Добрый день!
Камеру DS-2CD2623G0-IZS на руки получил в полуживом виде, возможно использовалась в Ростелекоме (но это не точно), web отсутствует, на Lan не реагирует
Лог с терминала при загрузке
Boot 3.1.6-540659 (Jun 4 2019-17:55:37)
boards:518302
Boot From: NAND 2048 RC BCH 6bit
SYS_CONFIG: 0x00070053 POC: 001
Cortex freq: 816000000
ENET freq: 50000000
iDSP freq: 348000000
Dram freq: 660000000
Core freq: 288000000
AHB freq: 144000000
APB freq: 72000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
dev_model:DS-2CD2623G0-IZS
[boot] In release mode!
|RCV UDP pack timeout|
cmd 'null' is not supported.
flash booting ...
booting from pri part...
load kernel...
[ 1.546499] Card authentication succeeded
init started: BusyBox v1.19.3 (2019-12-17 16:19:15 CST)
starting pid 60, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
create static device nodes under /dev dir
>>>run pre_app_hook
UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
>>>run post_app_hook
find net_node, loop : 1
Not find initrun.sh!
starting pid 362, tty '': '-/bin/psh'
BusyBox v2.0.0-548754 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
Лог с терминала при загрузке прошивки с TFTP сервера (IPC_G1_EN_STD_5.5.0_170725)
boards:518302
ENET freq: 50000000
AHB freq: 144000000
APB freq: 72000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
modprobe: chdir(): No such file or directory
iptables v1.4.18: can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
>>>run pre_app_hook
Formatting ...................................................................................................................................................................................................... done!
[ INFO][MIN]TFTP: TFTP from server 192.168.1.128
[ INFO][MIN]TFTP: Filename: 'digicap.dav'
tftp: falling back to blocksize 512
[ INFO][MIN]TFTP: Download File [OK]
[ INFO][MIN]BURN: File size is 29890501 bytes (29189 KB)
[ERROR][MIN]BURN: digicap package error, can not upgrade!!!
[ INFO][MIN]BURN: Write Flash [FAIL] error: write flash.
!!!!! UPDATE FAIL !!!!!
BusyBox v1.2.1 Protect Shell (psh)
Лог с терминала при загрузке прошивки с TFTP сервера, прошивка которая указана на шильдике вообще не загружается (IPC_G1_EN_STD_5.6.4_191224)
boards:518302
ENET freq: 50000000
AHB freq: 144000000
APB freq: 72000000
UART freq: 24000000
SD freq: 50000000
SDXC freq: 50000000
>>>run pre_app_hook
##############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################tftp: timeout
[ INFO][MIN]TFTP: Download File [FAIL] error: tftp.
Фото шильдика (замазал MAC и QR) от греха подальше
Подскажите какие действия предпринять.
Не прошивается IP камера Hikvision DS-2CD2623G0-IZS
Re: Не прошивается IP камера Hikvision DS-2CD2623G0-IZS
Эта загрузилась, но младше стоковой, возможно, что в загрузчике-миниядре есть ограничения.
Эта пока недогрузилась.
Использовать tftp32, tftp64 или другой умеющий передавать файлы более 32мб. Т.е. оригинальный хиковский не использовать.
ЗЫ. Важен серийник. Его тоже можно замазать в номере и в штрихкоде.
Tftp64 после установки на другой комп сделал своё дело, проблема была с ПК
спасибо, тему можно закрывать
- Снимок экрана 2023-05-17 204553.jpg (51.59 КБ) 5616 просмотров
С этой серией проблем быть не должно. Все штатно.
