Falcon Eye FE-3104H не стартует, черный экран (!!!Выяснилось что это FE3108H!!!)
Сообщение fobos » 09 фев 2017, 22:58
Добрый вечер! Попал в руки очередной аппарат. "Мертвый" загрузчик. Поиск привел к этой прошивке http://fa.itservice-bg.net/dumps/39639_DH-DVR3104H.zip. Залил через программатор во флешь, рег стартанул, но на мониторе чернота. Лог загрузки:
U-Boot 2010.06-svn502 (Oct 22 2012 - 12:43:11) svn:502
DRAM:  1 GiB
DM385-GP rev 1.0
N56_DVR Run at mode: B
dh_netmode: RMII
Net:   Ethernet clocking: 0x0
Detected MACID:92:2:a9:ab:d0:e7
cpsw
link up on port 0, speed 100, full duplex
netup time out: 3
Timeout
SPI probe: 16384 KiB MX25L12805D at 0:0 is now current device
### CRAMFS loading '/boot/uImage' to 0x81000000
### CRAMFS load complete: 2392360 bytes loaded to 0x81000000
*  kernel: default image load address = 0x81000000
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-2.6.37
   Data Size:    2392296 Bytes = 2.3 MiB
   Entry Point:  80008000
   kernel data at 0x81000040, len = 0x002480e8 (2392296)
   kernel loaded at 0x80008000, end = 0x802500e8
Starting kernel ... mem=120M, console=ttyO0,115200n8 rootfstype=cramfs root=/dev/mtdblock1 earlyprintk notifyk.vpssm3_sva=0xbffd0000 dh_keyboard=1 load_modules=1 m3_print=1 watchdog=1
Через пару-тройку минут рег сам перегружается.
Вывод help
DVR> help
?       - alias for 'help'
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
cmp     - memory compare
cp      - memory copy
eracfg  - eracfg - erase config partition
eralogo - eralogo - erase logo  partition
flwrite - flwrite - write data into FLASH memory
fsload  - load binary file from a filesystem image
hwid    - hwid      - set hardware id and save to flash
lip     - lip      - set local ip address but not save to flash
mac     - mac      - set mac address and save to flash
md      - memory display
mw      - memory write (fill)
netrep  - netrep     - report net up progress
netup   - netup     - update the system via net, without console
run     - run commands in an environment variable
sip     - sip      - set server ip address but not save to flash
tftpboot- boot image via network using TFTP protocol
не выходит на "DVR>" и не реагирует на клавиши пока самопроизвольно не перезагрузтся
Вывод printenv
DVR> printenv
bootargs=mem=90M, console=ttyO0,115200n8 rootfstype=cramfs root=/dev/mtdblock1 earlyprintk notifyk.vpssm3_sva=0xbffd0000
bootcmd=netup; fsload 0x81000000 /boot/uImage; bootm
bootdelay=3
gatewayip=192.168.1.1
netmask=255.255.255.0
load_modules=1
m3_print=1
watchdog=1
netup_timeout=3
logserver=127.0.0.1
da=tftp 0x81000000 u-boot.bin.img; flwrite
dr=tftp 0x81000000 romfs-x.cramfs.img; flwrite
du=tftp 0x81000000 user-x.cramfs.img; flwrite
dw=tftp 0x81000000 web-x.cramfs.img; flwrite
dl=tftp 0x81000000 logo-x.cramfs.img; flwrite
ds=tftp 0x81000000 slave-x.cramfs.img; flwrite
dc=tftp 0x81000000 custom-x.cramfs.img; flwrite
up=tftp 0x81000000 update.img; flwrite
tk=tftp 0x81000000 uImage; bootm
verify=yes
bootfile=/boot/uImage
loadaddr=0x81000000
tu=tftp 0x81000000 u-boot.bin; go 0x81000000
ethact=cpsw
ID=TZA3JP024D00103
ethaddr=92:02:A9:AB:D0:E7
ipaddr=192.168.0.111
serverip=192.168.0.222
appauto=1
dh_keyboard=1
Environment size: 977/8188 bytes
DVR>
Вывод appauto 0 и dh_keyboard
DVR> bootd
netup time out: 3
Timeout
Starting kernel ... mem=120M, console=ttyO0,115200n8 rootfstype=cramfs root=/dev/mtdblock1 earlyprintk notifyk.vpssm3_sva=0xbffd0000 dh_keyboard=0 load_modules=1 m3_print=1 watchdog=1
Linux version 2.6.37 (liu_xin@driver) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #288 Tue Nov 27 13:19:15 CST 2012, svn:1680
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
Machine: dm385evm
reserved size = 0 at 0x0
OMAP chip is DM385 1.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 30480
Kernel command line: mem=120M, console=ttyO0,115200n8 rootfstype=cramfs root=/dev/mtdblock1 earlyprintk notifyk.vpssm3_sva=0xbffd0000 dh_keyboard=0 load_modules=1 m3_print=1 watchdog=1
Memory: 120MB = 120MB total
Memory: 116688k/116688k available, 6192k reserved, 0K highmem
    DMA     : 0xffa00000 - 0xffe00000   (   4 MB)
    vmalloc : 0xc8000000 - 0xf8000000   ( 768 MB)
    lowmem  : 0xc0000000 - 0xc7800000   ( 120 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0038000   ( 192 kB)
      .text : 0xc0038000 - 0xc0477000   (4348 kB)
      .data : 0xc0478000 - 0xc04b4500   ( 242 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
omap_hwmod: gpio3: softreset failed (waited 10000 usec)
omap_hwmod: gpio4: softreset failed (waited 10000 usec)
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Calibrating delay loop... 999.42 BogoMIPS (lpj=4997120)
Security Framework initialized
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
omap_init_ahci  cpu_is_dm385
registered ti81xx_vpss device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
vgaarb: loaded
omap2_mcspi: probe of omap2_mcspi.3 failed with error -2
omap2_mcspi: probe of omap2_mcspi.4 failed with error -2
USBSS revision 4ea2080b
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: pio
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(31 14 14)
usb2phy: override computed values rxcalib(15)DACs(14 13 15)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f675b7e
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at c801e000 using PIO, IRQ 18
musb-hdrc musb-hdrc.1: dma type: pio
MUSB controller-1 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(30 13 15)
usb2phy: override computed values rxcalib(15)DACs(14 12 16)
usb2phy_config: musb(1) rxcalib done, rxcalib read value 6f675986
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at c8022800 using PIO, IRQ 19
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
msgmni has been set to 227
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
ahci ahci.0: forcing PORTS_IMPL to 0x1
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
ahci ahci.1: forcing PORTS_IMPL to 0x1
ahci ahci.1: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.1: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
scsi1 : ahci_platform
ata2: SATA max UDMA/133 mmio [mem 0x4a0ae000-0x4a0befff] port 0x100 irq 59
m25p80 spi1.0: found mx25l12805d, expected w25x32
m25p80 spi1.0: mx25l12805d (16384 Kbytes)
Creating 8 MTD partitions on "spi_flash":
0x000000000000-0x000000060000 : "boot"
0x000000060000-0x000000460000 : "rootfs"
0x000000460000-0x000000a60000 : "user"
0x000000a60000-0x000000c60000 : "web"
0x000000c60000-0x000000e60000 : "slave"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
davinci_mdio davinci_mdio.0: netcard_num = 1
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
OMAP Watchdog Timer Rev 0x00: initial timeout 180 sec
OMAP Watchdog is enabled!
start WDT check timer.
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbffd0000
TCP cubic registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=92:2:a9:ab:d0:e7
VFS: Mounted root (cramfs filesystem) readonly on device 31:1.
devtmpfs: mounted
Freeing init memory: 192K
UNRAR 3.93 freeware      Copyright (c) 1993-2010 Alexander Roshal
Extracting from /slave/dvr_rdk_fw_m3video.rar
Extracting  /var/dvr_rdk_fw_m3video.xe  OK
All OK
Extracting from /slave/dvr_rdk_fw_m3vpss.rar
Extracting  /var/dvr_rdk_fw_m3vpss.xem3          OK
All OK
[CSB ] MSG: bulid date: Sep  1 2012 14:59:34, svn version: 547
[CSB ] MSG: HWID ioval: 0x69
[I2C ] MSG: bulid date: Sep  1 2012 14:59:36, svn version: 538
[GPIO] MSG: bulid date: Sep  1 2012 14:59:38, svn version: 1524
[CNSL] MSG: bulid date: Sep  1 2012 14:59:39, svn version: 503
[audio.kernel] [param] asp_chn=1
davinci-mcasp id:0
mem_start:0x48038000, ioarea:c5e2e740 priv_data:bf0225c0,resource_size=0x3000
playback dma chl:8
capture dma chl:9 ,asp_chan_q:2 ram_chan_q:0
N56: mcasp.ko Version: V1.02.05 Svn: 11092+ Compile at Sep 18 2012 20:32:59
SysLink version : 2.10.02.17
SysLink module created on Date:Jul 30 2012 Time:09:24:38
Trace enabled
Trace SetFailureReason enabled
DMA: Module install successful, device major num = 249
DRV :make_devnode:272: Registered character driver.
DRV_setSharedHWID 88 HWID_BASE=0xbfd4fc00 video_channel=8 producttype=0
DRV: Module install successful
DRV: Module built on Sep 17 2012 19:33:37
Attached to slave procId 2.
BUG: Your driver calls ioremap() on system memory.  This leads
to architecturally unpredictable behaviour on ARMv6+, and ioremap()
will fail in the next kernel release.  Please fix your driver.
------------[ cut here ]------------
WARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x190()
Modules linked in: osa_kermod syslink mcasp console gpio i2c csbrw
Backtrace:
[<c0046c30>] (dump_backtrace+0x0/0x110) from [<c03543f0>] (dump_stack+0x18/0x1c)
 r7:00000000 r6:c004a3cc r5:c0412343 r4:000000d3
[<c03543d8>] (dump_stack+0x0/0x1c) from [<c0069808>] (warn_slowpath_common+0x54/0x6c)
[<c00697b4>] (warn_slowpath_common+0x0/0x6c) from [<c0069844>] (warn_slowpath_null+0x24/0x2c)
 r9:00000005 r8:c8fb2000 r7:bf042a4c r6:00087050 r5:000762bd
r4:00000000
[<c0069820>] (warn_slowpath_null+0x0/0x2c) from [<c004a3cc>] (__arm_ioremap_pfn_caller+0x58/0x190)
[<c004a374>] (__arm_ioremap_pfn_caller+0x0/0x190) from [<c004a588>] (__arm_ioremap_caller+0x64/0x6c)
[<c004a524>] (__arm_ioremap_caller+0x0/0x6c) from [<c005bf6c>] (omap_ioremap+0x60/0x64)
 r6:00000000 r5:000762bd r4:87050000
[<c005bf0c>] (omap_ioremap+0x0/0x64) from [<bf042a4c>] (MemoryOS_map+0x10c/0x1e4 [syslink])
 r7:00000000 r6:06a85000 r5:c5e33cc8 r4:c5e33d20
[<bf042940>] (MemoryOS_map+0x0/0x1e4 [syslink]) from [<bf02a7c8>] (_ProcMgr_map+0x78/0x1e0 [syslink])
 r7:000762bd r6:06a85000 r5:c8fa6000 r4:c5e33d20
[<bf02a750>] (_ProcMgr_map+0x0/0x1e0 [syslink]) from [<bf030004>] (ElfLoaderTrgWrite_copy+0x78/0x114 [syslink])
[<bf02ff8c>] (ElfLoaderTrgWrite_copy+0x0/0x114 [syslink]) from [<bf0333b0>] (DLIF_copy+0x10/0x1c [syslink])
 r7:00000026 r6:00000023 r5:c904f000 r4:c9070660
[<bf0333a0>] (DLIF_copy+0x0/0x1c [syslink]) from [<bf0321a8>] (DLOAD_load+0x734/0xa58 [syslink])
[<bf031a74>] (DLOAD_load+0x0/0xa58 [syslink]) from [<bf02fb34>] (ElfLoader_load+0xa0/0xf8 [syslink])
[<bf02fa94>] (ElfLoader_load+0x0/0xf8 [syslink]) from [<bf029e9c>] (Loader_load+0x28/0x30 [syslink])
 r8:c8fb2000 r7:c5e33ec8 r6:00000000 r5:bee06c2c r4:00000001
[<bf029e74>] (Loader_load+0x0/0x30 [syslink]) from [<bf02b298>] (ProcMgr_load+0xa8/0xf0 [syslink])
[<bf02b1f0>] (ProcMgr_load+0x0/0xf0 [syslink]) from [<bf02c2fc>] (ProcMgrDrv_ioctl+0x8e8/0x1410 [syslink])
[<bf02ba14>] (ProcMgrDrv_ioctl+0x0/0x1410 [syslink]) from [<c00d0160>] (vfs_ioctl+0x28/0x44)
 r7:00000007 r6:00000007 r5:c6246400 r4:00000000
[<c00d0138>] (vfs_ioctl+0x0/0x44) from [<c00d0870>] (do_vfs_ioctl+0x500/0x540)
[<c00d0370>] (do_vfs_ioctl+0x0/0x540) from [<c00d0908>] (sys_ioctl+0x58/0x7c)
[<c00d08b0>] (sys_ioctl+0x0/0x7c) from [<c0042e60>] (ret_fast_syscall+0x0/0x30)
 r8:c0043008 r7:00000036 r6:00000000 r5:00000000 r4:bee06bd0
---[ end trace d7bd7aa51f48aefc ]---
Backtrace:
 r9:00000005 r8:c8fb2000 r7:bf042a4c r6:000870ff r5:001086ec
r4:00000000
 r6:00000000 r5:001086ec r4:870ff000
 r7:001086ec r6:06a85000 r5:c8fa6000 r4:c5e33d20
 r7:00000026 r6:00000024 r5:c904f000 r4:c9070690
---[ end trace d7bd7aa51f48aefd ]---
Unable to handle kernel paging request at virtual address 28000014
pgd = c5554000
[28000014] *pgd=00000000
Internal error: Oops: 5 [#1]
last sysfs file:
CPU: 0    Tainted: G        W    (2.6.37 #288)
PC is at rb_next+0x34/0x64
LR is at alloc_vmap_area+0x13c/0x218
pc : [<c01b2bd4>]    lr : [<c00ba45c>]    psr: 20000013
sp : c5e33b88  ip : c5e33b98  fp : c5e33b94
r10: c55c1380  r9 : 00200000  r8 : 001fffff
r7 : 0010a000  r6 : 00000000  r5 : c55c1380  r4 : c8200000
r3 : 2800000c  r2 : c7000d8c  r1 : ffe00000  r0 : 2800000c
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c5387d  Table: 85554019  DAC: 00000015
Process fw_load.out (pid: 91, stack limit = 0xc5e322e8)
Stack: (0xc5e33b88 to 0xc5e34000)
3b80:                   c5e33bdc c5e33b98 c00ba45c c01b2bac c0412343 f8000000
3ba0: c8000000 ffe00000 00000005 00000000 c5e33bd4 c55c1340 00109000 c55c1340
3bc0: 00200000 00000001 000000d0 c8000000 c5e33c14 c5e33be0 c00ba61c c00ba32c
3be0: ffffffff 000000d0 c5e33c1c 00109000 001086ec 000870ff c047c8c4 c8fb2000
3c00: 00000005 00000000 c5e33c34 c5e33c18 c00ba75c c00ba544 f8000000 ffffffff
3c20: 000000d0 bf042a4c c5e33c5c c5e33c38 c004a400 c00ba71c 870ff000 00000000
3c40: bf042a4c bf042a4c c8fb2000 00000002 c5e33c84 c5e33c60 c004a588 c004a380
3c60: bf042a4c 00000001 00000000 870ff000 001086ec 00000000 c5e33ca4 c5e33c88
3c80: c005bf6c c004a530 c5e33d20 c5e33cc8 06a85000 00000000 c5e33cc4 c5e33ca8
3ca0: bf042a4c c005bf18 c5e33d20 c8fa6000 06a85000 001086ec c5e33d1c c5e33cc8
3cc0: bf02a7c8 bf04294c 870ff000 001086ec 00000000 00030000 c9280000 000762bd
3ce0: c5e33d1c bf000000 c904c000 03046000 c5e33d90 c5e33d90 c8fa6000 06a85000
3d00: 001086ec c8ff8000 c904c000 00000001 c5e33d64 c5e33d20 bf030004 bf02a75c
3d20: ffffffff 00000000 870ff000 870ff000 bf02f9d4 001086ec c5e30000 c5e33d48
3d40: bf033418 870ff000 c9070690 c904f000 00000024 00000026 c5e33d74 c5e33d68
3d60: bf0333b0 bf02ff98 c5e33de4 c5e33d78 bf0321a8 bf0333ac c6246200 c9049000
3d80: c904c000 bffff060 00000026 c8ff801c c904c000 c911f000 c9280000 00000001
3da0: 000aebc0 00000000 00000002 00000020 c904f000 c904f000 00000000 c8fa6000
3dc0: 03046000 bee06c2c 00000001 c5e33ec8 c5e32000 c9049000 c5e33e1c c5e33de8
3de0: bf02fb34 bf031a80 c5e33e24 c5e33df8 c00bb034 c904c000 bf04290c 00000001
3e00: bee06c2c 00000000 c5e33ec8 c8fb2000 c5e33e34 c5e33e20 bf029e9c bf02faa0
3e20: 00000000 c5e33ec8 c5e33e64 c5e33e38 bf02b298 bf029e80 00000000 c5e33ec8
3e40: 00000000 c6246400 c9049000 bee06bd0 bee06bd0 00000000 c5e33ef4 c5e33e68
3e60: bf02c2fc bf02b1fc 00000000 c5e33ec8 c7371bb8 c5e32000 c5e33eac c5e33e88
3e80: c006646c c01b2614 c7371bc4 c7020580 c0491430 00000001 c70205b0 00000000
3ea0: c5e33ed4 c5e33eb0 c00665b0 097d2000 c8fb2000 bee06ed8 0000001c 00000001
3ec0: bee06c2c 00000000 00000000 c035c6b0 c7371600 00000000 00000000 c6246400
3ee0: 00000007 00000007 c5e33f04 c5e33ef8 c00d0160 bf02ba20 c5e33f74 c5e33f08
3f00: c00d0870 c00d0144 c0067208 c70205b8 00000000 00000000 fffffffd 00000000
3f20: c5e33f54 c5e33f30 c035850c c003e230 c706201c c7371600 00000017 c7021080
3f40: c5e32000 00000000 c5e33f6c 00000000 bee06bd0 c020e0a2 00000007 c6246400
3f60: c5e32000 00000000 c5e33fa4 c5e33f78 c00d0908 c00d037c c5e33fac 00000001
3f80: c0354cac bee06bd0 00000000 00000000 00000036 c0043008 00000000 c5e33fa8
3fa0: c0042e60 c00d08bc bee06bd0 00000000 00000007 c020e0a2 bee06bd0 00000001
3fc0: bee06bd0 00000000 00000000 00000036 000f8c60 000cb0f8 000f8948 000f8948
3fe0: c020e0a2 bee06b98 00029530 00050a6c 60000010 00000007 04431d05 18029644
Backtrace:
[<c01b2ba0>] (rb_next+0x0/0x64) from [<c00ba45c>] (alloc_vmap_area+0x13c/0x218)
[<c00ba320>] (alloc_vmap_area+0x0/0x218) from [<c00ba61c>] (__get_vm_area_node+0xe4/0x184)
[<c00ba538>] (__get_vm_area_node+0x0/0x184) from [<c00ba75c>] (get_vm_area_caller+0x4c/0x58)
[<c00ba710>] (get_vm_area_caller+0x0/0x58) from [<c004a400>] (__arm_ioremap_pfn_caller+0x8c/0x190)
Code: e5923004 e3530000 0a000004 e1a00003 (e5933008)
---[ end trace d7bd7aa51f48aefe ]---
 и висит до самопроизвольной перезагрузки.
run up вот этот имидж http://www.dh-vision.com/main/firmware/ ... .20130129/
Все загрузилось без ошибок, но рег полноценно не загружается.
Может у Вас в закромах будет прошивка на этот аппарат?
Re: Falcon Eye FE-3104H не стартует, черный экран
Сообщение iTuneDVR » 09 фев 2017, 23:13
appauto=0 в связке с dh_keyboard=0 нужно только при сбросе конфига и потом возвращаем обратно
dh_keyboard=0 когда надо включить логи загрузки, чтобы увидеть на чём ломается, при этом для нормальной загрузки должно быть appauto=1
Лог представленный там всё понятно. Приложение валится.
Лог нормальной загрузки?
Сообщение fobos » 09 фев 2017, 23:28
вот...dh_keyboard=0, appauto=1
DVR> bootd
Auto negotitation failed
netup time out: 3
Timeout
Machine: dm385evm
NR_IRQS:375
GPMC revision 6.0
regulator: dummy:
vgaarb: loaded
usb2phy: computed values rxcalib(15)DACs(30 14 14)
devtmpfs: mounted
All OK
All OK
davinci-mcasp id:0
playback dma chl:8
Trace enabled
Backtrace:
r4:00000000
 r7:00000000 r6:06a85000 r5:c5e21cc8 r4:c5e21d20
 r7:000762bd r6:06a85000 r5:c8fa6000 r4:c5e21d20
 r8:c8fb2000 r7:c5e21ec8 r6:00000000 r5:bec31c2c r4:00000001
 r8:c0043008 r7:00000036 r6:00000000 r5:00000000 r4:bec31bd0
---[ end trace 00b4930f953be17d ]---
Backtrace:
r4:00000000
 r7:001086ec r6:06a85000 r5:c8fa6000 r4:c5e21d20
---[ end trace 00b4930f953be17e ]---
pgd = c5554000
last sysfs file:
sp : c5e21b88  ip : c5e21b98  fp : c5e21b94
Process fw_load.out (pid: 91, stack limit = 0xc5e202e8)
Stack: (0xc5e21b88 to 0xc5e22000)
1b80:                   c5e21bdc c5e21b98 c00ba45c c01b2bac c0412343 f8000000
1ba0: c8000000 ffe00000 00000005 00000000 c5e21bd4 c55c1340 00109000 c55c1340
1bc0: 00200000 00000001 000000d0 c8000000 c5e21c14 c5e21be0 c00ba61c c00ba32c
1be0: ffffffff 000000d0 c5e21c1c 00109000 001086ec 000870ff c047c8c4 c8fb2000
1c00: 00000005 00000000 c5e21c34 c5e21c18 c00ba75c c00ba544 f8000000 ffffffff
1c20: 000000d0 bf042a4c c5e21c5c c5e21c38 c004a400 c00ba71c 870ff000 00000000
1c40: bf042a4c bf042a4c c8fb2000 00000002 c5e21c84 c5e21c60 c004a588 c004a380
1c60: bf042a4c 00000001 00000000 870ff000 001086ec 00000000 c5e21ca4 c5e21c88
1c80: c005bf6c c004a530 c5e21d20 c5e21cc8 06a85000 00000000 c5e21cc4 c5e21ca8
1ca0: bf042a4c c005bf18 c5e21d20 c8fa6000 06a85000 001086ec c5e21d1c c5e21cc8
1cc0: bf02a7c8 bf04294c 870ff000 001086ec 00000000 00030000 c9280000 000762bd
1ce0: c5e21d1c bf000000 c904c000 03046000 c5e21d90 c5e21d90 c8fa6000 06a85000
1d00: 001086ec c8ff8000 c904c000 00000001 c5e21d64 c5e21d20 bf030004 bf02a75c
1d20: ffffffff 00000000 870ff000 870ff000 bf02f9d4 001086ec c5e20000 c5e21d48
1d40: bf033418 870ff000 c9070690 c904f000 00000024 00000026 c5e21d74 c5e21d68
1d60: bf0333b0 bf02ff98 c5e21de4 c5e21d78 bf0321a8 bf0333ac c6246200 c9049000
1d80: c904c000 bffff060 00000026 c8ff801c c904c000 c911f000 c9280000 00000001
1da0: 000aebc0 00000000 00000002 00000020 c904f000 c904f000 00000000 c8fa6000
1dc0: 03046000 bec31c2c 00000001 c5e21ec8 c5e20000 c9049000 c5e21e1c c5e21de8
1de0: bf02fb34 bf031a80 c5e21e24 c5e21df8 c00bb034 c904c000 bf04290c 00000001
1e00: bec31c2c 00000000 c5e21ec8 c8fb2000 c5e21e34 c5e21e20 bf029e9c bf02faa0
1e20: 00000000 c5e21ec8 c5e21e64 c5e21e38 bf02b298 bf029e80 00000000 c5e21ec8
1e40: 00000000 c6246400 c9049000 bec31bd0 bec31bd0 00000000 c5e21ef4 c5e21e68
1e60: bf02c2fc bf02b1fc 00000000 c5e21ec8 c7371bb8 c5e20000 c5e21eac c5e21e88
1e80: c006646c c01b2614 c7371bc4 c7020580 c0491430 00000001 c70205b0 00000000
1ea0: c5e21ed4 c5e21eb0 c00665b0 097d2000 c8fb2000 bec31ed8 0000001c 00000001
1ec0: bec31c2c 00000000 00000000 c035c6b0 c7371600 00000000 00000000 c6246400
1ee0: 00000007 00000007 c5e21f04 c5e21ef8 c00d0160 bf02ba20 c5e21f74 c5e21f08
1f00: c00d0870 c00d0144 c0067208 c70205b8 00000000 00000000 fffffffd 00000000
1f20: c5e21f54 c5e21f30 c035850c c003e230 c706201c c7371600 00000017 c7021080
1f40: c5e20000 00000000 c5e21f6c 00000000 bec31bd0 c020e0a2 00000007 c6246400
1f60: c5e20000 00000000 c5e21fa4 c5e21f78 c00d0908 c00d037c c5e21fac 00000001
1f80: c0354cac bec31bd0 00000000 00000000 00000036 c0043008 00000000 c5e21fa8
1fa0: c0042e60 c00d08bc bec31bd0 00000000 00000007 c020e0a2 bec31bd0 00000001
1fc0: bec31bd0 00000000 00000000 00000036 000f8c60 000cb0f8 000f8948 000f8948
1fe0: c020e0a2 bec31b98 00029530 00050a6c 60000010 00000007 00000000 00000000
Backtrace:
---[ end trace 00b4930f953be17f ]---
...и тормоза до перезагрузки
Сообщение iTuneDVR » 09 фев 2017, 23:57
Так по сути те же яйца, а значит образ другой по видимому должен быть другим.
В логах чётко указано!!!
Изначальный дамп был снят???
Сообщение fobos » 10 фев 2017, 00:08
Вы имеете ввиду это?
увы...
Сообщение iTuneDVR » 10 фев 2017, 00:20
Жаль.
Это N56 серия, в вот прошивки могут быть схожими, но разными!!! ;)
Вестить на название не стоит и лучше готовится очень тщательно и искать образы.
Сообщение fobos » 10 фев 2017, 00:22
Спасибо...понял, будем искать :)
Сообщение iTuneDVR » 10 фев 2017, 00:35
Если конечно принимать за основу то, что регистратор вышел только по причине порчи информации на флеше софтовым способом!
Сообщение fobos » 10 фев 2017, 01:03
на наличие всех необходимых напряжений проверил, кварцы все генерят (проверил осликом). Склоняюсь к тому, что проблема софтовая.
Сообщение iTuneDVR » 10 фев 2017, 01:17
Если есть возможность залить целый образ на программаторе, то запрос в почту и вышлю полный дамп.
Проверишь?
