С очень холодного состояния видет 8 камер как и положено , выключил включил 4 камеры и все не могу понять что за бок
сбрасывал не помогает
U-Boot 2008.10 (Jan 9 2011 - 22:26:52)
DRAM: 256 MB
Flash: 16 MB
*** Warning - bad CRC, using default environment
Press CTRL-C to abort autoboot in (Re)start USB...
USB: scanning bus for devices... 2 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
** Can't read from device 0 **
** Unable to use usb 0:1 for fatload **
stopping USB..
BIT_4_8_SEL=0
## Booting kernel from Legacy Image at 80100000 ...
Image Name:
Data Size: 1372720 Bytes = 1.3 MB
Load Address: c0800000
Entry Point: c0800000
Uncompressing Linux........................................................................................ done, booting the kernel.
Linux version 2.6.24-rt1-hi3515v100 (root@ubuntu) (gcc version 3.4.3 (release) (CodeSourcery ARM Q3cvs 2004)) #28 Mon Oct 25 20:28:45 PDT 2010
Machine: hi3515v100
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 24384
Kernel command line: mem=96M console=ttyAMA0,115200 root=1f01 rootfstype=cramfs mtdparts=physmap-flash.0:3072k(boot),6656k(rootfs),3584k(oem),3072k(config) test=abcd mac=00:17:4f:01:31:05 sel=8CH
PID hash table entries: 512 (order: 9, 2048 bytes)
Memory: 96MB = 96MB total
Memory: 94488KB available (2508K code, 237K data, 92K init)
HI_VERSION=LINUX_2_6_24-M01C06FB02F @Hi3515v100R001_C_0_0_0 2010-06-29 22:51:20
net_namespace: 64 bytes
Hisilicon clock system V0.01
Time: hisi_timer1 clocksource has been installed.
yaffs Oct 22 2010 01:55:41 Installing.
uart:0: ttyAMA0 at MMIO 0x20090000 (irq = 12) is a AMBA/PL011
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x200a0000 (irq = 12) is a AMBA/PL011
uart:2: ttyAMA2 at MMIO 0x200b0000 (irq = 13) is a AMBA/PL011
RAMDISK driver initialized: 1 RAM disks of 16384K size 4096 blocksize
physmap platform flash device: 04000000 at 80000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
4 cmdlinepart partitions found on MTD device physmap-flash.0
Creating 4 MTD partitions on "physmap-flash.0":
0x00000000-0x00300000 : "boot"
0x00300000-0x00980000 : "rootfs"
0x00980000-0x00d00000 : "oem"
0x00d00000-0x01000000 : "config"
No NAND device found!!!
hi3515v100-ehci hi3515v100-ehci.0: hi3515v100-ehci
hi3515v100-ehci hi3515v100-ehci.0: new USB bus registered, assigned bus number 1
hi3515v100-ehci hi3515v100-ehci.0: irq 23, io mem 0x100b0000
hi3515v100-ehci hi3515v100-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: 2 ports detected
hi3515v100-ohci hi3515v100-ohci.0: hi3515v100-ohci
hi3515v100-ohci hi3515v100-ohci.0: new USB bus registered, assigned bus number 2
hi3515v100-ohci hi3515v100-ohci.0: irq 22, io mem 0x100a0000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: 2 ports detected
TCP cubic registered
VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 92K
usb 2-2: new low speed USB device using hi3515v100-ohci and address 2
init started: BusyBox v1.1.2 (2010.03.16-02:37+0000) multi-call binary
_ _ _ _ _ _ _ _ _ _ _ _
\ _ _ _ _ _ ___
/ /__/ \ |_/
/ __ / - _ ___
_ _ _ _/ / / \_/ \_ ______
___________\___\__________________
usb 2-2: configuration #1 chosen from 1 choice
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S20Cfg
RESO=1024x768
RESO_W=1024
RESO_H=768
VDOSYS=Auto
NORM=4
*** Board tools : ver0.0.1_20060106 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x20110104: 0x00009654 --> 0x00009654
0x20110100: 0x00000887 --> 0x00000887
0x2011010c: 0x00000003 --> 0x00000003
0x20110110: 0x00000007 --> 0x00010303
0x20110114: 0x00000007 --> 0x00010303
0x20110118: 0x00010F01 --> 0x00000007
0x2011011c: 0x00010F01 --> 0x00000007
0x20110128: 0x00010020 --> 0x00010020
0x2011012c: 0x000103A2 --> 0x00010601
0x20110130: 0x00000005 --> 0x00010803
0x20110134: 0x00000007 --> 0x00000007
0x20110138: 0x00010804 --> 0x00010804
0x2011013c: 0x00000007 --> 0x00000007
0x20050078: 0x00000000 --> 0x00008002
0x20050054: 0x00000000 --> 0x00001573
0x200f0094: 0x00000001 --> 0x00000001
0x200f0098: 0x00000001 --> 0x00000001
hifb: module license 'Proprietary' taints kernel.
hifb info: HIFB_MAIN_VERSION[v1.0.0.2] Build Time[May 26 2010, 16:31:20]
hifb info: video:vram0_size=5242880,vram1_size=11538432,vram2_size=1658880,vram4_size=4096
hifb info: succeed in registering the fb0: ovl0 frame buffer device
hifb info: succeed in registering the fb1: ovl1 frame buffer device
hifb info: succeed in registering the fb2: ovl2 frame buffer device
hifb info: succeed in registering the fb3: ovl4 frame buffer device
TDE_MAIN_VERSION[v2.0.0.0] Build Time[May 26 2010, 16:31:24]
TDE_ADP_VERSION[hi3515adp v2.0.0.0] Build Time[May 26 2010, 16:31:24]
tde run on master arm
tde run for graphic service
tde map reg:basePhyAddr:20140000 baseVirAddr:c6874000 size:3000
Chip Version: Hi35150100
load vd.ko ....OK!
load vou.ko ....OK!
load vdec.ko ....OK
load vpp.ko ....OK!
load md.ko....OK!
load h264d.ko OK
Get No Signal On All Channels, Set Old System(PAL)
nvp1104a driver init successful! chips = 0, norm = 2,audio stage=0
chips:0, norm:2,init=1
RN6264_4CH_16bit_8KHz_I2S_Master
chip_addr=0x58
pt2864 driver init successful! chips = 0, norm = 2,audio stage=0
VD=NVP1104
VD_NORM=0
box_init[67]: pch=1024x768
box_init[90]: VO0: Type = 2, Sync = 8
box_init[67]: pch=AUTO
box_init[90]: VO2: Type = 0, Sync = 0
hifb info: vo max resolution w:1024 h:768
Thu Jan 1 00:00:06 UTC 1970
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 0)
HISI_WDT-MDC030001 @Hi3511v110_OSDrv_1_0_0_8 2009-03-30 10:45:48<6>HISI_WDT-MDC030001 @Hi3511v110_OSDrv_1_0_0_8 2009-03-30 10:45:48
0x200f00b4: 0x00000000 --> 0x00000001
HISI_IRDA-MF @Hi3515v100R001_C_0_0_0 2010-03-16 10:47:18
hiir: init ok. ver=May 12 2010, 20:29:57.
input: Logitech Optical USB Mouse as /class/input/input0
input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-hisilicon-2
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
mice: PS/2 mouse device common for all mice
Driver 'sd' needs updating - please use bus_type methods
hifb info: The layer is show(1) now!
hifb info: vo max resolution w:720 h:576
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.1
Driver 'sr' needs updating - please use bus_type methods
hi3515-ahci-device hi3515-ahci-device.: controller can't do NCQ, turning off CAP_NCQ
scsi0 : hi3515-ahci-device
scsi1 : hi3515-ahci-device
ata1: SATA max UDMA/133 irq 29
ata2: SATA max UDMA/133 irq 29
drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
usbcore: registered new interface driver TouchKit
acer_init
usbcore: registered new interface driver acer_t230h
Hisilicon ETH net controler(ver Jun 29 2010 22:54:22).
Hisilicon ETH MDIO Bus: probed
Invalid HW-MAC Address: 00:00:00:00:00:00
Set Random MAC address: 0A:93:12:BE:C3:4C
0x200f0000: 0x00000000 --> 0x00000001
0x200f0004: 0x00000000 --> 0x00000001
/etc/init.d/S20Cfg: /etc/init.d/S20Cfg: 234: /dvr/config/run: not found
/dev/ttyS001 4
box_profile[96]: NVP1104
get_ch_num[54]: ##########m_chips=0
box_profile[113]: z_chnum = 0, z_ntsc = 0, z_mdin = 0
box_profile[202]: wait mcu_profile
init()
get 8051 version = 10
get 8051 Firmware version = 10
data1=0x2f0f0baa,data2=0x775cddce,data3=0x8156fb45,data4=0xba20216c
index=35,type=NO-MCU
resetting the transceiver...
box_profile[287]: z_mcu = 8CH-480L2, mcu_idx = 24
box_profile[297]: a = 1, b = 0, c = 0
box_profile[314]: oem_id=1328f242
box_profile[323]:
box_ftp[6]: enter!!
FF
set_timeout[44]: WDIOC_SETTIMEOUT = 60s
dvr_ap[185]: ALPU CHECK
/dev/ttyS002 4
Cannot connect to AP Server exit
run[27]: rtc_time = 946684800
run[33]: sys_time = 00:00:58, rtc_time = 00:00:00, diff = 620611258
On Accept
(none) login: Cannot connect to AP Server exit
reconnect...
open[200]: m_data.num_dev = 0
load[997]: fd=75,file=/tmp/config/sys.conf
load[1107]: DDNS.Enable=0,Server=,HostName=
set_tz_param[2146]: TZ=STD-08:00, timezone=-28800, daylight = 0
set_spot_param[2062]: chbits=0xFF, secs=3, popup = 0, vloss=1
set_ao_param[2132]: gain=12
socket: Bad file descriptor
/dvr/bin/mini_httpd: started as root without requesting chroot(), warning only
set_mailsend_param_protocol[1817]: protocol = 0
set_mailsend_param_to[1810]: trigger = 0xFFFFFFFF, p_to =
set_param[33]: p_serv=, port=3100, p_id=, type=0x0
set_param[1810]: CONFIG_PARAM_FTP
set_ftp_param[1846]: enable =0, p_serv = , p_user = , p_pass=, port = 21
set_record_param[1919]: manual = 1, schedule = 1
set_reboot_param[2021]: weekly=0, time=3
set_lan_param[1868]: enable=0, ip=192.168.1.38, dns=168.95.1.1
save_config[2042]: m_config->save(/tmp/config/sys.conf)
power_on[39]: EVENT_TYPE_POWER_ON
thread_proc[272]: dvr_proc_rec: m_pid = 740
thread_proc[361]: dvr_proc_play: m_pid = 741
thread_proc[58]: dvr_proc_write: m_pid = 742
On Accept
run[420]: count=1
run[662]: nrec = 0xFF, erec = 0x0
thread_proc[168]: dvr_serv(65002): connect from host 127.0.0.1, port -18424.
connect success to server ap
reconnect...
thread_proc[168]: dvr_serv(65001): connect from host 127.0.0.1, port -27892.
login[29]: ip = 0.0.0.0
login[39]: Alice: g = 61, p = 67, g^x % p = 54
login[45]: Bob: g^y % p = 56
login[58]: auth success
ctrl_exec[391]: CMD_SYSTEM_SPEC
ctrl_exec[205]: CMD_CONFIG_GET: 201
broadcast[31]: RADIO_STATUS_ALL: 2
ctrl_exec[215]: CMD_CONFIG_UI_READ: 0, 128
ctrl_exec[215]: CMD_CONFIG_UI_READ: 128, 1040
ctrl_exec[248]: CMD_CONFIG_PRIV_READ: 0, 256
ctrl_exec[248]: CMD_CONFIG_PRIV_READ: 256, 256
ctrl_exec[457]: CMD_SYSTEM_SET_EVENT_REC_SINGLE_CH
ctrl_exec[396]: CMD_SYSTEM_STATUS
ctrl_exec[205]: CMD_CONFIG_GET: 1301
thread_proc[328]: ERR DVR_PROC_REC: TIMEOUT
### xml = 0x4033fa28
ctrl_exec[139]: CMD_VAC_SET_AO: CH-1
ctrl_exec[235]: CMD_CONFIG_UI_WRITE: 128, 1040
ctrl_exec[239]: CMD_CONFIG_UI_SYNC
ctrl_exec[265]: CMD_CONFIG_ENCOSD_READ
ctrl_exec[461]: CMD_SYSTEM_SET_SPOT_ENABLE
system_set_spot_enable[1274]: enable=0
ctrl_exec[248]: CMD_CONFIG_PRIV_READ: 512, 65536
fd_ReadFromServ = 12
fd_WritetoServ = 13
set baudrate = 9600
On Accept
thread_proc[168]: dvr_serv(65002): connect from host 127.0.0.1, port -18422.
TDE failed: QuickCopy
ctrl_exec[441]: CMD_SYSTEM_AUTORUN
client_recv[117]: fd = 102, res: type = -1, size = 0
/dev/mtdblock2 3580 3580 0 100% /dvr/oem
Partizan ADH-18V видет то 4 камеры то 8 камер
Re: Partizan ADH-18V видет то 4 камеры то 8 камер
Останови загрузку и выгрузи дамп.
Поглядим что с разделами в целом и в частности с oem разделом.
Есть ссылка или описание как это сделать я так понимаю через tftp
Сделал
flash_dump_Work.zip
- (10.95 МБ) 467 скачиваний
Правильно ?
- слив дампа.jpg (269.83 КБ) 11145 просмотров
Слил очень похожего только на 4 камеры
Дамп удалил
Дамп удалил
Дамп скачал и убрал.
Лирика:
Внутри вообщем нужное содержание, но чёрт возьми Холмс, почему адреса 0xD4000000?
Обычно для SPI это или для ранних NOR начинается с 0x0.
Может там ничего реально нет и на ноль съехал адрес.
Бывали случаи, когда банки флеша были по адресам 0x84000000, а по обычным данных не было, а у тебя прям роскошь
По сути:
Раздел mtd2 в норме, он только для чтения в cramfs
А вот последний раздел 0x00D000000-0x00FFFFFF там открылось с проблемами и эту область можно попробовать зачистить в надежде, что она пересоздастся сама. Оригинал есть, можно пробовать
Лирика:
По сути:
так я не правильно слил дамп??? микросхема Nor 56 ssop. нашел вашу тему на одном из форумов
как правильно слить? как правильно дать команду на очистку нужно области памяти?
второй дамп нормальный ??? как дать команду залить обратно чтобі не ошибиться в адрксации
Приветствую
Попробую Вам помочь.Напишите точную версию регистратора с шильдика,или точную версию вашей материнки установленной в реге
скиньте версию рега или материнки,попробую помочь
