = 2.4 MiB
   Load Address: 00c80000
   Entry Point:  01200000
Programing start at: 0x00c80000
erase : 0%erase : 2%erase : 4%erase : 6%erase : 9%erase : 11%erase : 13%erase : 15%erase : 18%erase : 20%erase : 22%erase : 25%erase : 27%erase : 29%erase : 31%erase : 34%erase : 36%erase : 38%erase : 40%erase : 43%erase : 45%erase : 47%erase : 50%erase : 52%erase : 54%erase : 56%erase : 59%erase : 61%erase : 63%erase : 65%erase : 68%erase : 70%erase : 72%erase : 75%erase : 77%erase : 79%erase : 81%erase : 84%erase : 86%erase : 88%erase : 90%erase : 93%erase : 95%erase : 97%erase : 100%erase : 100%write :  0%write :  00%write :  05%write :  10%write :  15%write :  20%write :  25%write :  30%write :  35%write :  40%write :  45%write :  50%write :  55%write :  60%write :  65%write :  70%write :  75%write :  80%write :  85%write :  90%write :  95%write : 100%
## Checking Image at c47dc744 ...
   Legacy image found
   Image Name:   CmdScript
   Created:      2015-11-06  11:35:36 UTC
   Data Size:    902 Bytes = 902 Bytes
   Load Address: c0000000
   Entry Point:  c0000400
exce update config script start!
   set da 'tftp 0xc2000000 dhboot.bin.img; flwrite; tftp dhboot-min.bin.img;nand protect off;flwrite;nand protect on'
   set dr 'tftp 0xc2000000 romfs-x.ubifs.img; flwrite'
   set dk 'tftp 0xc2000000 kernel.img; flwrite'
   set du 'tftp 0xc2000000 user-x.ubifs.img; flwrite'
   set dw 'tftp 0xc2000000 web-x.ubifs.img; flwrite'
   set ds 'tftp 0xc2000000 dsp-x.ubifs.img; flwrite'
   set dc 'tftp 0xc2000000 custom-x.ubifs.img; flwrite'
   set dt 'tftp 0xc2000000 data-x.ubifs.img; flwrite'
   set df 'tftp 0xc2000000 fpga.img; flwrite'
   set up 'tftp 0xc2000000 update.img; flwrite'
   set tk 'tftp 0xc2000000 uImage; bootm'
    setenv bootcmd 'nand read 0xc2000000 0x00c80000 0x00580000;bootm 0xc2000000'
    setenv bootargs 'console=ttyS0 mem=138M ubi.mtd=romfs root=ubi0:romfs ro rootfstype=ubifs init=/linuxrc video=amb0fb:720x480,720x480,1,0 lpj=2392064'
   save
Saving Environment to NAND...
Erasing Nand...
Erasing at 0x300000 --  12% complete.Erasing at 0x320000 --  25% complete.Erasing at 0x340000 --  37% complete.Erasing at 0x360000 --  50% complete.Erasing at 0x380000 --  62% complete.Erasing at 0x3a0000 --  75% complete.Erasing at 0x3c0000 --  87% complete.Erasing at 0x3e0000 -- 100% complete.
Writing to Nand... done
exce update config script complete!
вроде все ок.. далее грузим
>bootd
NAND read: device 0 offset 0xc80000, size 0x00580000
 5767168 bytes read: OK
## Booting kernel from Legacy Image at c2000000 ...
   Image Name:   Linux-2.6.38.8
   Created:      2015-11-06  11:19:25 UTC
   Data Size:    2546884 Bytes = 2.4 MiB
   Load Address: c0208000
   Entry Point:  c0208000
   Loading Kernel Image ...OK
1..2..3..boot_from:normal
U-Boot 2010.06-svn551 (Nov 06 2015 - 17:42:12)
DRAM:  254 MiB
gBootLogPtr:c0b80008.
NAND:  128 MiB
state:5a,err_count:00
backup partition...         erase 0%         erase 12%         erase 25%         erase 37%         erase 50%         erase 62%         erase 75%         erase 87%         write 0%         write 12%         write 25%         write 37%         write 50%         write 62%         write 75%         write 87%         write 100%
backup custom...         erase 0%         erase 3%         erase 7%         erase 11%         erase 15%         erase 19%         erase 23%         erase 26%         erase 30%         erase 34%         erase 38%         erase 42%         erase 46%         erase 50%         erase 53%         erase 57%         erase 61%         erase 65%         erase 69%         erase 73%         erase 76%         erase 80%         erase 84%         erase 88%         erase 92%         erase 96%         write 0%         write 3%         write 7%         write 11%         write 15%         write 19%         write 23%         write 26%         write 30%         write 34%         write 38%         write 42%         write 46%         write 50%         write 53%         write 57%         write 61%         write 65%         write 69%         write 73%         write 76%         write 80%         write 84%         write 88%         write 92%         write 96%         write 100%
backup product...         erase 0%         erase 3%         erase 7%         erase 11%         erase 15%         erase 19%         erase 23%         erase 26%         erase 30%         erase 34%         erase 38%         erase 42%         erase 46%         erase 50%         erase 53%         erase 57%         erase 61%         erase 65%         erase 69%         erase 73%         erase 76%         erase 80%         erase 84%         erase 88%         erase 92%         erase 96%         write 0%         write 3%         write 7%         write 11%         write 15%         write 19%         write 23%         write 26%         write 30%         write 34%         write 38%         write 42%         write 46%         write 50%         write 53%         write 57%         write 61%         write 65%         write 69%         write 73%         write 76%         write 80%         write 84%         write 88%         write 92%         write 96%         write 100%
backup Kernel...         erase 0%         erase 2%         erase 4%         erase 6%         erase 9%         erase 11%         erase 13%         erase 15%         erase 18%         erase 20%         erase 22%         erase 25%         erase 27%         erase 29%         erase 31%         erase 34%         erase 36%         erase 38%         erase 40%         erase 43%         erase 45%         erase 47%         erase 50%         erase 52%         erase 54%         erase 56%         erase 59%         erase 61%         erase 63%         erase 65%         erase 68%         erase 70%         erase 72%         erase 75%         erase 77%         erase 79%         erase 81%         erase 84%         erase 86%         erase 88%         erase 90%         erase 93%         erase 95%         erase 97%         write 0%         write 2%         write 4%         write 6%         write 9%         write 11%         write 13%         write 15%         write 18%         write 20%         write 22%         write 25%         write 27%         write 29%         write 31%         write 34%         write 36%         write 38%         write 40%         write 43%         write 45%         write 47%         write 50%         write 52%         write 54%         write 56%         write 59%         write 61%         write 63%         write 65%         write 68%         write 70%         write 72%         write 75%         write 77%         write 79%         write 81%         write 84%         write 86%         write 88%         write 90%         write 93%         write 95%         write 97%         write 100%
backup romfs...         erase 0%         erase 1%         erase 3%         erase 4%         erase 6%         erase 7%         erase 9%         erase 10%         erase 12%         erase 14%         erase 15%         erase 17%         erase 18%         erase 20%         erase 21%         erase 23%         erase 25%         erase 26%         erase 28%         erase 29%         erase 31%         erase 32%         erase 34%         erase 35%         erase 37%         erase 39%         erase 40%         erase 42%         erase 43%         erase 45%         erase 46%         erase 48%         erase 50%         erase 51%         erase 53%         erase 54%         erase 56%         erase 57%         erase 59%         erase 60%         erase 62%         erase 64%         erase 65%         erase 67%         erase 68%         erase 70%         erase 71%         erase 73%         erase 75%         erase 76%         erase 78%         erase 79%         erase 81%         erase 82%         erase 84%         erase 85%         erase 87%         erase 89%         erase 90%         erase 92%         erase 93%         erase 95%         erase 96%         erase 98%         write 0%         write 1%         write 3%         write 4%         write 6%         write 7%         write 9%         write 10%         write 12%         write 14%         write 15%         write 17%         write 18%         write 20%         write 21%         write 23%         write 25%         write 26%         write 28%         write 29%         write 31%         write 32%         write 34%         write 35%         write 37%         write 39%         write 40%         write 42%         write 43%         write 45%         write 46%         write 48%         write 50%         write 51%         write 53%         write 54%         write 56%         write 57%         write 59%         write 60%         write 62%         write 64%         write 65%         write 67%         write 68%         write 70%         write 71%         write 73%         write 75%         write 76%         write 78%         write 79%         write 81%         write 82%         write 84%         write 85%         write 87%         write 89%         write 90%         write 92%         write 93%         write 95%         write 96%         write 98%         write 100%
backup web...         erase 0%         erase 1%         erase 3%         erase 4%         erase 6%         erase 7%         erase 9%         erase 10%         erase 12%         erase 14%         erase 15%         erase 17%         erase 18%         erase 20%         erase 21%         erase 23%         erase 25%         erase 26%         erase 28%         erase 29%         erase 31%         erase 32%         erase 34%         erase 35%         erase 37%         erase 39%         erase 40%         erase 42%         erase 43%         erase 45%         erase 46%         erase 48%         erase 50%         erase 51%         erase 53%         erase 54%         erase 56%         erase 57%         erase 59%         erase 60%         erase 62%         erase 64%         erase 65%         erase 67%         erase 68%         erase 70%         erase 71%         erase 73%         erase 75%         erase 76%         erase 78%         erase 79%         erase 81%         erase 82%         erase 84%         erase 85%         erase 87%         erase 89%         erase 90%         erase 92%         erase 93%         erase 95%         erase 96%         erase 98%         write 0%         write 1%         write 3%         write 4%         write 6%         write 7%         write 9%         write 10%         write 12%         write 14%         write 15%         write 17%         write 18%         write 20%         write 21%         write 23%         write 25%         write 26%         write 28%         write 29%         write 31%         write 32%         write 34%         write 35%         write 37%         write 39%         write 40%         write 42%         write 43%         write 45%         write 46%         write 48%         write 50%         write 51%         write 53%         write 54%         write 56%         write 57%         write 59%         write 60%         write 62%         write 64%         write 65%         write 67%         write 68%         write 70%         write 71%         write 73%         write 75%         write 76%         write 78%         write 79%         write 81%         write 82%         write 84%         write 85%         write 87%         write 89%         write 90%         write 92%         write 93%         write 95%         write 96%         write 98%         write 100%
backup user...         erase 0%         erase 0%         erase 0%         erase 1%         erase 1%         erase 2%         erase 2%         erase 3%         erase 3%         erase 4%         erase 4%         erase 5%         erase 5%         erase 6%         erase 6%         erase 7%         erase 7%         erase 8%         erase 8%         erase 9%         erase 9%         erase 10%         erase 10%         erase 11%         erase 11%         erase 12%         erase 12%         erase 13%         erase 13%         erase 14%         erase 14%         erase 15%         erase 15%         erase 16%         erase 16%         erase 17%         erase 17%         erase 18%         erase 18%         erase 19%         erase 19%         erase 20%         erase 20%         erase 21%         erase 21%         erase 22%         erase 22%         erase 23%         erase 23%         erase 24%         erase 24%         erase 25%         erase 25%         erase 25%         erase 26%         erase 26%         erase 27%         erase 27%         erase 28%         erase 28%         erase 29%         erase 29%         erase 30%         erase 30%         erase 31%         erase 31%         erase 32%         erase 32%         erase 33%         erase 33%         erase 34%         erase 34%         erase 35%         erase 35%         erase 36%         erase 36%         erase 37%         erase 37%         erase 38%         erase 38%         erase 39%         erase 39%         erase 40%         erase 40%         erase 41%         erase 41%         erase 42%         erase 42%         erase 43%         erase 43%         erase 44%         erase 44%         erase 45%         erase 45%         erase 46%         erase 46%         erase 47%         erase 47%         erase 48%         erase 48%         erase 49%         erase 49%         erase 50%         erase 50%         erase 50%         erase 51%         erase 51%         erase 52%         erase 52%         erase 53%         erase 53%         erase 54%         erase 54%         erase 55%         erase 55%         erase 56%         erase 56%         erase 57%         erase 57%         erase 58%         erase 58%         erase 59%         erase 59%         erase 60%         erase 60%         erase 61%         erase 61%         erase 62%         erase 62%         erase 63%         erase 63%         erase 64%         erase 64%         erase 65%         erase 65%         erase 66%         erase 66%         erase 67%         erase 67%         erase 68%         erase 68%         erase 69%         erase 69%         erase 70%         erase 70%         erase 71%         erase 71%         erase 72%         erase 72%         erase 73%         erase 73%         erase 74%         erase 74%         erase 75%         erase 75%         erase 75%         erase 76%         erase 76%         erase 77%         erase 77%         erase 78%         erase 78%         erase 79%         erase 79%         erase 80%         erase 80%         erase 81%         erase 81%         erase 82%         erase 82%         erase 83%         erase 83%         erase 84%         erase 84%         erase 85%         erase 85%         erase 86%         erase 86%         erase 87%         erase 87%         erase 88%         erase 88%         erase 89%         erase 89%         erase 90%         erase 90%         erase 91%         erase 91%         erase 92%         erase 92%         erase 93%         erase 93%         erase 94%         erase 94%         erase 95%         erase 95%         erase 96%         erase 96%         erase 97%         erase 97%         erase 98%         erase 98%         erase 99%         erase 99%         write 0%         write 0%         write 0%         write 1%         write 1%         write 2%         write 2%         write 3%         write 3%         write 4%         write 4%         write 5%         write 5%         write 6%         write 6%         write 7%         write 7%         write 8%         write 8%         write 9%         write 9%         write 10%         write 10%         write 11%         write 11%         write 12%         write 12%         write 13%         write 13%         write 14%         write 14%         write 15%         write 15%         write 16%         write 16%         write 17%         write 17%         write 18%         write 18%         write 19%         write 19%         write 20%         write 20%         write 21%         write 21%         write 22%         write 22%         write 23%         write 23%         write 24%         write 24%         write 25%         write 25%         write 25%         write 26%         write 26%         write 27%         write 27%         write 28%         write 28%         write 29%         write 29%         write 30%         write 30%         write 31%         write 31%         write 32%         write 32%         write 33%         write 33%         write 34%         write 34%         write 35%         write 35%         write 36%         write 36%         write 37%         write 37%         write 38%         write 38%         write 39%         write 39%         write 40%         write 40%         write 41%         write 41%         write 42%         write 42%         write 43%         write 43%         write 44%         write 44%         write 45%         write 45%         write 46%         write 46%         write 47%         write 47%         write 48%         write 48%         write 49%         write 49%         write 50%         write 50%         write 50%         write 51%         write 51%         write 52%         write 52%         write 53%         write 53%         write 54%         write 54%         write 55%         write 55%         write 56%         write 56%         write 57%         write 57%         write 58%         write 58%         write 59%         write 59%         write 60%         write 60%         write 61%         write 61%         write 62%         write 62%         write 63%         write 63%         write 64%         write 64%         write 65%         write 65%         write 66%         write 66%         write 67%         write 67%         write 68%         write 68%         write 69%         write 69%         write 70%         write 70%         write 71%         write 71%         write 72%         write 72%         write 73%         write 73%         write 74%         write 74%         write 75%         write 75%         write 75%         write 76%         write 76%         write 77%         write 77%         write 78%         write 78%         write 79%         write 79%         write 80%         write 80%         write 81%         write 81%         write 82%         write 82%         write 83%         write 83%         write 84%         write 84%         write 85%         write 85%         write 86%         write 86%         write 87%         write 87%         write 88%         write 88%         write 89%         write 89%         write 90%         write 90%         write 91%         write 91%         write 92%         write 92%         write 93%         write 93%         write 94%         write 94%         write 95%         write 95%         write 96%         write 96%         write 97%         write 97%         write 98%         write 98%         write 99%         write 99%         write 100%
Net:   Detected MACID:4c:11:bf:96:73:b3
PHY:0x00221513,addr:0x00
Filename 'upgrade_info_7db780a713a4.txt'.
Load address: 0xc5000000
Loading: *
Fail to get info file!
Init error!
Filename 'failed.txt'.
Loading: *
DRAM:  254 MiB
NAND:  128 MiB
state:ff,err_count:00
Loading: *
Init error!
Loading: *
DRAM:  254 MiB
NAND:  128 MiB
state:ff,err_count:01
Loading: *
Init error!
Loading: *
DRAM:  254 MiB
NAND:  128 MiB
state:ff,err_count:02
Loading: *
Init error!
Loading: *
DRAM:  254 MiB
NAND:  128 MiB
state:ff,err_count:03
Loading: *1..2..3..boot_from:normal
DRAM:  254 MiB
NAND:  128 MiB
state:ff,err_count:04
тут уже проблема.... сразу crashflasg:1, logmagic:54410011, разворачивание чего-то из backup... и перезагрузки.. :((
Проблема с флэшкой??? Куда дальше смотреть и что сделать...
Re: HDBW4300E проблема с флэшкой??
Сообщение iTuneDVR » 11 июл 2017, 17:01
Это нормально.
В этой серии камер есть замечательное свойство.
После 5 раз подряд перезагрузки со сбоем (для этого есть спец.счётчик), идёт восстановления из резерва флеша и камера должна быть как новенькая?
Включи камеру, включи лог и оставь на какое-то время, пусть покрутится.
Потом, если результата не будет и поскольку это NAND, то наверное стоит еще раз тормознуть загрузку и попробовать потестить флеш прямо там.
Может с флешем всё нормально, но ...
должно быть при нормальных условиях как-то так по примеру из загрузки DH-IPC-HDW4300C:
Created: 2015-07-10 10:03:05 UTC
Data Size: 2546896 Bytes = 2.4 MiB
Linux version 2.6.38.8 (jenkins@jenkins127) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-70) ) #1 PREEMPT Fri Jul 10 18:03:00 CST 2015
CPU: ARMv6-compatible processor [4117b365] revision 5 (ARMv6TEJ), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: Coconut
kalam
Сообщение kalam » 11 июл 2017, 17:41
Похоже действительно разворачивает старый образ и грузится.... НО после загрузки доступа к ней нет.. ни через web, ни по telnet.
Последним ConfigTool из ToolBox камера находится, пишется ее MAC, а вот поле Version показывает 0.0.0.0
И из вкладок конфигтула при попытке живого просмотра или обновления прошивки - пишет "Connection failed" :(
В выводе ее загрузки (с dh_keyboard=0) каких либо стопаний или kernel panic не наблюдаю... Есть "Fail to get env hwidEx!"
>set dh_keyboard 0
>saveenv
Erasing Nand...
>bootd
Linux version 2.6.38.8 (jenkins@jenkins127) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-70) ) #1 PREEMPT Fri Nov 6 19:19:21 CST 2015
Machine: Coconut
ethaddr0=4c:11:bf:96:73:b3
ethaddr1=0:0:0:0:0:0
lip0=192.168.1.108
lip1=0.0.0.0
id=TZC4MX251W00024
U-Boot 0x100000 0x200000 0x0
hwid 0x100000 0x300000 0x0
updateflag 0x100000 0x400000 0x0
partition 0x100000 0x500000 0x0
custom 0x340000 0x600000 0x0
product 0x340000 0x940000 0x0
Kernel 0x580000 0xc80000 0x0
romfs 0x800000 0x1200000 0x0
web 0x800000 0x1a00000 0x0
user 0x1980000 0x2200000 0x0
syslog 0x400000 0x7200000 0x0
config 0x400000 0x7600000 0x0
backup 0x400000 0x7a00000 0x0
gLogRamRes: start=0xc8b7e000;size=0x80000
mem_relimitAddr:0xc8bfe000
init gLogRamRes: start=0xc8b7e000;size=0x80000
init mem_relimitAddr:0xc8bfe000
Ambarella: AHB   = 0x60000000[0xf0000000],0x01000000 0
Ambarella: APB   = 0x70000000[0xf1000000],0x01000000 0
Ambarella: PPM   = 0xc0000000[0xe0000000],0x00200000 9
Ambarella: BSB   = 0xc8c00000[0xe8c00000],0x00400000 9
Ambarella: DSP   = 0xc9000000[0xe9000000],0x07000000 9
Ambarella: HAL   = 0xc00a0000[0xfee00000],0x0000e708 9
bootmem_init: high_memory = 0xc8a00000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 35052
Kernel command line: console=ttyS0 mem=138M ubi.mtd=romfs root=ubi0:romfs ro rootfstype=ubifs init=/linuxrc video=amb0fb:720x480,720x480,1,0 lpj=2392064
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 138MB = 138MB total
Memory: 134516k/134516k available, 6796k reserved, 0K highmem
    DMA     : 0xfe600000 - 0xfee00000   (   8 MB)
    vmalloc : 0xc9000000 - 0xe0000000   ( 368 MB)
    lowmem  : 0xc0000000 - 0xc8a00000   ( 138 MB)
      .init : 0xc0008000 - 0xc002c000   ( 144 kB)
      .text : 0xc002c000 - 0xc0483000   (4444 kB)
      .data : 0xc0484000 - 0xc04ac750   ( 162 kB)
Preemptable hierarchical RCU implementation.
   RCU-based detection of stalled CPUs is disabled.
   Verbose stalled-CPUs detection is disabled.
NR_IRQS:224
console [ttyS0] enabled
Calibrating delay loop (skipped) preset value.. 478.41 BogoMIPS (lpj=2392064)
devtmpfs: initialized
Ambarella Coconut:
   chip id:      5100
   board type:      3
   board revision:      10
   chip name:      a5m
   HAL version:      207871
   reference clock:   24000000
   system configuration:   0x040004ea
   boot type:      0x00000002
   hif type:      0x00000000
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
msgmni has been set to 262
[serial_ambarella_probe]:700--devId:0;keyboard:0;Console:0;nr:2;total:2
ambarella-uart.0: ttyS0 at MMIO 0x70005000 (irq = 9) is a ambuart
[serial_ambarella_probe]:700--devId:1;keyboard:0;Console:0;nr:2;total:2
brd: module loaded
loop: module loaded
NAND device: Manufacturer ID: 0x92, Chip ID: 0xf1 (Unknown NAND 128MiB 3,3V 8-bit)
ambarella_nand_config_flash: 0x00000000, 0x02c00140
Scanning device for bad blocks
Creating 13 MTD partitions on "ambnand":
0x000000200000-0x000000300000 : "U-Boot"
0x000000300000-0x000000400000 : "hwid"
0x000000400000-0x000000500000 : "updateflag"
0x000000500000-0x000000600000 : "partition"
0x000000600000-0x000000940000 : "custom"
0x000000940000-0x000000c80000 : "product"
0x000000c80000-0x000001200000 : "Kernel"
0x000001200000-0x000001a00000 : "romfs"
0x000001a00000-0x000002200000 : "web"
0x000002200000-0x000003b80000 : "user"
0x000007200000-0x000007600000 : "syslog"
0x000007600000-0x000007a00000 : "config"
0x000007a00000-0x000007e00000 : "backup"
UBI: attaching mtd7 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    129024 bytes
UBI: smallest flash I/O unit:    2048
UBI: sub-page size:              512
UBI: VID header offset:          512 (aligned 512)
UBI: data offset:                2048
UBI: max. sequence number:       2
UBI: attached mtd7 to ubi0
UBI: MTD device name:            "romfs"
UBI: MTD device size:            8 MiB
UBI: number of good PEBs:        64
UBI: number of bad PEBs:         0
UBI: number of corrupted PEBs:   0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 64
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 1/0
UBI: image sequence number:  144503508
UBI: background thread "ubi_bgt0d" started, PID 679
console [netcon0] enabled
netconsole: network logging started
TCP bic registered
IPv6 over IPv4 tunneling driver
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
UBIFS: mounted UBI device 0, volume 0, name "romfs"
UBIFS: mounted read-only
UBIFS: file system size:   6193152 bytes (6048 KiB, 5 MiB, 48 LEBs)
UBIFS: journal size:       1419264 bytes (1386 KiB, 1 MiB, 11 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: zlib
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) readonly on device 0:15.
devtmpfs: mounted
Freeing init memory: 144K
UBI: attaching mtd9 to ubi1
UBI: attached mtd9 to ubi1
UBI: MTD device name:            "user"
UBI: MTD device size:            25 MiB
UBI: number of good PEBs:        204
UBI: total number of reserved PEBs: 204
UBI: image sequence number:  969090584
UBI: background thread "ubi_bgt1d" started, PID 727
UBI device number 1, total 204 LEBs (26320896 bytes, 25.1 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
UBIFS: mounted UBI device 1, volume 0, name "user"
UBIFS: file system size:   24256512 bytes (23688 KiB, 23 MiB, 188 LEBs)
UBIFS: journal size:       3612672 bytes (3528 KiB, 3 MiB, 28 LEBs)
UBI: attaching mtd4 to ubi2
UBI: attached mtd4 to ubi2
UBI: MTD device name:            "custom"
UBI: MTD device size:            3 MiB
UBI: number of good PEBs:        26
UBI: total number of reserved PEBs: 26
UBI: image sequence number:  1172883456
UBI: background thread "ubi_bgt2d" started, PID 734
UBI device number 2, total 26 LEBs (3354624 bytes, 3.2 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
UBIFS: mounted UBI device 2, volume 0, name "custom"
UBIFS: file system size:   1548288 bytes (1512 KiB, 1 MiB, 12 LEBs)
UBIFS: journal size:       903169 bytes (882 KiB, 0 MiB, 6 LEBs)
UBI: attaching mtd5 to ubi3
UBI: attached mtd5 to ubi3
UBI: MTD device name:            "product"
UBI: image sequence number:  460744644
UBI: background thread "ubi_bgt3d" started, PID 741
UBI device number 3, total 26 LEBs (3354624 bytes, 3.2 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
UBIFS: mounted UBI device 3, volume 0, name "pd"
UBI: attaching mtd8 to ubi4
UBI: attached mtd8 to ubi4
UBI: MTD device name:            "web"
UBI: image sequence number:  872112470
UBI: background thread "ubi_bgt4d" started, PID 748
UBI device number 4, total 64 LEBs (8257536 bytes, 7.9 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
UBIFS: mounted UBI device 4, volume 0, name "web"
UBI: attaching mtd10 to ubi5
UBI: max. sequence number:       3282
UBI: attached mtd10 to ubi5
UBI: MTD device name:            "syslog"
UBI: MTD device size:            4 MiB
UBI: number of good PEBs:        32
UBI: available PEBs:             6
UBI: max/mean erase counter: 127/103
UBI: image sequence number:  1794095553
UBI: background thread "ubi_bgt5d" started, PID 755
UBI device number 5, total 32 LEBs (4128768 bytes, 3.9 MiB), available 6 LEBs (774144 bytes, 756.0 KiB), LEB size 129024 bytes (126.0 KiB)
UBI error: ubi_create_volume: cannot create volume 1, error -17
ubimkvol: error!: cannot UBI create volume
          error 17 (File exists)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 5, volume 0, name "syslog"
UBIFS: journal size:       903169 bytes (882 KiB, 0 MiB, 5 LEBs)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  73129 bytes (71 KiB)
UBI: attaching mtd11 to ubi6
UBI: max. sequence number:       3268
UBI: attached mtd11 to ubi6
UBI: MTD device name:            "config"
UBI: max/mean erase counter: 130/102
UBI: image sequence number:  -254915772
UBI: background thread "ubi_bgt6d" started, PID 767
UBI device number 6, total 32 LEBs (4128768 bytes, 3.9 MiB), available 6 LEBs (774144 bytes, 756.0 KiB), LEB size 129024 bytes (126.0 KiB)
UBIFS: mounted UBI device 6, volume 0, name "config"
UBI: attaching mtd12 to ubi7
UBI: max. sequence number:       3123
UBI: attached mtd12 to ubi7
UBI: MTD device name:            "backup"
UBI: max/mean erase counter: 117/98
UBI: image sequence number:  1859897201
UBI: background thread "ubi_bgt7d" started, PID 779
UBI device number 7, total 32 LEBs (4128768 bytes, 3.9 MiB), available 6 LEBs (774144 bytes, 756.0 KiB), LEB size 129024 bytes (126.0 KiB)
UBIFS: mounted UBI device 7, volume 0, name "backup"
[OSA-DRV] OSA Build on Nov  6 2015 at 18:26:40.
[OSA-DRV] SVN NUM: 3047.
[OSA-DRV] Monitor    Task   pid=814   tid=814
[LOG-DRV] LOG Build on Nov  6 2015 at 18:29:19.
[LOG-DRV] SVN NUM: 7339.
[LOG-DRV] ramStart:0xc8b7e000;ramSize:0x80000;select:1
00:00:10|[Binder] Binder.ko Build on Nov  6 2015 at 17:59:56.
00:00:10|[Binder] SVN NUM: 2380.
00:00:10|[Binder] Create binder memory pool(size:524288) OK!
00:00:10|[Binder] Create binder memory pool(size:3145728) OK!
00:00:10|[Binder] NameServer Initial OK !
00:00:10|[Binder] Binder Initial OK !
00:00:10|[OSA-DRV] Char device create OK !
00:00:10|[Binder] SR driver initial OK !
00:00:10|[Binder] NS driver initial OK !
00:00:10|[Binder] Binder driver initial OK !
00:00:10|[SPF] SPF Build on Nov  6 2015 at 18:52:14.
00:00:10|[SPF] SVN NUM: 7586.
00:00:10|[SPF] SIL initial OK !
00:00:10|[SPF] SPF initial ok !
00:00:10|[SPF] SPF Proc Create OK!!!
00:00:10|[SPF] SPF driver initial ok !
00:00:11|[prc] PRC Driver Build on Nov  6 2015 at 18:43:43.
00:00:11|[prc] SVN NUM: 3122.
00:00:11|[prc] Start to init module!
00:00:11|[SPF] Dai 2 register OK !
00:00:11|[prc] Success to init module!
00:00:11|[pdc]
PDC Build on Nov  6 2015 at 18:31:46.
00:00:11|[pdc] SVN NUM: 5368.
00:00:11|[prc] ERROR  (/home/jenkins/jk_slave/workspace/IPC_DH3.S0507_IPCAmbarella2.420/tmp_build_dir/PRC_A5S/build/platbuild/../../src/module/submod/i2c/prc_i2c.c|I2C_isr|475): I2C0 dev0x68 wait ack timeout
00:00:11|[pdc] BASE_LINE: 240
00:00:11|[pdc] OSA_kProcCreate OK
00:00:11|[OSA-DRV] Char device create OK !
00:00:11|[pdc] PDC_PartionInit ok!!
00:00:11|[pdc] HWID : IPC-HDBW4100E:01:02:05:17:0B:00:01:00:00:00:00:210:00:00:02:00:00:00:00:00:100
00:00:11|[pdc] binderFlag: 0x3, funcap: 0x18538b,0x0,0x0,0x0
00:00:11|[pdc] SenCfg Match OK,pCfgParams->pCfg: bf1109b4
00:00:11|[pdc] Find Product: IPC-HDBW4100E.
00:00:11|[pdc] Config size 2508 !
00:00:11|[pdc] SenCfgSize: 212 Bytes
00:00:11|[pdc] Init spiBus1  Successed!
00:00:11|[pdc] Init I2CBus0  Successed!
00:00:11|[pdc] PDC_MODULE_RESET_STATE
00:00:11|[pdc] OSA_kProcAddFile:pdcIris OK!
00:00:11|[pdc] ircut types = [0]
00:00:11|[pdc] ircut types = [1]
00:00:11|[pdc] Dev has No shutDown Cfg!
00:00:11|[pdc] PDC_pinInit As Usual!
00:00:11|[pdc] Get reset pin: 7 OK !
00:00:11|[pdc] Get comPort Cfg ok !0sa
00:00:11|[pdc] PDC_comInit OK!
00:00:11|[pdc] PDC_MODULE_SENSOR
00:00:11|[pdc] Try RtcDev:DS1338
00:00:11|[prc] ERROR  (/home/jenkins/jk_slave/workspace/IPC_DH3.S0507_IPCAmbarella2.420/tmp_build_dir/PRC_A5S/build/platbuild/../../src/module/submod/i2c/prc_i2c.c|I2C_socTransfer|1032): I2C0 dev0x68 wait ack timeout
00:00:11|[prc] ERROR  (/home/jenkins/jk_slave/workspace/IPC_DH3.S0507_IPCAmbarella2.420/tmp_build_dir/PRC_A5S/build/platbuild/../../src/module/submod/i2c/prc_i2c.c|PRC_i2cTransfer|1106): I2C0 transfer fail!
00:00:11|[pdc] ERROR  (DS_read|143): Fail to write
00:00:11|[pdc] ERROR  (DS_enableRtc|364): Fail to read RTC register
00:00:11|[pdc] ERROR  (DS_open|421): Fail to enable RTC
00:00:11|[pdc] Try RtcDev: SocRtc
00:00:11|[prc] WARN  (/home/jenkins/jk_slave/workspace/IPC_DH3.S0507_IPCAmbarella2.420/tmp_build_dir/PRC_A5S/build/platbuild/../../src/module/submod/rtc/prc_rtc.c|PRC_rtcCreate|460): =====PRC_rtcCreate OK=====
00:00:11|[pdc] phyaddr = c8bfe000, memLen = 2000
00:00:11|[pdc] DDRdata crc incorrect, Load from sramFile
00:00:11|[pdc] A B OK
00:00:11|[pdc] Both of Chief and Backup File CRC check OK!
00:00:11|[pdc] Choose RtcType: 4 -> SocRtc
00:00:11|[pdc] OSA_kProcAddFile:pdcRtc OK!
00:00:11|[p00:00:11|[pdc]  SramFile_devRelease OK!
dc] smartIr light count:1
00:00:11|[pdc] SmartIR init pwmId: 0,mode: 0,activeLevel: 1
00:00:11|[pdc] OSA_kProcAddFile:pdcSmartIR OK!
00:00:11|[pdc] WDT proc Add OSA_kProcAddFile ok!
00:00:11|[pdc] sclGpio = [6], sdaGpio = [5]
00:00:11|[pdc] PDC_keyScanGpioInit OK
00:00:11|[pdc] Dev has No Key Cfg!
00:00:11|[pdc] SramFile init ok !
 00:00:11|[OSA-DRV] recordTsk  Task   pid=854   tid=854
00:00:11|[pdc] PDC Driver Initial OK !
CATEGORY = 2
IPC Device
00:00:11|[crypt]
Crypt Build on Nov  6 2015 at 17:53:02.
00:00:11|[crypt] SVN NUM: 2384.
***************AT88SC Crypt Version***************
Type: DH General. UserZone ReadOnly: false
SVN: 2848
Built in: Jul  7 2015 09:16:21
00:00:11|[crypt] gbuf[4]:43, gbuf[5]:44.
SVN: 2848
rwdata5 = 44, need authenticate
00:00:12|[crypt] crypto driver init successful!
00:00:12|[pdc]  SramFile_devRelease OK!
product_name =IPC-HDBW4100E
<1>gAutoneg: 1, gSpeed: 100, gDuplex: 1, gIsMiiToSwitch: 0, gAmbethRxPktsIsDelay: 600
<6>Ambarella MII Bus: probed
<5>ambarella-eth ambarella-eth.0: MAC Address[4c:11:bf:96:73:b3].
[OSA-APP] OSA Build on Nov  6 2015 at 18:26:33.
[OSA-APP] SVN NUM: 3047.
[libpdi] libpdi.so Build on Nov  6 2015 at 18:37:37.
[libpdi] SVN NUM: 19361.
00:00:12|[prc] WARN  (/home/jenkins/jk_slave/workspace/IPC_DH3.S0507_IPCAmbarella2.420/tmp_build_dir/PRC_A5S/build/platbuild/../../src/module/submod/rtc/prc_rtc.c|PRC_rtcCreate|460): =====PRC_rtcCreate OK=====
[libpdi] Support backup partition !!!
[libpdi]  Flashtype = 4,patSize = 100000,rwSize = 800,ersSize = 20000
00:00:12|[crypt] crypt_open ok!
00:00:12|[crypt]
00:00:12|[crypt] SVN NUM: 2384.
[libpdi] phyaddr= 0xc8bfe000, memLen= 0x2000
00:00:12|[pdc] Both of Chief and Backup File CRC check OK!
00:00:12|[crypt]
[Systools]: Build on Nov  6 2015 at 18:34:04.
[Systools]:SVN NUM: 18537.
UPGRADED_MSG: Do memlock
UPGRADED_MSG: lock failure: addrStart=40046000, addrEnd=4004d000
UPGRADED_MSG: lock failure: addrStart=4009d000, addrEnd=400a4000
00:00:13|[SEN-DRV] Sensor Build on Nov  6 2015 at 17:51:45.
00:00:13|[SEN-DRV] SVN NUM: 2760.
UPGRADED_MSG: lock failure: addrStart=4014a000, addrEnd=40151000
UPGRADED_MSG: lock failure: addrStart=40160000, addrEnd=40167000
UPGRADED_MSG: lock failure: addrStart=4016a000, addrEnd=40171000
UPGRADED_MSG: lock failure: addrStart=4017c000, addrEnd=40184000
UPGRADED_MSG: lock failure: addrStart=4019a000, addrEnd=401a2000
UPGRADED_MSG: lock failure: addrStart=401c3000, addrEnd=401ca000
00:00:13|[SEN-DRV] ERROR  (SEN_drvCoreAptinaPreInit|669): Invalid reg id value:0xffff
00:00:13|[SEN-DRV] ERROR  (SEN_drvCoreSensorPreInit|824): Failed to pre init sensor!
00:00:13|[SEN-DRV] ERROR  (SEN_drvCoreCreateSensorDev|842): init sensor failed
00:00:13|[SEN-DRV] ERROR  (SEN_drvCoreAllocSensorObj|1129): create sensor dev failed
00:00:13|[SEN-DRV] ERROR  (SEN_drvCoreInitSensorList|1210): alloc sensor obj failed
00:00:13|[SEN-DRV] ERROR  (SEN_drvInit|81): init core failed
insmod: can't insert '/usr/lib/modules/sensor.ko': Operation not permitted
<4>amba_video: Unknown symbol SEN_readReg (err 0)
<4>amba_video: Unknown symbol SEN_create (err 0)
<4>amba_video: Unknown symbol SEN_reset (err 0)
<4>amba_video: Unknown symbol SEN_writeReg (err 0)
<4>amba_video: Unknown symbol SEN_delete (err 0)
insmod: can't insert '/usr/lib/modules/amba_video.ko': unknown symbol in module, or unknown parameter
Syshelper: WdtSa23:47:11|[prc] Set WdtTimeout To WdtTimeoutMax:59652, instead !
trtTime = 60(s), appauto = 1, hctosystime = 1500
<6>syshelper uses obsolete (PF_INET,SOCK_PACKET)
sendto arp wrong23:47:11|[systools] sendmsg NA packet wrong code:-1.
Fail to get env coremnt!
23:47:11|[systools] WARN  : coremnt not found
UPGRADED_MSG: lock failure: addrStart=40308000, addrEnd=40310000
23:47:11|[ambarella_sd_card] SDIO Driver (mmc_core.ko) SVN_NUM : 2529, Build Date: Nov  6 2015,Time: 17:57:02
23:47:11|[ambarella_sd_card] SDIO Driver (ambarella_sd.ko) SVN_NUM : 2529, Build Date: Nov  6 2015,Time: 17:57:04
23:47:11|[ambarella_sd_card] SDIO NEW_DMA
23:47:11|[ambarella_sd_card] ERROR  (/home/jenkins/jk_slave/workspace/IPC_DH3.S0507_IPCAmbarella2.420/tmp_build_dir/SDIO/build/../src/host/ambarella_sd.c|ambarella_sd_power_supply|1368): sd_error: Get SdCard cfg failed !
23:47:11|[ambarella_sd_card] ERROR  (/home/jenkins/jk_slave/workspace/IPC_DH3.S0507_IPCAmbarella2.420/tmp_build_dir/SDIO/build/../src/host/ambarella_sd.c|ambarella_wifi_power_supply|1436): wifi_error: Get wifi cfg failed !
23:47:11|[ambarella_sd_card] WARN  (/home/jenkins/jk_slave/workspace/IPC_DH3.S0507_IPCAmbarella2.420/tmp_build_dir/SDIO/build/../src/host/ambarella_sd.c|ambarella_sd_init|2371): Get sd & wifi Card cfg failed !
UPGRADED_MSG: lock failure: addrStart=403b3000, addrEnd=403ba000
Name: upgraded, bulid date: Nov  6 2015 17:42:32, svn: 386
UPGRADED_MSG: start download file!
23:47:11|[ambarella_sd_card] SDIO Driver (mmc_block.ko) SVN_NUM : 2529, Build Date: Nov  6 2015,Time: 17:57:01
23:47:11|[IVF-Drv] IVF Driver(SVN:3375) Build on Nov  6 2015 at 17:37:13.
23:47:11|[OSA-DRV] Char device create OK !
23:47:11|[IVF-Drv] IVF Driver install successfull!
23:47:11|[crypt] crypt_open ok!
23:47:11|[crypt]
23:47:11|[crypt] SVN NUM: 2384.
23:47:11|[pdc] Both of Chief and Backup File CRC check OK!
init eth0 to default
23:47:11|[libpdi] NET_disableRoute = 0
eth0:
MAC: <4c:11:bf:96:73:b3>
23:47:11|[libpdi] set eth0 as defaultEth
IP: <192.168.1.108>      netmask: <255.255.255.0>
<5>net eth0: Could not find default PHY in 2.
<1>Autoneg enable<6>ADDRCONF(NETDEV_UP): eth0: link is not ready
Gateway: <192.168.1.1>
23:47:11|[libpdi] SetGateWay success
23:47:12|[crypt] crypt_open ok!
23:47:12|[crypt]
23:47:12|[crypt] SVN NUM: 2384.
23:47:12|[pdc] Both of Chief and Backup File CRC check OK!
IPV6: only init eth0
23:47:12|[libpdi] NET_disableRoute = 0
"netinit6 help" for help
eth0:
IPV6: <2001:250:3000:1::1:2>      preFixLen: <112>
23:47:12|[libpdi] WARN  (NetWorkDelIP|1124): del ip failed:Cannot assign requested address
IPV6 Gateway: <2001:250:3000:1::1:1>
/dev/ucode: No such device or address
Load ucode failed!
dh_keyboard:0
==============>PPPOE2.4.5:Complie time Nov  6 2015 17:45:44 SvnVersion = 2618<=============
<6>ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
23:47:16|[crypt] crypt_open ok!
23:47:16|[crypt]
23:47:16|[crypt] SVN NUM: 2384.
23:47:16|[pdc] Both of Chief and Backup File CRC check OK!
[libenc] libenc.a svn num: 21909 compile time: Nov  6 2015 17:46:04
23:47:16|[Binder-Lib] libbinder.so Build on Nov  6 2015 at 17:59:54.
23:47:16|[Binder-Lib] SVN NUM: 2380.
23:47:16|[Binder] ERROR  (BND_nsOpen|1000): hNs is Null !
23:47:16|[Binder-Lib] ERROR  (BND_nsOpen|283): CMD_NS_OPEN failed !
23:47:16|[Binder-Lib] ERROR  (BND_nsGet|163): Input params is null !
23:47:16|info  >>>>>>>>>>>>>>>>>INITION_begin:42949392770
23:47:16|trace main( /usr/bin/sonia)
23:47:16|info  Pack Environment
URL: http://10.6.5.2/svnpl/Renascence/Projects/IPCAmbarella/Trunk @ 305504M
23:47:16|trace ******************app lib info******************
23:47:16|[libInfra] info [*] Function 1.1.0.280751 Built in 2015/11/ 6 [*]
23:47:16|[libInfra] info [*] RemoteService 1.1.0.301767 Built in 2015/11/ 6 [*]
23:47:16|[libInfra] info [*] Manager 1.1.0.265216 Built in 2015/11/ 6 [*]
23:47:16|[libInfra] info [*] NetApp 2.0.0.251618 Built in 2015/11/ 6 [*]
23:47:16|[libInfra] info [*] Storage 1.0.1.254451 Built in 2015/11/ 6 [*]
23:47:16|[StreamApp@260600] info Src/./StreamApp.cpp 17 [StreamAppComponent] initStreamAppServerComponent.
23:47:16|[StreamApp@260600] info Src/MediaSender/UdpMediaSenderImp.cpp 12 [StreamAppComponent] initStreamAppQuickMulticastComponent.
23:47:16|[StreamApp@260600] info Src/./StreamAppComponent.cpp 22 [StreamAppComponent] initStreamAppComponentLibrary All.
23:47:16|info  >>>>>>>>>>>>>>>>>INITION_end:42949392780
23:47:16|info  >>>>>>>>>>>>>>>>>INFRA_begin:42949392780
23:47:16|[libInfra] trace CThreadManager::CThreadManager()>>>>>>>>>
23:47:16|[libInfra] info [*] Infra 1.0.0.245423 Built in 2015/11/ 6 [*]
23:47:16|trace memory total: 134660
23:47:16|[NetFramework] info [*] NetFramework 1.0.0.244309 Built in Nov  6 2015 18:29:59[*]
23:47:16|[libInfra] debug ThreadBody Enter name = [MemoryUsage], id = 936, prior = N64, stack = 0x41a76dcc
Arena 0:
system bytes     =     323584
in use bytes     =     209056
Total (incl. mmap):
max mmap regions =          1
max mmap bytes   =     135168
23:47:16|[libInfra] debug ThreadBody Enter name = TimerManager, id = 935, prior = N1, stack = 0x411fbdcc
23:47:16|[NetFramework] info [*] NetFramework with open_sslVerison= 1.0.1j Built in Nov  6 2015 18:29:59[*]
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 942, prior = N64, stack = 0x443e2dcc
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 941, prior = N64, stack = 0x43af3dcc
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 940, prior = N64, stack = 0x432c8dcc
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 939, prior = N64, stack = 0x42a95dcc
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 938, prior = N64, stack = 0x42276dcc
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 943, prior = N64, stack = 0x44c3ddcc
########## SSL_library_init ####################
########## OpenSSL_add_all_algorithms ##########
########## SSL_load_error_strings ##############
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 944, prior = N64, stack = 0x454b8dcc
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 945, prior = N64, stack = 0x45cc8dcc
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 946, prior = N64, stack = 0x464d9dcc
23:47:16|[libInfra] debug ThreadBody Enter name = NetFramework, id = 947, prior = N64, stack = 0x46d56dcc
########## OpenSSL1.0.1j Ready #################
23:47:16|info  >>>>>>>>>>>>>>>>>INFRA_end:42949392840
23:47:16|info  >>>>>>>>>>>>>>>>>MANAGER_begin:42949392840
23:47:16|[Manager] trace CLog::CLog()>>>>>>>>>
23:47:16|info  CDatabase::config set memory limit : 2097152, query limit : 2097152, line : 503
23:47:16|[libDatabase] info CLogSqliteOperate::SqliteOpen>>>>Open DataBase Success! database: /mnt/mtd/Log/log.db
23:47:16|[libInfra] debug ThreadBody Enter name = RedirServer, id = 948, prior = N64, stack = 0x4760edcc
23:47:17|[libDatabase] trace match: log.db.%x
23:47:17|[libDatabase] trace log.db.31
23:47:17|[libDatabase] info integrity_check(): errcode(0), errmsg((null))
23:47:17|[libDatabase] trace check_database(): query count of records, table(log)
23:47:17|[libDatabase] trace check_database(): create table __dahua_test!
23:47:17|[libDatabase] trace check_database(): drop table __dahua_test!
23:47:17|[libDatabase] trace open_database(): succeed to open file(/mnt/mtd/Log/log.db.31)!
23:47:17|[libInfra] debug ThreadBody Enter name = dbLog, id = 949, prior = N64, stack = 0x47e6adcc
23:47:17|[Manager] warn CCommonConfigManager::CCommonConfigManager() read custom config file failed.
23:47:17|[libpdi] >-------System3_getSystemInfo------->
Fail to get env authcode!
23:47:17|[libpdi] Get authcode error
23:47:17|[libpdi] SeriNumBuf = TZC4MX251W00024
23:47:17|[pdc] WARN  (MISC_ioctl|537): Get SdCard cfg failed !
23:47:17|[libpdi]  deviceType:         IPC-HDBW4300E
23:47:17|[libpdi]  processorType:      11
23:47:17|[libpdi]  hardwareVersion:    1.00
23:47:17|[libpdi]  appAutoStart:       1
23:47:17|[libpdi]  serialNumber:       TZC4MX251W00024
23:47:17|[libpdi]  deviceClass:        IPC
23:47:17|[libpdi]  noPtz:              1
23:47:17|[libpdi]  noSdCard:           1
23:47:17|[libpdi]  bandWidth:          48
23:47:17|[libpdi] <-------System3_getSystemInfo-------<
23:47:17|[Manager] warn init:82 use default cmos def path!
23:47:17|[Manager] info use default CMOS definition!
23:47:17|[libpdi]  read RTC_SRAM_REBOOT = 1
23:47:17|[libpdi] PDI_getStartUpFlag: 2
23:47:17|[Manager] info CMagicBox::CMagicBox() getStartUpFlag 2
23:47:17|[libDatabase] info CLogSqliteOperate::isSynced insertRet : 1, removeRet : 1, updateRet : 1, line : 1256
23:47:17|[libDatabase] info CLogSqliteOperate::SqliteBackup vacuum use 40ms, iRet : 0, line : 1129
23:47:17|[libDatabase] trace backup_database(): start >>>
23:47:17|[libDatabase] trace remove_database(): min(49), max(49)
23:47:17|[libDatabase] trace remove file: /mnt/mtd/Log23:47:17|[prc] Set WdtTimeout To WdtTimeoutMax:59652, instead !
/log.db.31
23:47:17|[libDatabase] trace backup_database(): finished successfully! elapsed(190)
23:47:17|[libDatabase] info CLogSqliteOperate::isSynced SqliteBackup use 230, line : 1264
23:47:17|[Manager] warn CMagicBox::setSubModuleInfo fail!
23:47:17|[Manager] info CMagicBox::onConfigAutoMaintain day = [2], hour = [2], min = [0], enable = [true]
23:47:17|[Manager] info CMagicBox::startDstTune readCMOS DstTune flag is 0.
23:47:17|[Manager] warn CMagicBox::CMagicBox() load /var/tmp/pd/ProductDefinition product definition Languages file failed.
23:47:17|trace Create Alarm Module>>>>>>>>>>>>>>>>
23:47:17|[libpdi] dev has no BATTERY_CDEV_NAME
23:47:17|[libpdi] WARN  : Fail to create hbat!
23:47:17|[libpdi] Temp Dev not exists, status = -1
23:47:17|[libpdi] PDI_tempCreate, status = -1
23:47:17|[libInfra] debug ThreadBody Enter name = WatchDog, id = 950, prior = N1, stack = 0x4866adcc
Fail to get env peripheral!
23:47:17|trace alarmInputs=[0], alarmpir=[0], Flashlight=[0]
23:47:17|[Manager] warn CCommonConfigManager::getConfig Alarm is Json::nullValue!
23:47:17|warn  Src/Comm/Alarm.cpp:707 not support pir alarm.
23:47:17|[Manager] warn CCommonConfigManager::getConfig AlarmOut is Json::nullValue!
23:47:17|[Manager] error currDevSerial:TZC4MX251W00024
23:47:17|[Manager] error DevInformation'SerialID:TZC4MX251W00024
23:47:17|[Manager] trace CConsole::registerCmd had been register!!
23:47:17|[Manager] info CLdapUserManager::initialize() tye login times is 3
23:47:17|[Manager] trace CLog::attachFilter
23:47:17|[libInfra] debug ThreadBody Enter name = Console, id = 951, prior = N1, stack = 0x48ffedcc
23:47:17|[Manager] warn CMagicBox::getDeviceSubClass DeviceSubClass empty !
23:47:17|[Manager] debug CTelnetConfigHelper::onConfigTelnet(), m_cfgtelnet: null
23:47:17|[Manager] debug ConfigTelnet={
   "Enable" : false
23:47:17|[Manager] debug setTelnet interface ok!!!!!!!!,110,Src/Helper/TelnetHelper.cpp
23:47:17|[crypt] LANGUAGE: copy_to_user
23:47:17|[libpdi]
23:47:17|[Manager] error Src/Locales.cpp:141 system has no supportLanguages.
====================== assert failed ==========================
Assert(0) failed
File       <---> Src/Locales.cpp
Function   <---> virtual bool Dahua::Manager::CLocales::config(const Json::Value&)
Line       <---> 142
Time : Sat Jan  1 23:47:17 2000
=========================== TRACE START ===================================
Tid:934, Exception type : Assert failed
PC:[0x00770fa4] (0x00770f28--0x0077105f) Unknown
PC:[0x00534aa8] (0x00534978--0x00534dc7) Unknown
PC:[0x0051eff8] (0x0051ef98--0x0051effb) Unknown
PC:[0x0051f258] (0x0051f1f0--0x0051f28b) Unknown
PC:[0x0001d868] (0x0001d040--0x0001f533) Unknown
PC:[0x40395834] (0x40395720--0x40395940) __libc_start_main + [0x114]
PC:[0x0002a244] (0x0002a218--0x0002a277) Unknown
=========================== TRACE   END ===================================
не поместилось все...
kalam
Сообщение kalam » 11 июл 2017, 17:42
=========================== New TRACE   START ===================================
=========================== New TRACE   END =====================================
=============== restore handler for signal -1 failed ====================
=============== no core dump will be generated  ====================
23:47:18|[Manager] warn CCommonConfigManager::getConfig Language is Json::nullValue!
23:47:18|info  >>>>>>>>>>>>>>>>>MANAGER_end:42949393930
23:47:18|info  >>>>>>>>>>>>>>>>>GDI_begin:42949393930
23:47:18|info  >>>>>>>>>>>>>>>>>GDI_end:42949393930
23:47:18|info  >>>>>>>>>>>>>>>>>DVRIP_INIT_begin:42949393930
23:47:18|trace setDefault DVRIP
23:47:18|trace AlarmServer setDefault
23:47:18|trace setDefault Qos config
23:47:18|info  >>>>>>>>>>>>>>>>>DVRIP_INIT_end:42949393940
23:47:18|info  >>>>>>>>>>>>>>>>>NETAPP_begin:42949393940
23:47:18|[libInfra] info [*] StreamApp 2.1.1.260600 Built in 2015/11/ 6 [*]
23:47:18|[libInfra] info [*] NetApp 2.0.0.251618 Built in 2015/11/ 6 [*]
23:47:18|[NetApp-251618] trace <CreateInterface:63> create eth0 success !
23:47:18|[NetApp-251618] info   MAC IS  4c:11:bf:96:73:b3
23:47:18|[libpdi] GetLinkLocalAddress
23:47:18|[libpdi] eth0 MAC : 4c:11:bf:96:73:b3
23:47:18|[libpdi] fe80::4e11:bfff:fe96:73b3/64
23:47:18|[NetApp-251618] trace CSmtpCli::CSmtpClient()>>>>>>>>>
23:47:18|[Manager] warn CCommonConfigManager::getConfig Https is Json::nullValue!
23:47:18|[Manager] error CEventManager::attach>>>>>>>ret:1
23:47:18|trace IDevVideoIn  channel = 1
23:47:18|[NetApp-251618] trace CDhcpClientv6::CDhcpClientv6() Enter -----------.
23:47:18|[NetApp-251618] trace CDhcpClientv6::initDhcpv6()--------------.
23:47:18|[NetApp-251618] error [initDhcpv6()][154]: m_ipv6Cli[0].stateless_cli == NULL.
23:47:18|[Manager] warn CCommonConfigManager::getConfig T2UServer is Json::nullValue!
23:47:18|[NetApp-251618] info Src/NewWlan/WlanCli.cpp:117
23:47:18|[NetApp-251618] info Src/NewWlan/WlanManager.cpp:225
23:47:18|[NetApp-251618] warn >>> NetApp::CDNSManager() !
23:47:18|trace udn is:uuid:device_3_0-TZC4MX251W00024
23:47:18|trace devinfo.udn is:uuid:device_3_0-TZC4MX251W00024
23:47:18|[NetApp-251618] trace CNetApp::config, param:{
   "UPNP" : {
      "UPNPDevDescribe" : {
         "DeviceType" : "urn:schemas-upnp-org:device:3.0-TZC4MX251W00024",
         "FriendlyName" : "TZC4MX251W00024",
         "Manufacturer" : "General",
         "ManufacturerUrl" : "http:\/\/\/",
         "ModelDescription" : "General IPC",
         "ModelName" : "IPC",
         "ModelNum" : "IPC",
         "ModelUrl" : "http:\/\/\/",
         "PresentationUrl" : "http:\/\/192.168.1.108:80",
         "SerialNumber" : "4c:11:bf:96:73:b3",
         "Udn" : "uuid:device_3_0-TZC4MX251W00024",
         "Upc" : ""
23:47:18|[NetApp-251618] trace CUPnPDevPoint config, param:{
      "ModelNum" : "IPC",
      "Upc" : ""
23:47:18|[NetApp-251618] trace NetApp start >>>>>>>>>>>>>>>>>>>>>>>
23:47:18|[NetApp-251618] debug checkEths>>>843: OldNetAccessPri:null
, m_configNetAccessPri:{
   "LAN" : [ "eth0" ]
23:47:18|[libInfra] debug ThreadBody Enter name = [ClientCheck], id = 952, prior = N64, stack = 0x497fedcc
23:47:18|[Manager] warn CCommonConfigManager::getConfig Wireless is Json::nullValue!
23:47:18|[libpdi] NET_disableRoute = 1
23:47:18|[NetApp-251618] trace UpdateConfigNetwork loading...
23:47:18|[NetApp-251618] trace CNetworkManager::OnConfigNetwork
23:47:18|[NetApp-251618] trace line[537]CNetworkManager::OnConfigNetworkIpv6().
Src/BaseApp/NetInterFace.cpp,588: SetIpByName set ip: 192.168.1.108, mask: 255.255.255.0, pEthName:eth0
Src/BaseApp/NetInterFace.cpp,621: SetGateByName set gate: 192.168.1.1, pEthName:eth0
23:47:18|[Manager] info ========================================================================
23:47:18|[Manager] info CMagicBox::onSecondTimer current date and time are : 2000-01-01 23:47:18
23:47:18|[NetApp-251618] trace CDhcpClientv4 Enter--------
23:47:18|[NetApp-251618] trace CDhcpClientv4::stopDhcp() Error.
23:47:18|[NetApp-251618] trace CNetApp::ARPPingSetIP() Start>>>>>>>>>>
23:47:18|[NetApp-251618] trace Src/Ntp/NtpClient.cpp,62: CNtpClient::start().
23:47:18|[NetApp-251618] trace Src/Ntp/NtpClient.cpp,90: NtpClient start succeed. update tamp is 10.
23:47:18|[NetApp-251618] trace Src/AutoSearchIPNew/UPnPDevPointServer.cpp,220: UPnPDevicePoint::start()>>>>>>>>>>>>>>>>>>>>>
23:47:18|[NetApp-251618] debug adjustPriTable>>>1003: [ "PPPOE", "WIFI", "3G", "LAN" ]
23:47:18|[NetApp-251618] trace CRouteManager::OnConfigNetAccessPri
23:47:18|[NetProt-258820] error Src/ssdp/Ssdp.cpp,2301:IP_ADD_MEMBERSHIP failed, Address already in use
Start Upnp Mini Server success! listen port: 49152
23:47:18|[NetApp-251618] trace CDdnsCli::start()>>>>>>>>>>>>>>>>>>>>>
23:47:18|[NetApp-251618] trace CSNMP::start()>>>>>>>>>>>>>>>>>>
23:47:18|[NetApp-251618] trace CSNMP::start  SNMP is disable!
23:47:18|[NetApp-251618] trace Src/Bonjour/DHBonjourRunner.cpp, 51:CDHBonjourRunner::start()>>>>>>>>>>>>>>>>>>>>>
DHBonjour_Start >> watch_process pid = 934, Thread 1241511008 enter !
DHBonjour: Registered service[0x1d9ce60] name 'TZC4MX251W00024', type '_http._tcp.', port 80
23:47:18|[NetApp-251618] trace Src/Bonjour/DHBonjourRunner.cpp, 199: service[TZC4MX251W00024:0x1d9ce60] registered, add to map.
23:47:18|[NetApp-251618] trace Src/Bonjour/DHBonjourRunner.cpp:107 bonjour run seccess
23:47:18|[NetApp-251618] trace CRouteManager::checkRoute >> ConfigNetwork changed !
23:47:18|[NetApp-251618] trace CRouteManager::checkRoute >> m_configWlan changed !
23:47:18|[NetApp-251618] info eth0 IP has been changed !
eth0            0
   192.168.1.108   255.255.255.0   192.168.1.1   1500
23:47:18|[libpdi] delete route: eth0, 192.168.1.0, 255.255.255.0
23:47:18|[libpdi] EthName:eth0 route delete ok!
23:47:18|[NetApp-251618] info &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&
<eth0:    ip. 192.168.1.108, mask. 255.255.255.0, gw. 192.168.1.1>
<eth0:    ip. 192.168.1.108, mask. 255.255.255.0, gw. 192.168.1.1, iscommit. , isdflt. 1>
<eth0  true>
23:47:18|[NetApp-251618] info Ethname: eth0   IpAddress: 192.168.1.108   netMask: 255.255.255.0   Gateway: 192.168.1.1
23:47:18|[libpdi] add route: eth0, 192.168.1.0, 255.255.255.0
23:47:18|[libpdi] add route success
23:47:18|[libpdi] delete route: eth0, default, 192.168.1.1
23:47:18|[libpdi] delete route success
23:47:18|[NetApp-251618] info set default route from eth0 to eth0, Src/NetworkManager/RouteManager.cpp,805
23:47:18|[libpdi] add route: eth0, default, 192.168.1.1
23:47:18|debug tracepoint: Src/NetworkManager/RouteManager.cpp, 872.
23:47:18|[NetApp-251618] info [Src/BaseApp/MultiInterfaceSocket.cpp,358][initSocket] we will do device discover on these interfaces {
   "eth0" : {
      "IPAddress" : "192.168.1.108",
      "Netmask" : "255.255.255.0"
 port 37810
23:47:18|[NetApp-251618] trace C802_1x::start()>>>>>>>>>>>>>>>>>>>>>
23:47:18|[NetApp-251618] info C802_1x::start>>>wpa_supplicant not run becaues 802.1x is disable!
23:47:18|[NetApp-251618] info Src/NewWlan/WlanManager.cpp:270
==============> libWireless version: 1.0 - Complie time Nov  6 2015 17:49:08 SvnVersion = 6760<=============
23:47:18|[NetApp-251618] trace CWlanCli::startCli()>>>>>>>>>>>>>>>>>>
23:47:18|[NetApp-251618] info CWlanCli::setStationMode()>>>0->1
23:47:18|[NetApp-251618] warn CWlanManager Src/NewWlan/WlanManager.cpp:303
23:47:18|[NetApp-251618] info CWlanManager::setWLanWorkMode()>>>0->1
23:47:18|[NetApp-251618] warn CWlanManager Src/NewWlan/WlanManager.cpp:369
pppoe enable have Disabled!
[libWifi]hotplug_thd pid=954--Src/wifi_lib/wifi_api.c(4155)wlan_hotplug_thd
[libWifi]watch_thd pid=955--Src/wifi_lib/wifi_api.c(5313)wlan_watch_thd
23:47:18|[NetApp-251618] trace Src/ARP/ARP.cpp,905: create arpmanger here.
23:47:18|[NetApp-251618] trace libnetArp.a version:V2.01 --modify 2012-4-9
23:47:18|[NetApp-251618] trace CArpManager::start()
23:47:18|[NetApp-251618] trace CArpManager add eth0 to arp map
23:47:18|[NetApp-251618] trace CArp:: eth0 Start
23:47:18|[NetApp-251618] trace CSmtpCli::Start()>>>>>>>>>>>>>>>>>>>>>
23:47:18|[NetApp-251618] trace CProviderManager::start() with config[MobilePushNotification]>>>>>>>>>>>>>>>>>>
23:47:18|[libInfra] debug ThreadBody Enter name = AppleProvider, id = 957, prior = N64, stack = 0x4c9d2dcc
23:47:18|[libpdi] set eth0 as defaultEth
23:47:19|[NetApp-251618] info Set default route from eth0 to 192.168.1.1
23:47:19|[libInfra] debug ThreadBody Enter name = SMTP, id = 956, prior = N64, stack = 0x4c0eddcc
23:47:19|[libInfra] debug ThreadBody Enter name = Arp, id = 958, prior = N64, stack = 0x4b84fdcc
23:47:19|[NetApp-251618] trace Src/ARP/ARP.cpp,267: thread loop now.
23:47:19|[NetApp-251618] info NetworkCheck::Network is Change,notify NetworkChange Event
23:47:19|info  >>>>>>>>>>>>>>>>>NETAPP_end:42949394670
23:47:19|info  >>>>>>>>>>>>>>>>>STORAGE_begin:42949395000
23:47:19|[NetApp-251618] trace Src/ARP/ARP.cpp,941: ip check.iframe: eth0
libnetArp.a::eth0 send free arp failed!iSocket == -1
23:47:19|[libInfra] debug ThreadBody Enter name = AndroidProvider, id = 959, prior = N64, stack = 0x4d24ddcc
23:47:19|[libInfra] debug ThreadBody Enter name = [EventManager], id = 962, prior = N64, stack = 0x4da4ddcc
23:47:19|[NetApp-251618] trace m_CurdfltNetCard:eth0, curdflt:eth0.
23:47:19|[NetApp-251618] info [Src/BaseApp/MultiInterfaceSocket.cpp,358][initSocket] we will do device discover on these interfaces {
   "eth0" : {
 port 37810
23:47:19|[libStorage] debug CStorageAdaptor::config. param is {
   "DefaultFileSystem" : {
      "General" : "FAT32",
      "HardDisk" : "FAT32",
      "SDCard" : "FAT32",
      "UsbDisk" : "FAT32",
      "UsbFlash" : "FAT32"
   "FileCountStat" : false,
   "MountDir" : "\/mnt",
   "RecordHoldBuffer" : {
      "HoldMaxMSec" : 1500,
      "HoldMaxSize" : 1048576,
      "WritevSectorNum" : 55
   "SafeSpace" : 512,
   "SpaceCheckInterval" : 1,
   "Summary" : "File",
   "WorkDirectory" : {
      "DirInfoFileName" : "DVRWorkDirectory"
23:47:19|info  >>>>>>>>>>>>>>>>>STORAGE_end:42949395020
23:47:19|info  >>>>>>>>>>>>>>>>>MEDIA_begin:42949395020
23:47:19|[Manager] warn CCommonConfigManager::getConfig VideoStandard is Json::nullValue!
23:47:19|warn  CDisplay::verifyConfigVideoStandard, Video Standard is , list is null
23:47:19|[libpdi] getConfig fun[0]: 0x18538b
23:47:19|[libpdi] getConfig fun[1]: 0x0
23:47:19|[libpdi] getConfig fun[2]: 0x0
23:47:19|[libpdi] bndFlag: 0x3
23:47:19|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:19|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:19|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:19|[NetApp-251618] trace [Src/NetworkManager/NetworkManager.cpp,383][NetSpeedUpdate]  eth0 is added to get the netspeed!!!!!
DHBonjour: Callback: Registered
23:47:20|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:20|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:20|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:20|[libpdi] Read: blkIndex: 1,pageIndex: 0,byteIndex: 0 ,fLag: ff
23:47:20|[libpdi] Write: blkIndex: 1,pageIndex: 0,byteIndex: 0 ,fLag: 0
23:47:21|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:21|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:21|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:21|[libpdi] ERROR  (safe_fopen|1754): Fail to open usb USB_DEVICE_NAME:/proc/bus/usb/devices!
23:47:21|[libpdi] ERROR  (get_usb_devs|2315): safe_fopen /proc/bus/v-usb/devices failed!!
23:47:22|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:22|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:22|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:23|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:23|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:23|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:23|[libpdi] ERROR  (safe_fopen|1754): Fail to open usb USB_DEVICE_NAME:/proc/bus/usb/devices!
23:47:23|[libpdi] ERROR  (get_usb_devs|2343): safe_fopen /proc/bus/usb/devices failed!
[libWifi]ALARM:Fail to open read usb devices information!--Src/wifi_lib/wifi_api.c(4568)get_usb_device
[libWifi]ALARM:no usb devices return !--Src/wifi_lib/wifi_api.c(4575)get_usb_device
[libWifi]ERROR:SDIO devices is not exist--Src/wifi_lib/wifi_api.c(4474)is_sdio_device_exist
23:47:24|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:24|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:24|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:25|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:25|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:25|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:26|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:26|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:26|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:27|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:27|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:27|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
23:47:28|[Binder] ERROR  (BND_open|949): Name videoInputBnd not exit !
23:47:28|[Binder] ERROR  (BND_drvIoctl|671): Binder open failed !
23:47:28|[Binder-Lib] ERROR  (BND_open|178): CMD_BINDER_OPEN Ioctl Failed !
[libWifi]ALARM:No wlan device--Src/ipc_lib/Wifi_IPC.c(1532)WLanConnChk
23:47:29|[libpdi] WARN  (VIDEOINPUT_openBinder|108): Open videoInputBnd failed !
23:47:29|[libpdi] ERROR  (createVideoInput|737): Fail to open binder!
23:47:29|[libpdi] ----------------------------------
23:47:29|[libpdi] device videoInCaps:
23:47:29|[libpdi] exposure: 16
23:47:29|[libpdi] syncFocus: 0
23:47:29|[libpdi] iris: 1
23:47:29|[libpdi] irisAuto: 0
23:47:29|[libpdi] rotate90: 1
23:47:29|[libpdi] maxRotatableWidth: 1920
23:47:29|[libpdi] maxRotatableHeight: 1080
23:47:29|[libpdi] gammaMode: 1
23:47:29|[libpdi] gammaModeRange: 100
23:47:29|info  VideoInput Caps :
 m_caps.maxWidth[2048]
 m_caps.maxHeight[1536]
 m_caps.ladenBitrate[972000]
 m_caps.horizontalBinning[0]
 m_caps.verticalBinning[0]
 m_caps.downScaling[0]
 m_caps.upScaling[0]
 m_caps.exposure[16]
 m_caps.backlight[2]
 m_caps.dayNightColor[1]
 m_caps.mirror[1]
 m_caps.flip[1]
 m_caps.whiteBalance[3]
 m_caps.gain[1]
 m_caps.gainAuto[1]
 m_caps.coverCount[3]
 m_caps.coverType[1]
 m_caps.titleCount[2]
 m_caps.iris[1]
 m_caps.irisAuto[0]
 m_caps.infraRed[1]
 m_caps.setcolor[1]
 m_caps.formatCout[6]
 m_caps.rotate90[1]
 m_caps.signalForamtMask[0]
 m_caps.syncChipChannels[0]
 m_caps.chipID[0]
 m_caps.multiOptions[0]
 m_caps.snapshotExposure[0]
 m_caps.limitedAutoExposure[1]
 m_caps.customManualExposure[1]
 m_caps.externalSyncInput[0]
 m_caps.refrenceLevel[0]
 m_caps.flashAdjust[0]
 m_caps.minExposureTime[1]
 m_caps.maxExposureTime[300]
 m_caps.wideDynamicRange[1]
 m_caps.glareInhibition[1]
 m_caps.doubleExposure[0]
 m_caps.utc[0]
 m_caps.version[0]
 m_caps.meteringRegionCount[0]
 m_caps.exposureMode[31]
 m_caps.afPeak[0]
 m_caps.gammaModeRange[100]
 m_caps.gammaMode[1]
23:47:29|debug CDevVideoIn::CDevVideoIn Create VideoInput Device [channel = 0, standard = 0] successfully
23:47:29|[libpdi] format P width:1280 height:1024 fps:25.000000
23:47:29|[libpdi] format P width:1280 height:960 fps:25.000000
23:47:29|[libpdi] format P width:1280 height:720 fps:25.000000
23:47:29|[libpdi] format P width:1920 height:1080 fps:25.000000
23:47:29|[libpdi] format P width:2048 height:1536 fps:20.000000
23:47:29|[libpdi] format P width:704 height:576 fps:25.000000
23:47:29|info  CDevVideoIn::CDevVideoIn VideoIn getFormatCaps success, Standard[0],Height[1024],Width[1280],FPS[25.000000]
23:47:29|[libpdi] format N width:1280 height:1024 fps:30.000000
23:47:29|[libpdi] format N width:1280 height:960 fps:30.000000
23:47:29|[libpdi] format N width:1280 height:720 fps:30.000000
23:47:29|[libpdi] format N width:1920 height:1080 fps:30.000000
23:47:29|[libpdi] format N width:2048 height:1536 fps:20.000000
23:47:29|[libpdi] format N width:704 height:480 fps:30.000000
23:47:29|info  CDevVideoIn::CDevVideoIn VideoIn getFormatCaps success, Standard[1],Height[1024],Width[1280],FPS[30.000000]
23:47:29|[libpdi] WARN  (VIDEOINPUT_getFormatCaps|216): Parameter standard is Not PAL or NTSC!
Parameter standard = 2, 2:stand for standard SECAM, 3:stand for standard Nr
23:47:29|warn  CDevVideoIn::CDevVideoIn VideoIn getFormatCaps failed, [2] not support,[0,PAL][1,NTSC],[2,SECAM]
23:47:29|[Manager] error CEventManager::attach>>>>>>>ret:1
23:47:29|[Manager] warn load std::string '&conf_img.channel1' failed!
23:47:29|[Manager] warn CCommonConfigManager::getConfig VideoOut is Json::nullValue!
23:47:29|[Binder] ERROR  (BND_put|1342): Handle 0x0 check failed !
23:47:29|[Binder] ERROR  (BND_drvIoctl|307): Put buffer failed !
23:47:29|[libpdi] WARN  (VIDEOINPUT_sendMsg|319): Fail to put buffer!
23:47:29|[libpdi] ERROR  (VIDEOINPUT_setStandard|1104): Fail to send message!
23:47:29|[Manager] warn CCommonConfigManager::getConfig VideoInOptions is Json::nullValue!
23:47:29|[libpdi] ERROR  (VIDEOINPUT_setColor|1188): Fail to send message!
23:47:29|warn  CDivisionModeFactory::getDivisionMode don't support mode 1
23:47:29|warn  CDivisionModeFactory::getDivisionMode don't support mode 8
23:47:29|warn  CDivisionModeFactory::getDivisionMode don't support mode 9
23:47:29|warn  CDivisionModeFactory::getDivisionMode don't support mode 10
23:47:29|warn  CDivisionModeFactory::getDivisionMode don't support mode 11
23:47:29|warn  CDivisionModeFactory::getDivisionMode don't support mode 12
23:47:29|warn  CDivisionModeFactory::getDivisionMode don't support mode 13
23:47:29|info  CRasterFont::CRasterFont load file '/usr/data/Fonts/Font24.bin' successfully!
23:47:29|info  CRasterFont::CRasterFont load file '/usr/data/Fonts/Font.bin' successfully!
23:47:29|warn  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
23:47:29|warn  CDevVideoEnc::stream:0,m_desc->OpSendPacket:00327460
23:47:29|[libenc] ERROR  (VIDEO_moduleInit|1706): open /dev/iav fail
23:47:29|[libenc] ERROR  (createVideoEncoder|1878): VIDEO_moduleInit failed
23:47:29|error CDevVideoEnc::CDevVideoEnc:createVideoEncoder() failed,need reboot device.
23:47:29|trace getTitleCount : 0, stream:0
23:47:29|info  CDevVideoEnc::CDevVideoEnc IDevVideoAnalyse start m_stream = 0,videoAnalyseChannel = 0
get OnvifMetaStream object:channel:0 stream:0
Attach proc is successfully:1
COnvifMetaStream attach'Num = 1
23:47:29|info  Src/Media/DevVideoEnc.cpp:298 Start OnvifMetaStream OK
23:47:29|error m_instance[channel:0][split:0][stream:0]->m_encoder == 0
23:47:29|[libInfra] debug ThreadBody Enter name = COnvifEventService, id = 990, prior = N64, stack = 0x4e24ddcc
2000-01-01 23:47:29 |  | Src/Service/Event/OnvifEventCollector.cpp::COnvifEventCollector@0372 | OnvifEventProducer::AttachEventNotify attach success
23:47:29|[libenc] product name IPC-HDBW4100E is not support undefocus
23:47:29|warn  CDevVideoDetect::getCaps: keyword HasPtz is not exists in ProductDefinition.
23:47:29|warn  MotionDetect config need update!channel = 0
23:47:29|[libenc] set motionPrms motionEnable 0,level 0 newmode 1, pirMotion 0 pirLevel 3
disturbing thread, let it go
Arena 0:
system bytes     =    1720320
in use bytes     =    1554064
Arena 1:
system bytes     =     135168
in use bytes     =       1120
Total (incl. mmap):
system bytes     =    3002368
in use bytes     =    2702064
max mmap regions =          4
max mmap bytes   =    1146880
Arena 0:
Arena 1:
in use bytes     =       1120
Total (incl. mmap):
23:49:18|[NetApp-251618] info CNetApp::setArpIp getip failed
23:49:18|[NetApp-251618] info Src/ARP/ArpPingParser.cpp:38 CArpPingParser::Stop
Src/ARP/ArpPingParser.cpp:116 time out
Src/ARP/ArpPingParser.cpp:108 close
Arena 0:
in use bytes     =    1551976
Arena 1:
in use bytes     =       1120
Total (incl. mmap):
in use bytes     =    2699976
Что-то можно по этому логу сказать?
kalam
Сообщение kalam » 11 июл 2017, 17:58
из uboot запускал mtest, за 20 минут прогона ничего не навыкидывала...
nand - nand bad (show bad blocks)
в ответ Device 0 bad blocks: и пустой список... как я понимаю нету плохих блоков
Сообщение iTuneDVR » 11 июл 2017, 21:36
Судя по логах - манипуляции с языком?
Воспользуйся инструкцией для сброса конфига с использованием appauto и так же обратить внимание, что нужно удалить еще и backup.
Потом не забыть вернуть обратно и снова сделать лог загрузки и выложить сюда.
kalam
Сообщение kalam » 12 июл 2017, 13:04
что и печально - никаких манипуляций с ней вообще не проводилось... просто стояла... просто работала... и перестала...
про сброс конфига с использованием appauto не совсем понял.. где эту инструкцию почитать???
или имеется ввиду appauto поставить 0.. дать загрузиться линуксу... и удалить /mnt/mtd/Config и /mnt/backup/Config???
Сообщение iTuneDVR » 12 июл 2017, 13:59
Бывают разные ситуации и сторонние факторы!
Инструкции по восстановлению доступны на форуме в объявлениях.
Да, примерную суть ты уловил, только лучше вначале выдать ls ,а так можно и целый rm /mnt/* -rf
не должен промахнуться и всё что доступно для записи удалится.
Однако....
В представленных логах есть вылеты по интересным причинам!
Во втором логе от начала, в котором старт с возвратом из резерва я не заметил, чтобы восстанавливался конфиг, вот я и предложил его удалить, раз в других логах есть вылеты и упоминания о языке.
Камера точно европа???
kalam
Сообщение kalam » 12 июл 2017, 14:33
да.. камера изначально с англ. языком была... никаких бубнов с ней не проводилось..
в общем сделал appauto 0... и удалил содержимое /mnt/mtd/Config и /mnt/backup/Config.. Затем вернул appauto 1..
камера несколько раз перезагрузилась.... потом развернула старый образ откуда-то.... потом еще несколько раз перезагрузилась...
в итоге через многое кол-во перезагрузок камера перестала перезагружаться, но и работать не начала. :(
Вот лог последней загрузки
NAND read: device 0 offset 0xc80000, size 0x00580000
 5767168 bytes read: OK
## Booting kernel from Legacy Image at c2000000 ...
   Image Name:   Linux-2.6.38.8
   Created:      2015-11-06  11:19:25 UTC
   Data Size:    2546884 Bytes = 2.4 MiB
   Load Address: c0208000
   Entry Point:  c0208000
   Loading Kernel Image ...OK
Machine: Coconut
lip0=192.168.1.108
lip1=0.0.0.0
id=TZC4MX251W00024
NR_IRQS:224
Ambarella Coconut:
   chip id:      5100
   board type:      3
   board revision:      10
   chip name:      a5m
   HAL version:      207871
brd: module loaded
loop: module loaded
TCP bic registered
devtmpfs: mounted
до сих пор вроде все ок... но последующие разделы, как я понимаю, не монтируются.. или монтируются не правильно...
UBI: max. sequence number:       3541
UBI: max/mean erase counter: 132/111
UBI: max. sequence number:       3579
UBI: max/mean erase counter: 138/112
UBI: max. sequence number:       3382
UBI: max/mean erase counter: 122/106
до этого (при перезагрузках) в логах данные разделы также писали ошибки при remount (file exist)...
kalam
Сообщение kalam » 12 июл 2017, 15:07
заново удалил все внутри /mnt/*.. и тут же залил заново прошивку... перезагрузки... и тот же вид с боку..
понять бы точно, что в ней не так...
а можно носом ткнуть в "вылеты по интересным причинам!"? и с чем исходя из вашего опыта они м.б. связаны.
или вообще радикальный способ какой с паяльником можно использовать?
